  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 18.7k Views 5 Watching
  • Pictor LallemandP
    Pictor LallemandP
    Pictor Lallemand
    the gateway log
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.15
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: 0;0;3;0;2;
    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
    0;255;3;0;9;Eth: 0;0;3;0;18;PING
    0;255;3;0;9;TSP:SANCHK:OK
    0;255;3;0;9;TSP:MSG:READ 123-123-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=123)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-123-123 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
    • X
      X
      xefil
      Do you have some spare-parts to use a different radio? My gateway has a radio with nrf24l01+pa+lna to increase the range. Maybe the gain is needed with the new API? I don't know. How far are the two objects?
      Simon
      • Pictor LallemandP
        Pictor LallemandP
        Pictor Lallemand
        the gateway and the remote sensors are 100 cm I use these nRF24L01 I'm beginner with mysensors. I'm really frustrated that it does not work properly malgrer all my efforts to get it working properly alt text
        tekkaT 1 Reply Last reply
        • Pictor LallemandP Pictor Lallemand
          tekkaT
          tekkaT
          tekka
          @Pictor-Lallemand
          Lets start with a simple setup:
          • all radio caps >= 22uF (ideal 100uF)
          • latest MySensors lib (i.e. 2.0.0)
          Gateway - Program GatewaySerial from the MySensors examples
          Node - Program this simple sketch:
          #define MY_NODE_ID 100
          MyMessage msgGeneral(0, V_VAR1);
          uint32_t counter = 0, lastSend = 0;
          uint8_t rebootCounter = 5;
            sendSketchInfo("TestNode", "1.0");
            present(0, S_ARDUINO_NODE, "Counter");
             if (millis() - lastSend > 500) {
                msgGeneral.setDestination(GATEWAY_ADDRESS);
                send(msgGeneral.set(counter), true);
                counter = 0;
                lastSend = millis();
                if(!rebootCounter--) {
                  hwReboot();
             counter++;
          ...and post the debug log from both, GW and node.
          • hensingH
            hensingH
            hensing
            same problem here:
            minimal example worked and I figured out that assignment of an ID helps :)
            Maybe I missed this point that I have to and that auto assignment doesn't work the way I thought.
            • hensingH hensing
              same problem here:
              tekkaT
              tekkaT
              tekka
              @hensing said:
              same problem here:
              Ok, so not related to UPL:Fail (as the title of this topic suggests)?
              • Pictor LallemandP
                Pictor LallemandP
                Pictor Lallemand
                i add 22uF capacitor to node and GW
                debug gw
                0;255;0;0;18;2.0.0
                0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
                0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                debug node
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=100)
                TSM:FPAR
                TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                TSP:MSG:PAR OK (ID=0, dist=1)
                TSM:FPAR:OK
                TSM:ID
                TSM:CHKID:OK (ID=100)
                TSM:UPL
                TSP:PING:SEND (dest=0)
                !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                TSP:CHKUPL:FAIL (hops=255)
                !TSM:UPL:FAIL
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                I'm really frustrated that it does not work correctly yet I applied literally your sugestions
                  debug gw
                  0;255;0;0;18;2.0.0
                  debug node
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:UPL
                  !TSM:UPL:FAIL
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  tekkaT
                  tekkaT
                  tekka
                  @Pictor-Lallemand ok, now next step: substitute all caps to 100uF (or if not available add a second 22uF in parallel). Please test and upload the same logs again. How do you power your nodes?
                  • Pictor LallemandP
                    Pictor LallemandP
                    Pictor Lallemand
                    i add 2 capacitors of 22uf in serie the gateway is powered by my laptop
                    the node is powered by my laptop for use serial debug
                    debug node
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    gw debug
                    0;255;0;0;18;2.0.0
                    Thank you for your support
                      debug node
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      gw debug
                      0;255;0;0;18;2.0.0
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      #27
                      @Pictor-Lallemand Did you add the 22uF caps in parallel or in series? In parallel you get 44uF, in series ~11uF...
                      Pictor LallemandP 1 Reply Last reply
                      • tekkaT tekka
                        Pictor LallemandP
                        Pictor LallemandP
                        Pictor Lallemand
                        @tekka in parallel
                          @tekka in parallel
                          tekkaT
                          tekkaT
                          tekka
                          @Pictor-Lallemand ok, then try putting them further away and/or decrease TX_POWER for both nodes by setting
                          • tekkaT tekka
                            Pictor LallemandP
                            Pictor LallemandP
                            Pictor Lallemand
                            @tekka I just try not conclusive
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:UPL
                            !TSM:UPL:FAIL
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            an idea ?
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              an idea ?
                              tekkaT
                              tekkaT
                              tekka
                              #31
                              @Pictor-Lallemand Looks to me like power issue and/or radio interference. If you have 100uF or larger caps, try replacing them. Also, is there a WiFi AP nearby?
                              • tekkaT tekka
                                Pictor LallemandP
                                Pictor LallemandP
                                Pictor Lallemand
                                @tekka it is always the same worries I added capacitors 330uF no wifi point naarby
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @Pictor-Lallemand What HW are you using & frequency?
                                  • tekkaT tekka
                                    Pictor LallemandP
                                    Pictor LallemandP
                                    Pictor Lallemand
                                    @tekka What is the HW?
                                      #35
                                      @Pictor-Lallemand
                                      HW= hardware ;) FW for firmware or SW software
                                      that's weird you're not lucky on this, I agree with tekka it looks like hardware issue..Perhaps you could try to replace your usb cable, not sure but who knows, or maybe some bad dupont cable too (try with some other). I have already seen bad usb or dupont cables so...or maybe try with another radio module.
                                      • Pictor LallemandP
                                        Pictor LallemandP
                                        Pictor Lallemand
                                        @tekka My HW is arduino pro mini 5v + ams1117 3,3V for radio module and NRF24L01 for radio
                                        • Pictor LallemandP
                                          Pictor LallemandP
                                          Pictor Lallemand
                                          @tekka
                                          I weld son tips on antenna here debug
                                          node
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSM:FPAR
                                          TSP:MSG:READ 0-0-255 s=255,c=3,t=20,pt=0,l=1,sg=0:0
                                          TSP:MSG:BC
                                          TSM:FPAR
                                          !TSM:FPAR:FAIL
                                          !TSM:FAILURE
                                          TSM:PDT
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSM:FPAR
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:UPL
                                          !TSM:UPL:FAIL
                                          TSM:FPAR
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          !TSP:FPAR:ACTIVE (msg not send)
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSP:MSG:BC
                                          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=21,pt=1,l=1,sg=0,ft=0,st=ok:0
                                          TSP:MSG:BC
                                          TSP:MSG:BC
                                          TSM:UPL
                                          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          TSP:MSG:READ 0-0-100 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          TSP:MSG:PONG RECV (hops=1)
                                          TSP:CHKUPL:OK
                                          TSM:UPL:OK
                                          TSM:READY
                                          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                          TSP:MSG:SEND 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                          TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                          TSP:MSG:READ 0-0-100 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          TSP:MSG:READ 0-0-100 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,ft=0,st=fail:TestNode
                                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=1,st=fail:1.0
                                          !TSP:MSG:SEND 100-100-0-0 s=0,c=0,t=17,pt=0,l=7,sg=0,ft=2,st=fail:Counter
                                          Request registration...
                                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=3,st=fail:2
                                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=4,st=fail:2
                                          !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
                                          !TSM:UPL FAIL, SNP
                                          TSM:FPAR
                                          !TSP:SEND:TNR
                                          TSM:FPAR
                                          Init complete, id=100, parent=255, distance=255, registration=1
                                          !TSP:SEND:TNR
                                          !TSP:SEND:TNR
                                          !TSP:SEND:TNR
                                          !TSP:SEND:TNR
                                          TSM:FPAR
                                          !TSP:SEND:TNR
                                          !TSP:SEND:TNR
                                          gateway debug from MYSController
                                          8	13/08/2016 18:33:12	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			required
                                          10	13/08/2016 18:33:20	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          11	13/08/2016 18:33:22	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          12	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                          14	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                          17	13/08/2016 18:33:27	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                          18	13/08/2016 18:33:27	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                          20	13/08/2016 18:33:27	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                          23	13/08/2016 18:33:28	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                          24	13/08/2016 18:33:46	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          25	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                          27	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                          30	13/08/2016 18:34:01	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                          31	13/08/2016 18:34:01	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                          33	13/08/2016 18:34:01	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                          36	13/08/2016 18:34:02	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                          37	13/08/2016 18:34:08	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          38	13/08/2016 18:34:08	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                          40	13/08/2016 18:34:08	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                          43	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                          44	13/08/2016 18:34:09	TX	100	100		BC	INTERNAL	C_INTERNAL	I_FIND_PARENT	STRING	0	NO
                                          46	13/08/2016 18:34:09	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			(sender=100)
                                          49	13/08/2016 18:34:09	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_FIND_PARENT_RESPONSE	BYTE	1	NO	ok	0
                                          50	13/08/2016 18:34:09	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          51	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          52	13/08/2016 18:34:10	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          53	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          54	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          55	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          56	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          57	13/08/2016 18:34:11	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          58	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          59	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          60	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          62	13/08/2016 18:34:12	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          63	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          64	13/08/2016 18:34:13	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
                                          65	13/08/2016 18:34:14	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                                          67	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                                          69	13/08/2016 18:34:15	TX	100	100		0	INTERNAL	C_INTERNAL	I_DISCOVER_RESPONSE	BYTE	1	NO		0
                                          71	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	NA (24)	BYTE	1	NO		1
                                          72	13/08/2016 18:34:16	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			hops=1)
                                          73	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	NA (25)	BYTE	1	NO	ok	1
                                          74	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO		0100
                                          75	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_SIGNING_PRESENTATION	CUSTOM	2	NO	ok	0100
                                          76	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_PRESENTATION	S_ARDUINO_NODE	STRING	5	NO		2.0.0
                                          78	13/08/2016 18:34:16	TX	100	100		0	INTERNAL	C_INTERNAL	I_CONFIG	BYTE	1	NO		0
                                          81	13/08/2016 18:34:16	TX	0	0	100	100	INTERNAL	C_INTERNAL	I_CONFIG	STRING	1	NO	ok	M
                                          84	13/08/2016 18:36:27	TX	0	0	255	BC	INTERNAL	C_INTERNAL	I_DISCOVER	STRING	1	NO	bc	0
