  3. Problems with first sensors
62 Posts 9 Posters 34.9k Views 11 Watching
  • blebbensB blebbens
    Think, I do not understand yet.
    The motion sketch uses #define CHILD_ID 1.
    Where do I have to insert #define MY_NODE_ID 1 ? Just into the skecht of the motion sensor ?
    Tore André RosanderT
    Tore André Rosander
    @blebbens i think you can just put it over "define child id"
    nielsokkerN 1 Reply Last reply
    • Tore André RosanderT Tore André Rosander
      nielsokkerN
      nielsokkerN
      nielsokker
      @Tore-André-Rosander said:
      define child id"
      I think so too.
      These are probably just minor mistakes, changing from MySensors versions.
      • blebbensB
        blebbensB
        blebbens
        So, I have to delete CHILD_ID und change it to MY_NODE_ID?
        Okay, reaching home today, perhaps. Hope, this works.
        nielsokkerN Tore André RosanderT 2 Replies Last reply
          Tore André Rosander
          No, just add the define node id.
            nielsokkerN
            nielsokkerN
            nielsokker
            @blebbens
            The old define, might become useless, but it wont be in the way either. It is your choice.
              @blebbens use MY_NODE_ID to define the id of your node. the child id is for your sensors id, not the node id.
                Tore André Rosander
                @blebbens I just replaced my RPi Gateway (the direct connection to GPIO) with the Serial Gateway, and the Repeater node you are seeing must be your gateway. Before i connected any nodes i got the same repeater node listed as hardware as you did, so it is probably your node that is the problem.
                • F
                  F
                  Fabien
                  I have exactly same error after loading new sketch (sensebender with BMP085). It was working fine for few days and suddenly it doesn't work. After verting my modification it doesn't work. Clear EEPROM doesn't solve the problem. RFM69W and static ID.
                  Gateway work fine with other sensors (sensebender without mods).
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=100)
                  TSM:FPAR
                  TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  F 1 Reply Last reply
                  • F Fabien
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    F
                    F
                    Fabien
                    Sorry, I made a mistake when updating my sketch with (deleting bad zero to change 100 to 10 ...)
                    #define MY_NODE_ID 100
                    Works fine now !
                    • blebbensB
                      blebbensB
                      blebbens
                      hi,
                      Was not at home for about 2 weeks now (driving home in 2 days), but AliExpress delivered 10 NRF2401 non-amplified without antenna. Is it still necessary to define low power and data rate of 1mbps?
                      #define MY_RF24_DATARATE RF24_1MBPS
                      Do I have to set the node ID still manually?
                      • SGiS
                        SGiS
                        SGi
                        I thought my problem was dodgy Dupont cables but after more experimenting all issues have now gone by soldering a 80mm aerial to the radio :) like a magic fix....
                        • SGiS
                          SGiS
                          SGi
                          Still cant get the stutus LED's working tho... hmmmm any suggestions? i have checked the polarity and connections are good to pins 4,5,6
                          • blebbensB
                            blebbensB
                            blebbens
                            wrote on last edited by blebbens
                            #52
                            I am trying to set up a Serial Gateway using the arduino IDE, this time using a NRF24L01 (not amplified, with build-in-antenna).
                            The Sketch compiles without any error, but afterwards the IDE tells me an error occurred: error during uploading the Sketch.
                            This occurs on compiling mysensors sketches.
                            Never had this Problem before. Now I get this error on all WIN10-machines.
                            Any tips ?
                            tekkaT 1 Reply Last reply
                              Any tips ?
                              tekkaT
                              tekkaT
                              tekka
                              @blebbens Did you manage to get your nodes running with a new set of RF24+ radios?
                              • blebbensB
                                blebbensB
                                blebbens
                                No...it ... is... so... frustrating...
                                Arduino IDE works fine, but all things combined with mysensors are not working.
                                Tried to upload the ClearEepromConfig sketch to the serial gateway (nano, NRF24L01+). After compiling the sketch, the IDE is not able to upload the sketch to the nano (error on uploading the sketch). The same with other example mysensors sketches.
                                Tried this on 2 WIn10-PCs and 2 Macs.
                                  tekkaT
                                  tekkaT
                                  tekka
                                  wrote on last edited by tekka
                                  #55
                                  @blebbens ...and uploading a sketch works with other non-MySensors sketches (i.e. blink example)? - did you select the right board in the boards manager?
                                  • blebbensB
                                    blebbensB
                                    blebbens
                                    Yes, chose arduino nano.
                                    Blank sketches work fine, uploading is no problem.
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @blebbens This is weird - can you post the log from the IDE here for both cases (i.e. successful uploading and failing)?
                                      • blebbensB
                                        blebbensB
                                        blebbens
                                        Tried it severl times... uploading an empty sketch works fine.
                                        Uploading a mysensors sketch ends with:
                                        Arduino: 1.6.10 (Windows 10), Board: "Arduino Nano, ATmega328"
                                        C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\blebb\OneDrive\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10610 -build-path "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\blebb\AppData\Local\Temp\arduino_modified_sketch_724130\GatewaySerial.ino"
                                        C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\blebb\OneDrive\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10610 -build-path "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\blebb\AppData\Local\Temp\arduino_modified_sketch_724130\GatewaySerial.ino"
                                        Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                                        Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                                        Detecting libraries used...
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                                        Generating function prototypes...
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                                        "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                                        Sketch wird kompiliert...
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp.o"
                                        Compiling libraries...
                                        Compiling library "SPI"
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\libraries\SPI\SPI.cpp.o
                                        Compiling library "MySensors"
                                        Compiling core...
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.S.o"
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WInterrupts.c.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\hooks.c.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring.c.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_analog.c.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_digital.c.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.c.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_shift.c.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\CDC.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial0.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial1.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial2.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial3.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\IPAddress.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\PluggableUSB.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Print.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Stream.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Tone.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\USBCore.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WMath.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WString.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\abi.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\main.cpp.o
                                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\new.cpp.o
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.S.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WInterrupts.c.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\hooks.c.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring.c.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_analog.c.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_digital.c.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.c.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_shift.c.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\CDC.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial0.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial1.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial2.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial3.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\IPAddress.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\PluggableUSB.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Print.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Stream.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Tone.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\USBCore.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WMath.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WString.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\abi.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\main.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\new.cpp.o"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp.o" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\libraries\SPI\SPI.cpp.o" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/core\core.a" "-LC:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -lm
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.eep"
                                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.hex"
                                        Bibliothek SPI in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI  wird verwendet
                                        Bibliothek MySensors in Version 2.0.0 im Ordner: C:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors  wird verwendet
                                        Der Sketch verwendet 13.982 Bytes (45%) des Programmspeicherplatzes. Das Maximum sind 30.720 Bytes.
                                        Globale Variablen verwenden 714 Bytes (34%) des dynamischen Speichers, 1.334 Bytes für lokale Variablen verbleiben. Das Maximum sind 2.048 Bytes.
                                        C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.hex:i
                                        Beim Hochladen des Sketches ist ein Fehler aufgetreten
                                        Sorry, did not find any logfile. I just want to use mysensors. Bought so many sensors.
                                          Compiling core...
                                          tekkaT
                                          tekkaT
                                          tekka
                                          #59
                                          @blebbens I'm afraid, but your issue is not MySensors-related.
                                          However, this may give further information:
                                          For comparison, please post the same Arduino IDE log when uploading the blink example (not an empty sketch) and - if successful - confirm that you see a blinking led in a 1sec interval.
                                          blink example:
                                          // the setup function runs once when you press reset or power the board
                                            // initialize digital pin 13 as an output.
                                            pinMode(13, OUTPUT);
                                          // the loop function runs over and over again forever
                                            digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
                                            delay(1000);              // wait for a second
                                            digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
