  3. Upgrade Ethernet GW -> 1.4 (wiznet)
w5100unowiznet
18 Posts 4 Posters 7.9k Views 2 Watching
    mitekg
    After 1.4 release, i tryed ti upgrade my EthGW (Wiznet W5100) to 1.4 but got some problems
    latest version from git is not works for me (no blinks and eth communication with vera)
    but old dev version http://pastebin.com/6YFrs6HT works partly:
    blinks and inclusion starts and stops from vera interface (with old version), but no lib version and new devices shows in vera after that.
    p.s.: nrf communications works fine.
    Help plz.
    Thank you
    hekH 1 Reply Last reply
    • M mitekg
      Help plz.
      Thank you
      @mitekg
      I have a hard time verifying the ethernet code on 1.4 with W5100 right now. I've ordered both ethernet shield and module on Aug 18 but nothing has arrived. :(
      Recently did some re-work on the gateway-code in development-branch that I would like to verify with Vera. @Damne tested it successfully though (even though has no vera).
      https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/EthernetGateway
        mitekg
        @hek
        ive tried dev version. compilation error..
        • HoffanH
          HoffanH
          Hoffan
          Same for me.. Compilation Error :(
            Did you replace the whole MySensors-library folder?
              mitekg
              @hek Yes, MySensors-library was replaced
              • HoffanH
                HoffanH
                Hoffan
                I did not :)
                • HoffanH Hoffan
                  I did not :)
                  mitekg
                  @Hoffan compilation success?
                  Evrthing works?
                  IDE version
                  thx?
                  • HoffanH
                    HoffanH
                    Hoffan
                    The Develepment Version looks like working Good for me
                      mitekg
                      thx! ill try today.
                      And what about IDE 1.0.5. or 1.5.7?
                      HoffanH 1 Reply Last reply
                      • M mitekg
                        thx! ill try today.
                        HoffanH
                        HoffanH
                        Hoffan
                        @mitekg
                        1.5.7
                          mitekg
                          1.5.7 + latest dev version
                          lib,,...\EthernetGateway.ino
                          Compilation, . error:
                          Arduino: 1.5.7 (Windows 7), Board: "Arduino Nano, ATmega328"
                          In file included from EthernetGateway.ino:57:0:
                          GatewayUtil.h: In function 'void parseAndSend(MySensor, char*)':
                          GatewayUtil.h:187:31: error: 'mSetRequestAck' was not declared in this scope
                          mSetRequestAck(msg,ack?1:0);
                          In file included from EthernetGateway.ino:53:0:
                          C:\Users\Dima\Documents\Arduino\libraries\MySensors/MySensor.h:248:10: error: 'boolean MySensor::sendRoute(MyMessage&)' is protected
                          boolean sendRoute(MyMessage &message);
                          GatewayUtil.h:193:26: error: within this context
                          ok = gw.sendRoute(msg);
                          • M mitekg
                            @mitekg
                            You don't seem to have updated everything (in the library folder) or forgot to restart Arduino IDE afterwards.
                              mitekg
                              @hek
                              test it twice!
                              clean installation (unpack in new dir) of 1.5.6. + latest dev version from git.
                                @mitekg
                                mitekg
                                  mitekg
                                  @hek
                                  sorry!!
                                  Im stupid man! compiled :+1:
                                  Continue testing!
                                    mitekg
                                    @hek , @Hoffan everything is work properly on master version!
                                    thank to ALL!
                                    • J
                                      J
                                      jmmorgan
                                      I have a similar problem. I upgraded from 1.3 to 1.4 and my Wiznet gateway does not work. I can ping version 1.3 from my PC and it see the gateway. When I ping 1.4 from my PC it says that the destination address can not be found. I have downloaded the latest Ethernet gateway sketch, but it did not help. Has any other file change that could effect this.
                                      John
