  3. Weight sensor node
Weight sensor node
9 Posts 5 Posters 4.3k Views 6 Watching
  • Sefi NinioS Offline
    Sefi NinioS Offline
    Sefi Ninio
    Hi!
    Say I want to create a node that turns everything off when I fall asleep.
    One option would be to use a heart rate / pulse sensor and when it goes below a certain amount, run the turn off action - but that will require me to wear the sensor.
    Another (less accurate option) would be to know when I lay down on the bed, and after a certain predefined time - run the turn off action.
    Another scenario is that I want to know when there's new mail in the mailbox.
    For this - I need a weight sensor node that can sense the weight change of the mattress or that there's new mail on the sensor in the mailbox.
    I can't, however, find such a sensor. All I can find is a pressure sensor which seems to be barometric + temperature sensor...
    Anyone knows of a weight sensor I can use for this node?
    Y D 2 Replies Last reply
    • Sefi NinioS Sefi Ninio
      Hi!
      Y Offline
      Y Offline
      @Sefi-Ninio Try searching for Force-Sensitive Resistor: https://learn.adafruit.com/force-sensitive-resistor-fsr
      Sefi NinioS 1 Reply Last reply
      • Y Yveaux
        Sefi NinioS Offline
        Sefi NinioS Offline
        Sefi Ninio
        @Yveaux Perfect, thanks!
        • B Offline
          B Offline
          bjacobse
          Put this underneath your mattress. It's a pressure sensor, add Mysensors door/window sketch, add timer to your homecontroller and switch off after timer runs out
          http://www.ebay.com/itm/MICRO-TECH-82715-MATTRESS-BED-SENSOR-PRESSURE-ALARM-MONITOR-PAD-BLUE-26-X4-NEW-/201617825462?hash=item2ef15bdeb6:m:mL8g8rjR_2rTw0murBem5iA
            Sefi NinioS Offline
            Sefi Ninio
            Will that work as a weight sensor?
            Couldn't understand from the description nor could I find the data sheet...
            http://www.ebay.com/itm/new-hx711-load-cell-weight-pressure-sensor-module-for-arduino-uno-mega2560/131778364781?hash=item1eae9a456d
            • hekH Offline
              hekH Offline
              Think you have to use it in combination with a sensor block like this.
              http://www.ebay.com/itm/10KG-Scale-Load-Cell-Weight-Weighing-Sensor-HX711-Weighing-Sensors-AD-Module-/281925026200?hash=item41a40a8198:g:rm8AAOSwnLdWsCQX
                Sefi NinioS Offline
                Sefi Ninio
                Hi @hek ,
                thanks for your answer. Unfortunately, this will not work for this application...
                  Hi!
                  @Sefi-Ninio I was checking out MySensors videos on youtube one day and I stumbled on this one.
                  Cheap Bed Occupancy Sensor using Arduino & MySensors
                  I think this concept is exactly what you are looking for. I have thought about building this one myself.
                    Sefi NinioS Offline
                    Sefi Ninio
                    This looks great! Thanks a lot @dbemowsk !
