MySensors plugin : Choose the Serial Port
Running a serial gateway with nano. (original nano, not knock off version)
Every time there is a power failure, after start up I get this message:
MySensors Plugin[3575] : Running Lua StartupThe options for the serial gateway setup are not present. I need to go into my roof and unplug my serial gateway and plug it back into my Vera. Once it I do I can see the options for the set up and everything works fine. The other day I hit the reboot button on the nano and this did not seem to do the trick. I will need to confirm about that.
Has anyone had this problem?
MySensors Plugin[3575] : Running Lua StartupThis message is coming from Vera?
If yes, then I think the problem is in Vera.
yes this message is coming from vera. Now, how can I solve this? I'm sure someone running the same setup can chime in. This must have happened to other people before.
Maybe adding a reboot every 6 hours in the arduino gateway sketch? Or is there a vera specific fix that might work?
Yes, there have been reports of Vera re-numerating the usb-serial devices at reboot, which is very annoying.
I use a usb hub and it always pops up again after reboot. The only time have problems, is if I leave the gateway unplugged during reboot. Then I have to reconfigure it again.
If it's a standard arduino (with 328p)then resetting won't have an effect, as the USB controller is external and won't reset/re-enumerate
If it's a 32u4, or atsam micro (with build in USB controller) then it will re-enumerate as you will be resetting the USB controller as well..
@hek said in MySensors plugin : Choose the Serial Port:
Its been quite some time since this issue has been discussed. Has there been any updates which can solve this re-numerating problem at reboot?
