  3. KY015 - Humidity and Temperature 2.0.x
17 Posts 6 Posters 5.0k Views 6 Watching
  • sinczeS
    sinczeS
    sincze
    MySensors Evangelist
    Hahaha
    I knew it ;-) you guys would be faster.
    Instead of checking the regular website:
    https://www.mysensors.org/build/humidity
    I Should have checked your latest commit ofcourse.
    https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/
    • sinczeS sincze
      Hahaha
      @sincze yeah, it is a bit confusing with the old examples on the build pages. Hek is working on a new site which will make updating much easier. I think the problem is that the weather has been too good for indoor work the last weeks ;-)
      • TheoLT
        TheoLT
        TheoL
        Since we're on the topic of Humidity sensors. I'm experiencing a lot of troubles with the DHT family. Nodes work for a period then suddenly stop reporting temperature of humidity or both. Or in some cases the Node crashes.
        Does anyone have a decent alternative that also will work outside? Meaning can handle temperature below zero and above 30 degrees Celcius?
        I've tried everything I could find about DHT. But to be honest. I'm through with the DHT.
        • TheoLT TheoL
          @TheoL Si7021 was praised when the sensebender was built.
          https://forum.mysensors.org/topic/3801/witch-temp-hum-sensor-is-best-to-use-for-battery-powered-sensors/2 has a link to a comprehensive study
          The DHTs are cheap and measure temperature which is something everyone can relate to. So they are a great "gateway drug" for attracting aspiring MySensor fans. But besides that they seem like crap :) I see that you are ready for the heavier stuff ;-)
          TheoLT 1 Reply Last reply
            TheoLT
            TheoLT
            TheoL
            @mfalkvidd It's not perse the DHT itself. I've tried several libraries. But most of the cause the arduino to stall even if I haven't hooked up an DHT. Which I find strange.
            I ordered a couple of si7021 sensors and experimented with them. They are great, except for the fact that they are 3.3V and you'll need a level converter if you want to connect them to a 5V arduino. That's probably the reason why most people who begin with the Arduino don't want to try them.
            Also the DHT seems to be cheap but on aliexpress an si7021 costs half the prize of a DHT22. But it is has similar accuracy. Would be nice if one of the hardware experts could make a breakout version with onboard logical level converter. So that you can connect it directly to a 5V Arduino. Might save a lot of people who start with the Arduino a lot of trouble and DHT frustration ;-)
            • Boots33B
              Boots33B
              Boots33
              When I built my WeatherDuino weather station I used a Sensirion SHT11. It has been going well for a couple of years now.
              sinczeS 1 Reply Last reply
              • Boots33B Boots33
                sinczeS
                sinczeS
                sincze
                @Boots33 Very nice project. I like it. I'll look into the Sensirion SHT11 as well thx for the tip
                • sinczeS sincze
                  @sincze si7021 is a clone of sht21 (sht11 is older and protocol is incompatible)
                  I have experience with all of these sensors and would just go for a si7021 on a cheap Chinese breakout.
                  TheoLT sinczeS 2 Replies Last reply
                  • YveauxY Yveaux
                    TheoLT
                    TheoLT
                    TheoL
                    @Yveaux I hooked one up to day with a logical level converter. Maybe the converter is broken, because the sensor worked on a pro mini 3.3v. Have to postpone this for a while. Couple of busy weeks ahead.
                    • YveauxY Yveaux
                      sinczeS
                      sinczeS
                      sincze
                      @Yveaux Ali E... here we go....
                      With all the free tips the pile of spare parts starts to grow ;-)
                      A well ... got to have a hobby.
                      Tnx for the tip.
                      • sinczeS sincze
                        Tnx for the tip.
                        TheoLT
                        TheoLT
                        TheoL
                        @sincze Is it just me, or do you guys also have to sign for each package you receive from China? I think it's a new regulation in the Netherlands. Oh well it just means that I have to go to the postal office once a week to collect me yellow envelopes ;-)
                        YveauxY sinczeS 2 Replies Last reply
                        • TheoLT TheoL
                          @TheoL few weeks ago I got a packet the postal office even didn't try to deliver. Just got a message I could pick it up at the nearest pick up point.
                          Happened only one though...
                          • TheoLT TheoL
                            sinczeS
                            sinczeS
                            sincze
                            @TheoL We have a nice receptionist that collects and distributes yellow envelopes.
                            If sender in China used POSTNL that means you have to walk to the post-office. ..
                            • sinczeS sincze
                              TheoLT
                              TheoLT
                              TheoL
                              @sincze I've noticed that I only have to sign with PTT deliveries. But it's okay the girl behind the postal office counter is a real beauty.
                              • tlpeterT
                                tlpeterT
                                tlpeter
                                Two days ago i got two through the mailbox and two at the postal office.
