  3. [Solved]UPL:Fail
[Solved]UPL:Fail
47 Posts 7 Posters 18.7k Views 5 Watching
  • Pictor LallemandP
    Pictor LallemandP
    Pictor Lallemand
    it didnt change anything here is the log for sensors
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=123)
    TSM:FPAR
    TSP:MSG:SEND 123-123-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:READ 0-0-123 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=123)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 123-123-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    the sketch use
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to control physical relays.
     * This example will remember relay state after power failure.
     * http://www.mysensors.org/build/relay
    #define MY_REPEATER_FEATURE
    #define RELAY_1  8  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    void before() {
        pinMode(pin, OUTPUT);
      sendSketchInfo("Relay", "1.0");
        present(sensor, S_LIGHT);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
    and that of the gateway
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.15
    0;255;3;0;9;Eth: connect
    0;255;3;0;9;Eth: 0;0;3;0;2;
    0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
    0;255;3;0;9;Eth: 0;0;3;0;18;PING
    0;255;3;0;9;TSP:SANCHK:OK
    the sketch use
     * Version 1.0 - Henrik EKblad
     * LED purposes:
    // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
    #define MY_RF24_CE_PIN 5
    #define MY_RF24_CS_PIN 6
    #define MY_GATEWAY_ENC28J60
    // Gateway IP address
    #define MY_IP_ADDRESS 192,168,1,15
    #define MY_PORT 5003
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
    #include <UIPEthernet.h>
      i add a capacitor 220U
    • Pictor LallemandP
      Pictor LallemandP
      Pictor Lallemand
      the gateway log
      IP: 192.168.1.15
      0;255;3;0;9;TSP:MSG:READ 123-123-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;TSP:MSG:BC
      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=123)
      0;255;3;0;9;TSP:CHKUPL:OK
      0;255;3;0;9;TSP:MSG:GWL OK
      0;255;3;0;9;TSP:MSG:SEND 0-0-123-123 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
      • X
        X
        xefil
        Do you have some spare-parts to use a different radio? My gateway has a radio with nrf24l01+pa+lna to increase the range. Maybe the gain is needed with the new API? I don't know. How far are the two objects?
        Simon
        • Pictor LallemandP
          Pictor LallemandP
          Pictor Lallemand
          the gateway and the remote sensors are 100 cm I use these nRF24L01 I'm beginner with mysensors. I'm really frustrated that it does not work properly malgrer all my efforts to get it working properly alt text
          tekkaT 1 Reply Last reply
          • Pictor LallemandP Pictor Lallemand
            tekkaT
            tekkaT
            tekka
            @Pictor-Lallemand
            Lets start with a simple setup:
            • all radio caps >= 22uF (ideal 100uF)
            • latest MySensors lib (i.e. 2.0.0)
            Gateway - Program GatewaySerial from the MySensors examples
            Node - Program this simple sketch:
            #define MY_NODE_ID 100
            MyMessage msgGeneral(0, V_VAR1);
            uint32_t counter = 0, lastSend = 0;
            uint8_t rebootCounter = 5;
              sendSketchInfo("TestNode", "1.0");
              present(0, S_ARDUINO_NODE, "Counter");
               if (millis() - lastSend > 500) {
                  msgGeneral.setDestination(GATEWAY_ADDRESS);
                  send(msgGeneral.set(counter), true);
                  counter = 0;
                  lastSend = millis();
                  if(!rebootCounter--) {
                    hwReboot();
               counter++;
            ...and post the debug log from both, GW and node.
            • hensingH
              hensingH
              hensing
              same problem here:
              minimal example worked and I figured out that assignment of an ID helps :)
              Maybe I missed this point that I have to and that auto assignment doesn't work the way I thought.
              • hensingH hensing
                same problem here:
                tekkaT
                tekkaT
                tekka
                @hensing said:
                same problem here:
                Ok, so not related to UPL:Fail (as the title of this topic suggests)?
                • Pictor LallemandP
                  Pictor LallemandP
                  Pictor Lallemand
                  i add 22uF capacitor to node and GW
                  debug gw
                  0;255;0;0;18;2.0.0
                  0;255;3;0;9;TSP:MSG:READ 100-100-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                  0;255;3;0;9;TSP:MSG:FPAR REQ (sender=100)
                  0;255;3;0;9;TSP:MSG:SEND 0-0-100-100 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                  debug node
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=100)
                  TSM:FPAR
                  TSP:MSG:SEND 100-100-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSP:MSG:READ 0-0-100 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=100)
                  TSM:UPL
                  !TSP:MSG:SEND 100-100-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                  !TSM:UPL:FAIL
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  I'm really frustrated that it does not work correctly yet I applied literally your sugestions
                    debug gw
                    0;255;0;0;18;2.0.0
                    debug node
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    !TSM:UPL:FAIL
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    tekkaT
                    tekkaT
                    tekka
                    @Pictor-Lallemand ok, now next step: substitute all caps to 100uF (or if not available add a second 22uF in parallel). Please test and upload the same logs again. How do you power your nodes?
                    • Pictor LallemandP
                      Pictor LallemandP
                      Pictor Lallemand
                      i add 2 capacitors of 22uf in serie the gateway is powered by my laptop
                      the node is powered by my laptop for use serial debug
                      debug node
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      !TSM:UPL:FAIL
                      TSM:FPAR
                      gw debug
                      0;255;0;0;18;2.0.0
                      Thank you for your support
                        debug node
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:UPL
                        !TSM:UPL:FAIL
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:UPL
                        !TSM:UPL:FAIL
                        TSM:FPAR
                        gw debug
                        0;255;0;0;18;2.0.0
                        tekkaT
                        tekkaT
                        tekka
                        wrote on last edited by tekka
                        #27
                        @Pictor-Lallemand Did you add the 22uF caps in parallel or in series? In parallel you get 44uF, in series ~11uF...
                        Pictor LallemandP 1 Reply Last reply
                        • tekkaT tekka
                          Pictor LallemandP
                          Pictor LallemandP
                          Pictor Lallemand
                          @tekka in parallel
                            @tekka in parallel
                            tekkaT
                            tekkaT
                            tekka
                            @Pictor-Lallemand ok, then try putting them further away and/or decrease TX_POWER for both nodes by setting
                            • tekkaT tekka
                              Pictor LallemandP
                              Pictor LallemandP
                              Pictor Lallemand
                              @tekka I just try not conclusive
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              an idea ?
                                TSM:INIT
                                TSM:RADIO:OK
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                !TSM:FPAR:FAIL
                                !TSM:FAILURE
                                TSM:PDT
                                TSM:INIT
                                TSM:RADIO:OK
                                TSM:FPAR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                an idea ?
                                tekkaT
                                tekkaT
                                tekka
                                #31
                                @Pictor-Lallemand Looks to me like power issue and/or radio interference. If you have 100uF or larger caps, try replacing them. Also, is there a WiFi AP nearby?
                                • tekkaT tekka
                                  Pictor LallemandP
                                  Pictor LallemandP
                                  Pictor Lallemand
                                  @tekka it is always the same worries I added capacitors 330uF no wifi point naarby
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @Pictor-Lallemand What HW are you using & frequency?
                                    • tekkaT tekka
                                      Pictor LallemandP
                                      Pictor LallemandP
                                      Pictor Lallemand
                                      @tekka What is the HW?
                                        #35
                                        @Pictor-Lallemand
                                        HW= hardware ;) FW for firmware or SW software
                                        that's weird you're not lucky on this, I agree with tekka it looks like hardware issue..Perhaps you could try to replace your usb cable, not sure but who knows, or maybe some bad dupont cable too (try with some other). I have already seen bad usb or dupont cables so...or maybe try with another radio module.
                                        • Pictor LallemandP
                                          Pictor LallemandP
                                          Pictor Lallemand
                                          @tekka My HW is arduino pro mini 5v + ams1117 3,3V for radio module and NRF24L01 for radio
