  3. Domoticz
  4. Mysensors Ethernet GW w5100 problem
45 Posts 7 Posters 13.5k Views 7 Watching
  • tlpeterT
    tlpeterT
    tlpeter
    Can you show the sketch?
    I succesfully connected a ENC28J60 gateway and connected fine.
    mrc-coreM 2 Replies Last reply
    • tlpeterT tlpeter
      mrc-coreM
      mrc-coreM
      mrc-core
      wrote on last edited by mrc-core
      @tlpeter
      I'm using the sketch that can be found on the test folder from the library 2.0.0
      #define MY_GATEWAY_W5100
      //#define MY_W5100_SPI_EN 4
      // radio on the same spi bus.
        #define MY_SOFTSPI
      #ifndef MY_RF24_CE_PIN
        #define MY_RF24_CE_PIN 5
      #ifndef MY_RF24_CS_PIN
        #define MY_RF24_CS_PIN 6
      // Enable to UDP
      //#define MY_USE_UDP
      #define MY_IP_ADDRESS 10,8,1,201   // If this is disabled, DHCP is used to retrieve address
      #define MY_PORT 5003
      // Flash leds on rx/tx/err
      // Set blinking period
      // Enable inclusion mode
      //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
      #if defined(MY_USE_UDP)
        #include <EthernetUdp.h>
      #include <Ethernet.h>
      2016-08-18 11:45:08.681 MySensors: Can not connect to: 10.8.1.201:5003
      2016-08-18 11:45:08.681 TCP: Connection problem (Unable to connect to specified IP/Port)
      2016-08-18 11:45:08.681 TCP: Reconnecting in 30 seconds...
      2016-08-18 11:45:38.687 TCP: Reconnecting...
      AnticimexA 1 Reply Last reply
      • tlpeterT
        tlpeterT
        tlpeter
        Can you ping it?
        • mrc-coreM
          mrc-coreM
          mrc-core
          Yes i can, but i can see some lag on the ping today, on the last 2 days this was not happening....
          Pinging 10.8.1.201 with 32 bytes of data:
          Request timed out.
          Reply from 10.8.1.201: bytes=32 time<1ms TTL=128
          Request timed out.
          Reply from 10.8.1.201: bytes=32 time=1ms TTL=128
          Request timed out.
          Request timed out.
          Request timed out.
          • mrc-coreM
            mrc-coreM
            mrc-core
            Funny now the ping does not have any lag since i hade done a reeboot to the gateway
            • tlpeterT
              tlpeterT
              tlpeter
              Can you still ping when it is disconnected? (IP conflict)
              Maybe power related?
              mrc-coreM 1 Reply Last reply
              • mrc-coreM mrc-core
                @tlpeter
                  #define MY_SOFTSPI
                // Enable to UDP
                AnticimexA
                AnticimexA
                Anticimex
                @mrc-core The sketches under the test folder in the mysensors git (the library) is intended for CI evaluations. They are not examples to be used on target.
                • tlpeterT tlpeter
                  mrc-coreM
                  mrc-coreM
                  mrc-core
                  @tlpeter Have tryed no ip conflit thats ok
                  arduino ide debug i get this
                  0;255;3;0;9;TSP:MSG:READ 5-5-0 s=9,c=1,t=14,pt=2,l=2,sg=0:55
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSM:RADIO:OK
                  0;255;3;0;9;TSM:GW MODE
                  0;255;3;0;9;TSM:READY
                  IP: 10.8.1.201
                  • AnticimexA Anticimex
                    mrc-coreM
                    mrc-coreM
                    mrc-core
                    @Anticimex so i have to get my old code and remake it with the code from sensors 2.0.0
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @mrc-core Examples have moved to a different repo: https://github.com/mysensors/MySensorsArduinoExamples
                        mrc-coreM
                        mrc-coreM
                        mrc-core
                        @Anticimex Thanks going to see yhe examples and tried to fix this problem.
                        • mrc-coreM
                          mrc-coreM
                          mrc-core
                          I'm getting this error on IDE
                          :\Users\marco\Documents\Arduino\libraries\MySensors/MySensors.h:233:5: error: #error UDP mode is not available for ENC28J60
                          YveauxY mfalkviddM 2 Replies Last reply
                            @mrc-core I think the error is quite clear : you enabled UDP which is not supported in combination with ENC
                              @mrc-core I found this comment in an old version of the code:
                               #undef MY_USE_UDP // Will not fit (or compile) on ENC28J60
                              So it seems the problem is what the message says, UDP doesn't work on ENC28J60.
                              @hek might know more
                                Yeah, had to reduce the ENC lib to a minimum to make it compile with MySensors. But it was a couple of years ago. Haven't got the bandwidth to test it now.
                                • mrc-coreM
                                  mrc-coreM
                                  mrc-core
                                  How did tlpeter got it to work ?
                                  What can i do? Go back to the w5100? At this moment i dont have nothing working at home.
                                  • tlpeterT tlpeter
                                    mrc-coreM
                                    mrc-coreM
                                    mrc-core
                                    @tlpeter can you upload your working sketch
                                    • tlpeterT
                                      tlpeterT
                                      tlpeter
                                      Sure i can:
                                       * Version 1.0 - Henrik EKblad
                                       * LED purposes:
                                      // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
                                      #define MY_GATEWAY_ENC28J60
                                      // Gateway IP address
                                      #define MY_IP_ADDRESS 10,0,0,25
                                      #include <UIPEthernet.h>
                                        sendSketchInfo("Ethernet GW", "1,0");
                                      • mrc-coreM
                                        mrc-coreM
                                        mrc-core
                                        Got a problem....
                                        In file included from C:\Users\marco\Documents\Arduino\gw\gw.ino:93:0:
                                        C:\Users\marco\Documents\Arduino\libraries\MySensors/MySensors.h:233:5: error: #error UDP mode is not available for ENC28J60
                                        Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                                        Using library UIPEthernet at version 1.04 in folder: C:\Users\marco\Documents\Arduino\libraries\UIPEthernet
                                        Using library MySensors at version 2.0.0 in folder: C:\Users\marco\Documents\Arduino\libraries\MySensors
                                        exit status 1
                                        Error compiling for board Arduino/Genuino Uno.
                                        • mfalkviddM
                                          #27
                                          I am able to compile tlpeter's sketch without problem:
                                          Sketch uses 28,142 bytes (91%) of program storage space. Maximum is 30,720 bytes.
                                          Global variables use 1,267 bytes (61%) of dynamic memory, leaving 781 bytes for local variables. Maximum is 2,048 bytes.
                                          @mrc-core did you modify tlpeter's sketch in some way?
