  3. Problems with first sensors
62 Posts 9 Posters 34.9k Views 11 Watching
  • Tore André RosanderT Tore André Rosander
    @blebbens i think you can just put it over "define child id"
    nielsokkerN
    nielsokkerN
    nielsokker
    @Tore-André-Rosander said:
    define child id"
    I think so too.
    These are probably just minor mistakes, changing from MySensors versions.
    • blebbensB
      blebbensB
      blebbens
      So, I have to delete CHILD_ID und change it to MY_NODE_ID?
      Okay, reaching home today, perhaps. Hope, this works.
      nielsokkerN Tore André RosanderT 2 Replies Last reply
        Tore André Rosander
        No, just add the define node id.
        • blebbensB blebbens
          nielsokkerN
          nielsokkerN
          nielsokker
          @blebbens
          The old define, might become useless, but it wont be in the way either. It is your choice.
            @blebbens use MY_NODE_ID to define the id of your node. the child id is for your sensors id, not the node id.
              Tore André Rosander
              @blebbens I just replaced my RPi Gateway (the direct connection to GPIO) with the Serial Gateway, and the Repeater node you are seeing must be your gateway. Before i connected any nodes i got the same repeater node listed as hardware as you did, so it is probably your node that is the problem.
              • F
                F
                Fabien
                I have exactly same error after loading new sketch (sensebender with BMP085). It was working fine for few days and suddenly it doesn't work. After verting my modification it doesn't work. Clear EEPROM doesn't solve the problem. RFM69W and static ID.
                Gateway work fine with other sensors (sensebender without mods).
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=100)
                TSM:FPAR
                TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                F 1 Reply Last reply
                • F Fabien
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  F
                  F
                  Fabien
                  Sorry, I made a mistake when updating my sketch with (deleting bad zero to change 100 to 10 ...)
                  #define MY_NODE_ID 100
                  Works fine now !
                  • blebbensB
                    blebbensB
                    blebbens
                    hi,
                    Was not at home for about 2 weeks now (driving home in 2 days), but AliExpress delivered 10 NRF2401 non-amplified without antenna. Is it still necessary to define low power and data rate of 1mbps?
                    #define MY_RF24_DATARATE RF24_1MBPS
                    Do I have to set the node ID still manually?
                    • SGiS
                      SGiS
                      SGi
                      I thought my problem was dodgy Dupont cables but after more experimenting all issues have now gone by soldering a 80mm aerial to the radio :) like a magic fix....
                      • SGiS
                        SGiS
                        SGi
                        Still cant get the stutus LED's working tho... hmmmm any suggestions? i have checked the polarity and connections are good to pins 4,5,6
                        • blebbensB
                          blebbensB
                          blebbens
                          wrote on last edited by blebbens
                          #52
                          I am trying to set up a Serial Gateway using the arduino IDE, this time using a NRF24L01 (not amplified, with build-in-antenna).
                          The Sketch compiles without any error, but afterwards the IDE tells me an error occurred: error during uploading the Sketch.
                          This occurs on compiling mysensors sketches.
                          Never had this Problem before. Now I get this error on all WIN10-machines.
                          Any tips ?
                          tekkaT 1 Reply Last reply
                            Any tips ?
                            tekkaT
                            tekkaT
                            tekka
                            @blebbens Did you manage to get your nodes running with a new set of RF24+ radios?
                            • blebbensB
                              blebbensB
                              blebbens
                              No...it ... is... so... frustrating...
                              Arduino IDE works fine, but all things combined with mysensors are not working.
                              Tried to upload the ClearEepromConfig sketch to the serial gateway (nano, NRF24L01+). After compiling the sketch, the IDE is not able to upload the sketch to the nano (error on uploading the sketch). The same with other example mysensors sketches.
                              Tried this on 2 WIn10-PCs and 2 Macs.
                                tekkaT
                                tekkaT
                                tekka
                                wrote on last edited by tekka
                                #55
                                @blebbens ...and uploading a sketch works with other non-MySensors sketches (i.e. blink example)? - did you select the right board in the boards manager?
                                • blebbensB
                                  blebbensB
                                  blebbens
                                  Yes, chose arduino nano.
                                  Blank sketches work fine, uploading is no problem.
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @blebbens This is weird - can you post the log from the IDE here for both cases (i.e. successful uploading and failing)?
                                    • blebbensB
                                      blebbensB
                                      blebbens
                                      Tried it severl times... uploading an empty sketch works fine.
                                      Uploading a mysensors sketch ends with:
                                      Arduino: 1.6.10 (Windows 10), Board: "Arduino Nano, ATmega328"
                                      C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\blebb\OneDrive\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10610 -build-path "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\blebb\AppData\Local\Temp\arduino_modified_sketch_724130\GatewaySerial.ino"
                                      C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\blebb\OneDrive\Documents\Arduino\libraries" -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10610 -build-path "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\blebb\AppData\Local\Temp\arduino_modified_sketch_724130\GatewaySerial.ino"
                                      Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                                      Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
                                      Detecting libraries used...
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "nul"
                                      Generating function prototypes...
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                                      "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                                      Sketch wird kompiliert...
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp.o"
                                      Compiling libraries...
                                      Compiling library "SPI"
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\libraries\SPI\SPI.cpp.o
                                      Compiling library "MySensors"
                                      Compiling core...
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino\wiring_pulse.S" -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.S.o"
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WInterrupts.c.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\hooks.c.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring.c.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_analog.c.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_digital.c.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.c.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_shift.c.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\CDC.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial0.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial1.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial2.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial3.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\IPAddress.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\PluggableUSB.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Print.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Stream.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Tone.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\USBCore.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WMath.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WString.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\abi.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\main.cpp.o
                                      Zuvor kompilierte Datei wird verwendet: C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\new.cpp.o
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.S.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WInterrupts.c.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\hooks.c.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring.c.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_analog.c.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_digital.c.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_pulse.c.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\wiring_shift.c.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\CDC.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial0.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial1.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial2.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\HardwareSerial3.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\IPAddress.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\PluggableUSB.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Print.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Stream.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\Tone.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\USBCore.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WMath.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\WString.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\abi.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\main.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc-ar" rcs  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\core.a" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\core\new.cpp.o"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\sketch\GatewaySerial.ino.cpp.o" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp\libraries\SPI\SPI.cpp.o" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/core\core.a" "-LC:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp" -lm
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.eep"
                                      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.elf" "C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.hex"
                                      Bibliothek SPI in Version 1.0 im Ordner: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI  wird verwendet
                                      Bibliothek MySensors in Version 2.0.0 im Ordner: C:\Users\blebb\OneDrive\Documents\Arduino\libraries\MySensors  wird verwendet
                                      Der Sketch verwendet 13.982 Bytes (45%) des Programmspeicherplatzes. Das Maximum sind 30.720 Bytes.
                                      Globale Variablen verwenden 714 Bytes (34%) des dynamischen Speichers, 1.334 Bytes für lokale Variablen verbleiben. Das Maximum sind 2.048 Bytes.
                                      C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b57600 -D -Uflash:w:C:\Users\blebb\AppData\Local\Temp\buildfc036358b36fd5724eaef1c2da26543a.tmp/GatewaySerial.ino.hex:i
                                      Beim Hochladen des Sketches ist ein Fehler aufgetreten
                                      Sorry, did not find any logfile. I just want to use mysensors. Bought so many sensors.
                                        Compiling core...
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #59
                                        @blebbens I'm afraid, but your issue is not MySensors-related.
                                        However, this may give further information:
                                        For comparison, please post the same Arduino IDE log when uploading the blink example (not an empty sketch) and - if successful - confirm that you see a blinking led in a 1sec interval.
                                        blink example:
                                        // the setup function runs once when you press reset or power the board
                                          // initialize digital pin 13 as an output.
                                          pinMode(13, OUTPUT);
                                        // the loop function runs over and over again forever
                                          digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
                                          delay(1000);              // wait for a second
                                          digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
                                        • blebbensB
                                          blebbensB
                                          blebbens
                                          I downgraded from arduino.cc IDE 1.6.10 to 1.6.8. Now it uploads to the arduino nano without errors...
                                          Seriell monitor (serial gateway):
                                          0;255;3;0;9;TSM:INIT
                                          0;255;3;0;9;TSM:RADIO:OK
                                          0;255;3;0;9;TSM:GW MODE
                                          0;255;3;0;9;TSM:READY
                                          0;255;0;0;18;2.0.0
                                          0;255;3;0;9;TSP:SANCHK:OK
                                          Now I want to connect the gw to my test VeraEdge. I followed the instructions, uploaded the .xml-files and created a device. But, in APPS/DEVELOP PPS/SERIAL PORT CONFIG" I can not find the via USB connected serial gateway. And, I do not know where to restart vera itself or the luup engine.
                                          The dashboard shows this message: MySensors plugin : Choose the Serial Port. Under DEVICES the MySensors Plugin shows: Lua Startup Failure.
                                          Using the IDE I saw the gw is working (see above). Why does Vera not recognize the gw on USB ?
                                          Could someone help, please ?
                                          korttomaK 1 Reply Last reply
