  3. Problems with first sensors
62 Posts 9 Posters 34.9k Views 11 Watching
  • F Fabien
    I have exactly same error after loading new sketch (sensebender with BMP085). It was working fine for few days and suddenly it doesn't work. After verting my modification it doesn't work. Clear EEPROM doesn't solve the problem. RFM69W and static ID.
    Gateway work fine with other sensors (sensebender without mods).
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=100)
    TSM:FPAR
    TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    F
    F
    Fabien
    Sorry, I made a mistake when updating my sketch with (deleting bad zero to change 100 to 10 ...)
    #define MY_NODE_ID 100
    Works fine now !
    • blebbensB
      blebbensB
      blebbens
      hi,
      Was not at home for about 2 weeks now (driving home in 2 days), but AliExpress delivered 10 NRF2401 non-amplified without antenna. Is it still necessary to define low power and data rate of 1mbps?
      #define MY_RF24_DATARATE RF24_1MBPS
      Do I have to set the node ID still manually?
      • SGiS
        SGiS
        SGi
        I thought my problem was dodgy Dupont cables but after more experimenting all issues have now gone by soldering a 80mm aerial to the radio :) like a magic fix....
        • SGiS
          SGiS
          SGi
          Still cant get the stutus LED's working tho... hmmmm any suggestions? i have checked the polarity and connections are good to pins 4,5,6
          • blebbensB
            blebbensB
            blebbens
            wrote on last edited by blebbens
            #52
            I am trying to set up a Serial Gateway using the arduino IDE, this time using a NRF24L01 (not amplified, with build-in-antenna).
            The Sketch compiles without any error, but afterwards the IDE tells me an error occurred: error during uploading the Sketch.
            This occurs on compiling mysensors sketches.
            Never had this Problem before. Now I get this error on all WIN10-machines.
            Any tips ?
            tekkaT 1 Reply Last reply
            • blebbensB blebbens
              Any tips ?
              tekkaT
              tekkaT
              tekka
              @blebbens Did you manage to get your nodes running with a new set of RF24+ radios?
              • blebbensB
                blebbensB
                blebbens
                No...it ... is... so... frustrating...
                Arduino IDE works fine, but all things combined with mysensors are not working.
                Tried to upload the ClearEepromConfig sketch to the serial gateway (nano, NRF24L01+). After compiling the sketch, the IDE is not able to upload the sketch to the nano (error on uploading the sketch). The same with other example mysensors sketches.
                Tried this on 2 WIn10-PCs and 2 Macs.
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #55
                  @blebbens ...and uploading a sketch works with other non-MySensors sketches (i.e. blink example)? - did you select the right board in the boards manager?
                  • blebbensB
                    blebbensB
                    blebbens
                    Yes, chose arduino nano.
                    Blank sketches work fine, uploading is no problem.
                      tekkaT
                      tekkaT
                      tekka
                      @blebbens This is weird - can you post the log from the IDE here for both cases (i.e. successful uploading and failing)?
                      • blebbensB
                        blebbensB
                        blebbens
                        Tried it severl times... uploading an empty sketch works fine.
                        Uploading a mysensors sketch ends with:
                        Arduino: 1.6.10 (Windows 10), Board: "Arduino Nano, ATmega328"
                        C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\blebb\OneDrive\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10610 -build-path "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\blebb\AppData\Local\Temp\arduino_modified_sketch_724130\GatewaySerial.ino"
                        C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\blebb\OneDrive\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10610 -build-path "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\blebb\AppData\Local\Temp\arduino_modified_sketch_724130\GatewaySerial.ino"
                        Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                        Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                        Detecting libraries used...
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                        Generating function prototypes...
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                        "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                        Sketch wird kompiliert...
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp.o"
                        Compiling libraries...
                        Compiling library "SPI"
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\libraries\SPI\SPI.cpp.o
                        Compiling library "MySensors"
                        Compiling core...
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.S.o"
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WInterrupts.c.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\hooks.c.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring.c.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_analog.c.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_digital.c.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.c.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_shift.c.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\CDC.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial0.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial1.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial2.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial3.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\IPAddress.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\PluggableUSB.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Print.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Stream.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Tone.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\USBCore.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WMath.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WString.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\abi.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\main.cpp.o
                        Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\new.cpp.o
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.S.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WInterrupts.c.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\hooks.c.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring.c.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_analog.c.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_digital.c.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.c.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_shift.c.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\CDC.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial0.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial1.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial2.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial3.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\IPAddress.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\PluggableUSB.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Print.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Stream.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Tone.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\USBCore.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WMath.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WString.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\abi.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\main.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\new.cpp.o"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp.o" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\libraries\SPI\SPI.cpp.o" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/core\core.a" "-LC:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -lm
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.eep"
                        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.hex"
                        Bibliothek SPI in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI  wird verwendet
                        Bibliothek MySensors in Version 2.0.0 im Ordner: C:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors  wird verwendet
                        Der Sketch verwendet 13.982 Bytes (45%) des Programmspeicherplatzes. Das Maximum sind 30.720 Bytes.
                        Globale Variablen verwenden 714 Bytes (34%) des dynamischen Speichers, 1.334 Bytes für lokale Variablen verbleiben. Das Maximum sind 2.048 Bytes.
                        C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.hex:i
                        Beim Hochladen des Sketches ist ein Fehler aufgetreten
                        Sorry, did not find any logfile. I just want to use mysensors. Bought so many sensors.
                          Compiling core...
                          tekkaT
                          tekkaT
                          tekka
                          #59
                          @blebbens I'm afraid, but your issue is not MySensors-related.
                          However, this may give further information:
                          For comparison, please post the same Arduino IDE log when uploading the blink example (not an empty sketch) and - if successful - confirm that you see a blinking led in a 1sec interval.
                          blink example:
                          // the setup function runs once when you press reset or power the board
                            // initialize digital pin 13 as an output.
                            pinMode(13, OUTPUT);
                          // the loop function runs over and over again forever
                            digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
                            delay(1000);              // wait for a second
                            digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
                          • blebbensB
                            blebbensB
                            blebbens
                            I downgraded from arduino.cc IDE 1.6.10 to 1.6.8. Now it uploads to the arduino nano without errors...
                            Seriell monitor (serial gateway):
                            0;255;3;0;9;TSM:INIT
                            0;255;3;0;9;TSM:RADIO:OK
                            0;255;3;0;9;TSM:GW MODE
                            0;255;3;0;9;TSM:READY
                            0;255;0;0;18;2.0.0
                            0;255;3;0;9;TSP:SANCHK:OK
                            Now I want to connect the gw to my test VeraEdge. I followed the instructions, uploaded the .xml-files and created a device. But, in APPS/DEVELOP PPS/SERIAL PORT CONFIG" I can not find the via USB connected serial gateway. And, I do not know where to restart vera itself or the luup engine.
                            The dashboard shows this message: MySensors plugin : Choose the Serial Port. Under DEVICES the MySensors Plugin shows: Lua Startup Failure.
                            Using the IDE I saw the gw is working (see above). Why does Vera not recognize the gw on USB ?
                            Could someone help, please ?
                            korttomaK 1 Reply Last reply
                              0;255;0;0;18;2.0.0
                              korttomaK
                              korttomaK
                              korttoma
                              @blebbens
                              Did you manage to do these steps in your Vera device:
                              Finally, go to: APPS Develop Apps Serial port configuration. See the screenshot to the right.
                              For the Used by device: setting, select the Arduino Gateway Plugin [] from the menu of available devices.
                              Set baud rate to 115200.
                              Set the parity to none with 8 data bits and 1 stop bit.
                              more details here -> https://www.mysensors.org/controller/vera#configuring-the-vera-plugin-for-the-serialusb-gateway
                              • Tomas
                              • blebbensB
                                blebbensB
                                blebbens
                                #62
                                There is no device listed in APPS/DEV APPS/Serial Port Config. There is only a save button.
                                That´s the big problem. Vera does not recognize the to USB connected gateway.
