  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.8k Views 1 Watching
  • tekkaT tekka
    @karl261 hmm...indeed, that's weird. Do you have the debug log of node 3?
    karl261K
    karl261K
    karl261
    @tekka Which log exactly? Node 3 is Mysensors 1.5... It is sitting somewhere hidden...
    tekkaT 1 Reply Last reply
    • karl261K karl261
      tekkaT
      tekkaT
      tekka
      wrote on last edited by tekka
      #24
      @karl261 But you wrote:
      Btw, all is on 2.0.0.
      mixed setups are not advisable (and not supported). Please update if possible.
      karl261K 1 Reply Last reply
      • tekkaT tekka
        karl261K
        karl261K
        karl261
        @tekka Yes, with "all" I meant those being involved in the repeater stuff.
        • karl261K karl261
          tekkaT
          tekkaT
          tekka
          @karl261 Can you add this to node 4 (this is the relayed one?):
          #define MY_PARENT_NODE_ID 99
          karl261K 2 Replies Last reply
          • tekkaT tekka
            karl261K
            karl261K
            karl261
            wrote on last edited by karl261
            #27
            @tekka I can add it to node 30 right now. It is also supposed to be relayed. In fact this is why I did start this thread in the first place, I had no luck with these two lines. Will try again.
            Oooohhh, there is a mistake further up: I am talking about node 30, and wrote node 3. That is incorrect. Let's see if I can edit. That is why you were asking about the 1.5...
            • tekkaT tekka
              karl261K
              karl261K
              karl261
              #28
              @tekka Node 30 does still not care about the two lines. It is sending direct.
              It also does not send back any routing table. Maybe because it is sleeping most of the time?
              • karl261K karl261
                tekkaT
                tekkaT
                tekka
                @karl261 If it's not defined as repeater, it won't have a routing table. And yes, sleeping nodes do not listen for incoming traffic. But still, if GW and node 99 are up, it should prefer 99 - can you show me the log of node 30 during booting?
                • tekkaT tekka
                  karl261K
                  karl261K
                  karl261
                  #30
                  @tekka Now it seems to work.
                  But I recompiled, because I had MY_DEBUG commented out. Somehow there is something wrong with debug...
                  TSM:INIT
                  TSM:RADIO:OK
                  TSP:ASSIGNID:OK (ID=30)
                  TSM:FPAR
                  TSP:MSG:SEND 30-30-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSP:MSG:READ 3-3-30 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                  TSP:MSG:FPAR RES (ID=3, dist=1)
                  TSP:MSG:PAR OK (ID=3, dist=2)
                  TSP:MSG:READ 99-99-30 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                  TSP:MSG:FPAR RES (ID=99, dist=1)
                  TSP:MSG:FPAR (PPAR FOUND)
                  TSP:MSG:PAR OK (ID=99, dist=2)
                  TSM:FPAR:OK
                  TSM:ID
                  TSM:CHKID:OK (ID=30)
                  TSM:UPL
                  TSP:PING:SEND (dest=0)
                  TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                  TSP:MSG:READ 0-0-30 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  TSP:MSG:READ 0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0:2
                  TSP:MSG:PONG RECV (hops=2)
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  Serial started
                  Voltage: 3289 mV
                  TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                  TSP:MSG:SEND 30-30-99-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                  TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:99
                  TSP:MSG:READ 0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=ok:EgTmpHumBat5min
                  TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0,ft=0,st=ok:1.0 151106
                  TSP:MSG:SEND 30-30-99-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                  TSP:MSG:SEND 30-30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                  Node and 2 children presented.
                  Request registration...
                  TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                  TSP:MSG:READ 0-99-30 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  Node registration=1
                  Init complete, id=30, parent=99, distance=2, registration=1
                  T: 21.59
                  TempDiff :121.59
                  TSP:MSG:SEND 30-30-99-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.6
                  T sent!
                  H: 81
                  HumDiff  :181.00
                  TSP:MSG:SEND 30-30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=ok:81
                  H sent!
                  Battery voltage: 3279 mV
                  Battery percent: 98 %
                  TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:98
                  T: 21.61
                  TempDiff :0.02
                  H: 81
                  HumDiff  :0.00
                  • karl261K karl261
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:UPL
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    Serial started
                    Voltage: 3289 mV
                    Node registration=1
                    T: 21.59
                    TempDiff :121.59
                    T sent!
                    H: 81
                    HumDiff  :181.00
                    H sent!
                    T: 21.61
                    TempDiff :0.02
                    H: 81
                    HumDiff  :0.00
                    tekkaT
                    tekkaT
                    tekka
                    You mean, if MY_DEBUG is commented out, the node does not communicate over the repeater (99)?
                    • tekkaT tekka
                      karl261K
                      karl261K
                      karl261
                      @tekka Well, yes, I added the two lines you suggested, re-compiled, and then it was not using the 99. And also some posts above, I had these weird messages transmitted 6-7 times, see logs. This happend while MY_DEBUG was commented out.
                      Hm, I can re-upload the sketch and see if this is reproducible.
                      • karl261K karl261
                        tekkaT
                        tekkaT
                        tekka
                        @karl261 Yes, that would be good - node 30 is running@1Mhz?
                        karl261K 3 Replies Last reply
                        • tekkaT tekka
                          karl261K
                          karl261K
                          karl261
                          @tekka Yes, @1 MHz.
                          • tekkaT tekka
                            karl261K
                            karl261K
                            karl261
                            @tekka No, it seems to work as expected. Any idea why I am getting this "fail" line?
                            23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:READ 30-30-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                            23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:BC
                            23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=30)
                            23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:CHKUPL:OK
                            23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:GWL OK
                            23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-30-30 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                            23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                            23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=99, hops=1)
                            23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                            23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
                            23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
                            23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            23.08.2016 00:30:35	RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0:99
                            23.08.2016 00:30:35	RX	30;255;3;0;6;99
                            23.08.2016 00:30:35	TX	30;255;3;0;6;M
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=ok:M
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0:1.0 151106
                            23.08.2016 00:30:35	RX	30;255;3;0;12;1.0 151106
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
                            23.08.2016 00:30:35	RX	30;1;0;0;7;
                            23.08.2016 00:30:35	DEBUG	Update child id=1, type=S_HUM
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.3
                            23.08.2016 00:30:35	RX	30;0;1;0;0;24.3
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:73
                            23.08.2016 00:30:35	RX	30;1;1;0;1;73
                            23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=0,pt=1,l=1,sg=0:91
                            23.08.2016 00:30:35	RX	30;255;3;0;0;91
                            • karl261K karl261
                              tekkaT
                              tekkaT
                              tekka
                              #36
                              @karl261 Does it fail regularly?
                              • tekkaT tekka
                                karl261K
                                karl261K
                                karl261
                                #37
                                @tekka yes, these fails come and go, I see them all the time, but not at the same place necessarily. The logs posted above show plenty of them.
                                I don't understand this radio trouble.,the distances between the nodes are not long. The radios are all connected using all tricks, the relay is a nrf24+pa+lna which is located in a good location... Maybe all radios are crap? There is only one wifi network and it is not very busy... It's my own. Maybe I should change the channel? 110 or so sounds good. I am using default now. Power is set to max for all nodes, the nrf24+pa+lna is shielded from itself, I put small antenna extensions on the normal ones after @petewill, they all have nice caps, gw and repeater have excellent power sources, ...
                                I found a script how to test nrf radios... Maybe I should try that?
                                If I was going to buy new radios, just to try, which ones are the best???
                                Edit: Hm, I think if I use antennas, it really helps if they all point into the same direction. Like all horizontal or all vertical. Which would make sens, wouldn't it?
                                • tekkaT tekka
                                  karl261K
                                  karl261K
                                  karl261
                                  @tekka But now I found something: the repeater sketch does not work, if MY_DEBUG is commented out. I tried several times forth and back. On the gw I get the output below.
                                  0;255;3;0;9;TSP:MSG:READ 99-99-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                  0;255;3;0;9;TSP:MSG:FPAR REQ (sender=99)
                                  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                                  tekkaT karl261K 2 Replies Last reply
                                  • karl261K karl261
                                    tekkaT
                                    tekkaT
                                    tekka
                                    #39
                                    @karl261 That's weird - I've just tested that scenario and everything is fine here.
                                    Can you add an indicator in loop() to make sure the repeater sketch is running? Also, what board are you using as repeater and how do you power it?
                                    • tekkaT tekka
                                      karl261K
                                      karl261K
                                      karl261
                                      @tekka I will try this a bit later, thanks.
                                      Right now I am going crazy, the node is again not using the defined parent. Did I overlook something in the sketch?
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSP:ASSIGNID:OK (ID=4)
                                      TSM:FPAR
                                      TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                      TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      TSP:MSG:PAR OK (ID=0, dist=1)
                                      TSM:FPAR:OK
                                      TSM:ID
                                      TSM:CHKID:OK (ID=4)
                                      TSM:UPL
                                      TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                      TSP:MSG:READ 0-0-4 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      TSP:MSG:PONG RECV (hops=1)
                                      TSP:CHKUPL:OK
                                      TSM:UPL:OK
                                      TSM:READY
                                      BME init success!
                                      TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                      TSP:MSG:SEND 4-4-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                      TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                      TSP:MSG:READ 0-0-4 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:OUTSIDE P&T&H
                                      TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.2
                                      TSP:MSG:SEND 4-4-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSP:MSG:SEND 4-4-0-0 s=2,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSP:MSG:SEND 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                                      TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                      TSP:MSG:READ 0-0-4 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      Node registration=1
                                      Init complete, id=4, parent=0, distance=1, registration=1
                                      TSP:MSG:SEND 4-4-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:24.7
                                      TSP:MSG:SEND 4-4-0-0 s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=ok:57
                                      TSP:MSG:SEND 4-4-0-0 s=2,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=ok:1012.9
                                      TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:115
                                      by m26872, 20151109
                                      #define MY_NODE_ID 4
                                      #define MY_BAUD_RATE 9600
                                      #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
                                      #include <RunningAverage.h>
                                      #include <SparkFunBME280.h>
                                      //#define DEBUG   // local debug
                                      #ifdef DEBUG
                                      // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                                      #define CHILD_ID_HUM 0
                                      #define CHILD_ID_TEMP 1
                                      #define CHILD_ID_PRES 2
                                       #define SLEEP_TIME 15000 // 15s for DEBUG
                                      //#define SLEEP_TIME 300000   // 5 min
                                      #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                                      #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                                      #define VMIN 1900
                                      #define VMAX 3300
                                      #define PRES_TRANSMIT_THRESHOLD 1.0
                                      #define AVERAGES 2
                                      int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                                      int measureCount = 0;
                                      float lastTemperature = -100;
                                      float lastPressure = -100;
                                      int lastHumidity = -100;
                                      //SI7021 humiditySensor;
                                      BME280 mySensor;
                                      // MyMessage to controler
                                      MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
                                        sendSketchInfo("OUTSIDE P&T&H", "1.2");
                                        present(CHILD_ID_PRES, S_BARO);
                                        present(CHILD_ID_HUM, S_HUM);
                                        DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
                                        DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                                        DEBUG_PRINT("Voltage: ");
                                        DEBUG_PRINT(readVcc());
                                        DEBUG_PRINTLN(" mV");
                                        delay(500);
                                        DEBUG_PRINTLN(" *C");
                                        mySensor.settings.commInterface = I2C_MODE;
                                        mySensor.settings.I2CAddress = 0x77;
                                        //runMode can be:
                                        //  0, Sleep mode
                                        //  1 or 2, Forced mode
                                        //  3, Normal mode
                                        mySensor.settings.runMode = 1;
                                        mySensor.settings.filter = 0;
                                        mySensor.settings.tempOverSample = 1;
                                        mySensor.settings.pressOverSample = 1;
                                        mySensor.settings.humidOverSample = 1;
                                        if (!mySensor.begin())
                                          Serial.println("BME init failed!");
                                          while (1);
                                        else Serial.println("BME init success!");
                                        raHum.clear();
                                        measureCount ++;
                                        batteryReportCounter ++;
                                        bool forceTransmit = false;
                                        if (measureCount > FORCE_TRANSMIT_CYCLE) {
                                          forceTransmit = true;
                                        mySensor.begin();
                                        // Read and print internal temp
                                        float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                                        DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                                        // Check battery
                                        if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                                          long batteryVolt = readVcc();
                                          DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                                          uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                                          DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                                          batteryReportCounter = 0;
                                        sleep(SLEEP_TIME);
                                      //if(isTransportOK()){
                                      //    sleep(SLEEP_TIME);  // transport is OK, node can sleep
                                      //  else {
                                      //    wait(5000); // transport is not operational, allow the transport layer to fix this
                                      // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                                      // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                                      long readVcc() {
                                        result = 1134738L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                                      // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                                      double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                                        unsigned int wADC;
                                        double t;
                                        // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                                        ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                                        ADCSRA |= _BV(ADEN);  // enable the ADC
                                        delay(20);            // wait for voltages to become stable.
                                        ADCSRA |= _BV(ADSC);  // Start the ADC
                                        while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                                        wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                                        t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                                        return (t);   // The returned temperature in degrees Celcius.
                                       * Parameters
                                        bool tx = force;
                                        float temperature = mySensor.readTempC();
                                        if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                                          send(msgTemp.set(temperature,1));
                                          measureCount = 0;
                                          DEBUG_PRINTLN("T sent!");
                                        int humidity = mySensor.readFloatHumidity();
                                        raHum.addValue(humidity);
                                        if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                                          send(msgHum.set(humidity));
                                          lastHumidity = humidity;
                                          measureCount = 0;
                                          DEBUG_PRINTLN("H sent!");
                                        float pressure = mySensor.readFloatPressure()/100.0;
                                        DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
                                        float diffPress = abs(lastPressure - pressure);
                                        DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
                                        if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
                                          send(msgPres.set(pressure,1));
                                          lastPressure = pressure;
                                          measureCount = 0;
                                          DEBUG_PRINTLN("P sent!");
                                      • karl261K
                                        karl261K
                                        karl261
                                        Total madness: I uploaded the same sketch again, and now it is using 99.
                                        Questions:
                                        1. Can I see in the log whether it "found" the parent or if it is using the parent I put into the sketch?
                                        2. Is it possible to avoid this transport failure counter? Like, when I put
                                          into my sketch I just want the node to send, whether it reaches the parent or not. Is that possible?
                                        • karl261K karl261
                                          karl261K
                                          karl261K
                                          karl261
                                          I checked and re-programmed the repeater. It seems that it has gone away. I can use my repeater without MY_DEBUG. I don't know what caused this, but the repeater is working now.
