  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 18.7k Views 5 Watching
  • Pictor LallemandP
    Pictor LallemandP
    Pictor Lallemand
    or find the code for my GW I use an Arduino pro mini card for a ENC28J60 network and nRF24L01 for radio. because I can not find it in the examples mysensors
    • X
      X
      xefil
      You mean you cannot find the examples from the API library? When you download it, you can find it in there. On github as well:
      https://github.com/mysensors/MySensors/tree/master/examples
      In case try to start uploading two examples (1 GW and 1 sensor) and check. They work without issues. If not, maybe a hardware failure.
      Simon
      • Pictor LallemandP
        Pictor LallemandP
        Pictor Lallemand
        in the examples of the API (MySensors 2.0.0) I can not find ENC28J60 Gateway
        send me please you the code in this gateway thank you
          https://github.com/mysensors/MySensorsArduinoExamples/tree/master/examples/GatewayENC28J60
          • Pictor LallemandP
            Pictor LallemandP
            Pictor Lallemand
            it didnt change anything here is the log for sensors
            TSM:INIT
            TSM:RADIO:OK
            TSP:ASSIGNID:OK (ID=123)
            TSM:FPAR
            TSP:MSG:SEND 123-123-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSP:MSG:READ 0-0-123 s=255,c=3,t=8,pt=1,l=1,sg=0:0
            TSP:MSG:PAR OK (ID=0, dist=1)
            TSM:FPAR:OK
            TSM:ID
            TSM:CHKID:OK (ID=123)
            TSM:UPL
            TSP:PING:SEND (dest=0)
            !TSP:MSG:SEND 123-123-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
            TSP:CHKUPL:FAIL (hops=255)
            !TSM:UPL:FAIL
            TSM:FPAR
            the sketch use
             * Version 1.0 - Henrik Ekblad
             * Example sketch showing how to control physical relays.
             * This example will remember relay state after power failure.
             * http://www.mysensors.org/build/relay
            #define MY_REPEATER_FEATURE
            #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
            void before() {
                pinMode(pin, OUTPUT);
              sendSketchInfo("Relay", "1.0");
                present(sensor, S_LIGHT);
              if (message.type==V_LIGHT) {
                 // Change relay state
                 // Store state in eeprom
            and that of the gateway
            0;255;3;0;9;TSM:INIT
            0;255;3;0;9;TSM:RADIO:OK
            0;255;3;0;9;TSM:GW MODE
            0;255;3;0;9;TSM:READY
            IP: 192.168.1.15
            0;255;3;0;9;Eth: connect
            0;255;3;0;9;Eth: 0;0;3;0;2;
            0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
            0;255;3;0;9;Eth: 0;0;3;0;18;PING
            0;255;3;0;9;TSP:SANCHK:OK
            the sketch use
             * Version 1.0 - Henrik EKblad
             * LED purposes:
            // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
            #define MY_RF24_CE_PIN 5
            #define MY_RF24_CS_PIN 6
            #define MY_GATEWAY_ENC28J60
            // Gateway IP address
            #define MY_IP_ADDRESS 192,168,1,15
            #define MY_PORT 5003
            // Flash leds on rx/tx/err
            // Set blinking period
            // Enable inclusion mode
            #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
            #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
            #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
            #include <UIPEthernet.h>
              i add a capacitor 220U
            • Pictor LallemandP
              Pictor LallemandP
              Pictor Lallemand
              the gateway log
              IP: 192.168.1.15
              0;255;3;0;9;TSP:MSG:READ 123-123-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
              0;255;3;0;9;TSP:MSG:BC
              0;255;3;0;9;TSP:MSG:FPAR REQ (sender=123)
              0;255;3;0;9;TSP:CHKUPL:OK
              0;255;3;0;9;TSP:MSG:GWL OK
              0;255;3;0;9;TSP:MSG:SEND 0-0-123-123 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
              • X
                X
                xefil
                Do you have some spare-parts to use a different radio? My gateway has a radio with nrf24l01+pa+lna to increase the range. Maybe the gain is needed with the new API? I don't know. How far are the two objects?
                Simon
                • Pictor LallemandP
                  Pictor LallemandP
                  Pictor Lallemand
                  the gateway and the remote sensors are 100 cm I use these nRF24L01 I'm beginner with mysensors. I'm really frustrated that it does not work properly malgrer all my efforts to get it working properly alt text
                  tekkaT 1 Reply Last reply
                  • Pictor LallemandP Pictor Lallemand
                    tekkaT
                    tekkaT
                    tekka
                    @Pictor-Lallemand
                    Lets start with a simple setup:
                    • all radio caps >= 22uF (ideal 100uF)
                    • latest MySensors lib (i.e. 2.0.0)
                    Gateway - Program GatewaySerial from the MySensors examples
                    Node - Program this simple sketch:
                    #define MY_NODE_ID 100
                    MyMessage msgGeneral(0, V_VAR1);
                    uint32_t counter = 0, lastSend = 0;
                    uint8_t rebootCounter = 5;
                      sendSketchInfo("TestNode", "1.0");
                      present(0, S_ARDUINO_NODE, "Counter");
                       if (millis() - lastSend > 500) {
                          msgGeneral.setDestination(GATEWAY_ADDRESS);
                          send(msgGeneral.set(counter), true);
                          counter = 0;
                          lastSend = millis();
                          if(!rebootCounter--) {
                            hwReboot();
                       counter++;
                    ...and post the debug log from both, GW and node.
                    • hensingH
                      hensingH
                      hensing
                      same problem here:
                      minimal example worked and I figured out that assignment of an ID helps :)
                      Maybe I missed this point that I have to and that auto assignment doesn't work the way I thought.
                      • hensingH hensing
                        same problem here:
                        tekkaT
                        tekkaT
                        tekka
                        @hensing said:
                        same problem here:
                        Ok, so not related to UPL:Fail (as the title of this topic suggests)?
                        • Pictor LallemandP
                          Pictor LallemandP
                          Pictor Lallemand
                          i add 22uF capacitor to node and GW
                          debug gw
                          0;255;0;0;18;2.0.0
                          0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
                          0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                          debug node
                          TSM:INIT
                          TSM:RADIO:OK
                          TSP:ASSIGNID:OK (ID=100)
                          TSM:FPAR
                          TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:CHKID:OK (ID=100)
                          TSM:UPL
                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                          !TSM:UPL:FAIL
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          I'm really frustrated that it does not work correctly yet I applied literally your sugestions
                            debug gw
                            0;255;0;0;18;2.0.0
                            debug node
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            tekkaT
                            tekkaT
                            tekka
                            @Pictor-Lallemand ok, now next step: substitute all caps to 100uF (or if not available add a second 22uF in parallel). Please test and upload the same logs again. How do you power your nodes?
                            • Pictor LallemandP
                              Pictor LallemandP
                              Pictor Lallemand
                              i add 2 capacitors of 22uf in serie the gateway is powered by my laptop
                              the node is powered by my laptop for use serial debug
                              debug node
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              gw debug
                              0;255;0;0;18;2.0.0
                              Thank you for your support
                                debug node
                                TSM:INIT
                                TSM:RADIO:OK
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                !TSM:FPAR:FAIL
                                !TSM:FAILURE
                                TSM:PDT
                                TSM:INIT
                                TSM:RADIO:OK
                                TSM:FPAR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                !TSM:FPAR:FAIL
                                !TSM:FAILURE
                                TSM:PDT
                                TSM:INIT
                                TSM:RADIO:OK
                                TSM:FPAR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                gw debug
                                0;255;0;0;18;2.0.0
                                tekkaT
                                tekkaT
                                tekka
                                wrote on last edited by tekka
                                #27
                                @Pictor-Lallemand Did you add the 22uF caps in parallel or in series? In parallel you get 44uF, in series ~11uF...
                                Pictor LallemandP 1 Reply Last reply
                                • tekkaT tekka
                                  Pictor LallemandP
                                  Pictor LallemandP
                                  Pictor Lallemand
                                  @tekka in parallel
                                    @tekka in parallel
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Pictor-Lallemand ok, then try putting them further away and/or decrease TX_POWER for both nodes by setting
                                    • tekkaT tekka
                                      Pictor LallemandP
                                      Pictor LallemandP
                                      Pictor Lallemand
                                      @tekka I just try not conclusive
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      !TSM:FPAR:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:UPL
                                      !TSM:UPL:FAIL
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      an idea ?
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        !TSM:FPAR:FAIL
                                        !TSM:FAILURE
                                        TSM:PDT
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        an idea ?
                                        tekkaT
                                        tekkaT
                                        tekka
                                        #31
                                        @Pictor-Lallemand Looks to me like power issue and/or radio interference. If you have 100uF or larger caps, try replacing them. Also, is there a WiFi AP nearby?
                                        • tekkaT tekka
                                          Pictor LallemandP
                                          Pictor LallemandP
                                          Pictor Lallemand
                                          @tekka it is always the same worries I added capacitors 330uF no wifi point naarby
