  3. Connecting first node to new gateway - what am I missing?
14 Posts 6 Posters 7.3k Views 6 Watching
  • JonnyDev13J
    JonnyDev13J
    JonnyDev13
    @TheoL, you're absolutely right. I was just about to post about that. In the instructions about Connecting the Radio to your Arduino it mentions "Refer to the notes about using a regulator or a coupling-capacitor below." The "or" in there made me think I didn't need a capacitor since maybe the regulator took care of the problem or something. I added in a capacitor and the sensor is connecting to the gateway!
    Now the gateway is at least receiving messages and passing them on to MQTT. Unfortunately, the messages don't contain any numbers. There also seems to be something wrong on the sensor node side. I don't see any of the serial prints that should be showing the temperature readings in the serial monitor:
    Here's the sensor node serial output:
    !TSM:CHKID:FAIL (ID=255)
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSM:ID
    TSM:ID
    TSM:ID
    And here's some output from the gateway. (I'm not sure if they line up exactly.)
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
    0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    0;255;3;0;9;Sending message on topic: mygateway1-out/255/255/3/0/3
    0;255;3;0;9;TSP:SANCHK:OK
    0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    The mygateway1-out/255/255/3/0/3 topic is receiving blank messages.
    Is there a reference somewhere about what the output failure messages mean? I feel like I could look some of these things up myself if I knew where to look.
    TheoLT 1 Reply Last reply
    • JonnyDev13J JonnyDev13
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:ID
      TSM:ID
      TSM:ID
      TheoLT
      TheoLT
      TheoL
      wrote on last edited by TheoL
      @JonnyDev13 @JonnyDev13 One thing at a time.
      1. You can communicate. That's great to hear.
      I investigated your sketch. I don't see anything strange at the first glance. Maybe @mfalkvidd can help us with locating the reference, because I've seen him post that somewhere. I'd want to look them up myself, but have limited time at moment.
      What I find strange, is that your gateway is saying mygateway1-out/255/255/3/0/3 so I'd expected at least two or three MQTT messages in that topic...
      • TheoLT TheoL
        @TheoL reference to how to read the 2.0 output? In that case it is available in the usual place, https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/4
        I have not learned how to read the 2.0 debug output yet myself.
          TheoLT
          TheoLT
          TheoL
          @mfalkvidd That's the one. Thanx buddie!
          • LOSTL
            LOSTL
            LOST
            @JonnyDev13
            Do you have a controller connected to the MQTT server? My thought is (not being an expert at all) that your node does not get an ID from a controller, and set it locally to 255...
            If you don't have a controller that hands out id's to nodes, set the node_id in the node sketch.
            • LOSTL LOST
              @JonnyDev13
              TheoLT
              TheoLT
              TheoL
              @LOST Not 100% positive on this one. But I have always thought that the gateway is responsible for handing out node id's. The controller assigns his own internal ID. At least that's what Domoticz is doing in mine setup.
              Otherwise assigning a static Node id couldn't work...... I think
              tekkaT 1 Reply Last reply
              • TheoLT TheoL
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                @TheoL @LOST @JonnyDev13 The GW does not assign node IDs, either you set them locally using
                #define NODE_ID 10
                (to be placed before
                or your controller supports node ID assignments.
                This debug log indicates a node requesting an ID from the controller:
                TSM:ID
                If no ID assigned after a few retries, the node will emit an error:
                and re-initialise.
                • LOSTL
                  LOSTL
                  LOST
                  wrote on last edited by LOST
                  Off Topic:
                  As I said, I'm no expert at all, not even experienced in MySensors..but in https://www.mysensors.org/about/network it says: Each node is assigned a unique sensorId or address that is used for sending and receiving point-to-point messages. You can assign a static sensorId or let the controller automatically assign one to the sensor. AUTO-mode configures the sensor to request a sensorId from the controller and is the default option for all the examples that we provide. The sensor stores the assigned sensorId in its non-volatile memory to ensure the correct sensorId persists across power transitions.
                  • LOSTL
                    LOSTL
                    LOST
                    Ok, @tekka. Thanks.
                    • JonnyDev13J
                      JonnyDev13J
                      JonnyDev13
                      Ok, now we're cooking! @tekka, thanks for explaining some of the details that I was missing. I'm sure I read that before, but I guess I swapped "gateway" with "controller" in my head, assuming that the sensor node would be assigned an id by the gateway.
                      I placed the following in my sensor node's sketch:
                      #define MY_NODE_ID 2
                      This avoided any errors, but I still wasn't seeing the correct message come through MQTT.
                      Not sure if it was required, but I ended up having to add
                      #define MY_PARENT_NODE_ID 1
                      to the sensor node's sketch, and
                      #define MY_NODE_ID 1
                      to the gateway node's sketch. Once I did that, the temperature readings started showing up in MQTT!
                      Thanks for the help everybody. I still have quite a bit to learn, but getting a working sensor sending data all the way through the gateway to MQTT was the biggest hurdle to really making progress on implementing these. THANK YOU!
