  2. Announcements
  3. 💬 Gas Sensor
💬 Gas Sensor
18 Posts 9 Posters 8.1k Views 9 Watching
    This thread contains comments for the article "Gas Sensor" posted on MySensors.org.
    • mrwombleM
      mrwombleM
      mrwomble
      Just a note for any Domoticz users who may try this sketch - it presents in the log, but is not available under 'Devices' to be added UNTIL it gets a reading > 0. My solution to that was to go put the node over the gas hob and let the gas run (unlit) for a few seconds so that it generated a reading :-D
      Remember kids, gas is dangerous, stay safe.
      • skywatchS
        skywatchS
        skywatch
        Where can I get chep MQ-138 sensor please?
          Have you looked at aliexpress?
          • skywatchS
            skywatchS
            skywatch
            HI Gohan,
            Yes I did, seems that they are very expensive wherever I look. I'll wait on this one ofr now.
            Thanks for the suggestion though :)
              I believe it is on the cheap side. These price ranges are mainly for hobbyist sensor. The real calibrated ones are usually way more expensive. The cheap ones are only good to measure trends, not for the actual value.
              • A
                APL2017
                Please advise what would be curve for MQ135 sensor for CO2. Thank you.
                • A APL2017
                  @apl2017 itsn't the curve in the datasheet linked on the build page sifficient?
                  • A
                    APL2017
                    Sure, the curve is there. I am trying to make sense out of two points curve that is used in sketch for MQ2 sensor, CO gas. "point1: (lg200, 0.72), point2: (lg10000, 0.15)" while I see on the curve from datasheet (lg200, 5.2) and (lg10000, 1.3). That is why I am asking for help, sorry for not making it clear.
                    • A
                      APL2017
                      Lack of support makes you think, so I figured out the "hidden" calculations in the sketch above and proposing the code modification to allow users to port the code to a different gas sensor using data taken directly from the sensor chart. Here are modified fragments of the code showing only CO curve for MQ2 sensor:
                      float CO2Curve[4] = {0.8,200,2.2,10};
                      //two end points are taken from the curve with two coordinates for each point
                      //in form of{Y1, X1,Y2, X2) where X is PPM axis, Y is Rs/Ro axis from the sensor chart for specifc gas
                      //then equation X=(Y-b)/m is used,
                      //where m is slope of the curve, b is Y axis intersept point
                      float Slope = (log(pcurve(1)-log(pcurve(0))/(log(pcurve(3)-log(pcurve(2));
                      float Y_Intercept=log(pcurve(1)-Slope*log(pcurve(3);
                      int MQGetPercentage(float rs_ro_ratio, float *pcurve)
                      { return (pow(10,((log(rs_ro_ratio)-Y_Intercept)/Slope))); }
                        I have found this sketch for MQ7 sensors
                        This code was developed by the_3d6 from Ultimate Robotics (http://ultimaterobotics.com.ua).
                        License: you can use it for any purpose as long as you don't claim that you are its author and
                        you don't alter License terms and formulations (lines 1-10 of this file).
                        You can share modifications of the code if you have properly tested their functionality,
                        including confirming correct sensor response on CO concentrations of 0-30ppm, 100-300ppm and 1000-10000ppm.
                        If you can improve this code, please do so!
                        You can contact me at aka.3d6@gmail.com
                        //WARNING! Each sensor is different!
                        //You MUST calibrate sensor manually and
                        //set proper sensor_reading_clean_air value before using
                        //it for any practical purpose!
                        int time_scale = 8; //time scale: we altered main system timer, so now all functions like millis(), delay() etc
                        					//will think that time moves 8 times faster than it really is
                        					//to correct that, we use time_scale variable:
                        					//in order to make delay for 1 second, now
                        					//we call delay(1000*time_scale)
                        void setTimer0PWM(byte chA, byte chB) //pins D5 and D6
                        	TCCR0A = 0b10110011; //OCA normal,OCB inverted, fast pwm
                        	TCCR0B = 0b010; //8 prescaler - instead of system's default 64 prescaler - thus time moves 8 times faster
                        	OCR0A = chA; //0..255
                        	OCR0B = chB;
                        void setTimer2PWM(byte chA, byte chB) //pins D11 and D3
                        	TCCR2A = 0b10100011; //OCA,OCB, fast pwm
                        	TCCR2B = 0b001; //no prescaler
                        	OCR2A = chA; //0..255
                        	OCR2B = chB;
                        void setTimer1PWM(int chA, int chB) //pins D9 and D10
                        	TCCR1A = 0b10100011; //OCA,OCB, fast pwm
                        	TCCR1B = 0b1001; //no prescaler
                        	OCR1A = chA; //0..1023
                        	OCR1B = chB;
                        float opt_voltage = 0;
                        byte opt_width = 240; //default reasonable value
                        void pwm_adjust()
                        //this function tries various PWM cycle widths and prints resulting
                        //voltage for each attempt, then selects best fitting one and
                        //this value is used in the program later
                        	float previous_v = 5.0; //voltage at previous attempt
                        	float raw2v = 5.0 / 1024.0;//coefficient to convert Arduino's
                        							   //analogRead result into voltage in volts
                        	for (int w = 0; w < 250; w++)
                        		setTimer2PWM(0, w);
                        		float avg_v = 0;
                        		for (int x = 0; x < 100; x++) //measure over about 100ms to ensure stable result
                        			avg_v += analogRead(A1);
                        			delay(time_scale);
                        		avg_v *= 0.01;
                        		avg_v *= raw2v;
                        		Serial.print("adjusting PWM w=");
                        		Serial.print(w);
                        		Serial.print(", V=");
                        		Serial.println(avg_v);
                        		if (avg_v < 3.6 && previous_v > 3.6) //we found optimal width
                        			float dnew = 3.6 - avg_v; //now we need to find if current one
                        			float dprev = previous_v - 3.6;//or previous one is better
                        			if (dnew < dprev) //if new one is closer to 1.4 then return it
                        				opt_voltage = avg_v;
                        				opt_width = w;
                        				return;
                        			else //else return previous one
                        				opt_voltage = previous_v;
                        				opt_width = w - 1;
                        				return;
                        		previous_v = avg_v;
                        float alarm_ppm_threshold = 100; //threshold CO concentration for buzzer alarm to be turned on,
                        float red_threshold = 40; //threshold when green LED is turned on red turns on
                        float reference_resistor_kOhm = 10.0; //fill correct resisor value if you are using not 10k reference
                        float sensor_reading_clean_air = 600; //fill raw sensor value at the end of measurement phase (before heating starts) in clean air here! That is critical for proper calculation
                        float sensor_reading_100_ppm_CO = -1; //if you can measure it
                        									  //using some CO meter or precisely calculated CO sample, then fill it here
                        									  //otherwise leave -1, default values will be used in this case
                        float sensor_100ppm_CO_resistance_kOhm; //calculated from sensor_reading_100_ppm_CO variable
                        float sensor_base_resistance_kOhm; //calculated from sensor_reading_clean_air variable
                        byte phase = 0; //1 - high voltage, 0 - low voltage, we start from measuring
                        unsigned long prev_ms = 0; //milliseconds in previous cycle
                        unsigned long sec10 = 0; //this timer is updated 10 times per second,
                        						 //when it will overflow, program might freeze or behave incorrectly.
                        						 //It will happen only after ~13 years of operation. Still,
                        						 //if you'll ever use this code in industrial application,
                        						 //please take care of overflow problem
                        unsigned long high_on = 0; //time when we started high temperature cycle
                        unsigned long low_on = 0; //time when we started low temperature cycle
                        unsigned long last_print = 0; //time when we last printed message in serial
                        float sens_val = 0; //current smoothed sensor value
                        float last_CO_ppm_measurement = 0; //CO concentration at the end of previous measurement cycle
                        float raw_value_to_CO_ppm(float value)
                        	if (value < 1) return -1; //wrong input value
                        	sensor_base_resistance_kOhm = reference_resistor_kOhm * 1023 / sensor_reading_clean_air - reference_resistor_kOhm;
                        	if (sensor_reading_100_ppm_CO > 0)
                        		sensor_100ppm_CO_resistance_kOhm = reference_resistor_kOhm * 1023 / sensor_reading_100_ppm_CO - reference_resistor_kOhm;
                        		sensor_100ppm_CO_resistance_kOhm = sensor_base_resistance_kOhm * 0.5;
                        		//This seems to contradict manufacturer's datasheet, but for my sensor it
                        		//looks quite real using CO concentration produced by CH4 flame according to
                        		//this paper: http://www.iafss.org/publications/fss/8/1013/view/fss_8-1013.pdf
                        		//my experiments were very rough though, so I could have overestimated CO concentration significantly
                        		//if you have calibrated sensor to produce reference 100 ppm CO, then
                        		//use it instead
                        	float sensor_R_kOhm = reference_resistor_kOhm * 1023 / value - reference_resistor_kOhm;
                        	float R_relation = sensor_100ppm_CO_resistance_kOhm / sensor_R_kOhm;
                        	float CO_ppm = 100 * (exp(R_relation) - 1.648);
                        	if (CO_ppm < 0) CO_ppm = 0;
                        	return CO_ppm;
                        void startMeasurementPhase()
                        	phase = 0;
                        	low_on = sec10;
                        	setTimer2PWM(0, opt_width);
                        void startHeatingPhase()
                        	phase = 1;
                        	high_on = sec10;
                        	setTimer2PWM(0, 255);
                        void setLEDs(int br_green, int br_red)
                        	if (br_red < 0) br_red = 0;
                        	if (br_red > 100) br_red = 100;
                        	if (br_green < 0) br_green = 0;
                        	if (br_green > 100) br_green = 100;
                        	float br = br_red;
                        	br *= 0.01;
                        	br = (exp(br) - 1) / 1.7183 * 1023.0;
                        	float bg = br_green;
                        	bg *= 0.01;
                        	bg = (exp(bg) - 1) / 1.7183 * 1023.0;
                        	if (br < 0) br = 0;
                        	if (br > 1023) br = 1023;
                        	if (bg < 0) bg = 0;
                        	if (bg > 1023) bg = 1023;
                        	setTimer1PWM(1023 - br, 1023 - bg);
                        void buzz_on()
                        	setTimer0PWM(128, 128);
                        void buzz_off()
                        	setTimer0PWM(255, 255);
                        void buzz_beep()
                        	byte sp = sec10 % 15;
                        	if (sp == 0)
                        		buzz_on();
                        	if (sp == 1)
                        		buzz_off();
                        	if (sp == 2)
                        		buzz_on();
                        	if (sp == 3)
                        		buzz_off();
                        	if (sp == 4)
                        		buzz_on();
                        	if (sp == 5)
                        		buzz_off();
                        	pinMode(5, OUTPUT);
                        	pinMode(6, OUTPUT);
                        	pinMode(3, OUTPUT);
                        	pinMode(9, OUTPUT);
                        	pinMode(10, OUTPUT);
                        	pinMode(A0, INPUT);
                        	pinMode(A1, INPUT);
                        	setTimer1PWM(1023, 0);
                        	analogReference(DEFAULT);
                        	pwm_adjust();
                        	Serial.print("PWM result: width ");
                        	Serial.print(opt_width);
                        	Serial.print(", voltage ");
                        	Serial.println(opt_voltage);
                        	Serial.println("Data output: raw A0 value, heating on/off (0.1 off 1000.1 on), CO ppm from last measurement cycle");
                        	//beep buzzer in the beginning to indicate that it works
                        	buzz_on();
                        	delay(100 * time_scale);
                        	buzz_off();
                        	buzz_on();
                        	buzz_off();
                        	buzz_on();
                        	buzz_off();
                        	startMeasurementPhase(); //start from measurement
                        	unsigned long ms = millis();
                        	int dt = ms - prev_ms;
                        	//this condition runs 10 times per second, even if millis()
                        	//overflows - which is required for long-term stability
                        	//when millis() overflows, this condition will run after less
                        	//than 0.1 seconds - but that's fine, since it happens only once
                        	//per several days
                        	if (dt > 100 * time_scale || dt < 0)
                        		prev_ms = ms; //store previous cycle time
                        		sec10++; //increase 0.1s counter
                        		if (sec10 % 10 == 1) //we want LEDs to blink periodically
                        			setTimer1PWM(1023, 1023); //blink LEDs once per second
                        									  //use %100 to blink once per 10 seconds, %2 to blink 5 times per second
                        		else //all other time we calculate LEDs and buzzer state
                        			int br_red = 0, br_green = 0; //brightness from 1 to 100, setLEDs function handles converting it into timer settings
                        			if (last_CO_ppm_measurement <= red_threshold) //turn green LED if we are below 30 PPM
                        			{//the brighter it is, the lower concentration is
                        				br_red = 0; //turn off red
                        				br_green = (red_threshold - last_CO_ppm_measurement)*100.0 / red_threshold; //the more negative is concentration, the higher is value
                        				if (br_green < 1) br_green = 1; //don't turn off completely
                        			else //if we are above threshold, turn on red one
                        				br_green = 0; //keep green off
                        				br_red = (last_CO_ppm_measurement - red_threshold)*100.0 / red_threshold; //the higher is concentration, the higher is this value
                        				if (br_red < 1) br_red = 1; //don't turn off completely
                        			if (last_CO_ppm_measurement > alarm_ppm_threshold) //if at 50 seconds of measurement cycle we are above threshold
                        				buzz_beep();
                        				buzz_off();
                        			setLEDs(br_green, br_red); //set LEDs brightness
                        	if (phase == 1 && sec10 - high_on > 600) //60 seconds of heating ended?
                        	if (phase == 0 && sec10 - low_on > 900) //90 seconds of measurement ended?
                        		last_CO_ppm_measurement = raw_value_to_CO_ppm(sens_val);
                        		startHeatingPhase();
                        	float v = analogRead(A0); //reading value
                        	sens_val *= 0.999; //applying exponential averaging using formula
                        	sens_val += 0.001*v; // average = old_average*a + (1-a)*new_reading
                        	if (sec10 - last_print > 9) //print measurement result into serial 2 times per second
                        		last_print = sec10;
                        		Serial.print(sens_val);
                        		Serial.print(" ");
                        		Serial.print(0.1 + phase * 1000);
                        		Serial.print(" ");
                        		Serial.println(last_CO_ppm_measurement);
                        from this guide http://www.instructables.com/id/Arduino-CO-Monitor-Using-MQ-7-Sensor/
                        I was wondering if it could be used on a MySensors node even with all those timers modifications
                        • B
                          B
                          borneo1910
                          Does anyone know if any of these sensors can be used to detect vaporized white mineral oil?
                            Vaporized oil is very messy, I don't think they would any good as it is not volatile
                            • B
                              B
                              borneo1910
                              Does it change things if it's actually atomized and not vaporized?
                                What I'm saying is that it is not a gas that dissolves in air, it is more particulate matter suspended in the air so an optical sensor is probably better given that the sensor could last as oil tends to stick to stuff
                                • U
                                  U
                                  user2684
                                  I spent the last few days trying to get a sense out of the black magic behind the calculations used for this sensor.
                                  I got the math now but still there is something I feel like it is not completely accurate with the current implementation.
                                  First of all the resulting ppm seems like a sort of normalized value; since I know e.g. CO2 ppm in clean air is around 400, the code seems not to take this into consideration. Also, configure it with a different MQ sensor doesn't seem an easy task.
                                  For these reasons I've tried starting from scratch, inspired by http://davidegironi.blogspot.com/2014/01/cheap-co2-meter-using-mq135-sensor-with.html#.WyLQo6qFNn5.
                                  Starting point is the power function y = a*x^b. The way to make the code more generic is to let the user provide the coordinates of two points (like @APL2017 was suggesting a while ago) which is an easy task and let the code solve the two equations and derive the values of a and b. Then, since ppm = a(rs/ro)^b, with a known value of ppm (e.g. the concentration in clear air of the gas, for co2 is 411), the equation can be solved for Ro by measuring Rs from the adc. Once a, b and Ro are known, the ppm comes naturally by solving again ppm = a(rs/ro)^b.
                                  I'm not sure this is better than the other methods but at least I get the same results from the blog above, both in terms of values of a, b and Ro as well as a real value of CO2 ppm measured with a MQ135.
                                  The downside of this of course is the difficulty to provide a known value of ppm for the calibration for other gas like e.g. Ch4, but if I claim I'm showing a ppm value, I want to be sure this is a real ppm :-)
                                  The code is here, within the dev branch of NodeManager, any feedback would be appreciated!
                                  https://github.com/user2684/NodeManager/blob/19e37a45792be4d698a1316bf6eb4f954a8455f5/NodeManagerLibrary.ino#L2441
                                  • F
                                    F
                                    FL74
                                    Hi all,
                                    which of the above sensors (listed in https://www.mysensors.org/build/gas) is the most suitable to detect a relevant leak of gasoline inside an engine bay?
                                      I'd say the ones with benzene
