another relay problem....
here is a link to the sketch i'm using :
https://home-assistant.io/components/switch.mysensors/#example-sketch
I'm using the first one. Simple switch sketch. -
I'm using the first one. Simple switch sketch.@Gefkuz I'm not sure who's responsible of generating the warning
WARNING:mysensors.mysensors:child_id 1 already exists in children, cannot add ch ildI find it hard to believe that the gateway is generating this warning. But maybe @Hek or @tekka can tell us more about this. I haven't seen this warning before.
Hi!
Everything in the log looks OK, except the node already has the child registered. But you said that doesn't happen when you start the arduino the first time after restart of hass? In that case it should be fine. Otherwise it could be an indication that there are already children loaded from persistence, which could conflict with the new settings.
It's not necessary to upgrade to mysensors 2.0.0. That's not fully supported either.
Try setting persistence to false, restart hass and start your arduino node again. If that doesn't work I'd like to see the log from the start of hass with all lines regarding mysensors.
No more result with persistent file to none (#) and persistent to false.
Deleting mysensor1.picle file.
Restarting homeassistant.
modify the switch to nodeid 56.
launch the switch.
And same things.....
For information, my temperatures sensors (mysensors) working perfectly. -
You said you're using mysensors 1.5.2, but the log indicates that atleast the node in question is 1.5.4. Is the gateway also on 1.5.4? There was a bug in 1.5.2-1.5.3 regarding payloads.
The log is usually in the same directory as the configuration.
I prefer to just start hass manually and look/copy the output at the console.
@martinhjelmare I already had a gut feeling that the gateway doesn't generate message's like this. Because it was designed to be a gateway with as less logic in it as possible ;-) Glad you cleared that one.
I reprogram the gateway with same pc than the switch, then the same mysensor library.
I launch homeassistant without persistent file mysensor.
And same problem... :( :(Microsoft Windows [version 6.3.9600] (c) 2013 Microsoft Corporation. Tous droits réservés. C:\Users\Fabien>py -m homeassistant Config directory: C:\Users\Fabien\AppData\Roaming\.homeassistant INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas sistant, service=turn_off> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas sistant, service=turn_on> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas sistant, service=toggle> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas sistant, service=reload_core_config> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=persis tent_notification, service=create> INFO:homeassistant.bootstrap:Home Assistant core initialized INFO:homeassistant.loader:Loaded script from homeassistant.components.script INFO:homeassistant.loader:Loaded group from homeassistant.components.group INFO:homeassistant.loader:Loaded input_select from homeassistant.components.inpu t_select INFO:homeassistant.loader:Loaded media_player from homeassistant.components.medi a_player INFO:homeassistant.loader:Loaded http from homeassistant.components.http INFO:homeassistant.loader:Loaded weblink from homeassistant.components.weblink INFO:homeassistant.loader:Loaded automation from homeassistant.components.automa tion INFO:homeassistant.loader:Loaded shell_command from homeassistant.components.she ll_command INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysenso rs INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend INFO:homeassistant.loader:Loaded api from homeassistant.components.api INFO:homeassistant.loader:Loaded history from homeassistant.components.history INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder INFO:homeassistant.loader:Loaded input_slider from homeassistant.components.inpu t_slider INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recor der> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=input_ select, service=select_option> INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, en tity_id=input_select.station, new_state=<state input_select.station=BBC Radio Be rkshire; options=['BBC Radio Berkshire', 'BBC Radio Two', 'Heart'], friendly_nam e=Station, icon=mdi:radio-tower @ 2016-08-17T21:07:10.881326+02:00>> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=input _select> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http> ERROR:homeassistant.bootstrap:Invalid config for [media_player]: required key no t provided @ data['platform']. Got None INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, en tity_id=weblink.freebox, new_state=<state weblink.freebox=http://192.168.1.1; fr iendly_name=FreeBox, icon=mdi:router-wireless @ 2016-08-17T21:07:11.146946+02:00 >> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=webli nk> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=shell_ command, service=battery> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=shell _command> INFO:homeassistant.loader:Loaded camera.generic from homeassistant.components.ca mera.generic INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, en tity_id=camera.london_road, new_state=<state camera.london_road=idle; entity_pic ture=/api/camera_proxy/camera.london_road?token=60691888, access_token=60691888, friendly_name=London Road @ 2016-08-17T21:07:11.240702+02:00>> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camer a> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysen sors> ERROR:homeassistant.bootstrap:Invalid config for [switch]: required key not prov ided @ data['platform']. Got None INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor INFO:homeassistant.loader:Loaded binary_sensor from homeassistant.components.bin ary_sensor INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=senso r> INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=load _platform.sensor, platform=mysensors, discovered=> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=binar y_sensor> INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=load _platform.binary_sensor, platform=mysensors, discovered=> INFO:homeassistant.loader:Loaded light from homeassistant.components.light INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components. sensor.mysensors INFO:homeassistant.loader:Loaded binary_sensor.mysensors from homeassistant.comp onents.binary_sensor.mysensors INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=front end> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=toggle> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light > INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=load _platform.light, platform=mysensors, discovered=> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=histo ry> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=input_ slider, service=select_value> INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, en tity_id=input_slider.volume, new_state=<state input_slider.volume=50; max=100, s tep=1, min=0, friendly_name=Volume, icon=mdi:volume-high @ 2016-08-17T21:07:13.0 53199+02:00>> INFO:homeassistant.loader:Loaded light.mysensors from homeassistant.components.l ight.mysensors INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=input _slider> ERROR:homeassistant.bootstrap:Invalid config for [switch]: required key not prov ided @ data['platform']. Got None INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=group > INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, en tity_id=script.battery, new_state=<state script.battery=off; friendly_name=batte ry, icon=mdi:refresh @ 2016-08-17T21:07:13.178206+02:00>> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=script , service=battery> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=script , service=turn_on> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=script , service=turn_off> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=script , service=toggle> INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=scrip t> ERROR:homeassistant.bootstrap:Invalid config for [automation]: required key not provided @ data['action']. Got None required key not provided @ data['trigger']. Got None INFO:homeassistant.core:Starting Home Assistant (17 threads) INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]> INFO:homeassistant.core:Timer:starting INFO:mysensors.mysensors:Trying to connect to COM4 INFO:mysensors.mysensors:COM4 is open... INFO:mysensors.mysensors:Connected to COM4 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, dist ance=0 INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas sistant, service=stop> INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeas sistant, service=restart> INFO:homeassistant.components.http:Serving /api/stream to 192.168.1.1 (auth: Tru e) INFO:homeassistant.components.http:Serving /api/camera_proxy/camera.london_road to 192.168.1.1 (auth: True) INFO:homeassistant.components.http:Serving /api/bootstrap to 192.168.1.1 (auth: True) INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 62.255.244.49 INFO:homeassistant.components.http:Serving /api/camera_proxy/camera.london_road to 192.168.1.1 (auth: True) INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 62.255.244.49 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=1,c=1,t=0,pt=7,l=5,sg =0:28.4 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-16-0 s=1,c=1,t=0,pt=7,l=5,sg= 0:29.8 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-16-0 s=0,c=1,t=1,pt=7,l=5,sg= 0:37.6 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=3,t=15,pt=2,l=2 ,sg=0:0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=0,t=17,pt=0,l=5 ,sg=0:1.5.4 INFO:homeassistant.components.mysensors:No sketch_name: node 55 INFO:homeassistant.components.mysensors:No sketch_name: node 55 INFO:homeassistant.components.mysensors:No sketch_name: node 55 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=3,t=6,pt=1,l=1, sg=0:0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-55-55 s=255,c=3,t=6,pt=0,l= 1,sg=0,st=ok:M INFO:homeassistant.components.http:Serving /api/camera_proxy/camera.london_road to 192.168.1.1 (auth: True) INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 62.255.244.49 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=3,t=11,pt=0,l=5 ,sg=0:Relay INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=255,c=3,t=12,pt=0,l=3 ,sg=0:1.0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=4,c=0,t=3,pt=0,l=0,sg =0: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 55-55-0 s=4,c=1,t=2,pt=0,l=3,sg =0:0.0 INFO:homeassistant.components.http:Serving /api/camera_proxy/camera.london_road to 192.168.1.1 (auth: True) INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 62.255.244.49 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=0,t=18,pt=0,l=5 ,sg=0:1.5.1 INFO:homeassistant.components.mysensors:No sketch_name: node 16 INFO:homeassistant.components.mysensors:No sketch_name: node 16 INFO:homeassistant.components.mysensors:No sketch_name: node 16 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=3,t=6,pt=1,l=1, sg=0:0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-16-16 s=255,c=3,t=6,pt=0,l= 1,sg=0,st=ok:M INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=3,c=1,t=18,pt=7,l=5,sg= 0:73094056.0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 3-16-0 s=0,c=1,t=1,pt=7,l=5,sg= 0:51.8 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=4,c=1,t=18,pt=7,l=5,sg= 0:49055452.0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=5,c=1,t=39,pt=7,l=5,sg= 0:0.0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=6,c=1,t=39,pt=7,l=5,sg= 0:0.0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0 :86.9 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=7,c=1,t=39,pt=7,l=5,sg= 0:5.0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 7-2-0 s=2,c=1,t=2,pt=7,l=5,sg=0 :0.0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=3,t=11,pt=0,l=1 1,sg=0:Sonde Salon INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=3,t=12,pt=0,l=3 ,sg=0:1.0 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=0,c=0,t=7,pt=0,l=8,sg =0:Humidite INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=1,c=0,t=6,pt=0,l=11,s g=0:Temperature INFO:homeassistant.components.http:Serving /api/camera_proxy/camera.london_road to 192.168.1.1 (auth: True) INFO:requests.packages.urllib3.connectionpool:Starting new HTTP connection (1): 62.255.244.49 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=1,c=1,t=0,pt=7,l=5,sg =0:28.6 INFO:homeassistant.components.mysensors:Adding new devices: <Entity Sonde Salon 16 1: None> INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, en tity_id=sensor.sonde_salon_16_1, new_state=<state sensor.sonde_salon_16_1=unavai lable; friendly_name=Sonde Salon 16 1 @ 2016-08-17T21:07:48.412571+02:00>> INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state s ensor.sonde_salon_16_1=unavailable; friendly_name=Sonde Salon 16 1 @ 2016-08-17T 21:07:48.412571+02:00>, entity_id=sensor.sonde_salon_16_1, new_state=<state sens or.sonde_salon_16_1=28.6; node_id=16, unit_of_measurement=°C, child_id=1, batter y_level=0, device=COM4, V_TEMP=28.6, friendly_name=Sonde Salon 16 1 @ 2016-08-17 T21:07:48.412571+02:00>> INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=0,c=1,t=1,pt=7,l=5,sg =0:1.0 INFO:homeassistant.components.mysensors:Adding new devices: <Entity Sonde Salon 16 0: None> INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=None, en tity_id=sensor.sonde_salon_16_0, new_state=<state sensor.sonde_salon_16_0=unavai lable; friendly_name=Sonde Salon 16 0 @ 2016-08-17T21:07:50.412569+02:00>> INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state s ensor.sonde_salon_16_0=unavailable; friendly_name=Sonde Salon 16 0 @ 2016-08-17T 21:07:50.412569+02:00>, entity_id=sensor.sonde_salon_16_0, new_state=<state sens or.sonde_salon_16_0=1.0; node_id=16, friendly_name=Sonde Salon 16 0, child_id=0, battery_level=0, V_HUM=1.0, device=COM4, unit_of_measurement=% @ 2016-08-17T21: 07:50.443821+02:00>> INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 16-16-0 s=255,c=3,t=1,pt=0,l=0, sg=0: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-16-16 s=255,c=3,t=1,pt=0,l= 10,sg=0,st=ok:14714608 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 5-16-0 s=1,c=1,t=0,pt=7,l=5,sg= 0:29.6 INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 5-16-0 s=0,c=1,t=1,pt=7,l=5,sg= 0:27.1really, I don't know what's happen.
I think I've found it. The
switchplatform errors on loading:ERROR:homeassistant.bootstrap:Invalid config for [switch]: required key not provided @ data['platform']. Got NoneThe S_TYPE is 3 and V_TYPE is 2 of your child which maps to the switch platform in home assistant. The mysensors component will try to load the switch platform via discovery but if something else tries to config the same platform and fails, mysensors will also be affected in that platform.
Can you provide relevant excerpt from your config,
mysensorsandswitchentries? -
Haha, I think we ahve something.
My mysensor config ismysensors: gateways: - device: 'COM4' # persistence_file: 'mysensors.json' baud_rate: 115200 debug: true persistence: false version: '1.5' optimistic: 'true'and switch file is empty.... I don't see anything about that in homeassistant website...
What can I do? -
What do you mean switch file is empty? Have you split your config into different yaml files? If so you can't point to an empty file in your main config file. Remove unused entries from your config. You seem to have problems with other platforms also besides
switch. -
