  3. Reliability?
Reliability?
reliability
51 Posts 9 Posters 26.3k Views 5 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    wrote on last edited by RJ_Make
    #22
    Locked up again this morning @ 7:37am with a temp of -0.1. So a .47uF cap isn't the answer.... I think my last option before giving up on this is to remove the stepup regulator.
    Any other idea's?
    RJ_Make
    • greglG
      greglG
      gregl
      @ServiceXp
      Could you try running a sketch which just uses the dallas temp lib eg: there is is an example called "Single" with the DallasTemperature lib. RUn it for 24hrs and see if it survives.
      Likewise... in your existing sketch...stop reading the temps ( but leave everything connected) and just send a value every say 30sec to Vera .... and leave for 24hrs or so...see if that survives.
      Also have you tried a different PIN for the onewire sensor?
      RJ_MakeR 2 Replies Last reply
      • greglG gregl
        @ServiceXp
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @gregl said:> @ServiceXp
        1. and 2) ---- will do and report back.
        Do you think the wire it self could be a/the problem. Since much of the sensor line is also subject to low temps, maybe it's breaking down some how... (Although I'm using 3 different DS18B20 sensors) just talking out loud..... ;-) ....
        1. I have not, but I can add that to the 'things to try' list..
        Thanks for you help @gregl
        RJ_Make
        • B
          B
          Bandra
          @ServiceXp
          My PCBs are winging their way to you (sorry, got forgot to send them for a week or two). They may solve your problem. Let me know when you get them.
          RJ_MakeR 1 Reply Last reply
          • B Bandra
            @ServiceXp
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @Bandra Thank you Sir. I'll report back.
            RJ_Make
            • greglG gregl
              @ServiceXp
              RJ_MakeR
              RJ_MakeR
              RJ_Make
              @gregl
              Only sending this, every 30 sec
              gw.send(msgTEMP.setSensor(i).set(777, 1));
              and this is what I'm getting in return.. Not sure what the fails are about?
              RJ_Make
              • RJ_MakeR
                RJ_MakeR
                RJ_Make
                The section of code
                	void sendTemperatureToController(){
                		//Start time for Temperature readings
                		TemperatureTimeing = millis ();
                		//sensors.requestTemperatures();
                			//float temperature = static_cast<float>(static_cast<int>((sensors.getTempFByIndex(i)) * 10.)) / 10.;
                			//float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                			//if (lastTemperature[i] != temperature && temperature != -127.00) {
                				//// Send in the new temperature
                				//gw.send(msgTEMP.setSensor(i).set(temperature,1));
                				//lastTemperature[i]=temperature;
                RJ_Make
                • RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  Ok,
                  The sensor has has been running for ~24 hrs and has not locked up. So the problem is either in the code (which I doubt because I think others would be seeing this problem) or the actual DS18B20's. Maybe a bad run of them?
                  I think I'm going to let it run a while longer like this, just to make sure.
                  RJ_Make
                  • RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    Oh and the strangest thing.. those fails stopped.. So I still don't know what those where about..
                    send: 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,st=ok:777.0
                    RJ_Make
                    • RJ_MakeR RJ_Make
                      @ServiceXp Your previous logging showed the failing messages being routed from node 2 via 1 to 0 (gateway).
                      This log shows messages from node 1 directly to 0 (gateway).
                      This is a different situation, so message routing seems to fail.
                      Any idea what could cause this?
                      Furthermore, which DS18B20 library do you use?
                      • YveauxY Yveaux
                        RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        #32
                        @Yveaux
                        1. I'm thinking maybe that's because this node is a relaying node?? Other than that I have no ideal.
                        2. Whatever comes with MySensors.
                        I did try using another Dallas library (the latest version) but there was a gazillion compile errors so I quickly replace it with existing... :-)
                        I just don't know enough yet, to work out all those compile errors.
                        RJ_Make
                        YveauxY 2 Replies Last reply
                        • RJ_MakeR RJ_Make
                          @Yveaux
                          #33
                          What do you pass for the 'repeaterMode' flag when calling 'begin' on the sensor object?
                          This determines whether the node behaves as a sensor or a repeater.
                          What does your setup look like exactly?
                          How do you power the DS18B20?
                          Btw. I'll review the DS18B20 code shipped with MySensors. Maybe I can find what causes the hangup.
                          • RJ_MakeR RJ_Make
                            @Yveaux
                            @ServiceXp Seems that you're not alone when Arduino hangs up with DS18B20 connected, see http://tushev.org/articles/arduino/item/46-arduino-and-watchdog-timer.
                            This guy suffered from condensation causing a 'shortcut' between the sensor wires...
                            IMO a library should never hang on communication errors, but return an error value after a timeout or so...
                            • YveauxY Yveaux
                              RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              1. Here is the link to one project that uses the DS18B20 sensor, The 2nd sketch is pretty much how it's running now (Locks up when there is a call to read the DS18B20, but doesn't when the code is commented out).
                              2. In all cases, the sensors VCC and GND are connected in common to the power source. Here is the pcb prototype of the EH40 project.
                              Thanks for the help!
                              RJ_Make
                              • YveauxY Yveaux
                                RJ_MakeR
                                RJ_MakeR
                                RJ_Make
                                @Yveaux said:> @ServiceXp Seems that you're not alone when Arduino hangs up with DS18B20 connected, see http://tushev.org/articles/arduino/item/46-arduino-and-watchdog-timer.
                                I think if this problem winds up being directly related to the DS18B20, its going to have to be a manufacturing issue, because I have 3, (brand new) of these things and they all lock up the Arduino's (3 different mini pros, with 3 different DS18B20's of the same batch)
                                I'm not even sure the watchdog timer would help in my case, because in most cases, once the sensor is locked up, the only fix is to clear eeprom and re-install sketch.
                                RJ_Make
                                • RJ_MakeR
                                  RJ_MakeR
                                  RJ_Make
                                  Oh and power is introduced on the upper left side of the board in the pictures.
                                  RJ_Make
                                  • JohnJ
                                    JohnJ
                                    John
                                    Maybe already checked, but i'm remembering that a while ago i created a library for light intensity and other LED based stuff, after a while my device also locked up, after searching for merely a week i found a little memory leak in one of my libraries which was just related to a incorrect fixed size char array. It also used the eeprom for storing particular LED settings.
                                    It happened every time after storing a particular setting after a coupe of hours, if stored after 5 minutes there was no problem but the device then just locked up after a couple of hours.
                                    I also had to reset eeprom values before i could continue....
                                    I also remember with a tmp36 receiving 500 degrees celcius values, which was related to a bug code which had nothing to do with it.
                                    If there would be a leak somewhere in the code it can completely #%$#% up. It's the only thing i can come up with now.
                                    • RJ_MakeR RJ_Make
                                      Could be the case of course, but I would also setup an endurance test with a completely different ds1820 library and see how this behaves over time. In the onewire library there is an example sketch for ds1820 that only uses the onewire library.
                                      Maybe you could try this one.
                                      Just to rule things out, and please run it without mysensors.
                                      Good luck!
                                      • RJ_MakeR
                                        RJ_MakeR
                                        RJ_Make
                                        Was excited last night, a new batch of DS18B20 arrived, so I connected it, uploaded the original sketch and........ This morning @ 4:48 with a temp of 74.6F it locked up.
                                        Well, I guess it's not the DS18B20 hardware... This is just ridiculous, I've got to be doing something wrong here....
                                        RJ_Make
                                        • RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          As suggested by @gregl, I loaded the 'single' sketch found in the MySensors download on one of the other sensors that was locking up and put it in the freezer for ~2 days. Removed it this morning, and connected it to the serial monitor. (there was a power cycle when moving from the batteries to the serial connector) and it was humming along just fine.
                                          RJ_Make
