  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 18.7k Views 5 Watching
  • X
    X
    xefil
    Do you have some spare-parts to use a different radio? My gateway has a radio with nrf24l01+pa+lna to increase the range. Maybe the gain is needed with the new API? I don't know. How far are the two objects?
    Simon
    • Pictor LallemandP
      Pictor LallemandP
      Pictor Lallemand
      the gateway and the remote sensors are 100 cm I use these nRF24L01 I'm beginner with mysensors. I'm really frustrated that it does not work properly malgrer all my efforts to get it working properly alt text
      tekkaT 1 Reply Last reply
      • Pictor LallemandP Pictor Lallemand
        tekkaT
        tekkaT
        tekka
        @Pictor-Lallemand
        Lets start with a simple setup:
        • all radio caps >= 22uF (ideal 100uF)
        • latest MySensors lib (i.e. 2.0.0)
        Gateway - Program GatewaySerial from the MySensors examples
        Node - Program this simple sketch:
        #define MY_NODE_ID 100
        MyMessage msgGeneral(0, V_VAR1);
        uint32_t counter = 0, lastSend = 0;
        uint8_t rebootCounter = 5;
          sendSketchInfo("TestNode", "1.0");
          present(0, S_ARDUINO_NODE, "Counter");
           if (millis() - lastSend > 500) {
              msgGeneral.setDestination(GATEWAY_ADDRESS);
              send(msgGeneral.set(counter), true);
              counter = 0;
              lastSend = millis();
              if(!rebootCounter--) {
                hwReboot();
           counter++;
        ...and post the debug log from both, GW and node.
        • hensingH
          hensingH
          hensing
          same problem here:
          minimal example worked and I figured out that assignment of an ID helps :)
          Maybe I missed this point that I have to and that auto assignment doesn't work the way I thought.
          • hensingH hensing
            same problem here:
            tekkaT
            tekkaT
            tekka
            @hensing said:
            same problem here:
            Ok, so not related to UPL:Fail (as the title of this topic suggests)?
            • Pictor LallemandP
              Pictor LallemandP
              Pictor Lallemand
              i add 22uF capacitor to node and GW
              debug gw
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;TSM:RADIO:OK
              0;255;3;0;9;TSM:GW MODE
              0;255;3;0;9;TSM:READY
              0;255;0;0;18;2.0.0
              0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
              0;255;3;0;9;TSP:MSG:BC
              0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
              0;255;3;0;9;TSP:CHKUPL:OK
              0;255;3;0;9;TSP:MSG:GWL OK
              0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
              0;255;3;0;9;TSP:SANCHK:OK
              debug node
              TSM:INIT
              TSM:RADIO:OK
              TSP:ASSIGNID:OK (ID=100)
              TSM:FPAR
              TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
              TSP:MSG:PAR OK (ID=0, dist=1)
              TSM:FPAR:OK
              TSM:ID
              TSM:CHKID:OK (ID=100)
              TSM:UPL
              TSP:PING:SEND (dest=0)
              !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
              TSP:CHKUPL:FAIL (hops=255)
              !TSM:UPL:FAIL
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              I'm really frustrated that it does not work correctly yet I applied literally your sugestions
                debug gw
                0;255;0;0;18;2.0.0
                debug node
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR:OK
                TSM:ID
                TSM:UPL
                !TSM:UPL:FAIL
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                tekkaT
                tekkaT
                tekka
                @Pictor-Lallemand ok, now next step: substitute all caps to 100uF (or if not available add a second 22uF in parallel). Please test and upload the same logs again. How do you power your nodes?
                • Pictor LallemandP
                  Pictor LallemandP
                  Pictor Lallemand
                  i add 2 capacitors of 22uf in serie the gateway is powered by my laptop
                  the node is powered by my laptop for use serial debug
                  debug node
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:UPL
                  !TSM:UPL:FAIL
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:UPL
                  !TSM:UPL:FAIL
                  TSM:FPAR
                  gw debug
                  0;255;0;0;18;2.0.0
                  Thank you for your support
                    debug node
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    gw debug
                    0;255;0;0;18;2.0.0
                    tekkaT
                    tekkaT
                    tekka
                    wrote on last edited by tekka
                    #27
                    @Pictor-Lallemand Did you add the 22uF caps in parallel or in series? In parallel you get 44uF, in series ~11uF...
                    Pictor LallemandP 1 Reply Last reply
                    • tekkaT tekka
                      Pictor LallemandP
                      Pictor LallemandP
                      Pictor Lallemand
                      @tekka in parallel
                        @tekka in parallel
                        tekkaT
                        tekkaT
                        tekka
                        @Pictor-Lallemand ok, then try putting them further away and/or decrease TX_POWER for both nodes by setting
                        • tekkaT tekka
                          Pictor LallemandP
                          Pictor LallemandP
                          Pictor Lallemand
                          @tekka I just try not conclusive
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          !TSM:FPAR:FAIL
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:UPL
                          !TSM:UPL:FAIL
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          TSM:FPAR
                          an idea ?
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            an idea ?
                            tekkaT
                            tekkaT
                            tekka
                            #31
                            @Pictor-Lallemand Looks to me like power issue and/or radio interference. If you have 100uF or larger caps, try replacing them. Also, is there a WiFi AP nearby?
                            • tekkaT tekka
                              Pictor LallemandP
                              Pictor LallemandP
                              Pictor Lallemand
                              @tekka it is always the same worries I added capacitors 330uF no wifi point naarby
                                tekkaT
                                tekkaT
                                tekka
                                @Pictor-Lallemand What HW are you using & frequency?
                                • tekkaT tekka
                                  Pictor LallemandP
                                  Pictor LallemandP
                                  Pictor Lallemand
                                  @tekka What is the HW?
                                    #35
                                    @Pictor-Lallemand
                                    HW= hardware ;) FW for firmware or SW software
                                    that's weird you're not lucky on this, I agree with tekka it looks like hardware issue..Perhaps you could try to replace your usb cable, not sure but who knows, or maybe some bad dupont cable too (try with some other). I have already seen bad usb or dupont cables so...or maybe try with another radio module.
                                    • Pictor LallemandP
                                      Pictor LallemandP
                                      Pictor Lallemand
                                      @tekka My HW is arduino pro mini 5v + ams1117 3,3V for radio module and NRF24L01 for radio
                                      • Pictor LallemandP
                                        Pictor LallemandP
                                        Pictor Lallemand
                                        @tekka
                                        I weld son tips on antenna here debug
                                        node
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        !TSM:FPAR:FAIL
                                        !TSM:FAILURE
                                        TSM:PDT
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        !TSM:FPAR:FAIL
                                        !TSM:FAILURE
                                        TSM:PDT
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        !TSM:FPAR:FAIL
                                        !TSM:FAILURE
                                        TSM:PDT
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        !TSM:FPAR:FAIL
                                        !TSM:FAILURE
                                        TSM:PDT
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        !TSM:FPAR:FAIL
                                        !TSM:FAILURE
                                        TSM:PDT
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSM:FPAR
                                        TSP:MSG:READ 0-0-255 s=255,c=3,t=20,pt=0,l=1,sg=0:0
                                        TSP:MSG:BC
                                        TSM:FPAR
                                        !TSM:FPAR:FAIL
                                        !TSM:FAILURE
                                        TSM:PDT
                                        TSM:INIT
                                        TSM:RADIO:OK
                                        TSM:FPAR
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSM:UPL
                                        !TSM:UPL:FAIL
                                        TSM:FPAR
                                        TSP:MSG:BC
                                        TSP:MSG:BC
                                        !TSP:FPAR:ACTIVE (msg not send)
                                        TSP:MSG:BC
                                        TSP:MSG:BC
                                        TSP:MSG:BC
                                        TSP:MSG:BC
                                        TSM:FPAR:OK
                                        TSM:ID
                                        TSP:MSG:BC
                                        TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=ok:0
                                        TSP:MSG:BC
                                        TSP:MSG:BC
                                        TSM:UPL
                                        TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                        TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                        TSP:MSG:PONG RECV (hops=1)
                                        TSP:CHKUPL:OK
                                        TSM:UPL:OK
                                        TSM:READY
                                        TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                        TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                        TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                        TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        TSP:MSG:READ 0-0-100 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                        !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=fail:TestNode
                                        !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
                                        !TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=17,pt=0,l=7,sg=0,ft=2,st=fail:Counter
                                        Request registration...
                                        !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=fail:2
                                        !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=fail:2
                                        !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
                                        !TSM:UPL FAIL, SNP
                                        TSM:FPAR
                                        !TSP:SEND:TNR
                                        TSM:FPAR
                                        Init complete, id=100, parent=255, distance=255, registration=1
                                        !TSP:SEND:TNR
                                        !TSP:SEND:TNR
                                        !TSP:SEND:TNR
                                        !TSP:SEND:TNR
                                        TSM:FPAR
                                        !TSP:SEND:TNR
                                        !TSP:SEND:TNR
                                        gateway debug from MYSController
                                        8	13/08/2016 18:33:12	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			required
                                        10	13/08/2016 18:33:20	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        11	13/08/2016 18:33:22	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        12	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                        14	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                        17	13/08/2016 18:33:27	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                        18	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                        20	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                        23	13/08/2016 18:33:28	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                        24	13/08/2016 18:33:46	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        25	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                        27	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                        30	13/08/2016 18:34:01	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                        31	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                        33	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                        36	13/08/2016 18:34:02	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                        37	13/08/2016 18:34:08	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        38	13/08/2016 18:34:08	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                        40	13/08/2016 18:34:08	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                        43	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                        44	13/08/2016 18:34:09	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                        46	13/08/2016 18:34:09	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                        49	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                        50	13/08/2016 18:34:09	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        51	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        52	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        53	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        54	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        55	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        56	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        57	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        58	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        59	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        60	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        62	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        63	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        64	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                        65	13/08/2016 18:34:14	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                                        67	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                                        69	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                                        71	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	NA (24)	BYTE	1	NO		1
                                        72	13/08/2016 18:34:16	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			hops=1)
                                        73	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	NA (25)	BYTE	1	NO	ok	1
                                        74	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO		0100
                                        75	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO	ok	0100
                                        76	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_PRESENTATION	S_ARDUINO_NODE	STRING	5	NO		2.0.0
                                        78	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_CONFIG	BYTE	1	NO		0
                                        81	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_CONFIG	STRING	1	NO	ok	M
                                        84	13/08/2016 18:36:27	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          @tekka
                                          node
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSP:MSG:BC
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSM:UPL
                                          TSP:CHKUPL:OK
                                          TSM:UPL:OK
                                          TSM:READY
                                          !TSM:UPL FAIL, SNP
                                          TSM:FPAR
                                          !TSP:SEND:TNR
                                          TSM:FPAR
                                          !TSP:SEND:TNR
                                          !TSP:SEND:TNR
                                          !TSP:SEND:TNR
                                          !TSP:SEND:TNR
                                          TSM:FPAR
                                          !TSP:SEND:TNR
                                          !TSP:SEND:TNR
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @Pictor-Lallemand Looks to me like a power issue, not an antenna issue.
                                          Half of the messages are OK, and then all of a sudden they all fail:
                                          TSM:UPL
                                          TSP:CHKUPL:OK
                                          TSM:UPL:OK
                                          TSM:READY
                                          At what frequency are you running your minis? Out of curiosity, can you post a pic of your node+radio (ideally with a pic of the cap) and GW+radio - this may give additional info.
