  3. 💬 MDMSNode "Lighting"
nrf24l01rfm69arduinomysensorslight switchlightacdc
37 Posts 11 Posters 15.0k Views 10 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/249/MDMSNode-Lighting
    • Daniel OliveiraD
      Daniel OliveiraD
      Daniel Oliveira
      Can you please give a reference for the MDMS series devices? I'm not aware of it neither was able to find any reference in the forum. But I'm curious.
      MySensors rules my home :)
      kalinaK 1 Reply Last reply
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        Will it be possible to buy this pre-assembled?
        • Daniel OliveiraD Daniel Oliveira
          kalinaK
          kalinaK
          kalina
          @Daniel-Oliveira Hi,
          I can explain a little about this series.
          MDMSGate is my first device which I has developed and tested already and I will be ready to sale it in late September.
          https://www.openhardware.io/view/118/MDMSGATE
          The next device is MDMSNode "Lighting", it is currently under development. I am expecting arrivial of printed circuit boards for testing.
          After receiving the pcbs, I will solder and test MDMSNode "Lighting".
          Then I am going to develop several devices (powered by lithium battery) for measurement of temperature, pressure, humidity, etc. These devices will be called MDMSensor "Temperature", MDMSensor "Pressure" or MDMSensor "Humidity".
            kalinaK
            kalinaK
            kalina
            @Cliff-Karlsson
            Yes it is possible. I sell all of the devices that I have developed and tested.
            • kalinaK
              kalinaK
              kalina
              Hi everyone!
              I want to tell something about my project. Before I ordered a printed circuit board, I had made some improvements:
              • added LED for power supply indicating;
              • used two free pins of the microcontroller for connecting to SMD pads;
              • added two technological zones;
              • fixed errors in silkscreen layer.
              I have ordered 30 pcbs and, in my opinion, they will arrive in two weeks...
              • rubenverhoefR
                rubenverhoefR
                rubenverhoef
                Is it possible to dim the light with this device? (and also LED lights)
                • rubenverhoefR rubenverhoef
                  kalinaK
                  kalinaK
                  kalina
                  @rubenverhoef Unfortunately, it isn't possible. I got the task to control the lighting on the basis of fluorescent and LED lamps, where dimming is not provided. But if it becomes necessary, in the new version MDMSNode "Lighting" I might add it.
                  • KoreshK
                    KoreshK
                    Koresh
                    Nice project. I like high density placement :thumbsup:
                    But how this device will be cooled?
                    Bt137s dissipates a lot of power (see picture)
                    So it will dissipate 1W at 0.8A current. But Bt137s has 75K/W thermal resistance from junction to ambient (without heatsink).
                    This means a junction temperature will be ~100 celsius degrees if it lies on the table with connected less than 200W device. If we puts it inside a closed box... :fire: These is very rough estimation, but it pause for thought I think :)
                    PS
                    15mm height... You are cunning, at least 20mm :trollface:
                    • kalinaK
                      kalinaK
                      kalina
                      @Koresh Thank you for your detailed question and interest in my project. I will try to explain.
                      Firstly, as I wrote earlier, I design the device to control the LED and fluorescent lamps. The max power, which I hope to use, not more than 35-40 watts. Following this, the current through the triac should not exceed 0.2-0.3 A. So, the power dissipated in the triac will not exceed 0.5W.
                      Secondly, I created the special area on the pcb (as you can see in the picture, the polygons on the top and bottom sides + vias),
                      which provides heat distribution and dissipation.
                      Thirdly, the fuse have to provides safety. Value of fuse, if somebody wants, can be set 0.2A. Also, close to the triac I put a thermistor.
                      As soon as I get the pcbs and soldered, I’m going to test it carefully and I’ll share with the results.
                      And as about the size, you are right, it will be, at least, 20 mm.
                      • kalinaK
                        kalinaK
                        kalina
                        I have already received the pcbs. I am sharing a few photos. Please, pay attention to the edge connector for programming, it looks good and technologically)). In the near future, I am going to solder device and start it testing!
                        • kalinaK
                          kalinaK
                          kalina
                          First device is assembled and is under testing now... But i haven't diceded yet, which type of radios i wanna to use...
                          • kalinaK
                            kalinaK
                            kalina
                            Two variants of MDMSNode "Lighting"
                            Cliff KarlssonC 1 Reply Last reply
                            • kalinaK kalina
                              Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              @kalina
                              Can we buy it preassembled soon?
                                @kalina
                                kalinaK
                                kalinaK
                                kalina
                                @Cliff-Karlsson Yes, i have made 10 pcs. But if necessary i can solder more. Price for model with RFM69 is 23$ and with NRF24L01 is 20$...
                                • Cliff KarlssonC
                                  Cliff KarlssonC
                                  Cliff Karlsson
                                  Ok, great. Are there any progress on the MDMSensor "Multisensor" and gateway?
                                    kalinaK
                                    kalinaK
                                    kalina
                                    @Cliff-Karlsson Yes, gateway is ready, but MDMSensor "Multisensor" is still in progress...
                                    • tonnerre33T
                                      tonnerre33T
                                      tonnerre33
                                      Hello
                                      Why do you use a triac instead a relay for command the light ? What is the point ?
                                      • tonnerre33T tonnerre33
                                        Hello
                                        kalinaK
                                        kalinaK
                                        kalina
                                        Hi @tonnerre33. MOC3043 triac includes the function of Zero Voltage Crossing, this mean that triac can trigger only when AC voltage close to 0 V. SSR doesn't use this feature. If you use just one device with ordinary relay or SSR, it is not appreciably, but if the number of switching devices increases and they all switch on at the moment of maximum value AC voltage, this will produce a lot of impulse spikes of voltage, which is not desirable. Ordinary relay also makes a not comfortable sound...
                                        • tonnerre33T
                                          tonnerre33T
                                          tonnerre33
                                          @kalina thx for your answer ;)
