  2. Announcements
  3. Converting a sketch from 1.5.x to 2.0.x
52 Posts 21 Posters 37.9k Views 26 Watching
  • pascalgauthierP pascalgauthier
    How can i call the process() inside a while in the loop() ?
    nielsokkerN
    nielsokkerN
    nielsokker
    @pascalgauthier
    I think the function "wait()" might be useful. It is like a sleep, but now it calls "process()"
    pascalgauthierP 1 Reply Last reply
    • nielsokkerN nielsokker
      @pascalgauthier
      pascalgauthierP
      pascalgauthierP
      pascalgauthier
      @nielsokker said:
      @pascalgauthier
      I was thinking of using it with wait(0) but I was wondering if there was any way to call the process directly.
      nielsokkerN 1 Reply Last reply
        @nielsokker said:
        @pascalgauthier
        nielsokkerN
        nielsokkerN
        nielsokker
        @pascalgauthier
        I'm not sure. I think the developers will know.
          @pascalgauthier why do you need to call process ? It's already done internally by the lib. Or is it for inside some longtime loop? you still can use process but now it's _process()
          Wait is not the same as sleep.
          Wait : wait for a time and call _process
          sleep: does not call _process. it sleeps. for a time if set
          • scalzS scalz
            pascalgauthierP
            pascalgauthierP
            pascalgauthier
            @scalz
            Because i have while() that increment motion detected in a 30sec timeframe. And i would like to be sure that i'm not missing any cmd from the gateway. Do i need to define any additional library to use the _process() ?
            AWIA 1 Reply Last reply
              @scalz
              AWIA
              AWIA
              AWI
              @pascalgauthier I would recommend making your while loop non-blocking i.s.o. hacking into a MySensors function.
                @pascalgauthier
                yes it's better non blocking. for non blocking it's better to use "if" like. for beginning, I advise you to look at "blink without delay" concept. then learning a bit how a state machine works etc...could be useful to you. but it's a bit more advanced, or not..
                • scalzS scalz
                  @pascalgauthier
                  pascalgauthierP
                  pascalgauthierP
                  pascalgauthier
                  @scalz @AWI
                  Thanks for your help ! :)
                    moskovskiy82
                    Little bit confused. reading through the release notes...
                    Deprecated variables: V_DIMMER (use V_PERCENTAGE), V_HEATER (use V_HVAC_FLOW_STATE), V_LIGHT (use V_STATUS)
                    Now back to the API page for 2.0...
                    S_DIMMER	4	Dimmable device of some kind	V_STATUS (on/off), V_DIMMER (dimmer level 0-100), V_WATT
                    WHICH ONE TRUST?!
                      moskovskiy82
                      And if my loop statement consists only of
                      { gw.process(); }
                      Rewrite like
                      void loop() { }
                      or exclude loop completely?
                      • M moskovskiy82
                        { gw.process(); }
                        Rewrite like
                        void loop() { }
                        @moskovskiy82 said:
                        Rewrite like
                        void loop() { }
                        That's correct
                        • M moskovskiy82
                          WHICH ONE TRUST?!
                          @moskovskiy82 said:
                          WHICH ONE TRUST?!
                          The release notes (as I added this statement ;-) )
                          • Maurizio ColluM
                            Maurizio ColluM
                            Maurizio Collu
                            Dear all, I'm a bit lost.
                            I upgraded the library in Arduino to 2.0.0 and now I am having big problems.
                            I downloaded the sketch for the relay from the MySensors website:
                            https://www.mysensors.org/build/relay
                            but I suppose this is still for 1.5
                            I tried to modify the sketch as suggested - I do not receive any compiling error, but the skectch simply does not do anything. If I use the "monitor" in Arduino IDE, I do not see anything 0_1469262004446_RelayActuator2.ino
                            There must be something fundamentally wrong in my code, can anyone help?
                            mfalkviddM Boots33B 2 Replies Last reply
                            • Maurizio ColluM Maurizio Collu
                              @Maurizio-Collu the examples for 2.0 are included in the library. They can be opened directly fromthe Examples menu in the Arduino IDE. It is also possible to fetch the examples from github, see https://github.com/mysensors/MySensors/tree/development/examples/RelayActuator For the relay example.
                              Maurizio ColluM 1 Reply Last reply
                                Boots33B
                                Boots33B
                                Boots33
                                @Maurizio-Collu
                                You have a few mistakes in your sketch, Download the V2 sketch that @mfalkvidd has pointed you to and compare the two side by side. you will soon see where you have gone wrong. don't forget you will need to update your gateway to V2 as well, a version 1.5 gateway will not connect with a version 2 node.
                                  Maurizio ColluM
                                  Maurizio ColluM
                                  Maurizio Collu
                                  @mfalkvidd @Boots33
                                  Thanks a lot, I knew I was missing something basic. For the newbies like me, it would be good to mention this somewhere (if you have not done so already and I missed it).
                                  In the Home Assistant website it is mentioned that they only support 1.4 and 1.5. I'm trying with 2.0.
                                  Thanks Again
                                    @mfalkvidd @Boots33
                                    Thanks Again
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    @Maurizio-Collu
                                    2.0 should work with home assistant, but all new features of 2.0 are not supported yet. WIP.
                                    • rchampR
                                      rchampR
                                      rchamp
                                      wrote on last edited by rchamp
                                      #32
                                      I'm trying to upgrade my gateway to 2.0, but every time I go to upload, I get a 'error' not in sync.
                                      I'm using just a standard nano w/ NRF24.
                                      Note, my hardware profile is set properly to nano, 328p and proper com.
                                      I restart app, and switched to my APM hardware profile and loaded my new 2.0 sensor code into my new APM node (DHT11 + motion) and was able to upload no problem.
                                      Is there something i'm missing for the gateway?
                                      Idon'tunderstandwhatwouldcauseittostopbeingabletocommunicate,
                                        Are you able to upload some other sketch to the nano?
                                        Or has something bad happen to the FTDI chip on your nano perhaps?
                                        rchampR 1 Reply Last reply
                                          moskovskiy82
                                          Just for clarification. V2.0 gateway (MQTT client esp8266) - will it work with the 1.5/1.6 sensors? Or everything needs to be flashed as soon as possible?
