  3. Can't get started
Can't get started
15 Posts 3 Posters 4.7k Views 3 Watching
  • LarsMachielsL
    LarsMachielsL
    LarsMachiels
    I am trying to get started with building the Mysensors Ethernet Gateway (Arduino Uno with W5100 shield). Whatever I try I do not get it to work due to zillions of compilation errors (files not found, etc.). Would it be possible to create a very simple step by step "build Ethernet gateway" including EXACT instructions which libraries to use and where to put them i.e. :
    STEP 1 : Download this and that file and put them in : "C:\PROGRAM FILES\ARDUINO\LIBRARIES"
    STEP 2: Download sketch this and that and put them in folder blablabla.
    ETC.
    Obviously the current instruction video's don't work. It is not that I am completely new to programming but all the contradictions dazzle me a bit.
    Thanks in advance!
    mfalkviddM Boots33B 2 Replies Last reply
    • LarsMachielsL LarsMachiels
      ETC.
      Thanks in advance!
      Hi @LarsMachiels, welcome to the MySensors community!
      Most video tutorials are for MySensors 1.x. MySensors 2 was released during the summer. All video and documentation is created by people like you and me, so the pace and quality is limited by how much time people like you and me are prepared to spend. That's why there aren't as many videos for MySensors 2.0 yet.
      Instructions for installing the library is available at https://www.mysensors.org/download/
      You can still install MySensors 1.5 and use the video tutorials, if your top priority is to get something working and you prefer to get started by watching video tutorials.
      MySensors 2.0 has several new features (see https://forum.mysensors.org/topic/4261/mysensors-2-0-0-released ) and going from MySensors 1.5 to 2 will require some changes, so if you want to learn the latest stuff from the start you should go with version 2. Version 2 is installed from the Arduino IDE using the Library Manager, which will put all files in the correct places automatically. You can then open the included example for the w5100 ethernet gateway and compile it.
        ETC.
        Thanks in advance!
        Boots33B
        Boots33B
        Boots33
        Hi @LarsMachiels
        As @mfalkvidd has said you are starting out with MySensors right in the changeover to V2 so there is understandably a lot of data still to be updated on the site.
        luckily for you the w5100 gateway is even easier to do on V2, no more changing settings in the config files etc.
        So the first thing you must do is remove the MySensors library you have installed as it does not appear to be in the right place and may conflict with the new install.
        Make sure your IDE is the one from arduino.cc and not from arduino.org
        You can then install the MySensors v2 library using the library manager with just a couple of mouse clicks. This will put everything in the right place. See instructions in this post.
        When the MySensors library is installed it also includes many of the example sketches as well. The w5100 gateway is also included. So you just need to open it from the IDE example menu .
        The sketch should work with your shield without much change needed. You will have to change the line that sets the ip address to the address you want.
        #define MY_IP_ADDRESS 192,168,178,66   // If this is disabled, DHCP is used to retrieve address
        The wiring for the radio etc will be the same as in the V1.5 w5100 guide
        Remember you no longer need to change any MySensors config files either.
        LarsMachielsL 1 Reply Last reply
        • LarsMachielsL
          LarsMachielsL
          LarsMachiels
          Hi Boots33,
          Thanks a lot for all the explanation! It looks very clear. Tonight I will try again. I might have the wrong Arduino compiler.
          Thanks again,
          Lars
          • Boots33B Boots33
            Hi @LarsMachiels
            LarsMachielsL
            LarsMachielsL
            LarsMachiels
            Hi @Boots33,
            I deleted all my Arduino files including the ones in the user\documents\ directory (I hate it when files are automatically installed there), downloaded the Arduino compiler from Arduino.cc compiled and uploaded the W5100 sketch. Everything seems to be working fine now. Also Ping says it is OK. Thanks again for your simple and clear instructions.
            The only thing I do not understand is why the Setup and Loop section are empty and I wonder how I can use the gateway itself with a simple sensor. If would like to first test it with my Homey before I start buying all kinds of sensors.
            Regards,
            Lars
            Boots33B 1 Reply Last reply
              Hi @Boots33,
              Regards,
              Lars
              Boots33B
              Boots33B
              Boots33
              Great news your MySensors journey has begun !
              That is the power of libraries. Once you have defined this as a gateway all the work is then handled by the MySensors library so it only needs us to set up a few parameters. You will use libraries for many of the sensors you build.
              Yes under V2 sensors can be added to the gateway but i have not done this so am not sure of the correct way. You can try the modified sketch below and see if it works. I have commented the changes I have added. This just adds a dummy sensor to the gateway sketch. You will have to change to your ip as well.
              I am sure someone will let us know how it is done if this is not correct and then we will both know . :)
               * Version 1.0 - Henrik EKblad
               * LED purposes:
              #define MY_GATEWAY_W5100
              //#define MY_W5100_SPI_EN 4
              // radio on the same spi bus.
                #define MY_SOFTSPI
              #ifndef MY_RF24_CE_PIN
                #define MY_RF24_CE_PIN 5
              #ifndef MY_RF24_CS_PIN
                #define MY_RF24_CS_PIN 6
              // Enable to UDP
              //#define MY_USE_UDP
              #define MY_PORT 5003
              // Flash leds on rx/tx/err
              // Set blinking period
              // Enable inclusion mode
              //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
              #if defined(MY_USE_UDP)
                #include <EthernetUdp.h>
              #include <Ethernet.h>
              /*--------------ADDED BY BOOTS-------------------*/
              #define CHILD_ID_LIGHT 0
              unsigned long WAIT_TIME = 10000; //  time between reads (in milliseconds)
              void presentation()  {
                sendSketchInfo("gateway sensor", "1.0");
                for (int i=0; i<20; i++) {
                 send(msg.set(i));
                 Serial.println(i);
                 wait(WAIT_TIME);
              • LarsMachielsL
                LarsMachielsL
                LarsMachiels
                Thanks for your sketch. I tried the sketch but unfortunately I could not connect the gateway to my Homey. So maybe it is not the sketch but something else. I ordered some Arduino stuff and will try again with separate sensor node.
                • Boots33B
                  Boots33B
                  Boots33
                  It could be my sketch, like I said i am not sure of what changes need to be made with sensors on the gateway. @mfalkvidd do you know the correct way to do this?
                  mfalkviddM LarsMachielsL 2 Replies Last reply
                  • Boots33B Boots33
                    @Boots33 sorry I haven't built any gateway with local sensors yet so I don't know how it works. It should "just" be a matter of merging the gateway example with a sensor example I think.
                    • Boots33B Boots33
                      LarsMachielsL
                      LarsMachielsL
                      LarsMachiels
                      Hi @Boots33 ,
                      Today I got my Arduino stuf in. I took a new Nano V3, uploaded a sensor sketch, connected the radio etc. but still no success. I activated the debugger and it turns out that the radio doesn't initialise (RADIO:FAIL or something like that). I checked all my connections several times but those were all OK. The radio was working fine on the gateway (Uno + W5100 shield) so I tried the sensor sketch on the UNO. Now the radio was OK. Also tried the gateway on my Mega but there I get the same radio problem. So it seems I need another UNO to make it hopefully work. Or maybe there is another way (Burn new bootloader maybe?).
                      All suggestions are welcome.
                      Greetings,
                      Lars
                        Hi @Boots33 ,
                        Greetings,
                        Lars
                        Boots33B
                        Boots33B
                        Boots33
                        @LarsMachiels Yes I think RADIO:FAIL is usually some sort of hardware problem like wiring etc. Maybe try using new wires in case one of them is faulty. The Mega uses different pins for spi I think 50,51,52 so you will need to define and use those pins for spi for the radio to work
                        • Boots33B Boots33
                          LarsMachielsL
                          LarsMachielsL
                          LarsMachiels
                          Finally I got at least something to work after a lot of trying and fiddling with Murphy next to my side. I found out that RADIO:OK doesn't necessarily mean the radio is actually working. Unfortunately automatically assigning an ID to the node didn't work, but with #define CHILD_ID 1 it was OK. I can see the node / gateway sending and receiving each others messages. When I comment #define MY_CONTROLLER_IP_ADDRESS the gateway keeps on initialising. I assume I need to use my controllers IP there. Can anybody explain me what this constant is for?
                          Even though I have been programming for more than 20 years I find it hard to get everything up and running but I will not rest before it is working fine. Next step will be to connect the Gateway to my Homey. So far thanks for all the help.
                            @LarsMachiels I found this in GatewayESP8266MQTTClient.ino:
                            // MQTT broker ip address.
                            #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
                            this is in MyConfig.h:
                            this in GatewayESP8266.ino
                            From GatewayW5100MQTTClient.ino
                            So it seems to be controlling where the gateway should be sending data. How it will be sending data depends on other parameters, it seems UDP and MQTT are supported at least.
                            The parameter is also mentioned on https://www.mysensors.org/download/sensor_api_20 but so far without details.
                            • LarsMachielsL
                              LarsMachielsL
                              LarsMachiels
                              Thanks @mfalkvidd. The thing is that I have a Homey controller which unfortunately does not see any sensors even though I have the GW send the data to the IP address of the controller (could be Homey app as well). When I let the gateway act as a server it keeps on restarting. Maybe this is due to the W5100 shield. When I disconnect the ethernet cable it starts normally. I will try another w5100 to see if the restarting problem will be solved. My modem does supply an IP and the GW is pingable in client mode.
                                Boots33B
                                Boots33B
                                Boots33
                                wrote on last edited by Boots33
                                @LarsMachiels There was a problem with some versions of the arduino ide that caused the rebooting. You may have to revert to an older version, I am using 1.6.9 and I have compiled the gateway without issue but some have had to go back to 1.6.7 See this post for more details.
