  3. Domoticz
  4. Mysensors Ethernet GW w5100 problem
45 Posts 7 Posters 13.5k Views 7 Watching
    A Former User
    There seems to be a problem with mysensors 2.0 and the arduino IDE version 1.6.9 and1.6.10.
    On the arduino website you can download old versions of the IDE. Try version 1.6.8.
    • mrc-coreM
      mrc-coreM
      mrc-core
      Ok. problem with the arduino IDE fix, i can upload the code without errors thanks Jason37.
      But i still have the problem with the ethernet gateway no connecting to domoticz, same error, reconnecting.....
      • tlpeterT
        tlpeterT
        tlpeter
        Can you show the sketch?
        I succesfully connected a ENC28J60 gateway and connected fine.
        mrc-coreM 2 Replies Last reply
        • tlpeterT tlpeter
          mrc-coreM
          mrc-coreM
          mrc-core
          wrote on last edited by mrc-core
          @tlpeter
          I'm using the sketch that can be found on the test folder from the library 2.0.0
          #define MY_GATEWAY_W5100
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
            #define MY_SOFTSPI
          #ifndef MY_RF24_CE_PIN
            #define MY_RF24_CE_PIN 5
          #ifndef MY_RF24_CS_PIN
            #define MY_RF24_CS_PIN 6
          // Enable to UDP
          //#define MY_USE_UDP
          #define MY_IP_ADDRESS 10,8,1,201   // If this is disabled, DHCP is used to retrieve address
          #define MY_PORT 5003
          // Flash leds on rx/tx/err
          // Set blinking period
          // Enable inclusion mode
          //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
          #if defined(MY_USE_UDP)
            #include <EthernetUdp.h>
          #include <Ethernet.h>
          2016-08-18 11:45:08.681 MySensors: Can not connect to: 10.8.1.201:5003
          2016-08-18 11:45:08.681 TCP: Connection problem (Unable to connect to specified IP/Port)
          2016-08-18 11:45:08.681 TCP: Reconnecting in 30 seconds...
          2016-08-18 11:45:38.687 TCP: Reconnecting...
          AnticimexA 1 Reply Last reply
          • tlpeterT
            tlpeterT
            tlpeter
            Can you ping it?
            • mrc-coreM
              mrc-coreM
              mrc-core
              Yes i can, but i can see some lag on the ping today, on the last 2 days this was not happening....
              Pinging 10.8.1.201 with 32 bytes of data:
              Request timed out.
              Reply from 10.8.1.201: bytes=32 time<1ms TTL=128
              Request timed out.
              Reply from 10.8.1.201: bytes=32 time=1ms TTL=128
              Request timed out.
              Request timed out.
              Request timed out.
              • mrc-coreM
                mrc-coreM
                mrc-core
                Funny now the ping does not have any lag since i hade done a reeboot to the gateway
                • tlpeterT
                  tlpeterT
                  tlpeter
                  Can you still ping when it is disconnected? (IP conflict)
                  Maybe power related?
                  mrc-coreM 1 Reply Last reply
                  • mrc-coreM mrc-core
                    @tlpeter
                      #define MY_SOFTSPI
                    // Enable to UDP
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @mrc-core The sketches under the test folder in the mysensors git (the library) is intended for CI evaluations. They are not examples to be used on target.
                    • tlpeterT tlpeter
                      mrc-coreM
                      mrc-coreM
                      mrc-core
                      @tlpeter Have tryed no ip conflit thats ok
                      arduino ide debug i get this
                      0;255;3;0;9;TSP:MSG:READ 5-5-0 s=9,c=1,t=14,pt=2,l=2,sg=0:55
                      0;255;3;0;9;TSM:INIT
                      0;255;3;0;9;TSM:RADIO:OK
                      0;255;3;0;9;TSM:GW MODE
                      0;255;3;0;9;TSM:READY
                      IP: 10.8.1.201
                      • AnticimexA Anticimex
                        mrc-coreM
                        mrc-coreM
                        mrc-core
                        @Anticimex so i have to get my old code and remake it with the code from sensors 2.0.0
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @mrc-core Examples have moved to a different repo: https://github.com/mysensors/MySensorsArduinoExamples
                            mrc-coreM
                            mrc-coreM
                            mrc-core
                            @Anticimex Thanks going to see yhe examples and tried to fix this problem.
                            • mrc-coreM
                              mrc-coreM
                              mrc-core
                              I'm getting this error on IDE
                              :\Users\marco\Documents\Arduino\libraries\MySensors/MySensors.h:233:5: error: #error UDP mode is not available for ENC28J60
                              YveauxY mfalkviddM 2 Replies Last reply
                                @mrc-core I think the error is quite clear : you enabled UDP which is not supported in combination with ENC
                                  @mrc-core I found this comment in an old version of the code:
                                   #undef MY_USE_UDP // Will not fit (or compile) on ENC28J60
                                  So it seems the problem is what the message says, UDP doesn't work on ENC28J60.
                                  @hek might know more
                                    Yeah, had to reduce the ENC lib to a minimum to make it compile with MySensors. But it was a couple of years ago. Haven't got the bandwidth to test it now.
                                    • mrc-coreM
                                      mrc-coreM
                                      mrc-core
                                      How did tlpeter got it to work ?
                                      What can i do? Go back to the w5100? At this moment i dont have nothing working at home.
                                      • tlpeterT tlpeter
                                        mrc-coreM
                                        mrc-coreM
                                        mrc-core
                                        @tlpeter can you upload your working sketch
                                        • tlpeterT
                                          tlpeterT
                                          tlpeter
                                          Sure i can:
                                           * Version 1.0 - Henrik EKblad
                                           * LED purposes:
                                          // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
                                          #define MY_GATEWAY_ENC28J60
                                          // Gateway IP address
                                          #define MY_IP_ADDRESS 10,0,0,25
                                          #include <UIPEthernet.h>
                                            sendSketchInfo("Ethernet GW", "1,0");
