  3. 💬 MySensor Dioder (Ikea)
contest2017diodermysensorshuergbledtrimmerarduinoikea
41 Posts 10 Posters 19.5k Views 10 Watching
    mortommy
    Thank you!
    • A
      Adam McCartney
      i take it i could use an Arduino nano and not have to worry about the voltage Regulator? it can take 5v or 3.3v meaning i already have all the parts to replicate this with my existing Dioder setup..:)
      • loralgL
        loralgL
        loralg
        Thank you for the awesome work you have done! Would you be willing to share your OpenHAB items and sitemap setup to get this to work?
          mortommy
          I'll post items, rules and sitemap as soon as I'll have the stable version.
          • barduinoB
            barduinoB
            barduino
            This is great.
            I just got myself one of these Dioders
            Could you detail the connections between arduino and the ikea board?
            For example when you label AIN6 on the ikea board picture it connects to D6 in arduino?
            • 3 for RGB (AIN6, AIN5, AIN4) - (D6, D5, D3)
            • 3 for Buttons (OEN, AIN2, AIN3) - (D7, D4, D2)
            • 1 ground
            • 1 5v to arduino vin?
            • 1 Color Wheel (AIN7 to Arduino A0)?
            Is this correct?
              mortommy
              wrote on last edited by mortommy
              3 pins for RGB: R (AIN4) -> D3; G (AIN5) -> D6; B (AIN6) -> D5
              3 pins for buttons: S1(AIN3) -> D7; S2(CEN) -> D2; S3(AIN2) -> D4
              1 ground
              1 5V to Arduino's Vcc if it is 5V version or to RAW if it is 3,3V version
              1 color wheel (AIN7) -> A0
              barduinoB 1 Reply Last reply
              • M mortommy
                1 ground
                barduinoB
                barduinoB
                barduino
                Thanks @mortommy
                  mortommy
                  please find items and rules here: https://github.com/mortommy/MySensorDioder
                  • loralgL
                    loralgL
                    loralg
                    @mortommy Thank you!
                      mortommy
                      I just updated the rules.
                      loralgL 1 Reply Last reply
                      • M mortommy
                        loralgL
                        loralgL
                        loralg
                        @mortommy Awesome thanks for the update!
                        • kevvetteK
                          kevvetteK
                          kevvette
                          Just for clarification, you posted in a comment that S3(AIN2) -> D11 but shouldn't it be D4 per schematic and source code? Also, it looks like R20 has been removed. Why was that done and is it critical to make this work? Thanks, nice work.
                            mortommy
                            Hi @kevvette ,
                            yes, my mistake, S3 goes to D4, I'll correct the post, thank you.
                            Regarding the R20, it is just a jumper and first I thought I could use that point for some connection but at the end I didn't use it, so I reestablished the connection. It is not needed to remove the R20.
                            • TON RIJNAARDT
                              TON RIJNAARDT
                              TON RIJNAARD
                              Very nice project!
                              Is it possible to use in DOMOTICZ?
                              Ton
                                mortommy
                                if you are already using a gateway in Domoticz I guess so. From the mysensor point of view is a RGB sensor (or light switch or dimmer light) the source of the command sento to the serial gateway and then to the ikea mysensorized sensor it doesn't matter.
                                • Juan8tacoJ
                                  Juan8tacoJ
                                  Juan8taco
                                  I was using your code from MySensorDioder_133.ino
                                  I downloaded the library from https://github.com/mysensors/MySensors
                                  I tried to run the code but I got a error message saying no such file located.
                                  These were the two files that couldn't be found
                                  MyTransportNRF24.h
                                  MySensor.h
                                  I was wondering if you had the same issues when you were working on the code?
                                    mortommy
                                    yes it happens sometimes. Try to import the library by Arduino IDE (Sketch -> Include Library -> MySensors). You'll have in the sketch two new lines:
                                    #include <MyConfig.h>
                                    and you can delete the same lines already included in the code.
                                    Remember that the sketch is based on mysensor library 1.5.4 it is not converted to 2.0 yet.
                                    Hope it helps.
                                    • Juan8tacoJ
                                      Juan8tacoJ
                                      Juan8taco
                                      Thank you,
                                      I found those missing files and uses the mysensor library 1.5.4 but after I put all the files it asked for I got this odd message. I was looking for the error but had no luck. It says that "was not declared in this scope". Did you happened to run into this issue?
                                      0_1479706500439_upload-81042e07-857f-48cb-aef0-f62af70f2189
                                        mortommy
                                        Have you cleaned the folder MySensor within the folder libraries before to copy the 1.5.4 one?
                                        • pentti12P
                                          pentti12P
                                          pentti12
                                          Hello
                                          I got lot of errors during the compiling stage. I tried to use older MySensors 1.5.4 library and Arduino 1.5.7 IDE. My question is, how to install correct MySensors library and not use anything else?
