  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.5k Views 20 Watching
  • rsachocR rsachoc
    @LastSamurai I'm having a go as well at updating the .ino file with the different library, but I'm not a coder so I'm "having a hack" - if you have any luck could you post your code?
    L
    L
    LastSamurai
    wrote on last edited by LastSamurai
    #90
    @rsachoc Yes, I actually just tried it out and its working.
    Here is my code for now (just for testing):
    I basically just switched libraries
    by m26872, 20151109
    Changed by LastSamurai
    15052016
    #include <SparkFunHTU21D.h>
    #include <RunningAverage.h>
    //#define DEBUG
    #ifdef DEBUG
    #define NODE_ID 100             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
    #define CHILD_ID_TEMP 0
    #define CHILD_ID_HUM 1
    // #define SLEEP_TIME 15000 // 15s for DEBUG
    #define SLEEP_TIME 300000   // 5 min
    #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
    #define BATTERY_REPORT_CYCLE 2016   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
    #define VMIN 1900
    #define VMAX 3300
    #define AVERAGES 2
    int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
    int measureCount = 0;
    float lastTemperature = -100;
    int lastHumidity = -100;
    HTU21D humiditySensor;
      DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
      DEBUG_PRINT("Voltage: ");
      DEBUG_PRINT(readVcc());
      DEBUG_PRINTLN(" mV");
      delay(500);
      DEBUG_PRINTLN(" *C");
      gw.begin(NULL, NODE_ID);
      gw.sendSketchInfo("TempHumTest2", "1.0 17052016");
      gw.present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
      DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
      raHum.clear();
      humiditySensor.begin();
      measureCount ++;
      batteryReportCounter ++;
      bool forceTransmit = false;
      if (measureCount > FORCE_TRANSMIT_CYCLE) {
        forceTransmit = true;
      // Read and print internal temp
      float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
      DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
      // Check battery
      if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
        long batteryVolt = readVcc();
        DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
        uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
        DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
        batteryReportCounter = 0;
      gw.sleep(SLEEP_TIME);
    // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
    // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
    long readVcc() {
    // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
    double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
      unsigned int wADC;
      double t;
      // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
      ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
      ADCSRA |= _BV(ADEN);  // enable the ADC
      delay(20);            // wait for voltages to become stable.
      ADCSRA |= _BV(ADSC);  // Start the ADC
      while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
      wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
      t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
      return (t);   // The returned temperature in degrees Celcius.
     * Parameters
      bool tx = force;
      float temperature = humiditySensor.readTemperature();
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
        gw.send(msgTemp.set(temperature,1));
        measureCount = 0;
        DEBUG_PRINTLN("T sent!");
      int humidity = humiditySensor.readHumidity();
      raHum.addValue(humidity);
      if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
        gw.send(msgHum.set(humidity));
        lastHumidity = humidity;
        measureCount = 0;
        DEBUG_PRINTLN("H sent!");
    rsachocR 1 Reply Last reply
    • L LastSamurai
      by m26872, 20151109
      15052016
      //#define DEBUG
      #ifdef DEBUG
      #define VMIN 1900
      #define VMAX 3300
      #define AVERAGES 2
        delay(500);
        raHum.clear();
        measureCount ++;
        // Check battery
      long readVcc() {
        unsigned int wADC;
        double t;
       * Parameters
        bool tx = force;
          measureCount = 0;
          measureCount = 0;
      rsachocR
      rsachocR
      rsachoc
      @LastSamurai thanks, progress, I'm getting this now, which means it's working! Finally, a working node from a complete rookie like me!
      Serial started
      Voltage: 3389 mV
      Internal temp: 266.00 *C
      send: 100-100-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
      send: 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
      send: 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
      read: 0-0-100 s=255,c=3,t=15,pt=0,l=2,sg=0:
      sensor started, id=100, parent=0, distance=1
      send: 100-100-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,st=fail:TempHumTest2
      send: 100-100-0-0 s=255,c=3,t=12,pt=0,l=12,sg=0,st=fail:1.0 17052016
      send: 100-100-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
      send: 100-100-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=fail:
      Node and 2 children presented.
      T: 998.00
      TempDiff :1098.00
      send: 100-100-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:998.0
      T sent!
      H: 118
      HumDiff  :218.00
      send: 100-100-0-0 s=1,c=1,t=1,pt=2,l=2,sg=0,st=ok:118
      H sent!
      Battery voltage: 3359 mV
      Battery percent: 104 %
      send: 100-100-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:104
      I think that the readings are not accurate though, not sure why, but I'll have a go at figuring our why anyway!
      • rsachocR rsachoc
        Serial started
        Voltage: 3389 mV
        T: 998.00
        TempDiff :1098.00
        T sent!
        H: 118
        HumDiff  :218.00
        H sent!
        GertSandersG
        GertSandersG
        GertSanders
        @rsachoc
        Congrats !!!
        m26872M 1 Reply Last reply
        • GertSandersG GertSanders
          @rsachoc
          Congrats !!!
          m26872M
          m26872M
          m26872
          @GertSanders Thx a lot for your help! I had no clue about the HTU21D lib.
          • badmannenB
            badmannenB
            badmannen
            • siodS
              siodS
              siod
              so with the correct library there is no need to solder those 3 spots together!?
              still learning...
              • siodS siod
                GertSandersG
                GertSandersG
                GertSanders
                @siod
                The "spots" are there to connect the pullup resistors to the SDA and SCL lines. This is always needed, regardless of the library of the board onto which you connect the sensor board does not provide pullup resistors itself. On a minimal board like the one in this thread, this is not the case, so the pull up resistors are needed.
                • siodS
                  siodS
                  siod
                  wrote on last edited by siod
                  #97
                  ok, thanks for making it clear for me Gert!!
                  update:
                  finally found time to build my sensor and it seems to work fine, will do more testing but for now my results are:
                  7.5 uA when sleeping, 15,3 mA when working (every 15 minutes for about 2seconds, but I think my cheap multimeter gives bad readings on those spikes, I guess it´s only around 1 mA)
                  seems to be okay, isn´t it?
                  edit:
                  I have 2 reed switches attached. I recognized that I have +0,10 mA for each reed switch when activated. So when reed switches are both touching their counterpart I have a sleeping consumption of 0,20 mA. Why is that??
                  still learning...
                  • J
                    J
                    jacikaas
                    wrote on last edited by jacikaas
                    #98
                    I'm trying to convert existing Si7021 sensor code from 1.5 to 2.0.0 library. I change the code and then I was getting an error which said:
                    Si7021_sensor_MySensors_2.0.0:158: error: 'si7021_env' has no member named 'humidityPercent'
                    exit status 1
                    Then I chech the Si7021 library, and how I saw there wasn't member 'humidityPercent', but there was a member 'humidityBasisPoints'.
                    So I change line from:
                    ...to:
                      int humidity = data.humidityBasisPoints;
                    Then code compiles and I upload it to Slim Node Si7021. I leave sensor and today I checked it log on Domoticz. I have this:
                    Temperature looks ok, but Humidity value jumping a lot, thats why I don't want to believe it is true.
                    Could someone, who has a 2.0.0 library and Si7021 sensor chech is it same situation? Becose I have only one Si7021 sensor.
                    Maybe someone could look also on the code and say if I convert it right?
                    Converted code:
                    by m26872, 20151109
                    #define MY_NODE_ID 5             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                    #define MY_BAUD_RATE 115200
                    #include <SI7021.h>
                    //#define DEBUG
                    #ifdef DEBUG
                    #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                    #define VMIN 1900
                    #define VMAX 3300
                    #define AVERAGES 2
                    SI7021 humiditySensor;
                      sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
                      DEBUG_SERIAL(115200);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                      delay(500);
                      raHum.clear();
                      measureCount ++;
                      // Check battery
                      sleep(SLEEP_TIME);
                    long readVcc() {
                      unsigned int wADC;
                      double t;
                     * Parameters
                      bool tx = force;
                      float temperature = data.celsiusHundredths / 100.0;
                        measureCount = 0;
                        measureCount = 0;
                    Thank You!
                    AWIA 1 Reply Last reply
                    • J jacikaas
                      exit status 1
                      ...to:
                      Converted code:
                      by m26872, 20151109
                      #include <SI7021.h>
                      //#define DEBUG
                      #ifdef DEBUG
                      #define VMIN 1900
                      #define VMAX 3300
                      #define AVERAGES 2
                        delay(500);
                        raHum.clear();
                        measureCount ++;
                        // Check battery
                        sleep(SLEEP_TIME);
                      long readVcc() {
                        unsigned int wADC;
                        double t;
                       * Parameters
                        bool tx = force;
                          measureCount = 0;
                          measureCount = 0;
                      Thank You!
                      AWIA
                      AWIA
                      AWI
                      @jacikaas where did you get the si7021 library? Take a look at the sensebender sketch for a good reference.
                      J 1 Reply Last reply
                      • AWIA AWI
                        J
                        J
                        jacikaas
                        @AWI
                        I download Si7021 library from here: https://github.com/LowPowerLab/SI7021
                        I was heard about Sensbender node, but never look deeper what is in it. I will look at it and try to understand whats in there. I just learning about all that stuff, so it will be good practice :blush:
                        • J jacikaas
                          @AWI
                          AWIA
                          AWIA
                          AWI
                          @jacikaas that's the way to go. The sensebender sketch contains some rather nice best practices for low power. You best replace the si library with the one in the MySensors examples on github.
                          • AWIA AWI
                            J
                            J
                            jacikaas
                            #102
                            @AWI I try to replace library from this one https://github.com/LowPowerLab/SI7021 to this one https://github.com/mysensors/MySensorsArduinoExamples
                            to work it I need to return variable name from:
                            to:
                            I think this library https://github.com/LowPowerLab/SI7021 was updated, so it is not suitable for this one code. Now I test it again and everything looks fine:
                            Temperature and humidity node unregister or stop working repeatedly for about 2 hours (2h25min, 2.20, 1.50...). But after that it start to send data again, for some time and then goes around again. :) I will try to understand why it happening too.
                            • W
                              W
                              wergeld
                              I am trying to build the code using the HTU21D sensors. This built fine under 1.4 and 1.5 but now under v2 of MySensors I am getting this error:
                              C:\Users\wergeld\Documents\Arduino\SlimNodeSi7021\SlimNodeSi7021.ino:4:24: fatal error: MySensor.h: No such file or directory
                              compilation terminated.
                              exit status 1
                              Error compiling for board APM Optiboot internal 1MHz noBOD 9600baud.
                              Okay, so I change my reference to:
                              And I get this lovely error:
                              In file included from C:\Users\wergeld\Documents\Arduino\SlimNodeSi7021\SlimNodeSi7021.ino:4:0:
                              C:\Users\wergeld\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                              exit status 1
                              So, other than slamming my head against my desk how can I solve this?
                              • W
                                W
                                wergeld
                                Well, I solved it by modifying the code to 2.0 spec. Good lord I need sleep. :anguished:
                                Working on debugging temp outputs now to Ethernet Gateway running on my Uno. Or I will sleep...
                                • W
                                  W
                                  wergeld
                                  Okay, I now have a soldered node and serial gateway setup to my laptop for testing. It presents the sensor node! The name and available sensors is correct. Howevr, it never sends any message payload with temp/hum or battery values. I am using the HTU21D without soldering those 3 pads on it together. I need to get myself a 3.3v FTDI cable so I can serially debug I guess. But, still! Progress.
                                  • W
                                    W
                                    wergeld
                                    After soldering the 3 pads on the HTU21D I am now reading data and it is being sent to my test serial gateway. Need to measure current usage but at least it is functional.
                                    • W
                                      W
                                      wergeld
                                      Okay, seeing something odd. The force transmit does not appear to be working.
                                      Here is my current sketch:
                                      #include <MyConfig.h>
                                      by m26872, 20151109
                                      //#include <MySensors.h>
                                      //#define DEBUG
                                      #ifdef DEBUG
                                      #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                                      #define VMIN 1900
                                      #define VMAX 3300
                                      #define AVERAGES 2
                                      //MySensor gw;
                                        sendSketchInfo("HTU21D", "1.0");
                                        delay(500);
                                        //gw.begin(NULL,NODE_ID);
                                        //sendSketchInfo("HTU21D", "1.0");
                                        //present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
                                        //present(CHILD_ID_HUM, S_HUM);
                                        raHum.clear();
                                        measureCount ++;
                                        // Check battery
                                        sleep(SLEEP_TIME);
                                      long readVcc() {
                                        unsigned int wADC;
                                        double t;
                                       * Parameters
                                        bool tx = force;
                                          measureCount = 0;
                                          measureCount = 0;
                                      I am at 1+ hours since last transmission.
                                      • W wergeld
                                        by m26872, 20151109
                                        //#define DEBUG
                                        #ifdef DEBUG
                                        #define VMIN 1900
                                        #define VMAX 3300
                                        #define AVERAGES 2
                                        //MySensor gw;
                                          delay(500);
                                          raHum.clear();
                                          measureCount ++;
                                          // Check battery
                                          sleep(SLEEP_TIME);
                                        long readVcc() {
                                          unsigned int wADC;
                                          double t;
                                         * Parameters
                                          bool tx = force;
                                            measureCount = 0;
                                            measureCount = 0;
                                        m26872M
                                        m26872M
                                        m26872
                                        @wergeld It looks like it's set to 3 hrs.
                                        W 1 Reply Last reply
                                        • m26872M m26872
                                          W
                                          W
                                          wergeld
                                          @m26872
                                          Indeed it does. Just was throwing me off with the wording. I read it as "1/2 hour" or "1/3 hour". So far I am prepping up more nodes. Have 4 more 328s to programs and build out. I am thinking at the end I will have:
                                          1. Gateway (serial or the direct connect nrf+ once it supports v2)
                                          2. Temp/Hum node using HTU21D for back porch sending every 5 minutes and force send every 30 minutes.
                                          3. Temp/Hum node using HTU21D inside using same send times.
                                          4. Parking sensor in garage hardwired to mains.
                                            5 & 6 I am not sure yet.
                                          Lots of fun so far.
