  3. Combined MySensor Gateway with 433Mhz transmitter (HomeEasy/Klik-Aan-Klik-uit)
26 Posts 13 Posters 32.7k Views 11 Watching
  • TheoLT TheoL
    @mvader Yes for me it's easier and actually the only way. My gateway is not located in my living room, but in the closet with my energy meter. 2.4 Ghz can reach my living room, but the 433Mhz just doesn't get there. So be adding a sensor node, which acts as a 5 switch controller I can control the power outlets. In my bedroom I have some other Impuls power outlets. So I'll just install another gateway or bridge there as well and I'll be done.
    I'm having a hard time decoding the remote control commands. It should be an easy to decode bitpattern. But it's getting late. I'll try to solve this puzzle tomorrow.
    mvader
    @TheoL i'm not sure what hardware you are using.but i have the etekcity ZAP 433 remote & outlets.
    i just bought a 433 mhz transceiver off ebay and hooked it up to my raspberry pi2 and sniffed the codes.
    i found it easier than going the arduino route. however the whole intention was to run this off the mysensors network i'm building. so the RPI2 was just for sniffing the codes.
    afenoA 1 Reply Last reply
    • TheoLT TheoL
      AWIA
      AWIA
      AWI
      @TheoL you can take a look at the RFlink project. This is arduino based, open source and can handle most protocols. It is also great for sniffing codes in Debug mode...
      • B
        B
        Bazeman
        RFLink and Domoticz work great together with klik aan klik uit and my Alecto WS 3500 weather station. Also receiving weather sensors from my neighbours. Next project is building Mysensors.org sensors. RFLink works alsoas an gateway.
        • TheoLT
          TheoLT
          TheoL
          @mvader I just hooked up a set of cheap 433mhz transmitter and receiver (see http://www.seeedstudio.com/depot/images/product/rf433k.jpg). I added a 20 cm wire as an antena to the transmitter. which worked out great. The transmitter on the arduino has a larger transmitting range than my remote control!
          @AWI sniffing wasn't the problem. I received all commands send by my remote control, the impuls protocol should be really simpel. SYSTEMCODE (5 bits) device (5 bits) command (2 bits). But it seems like they use some kind of encoding mechanism, because the bit pattern I receive doesn't follow that pattern. I'll have to lookup how to decode trits (for whatever that may be)
          @Bazeman RFlink looks really cool, thanks for the advice. But I think I'll try to get this to work somehow. I'm close to the solution, and I only need a bridge for my Impuls power outleds. As tempting as it is to use my neighbours weatherstation, I don't want to depend on him changing the batteries in time. I have a frost alarm that wakes me up earlier during wintertime, whenever I have to remove the ice from the windows of my car. For the moment I'm using the forecast IO services for measuring outside weather conditions.
          Besides i'm a DIY kind of guy. I like to make and design things myself. I want to build the solar powered weather station comming winter. As of now I have to leave the 433mHz bridge as is. Because I'm having some guest whom will be staying with us for the next two weeks. They will sleep in the room in which I do my electronic stuff. I have to clean that up :(
          B 1 Reply Last reply
          • TheoLT TheoL
            B
            B
            Bazeman
            @TheoL I'm going to build de outdoor solar weather station, also! Busy with ordering the parts on Ebay.
            • TheoLT TheoL
              @mvader Since it's just a Sensor it should work on any Gateway. After it's running you should see a new device in Domoticz with 5 sub nodes. They's all of the type lightning 2. Each sub device represents one of the swicthes on the impuls remote controller. The system code has to be adjusted to your own system code. On my outlets the dipswitches are all on, see the byte is 31.
               * MySensors node for switching on/of cheap 433Mhz based Power outlets from the Action
               * Author  Theo Leloux
               * Created 05-09-2015
               * Version 0.1alpha
               * Import the libraries needed by the Sketch
              #include <RemoteTransmitter.h>
               * Declare constants like pin settings etc.
              #define TRANSMITTERPIN 6 // documentation doesn't see anything if the needs to be a PWM, but why take the risk?
              #define CHILD_ID_ACTION_SWITCH_A 1 // Declare the DEVICE A as a separate switch
              #define CHILD_ID_ACTION_SWITCH_B 2 // Declare the DEVICE B as a separate switch -- In my situation I configured all outlet's as DEVICE A, so reserved for future useage
              #define CHILD_ID_ACTION_SWITCH_C 3 // Declare the DEVICE B as a separate switch -- In my situation I configured all outlet's as DEVICE A, so reserved for future useage
              #define CHILD_ID_ACTION_SWITCH_D 4 // Declare the DEVICE B as a separate switch -- In my situation I configured all outlet's as DEVICE A, so reserved for future useage
              #define CHILD_ID_ACTION_SWITCH_E 5 // Declare the DEVICE B as a separate switch -- In my situation I configured all outlet's as DEVICE A, so reserved for future useage
              const char SYSTEMCODE = char(31); // cast the integer byte value to a char should do the trick. Adjust this to your own SYSTEMCODE see RemoteTransmitter.h
               * Declare variables
              ActionTransmitter switchTransmitter = ActionTransmitter( TRANSMITTERPIN );
              unsigned long SLEEP_TIME = 5000; // the main loop will probably won't do a thing if we only attach a transmitter.
               * Declare MySensors Messages
              MyMessage msgDeviceA( CHILD_ID_ACTION_SWITCH_A, V_LIGHT );
              MyMessage msgDeviceB( CHILD_ID_ACTION_SWITCH_B, V_LIGHT );
              MyMessage msgDeviceC( CHILD_ID_ACTION_SWITCH_C, V_LIGHT );
              MyMessage msgDeviceD( CHILD_ID_ACTION_SWITCH_D, V_LIGHT );
              MyMessage msgDeviceE( CHILD_ID_ACTION_SWITCH_E, V_LIGHT );
               * Preparation code during initialization of the Arduino
                // Serial.begin( 115200 );
                gw.begin( incomingMessage ); // attach a message handler for handling commands transmitted by the controller.
                gw.sendSketchInfo("433Mhz bridge", "1.0");       // Send the sketch version information to the gateway and Controller
                gw.present( CHILD_ID_ACTION_SWITCH_A, S_LIGHT ); // Present Device A to the gateway
                gw.present( CHILD_ID_ACTION_SWITCH_B, S_LIGHT ); // Present Device B to the gateway
                gw.present( CHILD_ID_ACTION_SWITCH_C, S_LIGHT ); // Present Device C to the gateway
                gw.present( CHILD_ID_ACTION_SWITCH_D, S_LIGHT ); // Present Device D to the gateway
                gw.present( CHILD_ID_ACTION_SWITCH_E, S_LIGHT ); // Present Device E to the gateway
                gw.sendBatteryLevel(100); // It just looks better in Domoticz if we let Domoticz no we're running on 100% power.
               * The Sketch's main loop.
                // I have nothing to do if only attach a transmitter.
                gw.wait( SLEEP_TIME ); // call the wait routine, which will allow for incomming messages during the waiting
                Serial.println("message");
                if (message.type==V_LIGHT) {
                  char device = 64 + message.sensor; // translate child id to device ID. A = 65 so if we take off one and add the received sensor ID we get the correct device
                //  Serial.println( "Command received for Device " + (String)device + " on id " + (String)message.sensor + " request to turn " + (message.getBool()?"on":"off") );
                  if ( device >= 'A' && device <= 'E' ) { // Impuls/Action system only allows device 'A' to 'E'
                    switchTransmitter.sendSignal(SYSTEMCODE, device, message.getBool() );
              I attached the 433 Mhz data line to pin 6 of the arduino. Not sure if it needs PWM. But I just started an hour ago and haven't had the time yet to look that up. For around 15 euro I'm able to control all my cheap 433Mhz outlets with Domoticz. I feel like a little kid in a candy shop ;)
              Next thing to do is to hook up the receiver. So that I can receive the commands from the remote controller and send them to Domoticz. Work in progress hope to finish it this evening. But the reciever library has no support for impuls, so it might take a while.
              ArieKanarie
              @TheoL said:
              • MySensors node for switching on/of cheap 433Mhz based Power outlets from the Action
              • Author Theo Leloux
              • Created 05-09-2015
              • Version 0.1alpha
              ould you give me hint how to change this for a kaku tranmitter?
              The one that uses this command:
                //Switch off KaKu-device 10 on address M
                kaKuSwitch.sendSignal('M',10,false);
                //Switch on KaKu-device 10 on address M
                kaKuSwitch.sendSignal('M',10,true);
              TheoLT 1 Reply Last reply
              • A ArieKanarie
                • Version 0.1alpha
                TheoLT
                TheoLT
                TheoL
                @ArieKanarie I'd love to. But I don't have any kaku transmitter on which I can test it. Well I could use the Kaku wall plugs from my neighbours, but I don't think they'd be happy with it ;-)
                I recently bought an RFXtrx433E for controlling my Somfy blinds which really works well for controlling a lot of 433 Mhz devices, like KaKu. That's why I know my neighbours use KaKu. I use the RFX for controlling the Action remote controlled plugs. There's only one thing that the RFX can't do, and that is detecting button pushes on the remote controller. That's something I need, so this sensor will be reprogrammed for that purpose. But I'll have to wait until the X-mas break. I'll post on update on that in this post.
                Also if I'm not mistaken, the RFLink projects deals with KaKu for you. That might be an interesting project for you
                • TheoLT TheoL
                   * Version 0.1alpha
                   * Declare variables
                  Michel - ItM
                  Michel - ItM
                  Michel - It
                  @TheoL hello, I would like to do your own thing, then how did you manage to make the code? I would be grateful if you share it.
                  • Michel - ItM
                    Michel - ItM
                    Michel - It
                    forget it, I managed to make it work now I would like to add a 4x4 keypad for a total of 16 buttons currently on the code there are 11 virtual reley but will arrive at 16 someone can give me a hand to add the keypad of 16 buttons that control the relay 16 ?
                    http://forum.mysensors.org/topic/2650/relay-433mhz-keypad-4x4-comander-vera-domoticzlink text
                    • M mvader
                      afenoA
                      afenoA
                      afeno
                      @mvader said:
                      I have the etekcity ZAP 433 remote & outlets. I just bought a 433 mhz transceiver off ebay and hooked it up to my raspberry pi2 and sniffed the codes.
                      Did you manage to turn on/off the etekcity outlets from the gateway?
                      I would like to do the same on my side... But I don't know too much about radio protocols.
                      • afenoA afeno
                        mvader
                        Yes, i have my gateway in the basement. and then i built a mysensors 433mhz repeater (arduino + NRF radio + 433 transmitter / mysensors) this one is USB powered, stays on full time, it is on the 1st floor.. I control about 7 of the etek city outlets with it. I have to say though, most of my outlets are on the 2nd floor (which is why i put the transmitter on the 1st floor and not in the basement) even with an 433 external antenna, they fail to respond 10-15% of the time, with my z wave devices, they never fail to turn on/off no matter where they are, and with my sensors devices, i can always see/talk no matter where they are..
                        based on that, if i had to do it again, i would either zwave those or mysensor those devices (which i will probably move to down the road).
                        during the holidays, i controlled another 5-7 etek outlets on the 1st floor, to control holiday lights, tree lights.. etc. all of those were on the 1st floor and generally worked fine.
