  3. problem with implementation of my sensors in rollershutter sketch
13 Posts 2 Posters 3.0k Views 2 Watching
  • ihtgtwtdI ihtgtwtd
    @AWI
    thank you, that helped a lot.
    I received my first arduino 3 weeks ago and since then I'm constantly learning. Getting things explained helps a lot.
    the code receives my commands now but when I press down, all the down relays switch on/off and the other way around. I thought the line for (int i=0;i<ANZAHLROLLLADEN;i++) declares the number of the rollershutter.
    #define MY_REPEATER_FEATURE
    // Rollladensteuerung by jurs for German Arduino-Forum
    #define BUTTONPRESSED LOW
    #define RELAYACTIVE LOW
    MyMessage sensorMsg0(0,V_DIMMER);
    MyMessage sensorMsg1(1,V_DIMMER);
    MyMessage sensorMsg2(2,V_DIMMER);
    enum {NOACTION, UPACTION, DOWNACTION};
    struct roll_t{byte downPin; byte upPin; boolean downPressed; boolean upPressed; byte action; unsigned long actionStarttime; unsigned long actionTimeout; byte relayOnePin; byte relayTwoPin;};
    roll_t rollladen[]={
      {2,3,false, false, NOACTION,0,60000L, A0, A1}, // Button-Pins 2, 3, Relay-Pins A0, A1, Timeout 60 secons
      {4,5,false, false, NOACTION,0,45000L, A2, A3}, // Button-Pins 4, 5, Relay-Pins A2, A3, Timeout 45 secons
      {6,7,false, false, NOACTION,0,45000L, A4, A5}, // Button-Pins 6, 7, Relay-Pins A4, A5, Timeout 45 secons
    #define ANZAHLROLLLADEN sizeof(rollladen)/sizeof(rollladen[0])
        if (BUTTONPRESSED==HIGH)
          pinMode(rollladen[i].downPin,INPUT);
          pinMode(rollladen[i].upPin,INPUT);
          pinMode(rollladen[i].downPin,INPUT_PULLUP);
          pinMode(rollladen[i].upPin,INPUT_PULLUP);
        if (RELAYACTIVE==LOW)
           digitalWrite(rollladen[i].relayOnePin,HIGH);
           digitalWrite(rollladen[i].relayTwoPin,HIGH);
        pinMode(rollladen[i].relayOnePin,OUTPUT);
        pinMode(rollladen[i].relayTwoPin,OUTPUT);
    void switchRelay(byte i)
      Serial.print("Schalte Rolladen-");
      Serial.print(i);
      switch (rollladen[i].action)
        case NOACTION: // STOP
          digitalWrite(rollladen[i].relayOnePin,!RELAYACTIVE);
          digitalWrite(rollladen[i].relayTwoPin,!RELAYACTIVE);
          Serial.println(" STOP");
        case UPACTION: // UP
          digitalWrite(rollladen[i].relayOnePin,RELAYACTIVE);
          Serial.println(" UP");
        case DOWNACTION: // DOWN
          digitalWrite(rollladen[i].relayTwoPin,RELAYACTIVE);
          Serial.println(" DOWN");
    void loop(void)
      byte state;
        // Prüfen, ob Down gedrückt wurde
        state=digitalRead(rollladen[i].downPin);
        if (BUTTONPRESSED==LOW) state=!state;
        if (state && !rollladen[i].downPressed)
            case NOACTION: rollladen[i].action=DOWNACTION;
                           rollladen[i].actionStarttime=millis();
                           switchRelay(i);
            default: if (rollladen[i].action!=NOACTION)
                       rollladen[i].action=NOACTION;
                       switchRelay(i);
        rollladen[i].downPressed=state;
        // Prüfen, ob Up gedrückt wurde
        state=digitalRead(rollladen[i].upPin);
        if (state && !rollladen[i].upPressed)
            case NOACTION: rollladen[i].action=UPACTION;
                           switchRelay(i);
                       switchRelay(i);
        rollladen[i].upPressed=state;
        // Prüfen auf Timeout
        if (rollladen[i].action!=NOACTION && millis()-rollladen[i].actionStarttime>=rollladen[i].actionTimeout)
          switchRelay(i);
      delay(5); // kleines Delay zum Entprellen der Buttons
      sendSketchInfo("Test", "1.0");
      // Fetch relay status
       for (int sensor = 1, pin = A0; sensor <= ANZAHLROLLLADEN; sensor++, pin++) {
          present(sensor, S_COVER);
        pinMode(pin, OUTPUT);
      byte state;
      if (message.type == V_UP) {
                           switchRelay(i);
                       switchRelay(i);
        Serial.println("going up:" + String(message.type));
      else if (message.type == V_DOWN) {
                           switchRelay(i);
                       switchRelay(i);
        Serial.println("going down:" + String(message.type));
      else if (message.type == V_STOP) {
            case DOWNACTION: rollladen[i].action=NOACTION;
                           switchRelay(i);
            case UPACTION: rollladen[i].action=NOACTION;
                           switchRelay(i);
        Serial.println("stopping:" + String(message.type));
    Do you have any idea whats wrong?
    thx
    AWIA
    AWIA
    AWI
    wrote on last edited by AWI
    @ihtgtwtd in your receive() routine you are explicitly executing the action for all shutters in the for(.....) loop. What you should do is execute the action only for the shutter with the Id received . I.e. i = message.sensor
    ihtgtwtdI 1 Reply Last reply
    • AWIA AWI
      ihtgtwtdI
      ihtgtwtdI
      ihtgtwtd
      @AWI
      I don't get it. I inserted for (int i=0;i<message.sensor;i++) and the result is
      switch 1 up= relay 1; switch 1 down= relay 2
      switch 2 up= relay 1+3 ; switch 2 down=relay 2+4
      switch 3 up= relay 1+3+5; switch 3 down=relay 2+4+6
      shouldn't i++ give each following message.sensor it's own number?
      maybe I am just too tired to get it.
      thanks for your help, I'm going to sleep now
      AWIA 1 Reply Last reply
        @AWI
        AWIA
        AWIA
        AWI
        @ihtgtwtd something for when you wake up... :smile:
        Remove the whole for loop. When you want to switch only 1 shutter only 1 should be activated. So replace the whole for loop with only i = message.sensor.
        Btw.. I think the behavior of you last action is creative at least :bowtie:
        • AWIA AWI
          ihtgtwtdI
          ihtgtwtdI
          ihtgtwtd
          @AWI
          :smile: the result was indeed interesting and fun to watch.
            byte state;
            i = message.sensors
                                 switchRelay(i);
                             switchRelay(i);
                                 switchRelay(i);
                             switchRelay(i);
                                 switchRelay(i);
                                 switchRelay(i);
          I replaced the for loop with i = sensor.message , now i get "exit status 1
          'i' was not declared in this scope". Do I have to declare the variable?
            @AWI
              byte state;
              i = message.sensors
                                   switchRelay(i);
                               switchRelay(i);
                                   switchRelay(i);
                               switchRelay(i);
                                   switchRelay(i);
                                   switchRelay(i);
            AWIA
            AWIA
            AWI
            @ihtgtwtd int i = message.sensors ; would be the right syntax
            • AWIA AWI
              ihtgtwtdI
              ihtgtwtdI
              ihtgtwtd
              @AWI
              thx, I tried that. it exits with 'const class MyMessage' has no member named 'sensors'.
                @AWI
                AWIA
                AWIA
                AWI
                @ihtgtwtd typo ... int i = message.sensor ; would be the right syntax, leave out the 's'
                • AWIA AWI
                  ihtgtwtdI
                  ihtgtwtdI
                  ihtgtwtd
                  @AWI
                  thanks, still small problems to figure out though.
                  when I send a command to rollershutter 1 then rollershutter 2 receives the command. I can not control shutter 1, only 2 and 3 (with the buttons of 1 and 2)
                  output in serial monitor is right and physical buttons work the right way too
                  is there a problem in the registration or am I missing something (again)?
                  the physical buttons work the right way.
                  MyMessage sensorMsg0(0, V_DIMMER);
                  MyMessage sensorMsg1(1, V_DIMMER);
                  MyMessage sensorMsg2(2, V_DIMMER);
                  struct roll_t {
                    byte downPin;
                    byte upPin;
                    boolean upPressed;
                    byte action;
                    byte relayOnePin;
                    byte relayTwoPin;
                  roll_t rollladen[] = {
                    {2, 3, false, false, NOACTION, 0, 60000L, A0, A1}, // Button-Pins 2, 3, Relay-Pins A0, A1, Timeout 60 secons
                    {4, 5, false, false, NOACTION, 0, 45000L, A2, A3}, // Button-Pins 4, 5, Relay-Pins A2, A3, Timeout 45 secons
                    {6, 7, false, false, NOACTION, 0, 45000L, A4, A5}, // Button-Pins 6, 7, Relay-Pins A4, A5, Timeout 45 secons
                    for (int i = 0; i < ANZAHLROLLLADEN; i++)
                      if (BUTTONPRESSED == HIGH)
                        pinMode(rollladen[i].downPin, INPUT);
                        pinMode(rollladen[i].upPin, INPUT);
                        pinMode(rollladen[i].downPin, INPUT_PULLUP);
                        pinMode(rollladen[i].upPin, INPUT_PULLUP);
                      if (RELAYACTIVE == LOW)
                        digitalWrite(rollladen[i].relayOnePin, HIGH);
                        digitalWrite(rollladen[i].relayTwoPin, HIGH);
                      pinMode(rollladen[i].relayOnePin, OUTPUT);
                      pinMode(rollladen[i].relayTwoPin, OUTPUT);
                    Serial.print(i);
                        digitalWrite(rollladen[i].relayOnePin, !RELAYACTIVE);
                        digitalWrite(rollladen[i].relayTwoPin, !RELAYACTIVE);
                        digitalWrite(rollladen[i].relayOnePin, RELAYACTIVE);
                        digitalWrite(rollladen[i].relayTwoPin, RELAYACTIVE);
                  void loop(void)
                    byte state;
                      state = digitalRead(rollladen[i].downPin);
                      if (BUTTONPRESSED == LOW) state = !state;
                          case NOACTION: rollladen[i].action = DOWNACTION;
                            rollladen[i].actionStarttime = millis();
                            switchRelay(i);
                          default: if (rollladen[i].action != NOACTION)
                              rollladen[i].action = NOACTION;
                              switchRelay(i);
                      rollladen[i].downPressed = state;
                      state = digitalRead(rollladen[i].upPin);
                          case NOACTION: rollladen[i].action = UPACTION;
                            switchRelay(i);
                              switchRelay(i);
                      rollladen[i].upPressed = state;
                      if (rollladen[i].action != NOACTION && millis() - rollladen[i].actionStarttime >= rollladen[i].actionTimeout)
                        switchRelay(i);
                    byte state;
                            switchRelay(i);
                              switchRelay(i);
                            switchRelay(i);
                              switchRelay(i);
                          case DOWNACTION: rollladen[i].action = NOACTION;
                            switchRelay(i);
                          case UPACTION: rollladen[i].action = NOACTION;
                            switchRelay(i);
                  hope it's clear what I mean. It is a bit weird...
                    @AWI
                    struct roll_t {
                      byte downPin;
                      byte upPin;
                      boolean upPressed;
                      byte action;
                      byte relayOnePin;
                      byte relayTwoPin;
                      Serial.print(i);
                    void loop(void)
                      byte state;
                              switchRelay(i);
                                switchRelay(i);
                              switchRelay(i);
                                switchRelay(i);
                          switchRelay(i);
                      byte state;
                              switchRelay(i);
                                switchRelay(i);
                              switchRelay(i);
                                switchRelay(i);
                              switchRelay(i);
                              switchRelay(i);
                    AWIA
                    AWIA
                    AWI
                    @ihtgtwtd that is caused in the presentation part of your routine. You did not create a switch for shutter 0. (started with 1)
                    • ihtgtwtdI
                      ihtgtwtdI
                      ihtgtwtd
                      well thanks, I already tried that because it looked suspicious ;-)
                      but i was sending on switch 1 in domoticz and did not create a switch for 0.
                      So it seems this thing works, thanks again for your help and the patience to deal with my noob questions :-)
