  3. Sensors to add to buy page
17 Posts 6 Posters 7.4k Views 1 Watching
    wrote on last edited by hek
    @jesse said:
    http://www.ebay.com/itm/390851034766
    Thanks @Jesse. The lightning sensor will definitely be added.
    The FM radio also if there is a way to pick up RDS data. Do you know if it is possible?
    Z 1 Reply Last reply
      Z
      Z
      Zeph
      The TEA5767 doesn't have RDS onboard.
      One could add a SAA6588 per http://www.rockbox.org/wiki/pub/Main/DataSheets/application_note_tea5767-8.pdf
      Possible Alternatives to consider:
      Si4703 http://www.ebay.com/itm/221463938377
      FM2011 http://www.ebay.com/itm/261217969109
      There's an interesting paper about using RDS as an accurate timebase, with the TEA5764HN chip, tho I don't know where to get a module with that chip:
      http://www.cse.msu.edu/~glxing/docs/rds-li.pdf
        @Zeph :
        Yes, Time and Traffic Jam warning system would be cool.
          @Zeph :
          Z
          Z
          Zeph
          @hek
          I don't know about the traffic jam thing - do you have any reference? I'm wondering if that's based on low power radios along the highway reporting local conditions, vs wide area FM broadcast RDS. If it's the former, you might have to drive your sensors around to get local traffic jam info from various places (or live next to the highway that matters). :-) But I'm only guessing.
          As for time, according to the paper linked at the bottom of my last msg, RDS content can include real time info with about 100ms accuracy - and the paper itself was about a method of getting more precise incremental timing from the RDS packet timing (there's an IRQ on that chip at the end of a RDS packet and apparently they found the timing on that to be precise).
            Or we could try receiving DCF77 signal :)
            http://thijs.elenbaas.net/2012/04/arduino-dcf77-radio-clock-receiver-signal/
            Other radio clock signals:
            http://en.wikipedia.org/wiki/Radio_clock
            • DammeD
              DammeD
              Damme
              Code Contributor
              Or GPS for a very accurate time :)
              • YveauxY
                What's wrong with NTP guys?
                hekH 1 Reply Last reply
                • YveauxY Yveaux
                  @Yveaux
                  Why make it simple when you can build something complicated?
                    @Yveaux
                    @hek ;-)
                    https://www.youtube.com/watch?v=F4G74kprBK8
                    • YveauxY Yveaux
                      @hek ;-)
                      @Yveaux
                      A few of those was really good ;)
                      I must start sticking remotes to my head.
                      • epierreE
                        epierreE
                        epierre
                        @hek a sensor I'll explain the use later... quite sensible...
                        http://www.dfrobot.com/wiki/index.php/Analog_Grayscale_Sensor_V2_SKU:DFR0022
                        z-wave - Vera -> Domoticz
                        • epierreE epierre
                          Curious on how this could be useful!
                            I think he got inspired by my YouTube video and wants to create a line-following temperature sensor ;-)
                            epierreE 1 Reply Last reply
                            • YveauxY Yveaux
                              epierreE
                              epierreE
                              epierre
                              @Yveaux haem no... this is my quest of the gas meter reading... this is the cheap, there is the cheapest, and the expensive (raspi+cam+tesseract)...
