  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 657.0k Views 35 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @Anticimex @FotoFieber
    Yup, it was moved over from development branch on the release night. So should be the latest and greatest
    • J
      J
      jovo
      Hi!
      I am in process of upgrading my Sensebenders to V2.0 and like to enable the OTA function.
      Who can give me some pointers on the capabilities of OTA for this Sensebender Micro board?
      I know that has external flash for this purpose, but i am stuggling a bit finding how to use it.
      So I am keen to read information on dependencies of the Sensebender sketch as well as the controller options.
      My environment:
      6x Sensebender
      Wifi based Gateway
      Domoticz as controller
      Things I like to know:
      • Is my sensebender shipped with optiboot bootloader? (have them about 1 year now)?
      • do i require special Gateway software? (i noticed a sketch called something like GatewayESP8266OTA)
      • what can i expect from Domoticz? probably not much, so do i need to connect to another controller (e.g. MYSController) to perform an update?
      • What controller is advised for the standard bootloader (optiboot bootloader)?
      I am sure those things are discussed in the past, but I was unable to find it.
      Would be great if somebody can share a howto or wiki on this topic.
      thanks in advance
      • tbowmoT
        tbowmoT
        tbowmo
        @jovo
        Sensebender is delivered with "DualOptiboot" which uses the external flash.
        To enable OTA with 2.0.0, you have to compile your sketches with
        #define MY_OTA_FIRMWARE_FEATURE
        enabled. For controller / Gateway, you need something else than domoticz. I haven't tried OTA firmware upgrades myself yet, so I do not have any experience with what works, and what doesn't work, other than the fact that domoticz doesn't support OTA..
        TheoLT 1 Reply Last reply
        • tbowmoT tbowmo
          @jovo
          TheoLT
          TheoLT
          TheoL
          Today I soldered the headers to a new sensebender and try to start it. I've uploaded the 2.0 example but it can't find the gateway:
          Started
          Starting sensor (RNONA-, 2.0.0)
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          My other sense benders worked flawelessly. But this one can't communicate. Does anyone have any idea, what might be wrong?
          alexsh1A Q 2 Replies Last reply
          • TheoLT TheoL
            Started
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            TSM:FPAR
            !TSM:FPAR:FAIL
            !TSM:FAILURE
            TSM:PDT
            alexsh1A
            alexsh1A
            alexsh1
            @TheoL I have exactly the same issue with one of the nodes though not the sensebender.
            All other nodes work just fine.
            Take a look:
            https://forum.mysensors.org/topic/4723/tsp-chkupl-fail
            • TheoLT TheoL
              Started
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              TSM:FPAR
              !TSM:FPAR:FAIL
              !TSM:FAILURE
              TSM:PDT
              Q
              Q
              Qu3Uk
              @TheoL I had this problem last night, its unable to find the parent/gateway. I ended up swapping out the radio with one I'd extended the antenna on and it worked. I then attached a piece of wire to the original radio and that was worked too. I put it down to knock off components.
              I think there is a video detailing the correct length etc.
              • TheoLT
                TheoLT
                TheoL
                Solved. I had forgotten to config the correct baudrate. My network is on one 1 mbyte, because of the mixed NRF24L01 and NRF24L01+ radios.
                • stefaanvS
                  stefaanvS
                  stefaanv
                  I get "not in sync" errors from avrdude if I try uploading a sketch to the sensorbender.
                  I do have correct serial communication, when I open the serial monitor, I get the info from the default sketch (which unfortunately uses the 1.4.1 API).
                  I tried with a different SenseBender board, same result. Tried with an older IDE version (1.6.9) on an other computer, same result.
                  Any suggestions ?
                  avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x20
                  avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2d
                  avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x20
                  avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4f
                  avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x6e
                  avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x6c
                  avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x69
                  avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x6e
                  avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x65
                  avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x21
                  alexsh1A 1 Reply Last reply
                  • stefaanvS stefaanv
                    Any suggestions ?
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @stefaanv sounds like you have a wrong board in Arduino. Did you install the correct board in Arduino IDE? I'm programming the Sensebender in 1.6.9 via the FTDI adapter without any difficulties
                    stefaanvS 1 Reply Last reply
                    • alexsh1A alexsh1
                      stefaanvS
                      stefaanvS
                      stefaanv
                      @alexsh1 I'm using the Uno board. Which one should I use ? Can't find anything in the SenseBender page.
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @stefaanv well, that's the problem - you must install Sensebender Micro (or I think you can use Arduino Pro Mini 3.3V) board. You MUST NOT provide more than 3.3V otherwise you may damage the board or radio. Please double check
                        Please refer to this link below to install the correct board in Arduino:
                        https://github.com/mysensors/ArduinoBoards
                        • alexsh1A alexsh1
                          stefaanvS
                          stefaanvS
                          stefaanv
                          @alexsh1 Thanks, got it working now.
                          • J
                            J
                            jovo
                            Is there anybody who can comment if the battery usage is increased in V2.0?
                            I feel that my batteries are draining faster then with 1.4 I had installed before.
                            Also I am seeing issues with the Force Retransmit. I dont see this working either. it just transmits when Transmit_Treshhold is kicked.
                            My sketch is pretty default. As far as I can see, I only turned Batt_Sensor on.
                            • J jovo
                              mvader
                              @jovo what is your usage? I'm getting 8+ months easily
                              I have a sensor in my deep freeze, been there for 8+ months and still working fine.
                              J 1 Reply Last reply
                              • M mvader
                                J
                                J
                                jovo
                                @mvader Hi,
                                I guess you are not for 8 months on v2?
                                I had a long time on the previous version as well.
                                Haven't done the measurements, but I noticed my batteries were depleted quickly since v2 was on.
                                I am more concerned about the fact that the force transmission doesn't seem to be working.
                                • J jovo
                                  @mvader Hi,
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @jovo how exactly do you define "quicker" please? I do not think anyone had enough time to test it. My batteries dropped 0.2V for 2 months (reporting temp/humidity/pressure every minute) but that does not mean anything at all. I would need to run it for another 6 months at least to say what I think.
                                  • Mitja BlazinsekM
                                    Mitja BlazinsekM
                                    Mitja Blazinsek
                                    i have some problems with sensbender micro it all work fine it shows temp and hum in mycontroller bu then i try to program the board to test my FTDI programmer, for test i was try to upload default sketch but since then it showing me only node in mycontroller without any sensors :(
                                    this is my log from debug:
                                    0 MCO:BGN:INIT NODE,CP=RNONA--,VER=2.1.1
                                    4 TSM:INIT
                                    4 TSF:WUR:MS=0
                                    12 TSM:INIT:TSP OK
                                    14 TSF:SID:OK,ID=5
                                    16 TSM:FPAR
                                    53 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    2062 !TSM:FPAR:NO REPLY
                                    2064 TSM:FPAR
                                    2101 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    4110 !TSM:FPAR:NO REPLY
                                    4112 TSM:FPAR
                                    4149 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    6158 !TSM:FPAR:NO REPLY
                                    6160 TSM:FPAR
                                    6197 TSF:MSG:SEND,5-5-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                    8206 !TSM:FPAR:FAIL
                                    8208 TSM:FAIL:CNT=1
                                    8210 TSM:FAIL:PDT
                                    18214 TSM:FAIL:RE-INIT
                                    18216 TSM:INIT
                                    18225 TSM:INIT:TSP OK
                                    18227 TSF:SID:OK,ID=5
                                    18229 TSM:FPAR
                                      That looks like there is no communication with gateway. Did you check gw log? You could also update mysensors to latest 2.2
                                      • Mitja BlazinsekM
                                        Mitja BlazinsekM
                                        Mitja Blazinsek
                                        but before it was working im using sensebender gateway and i see node in controler, i update my sensors and still nothing
                                        • Mitja BlazinsekM
                                          Mitja BlazinsekM
                                          Mitja Blazinsek
                                          OK i found the problem i just needed to clear the eeprom and it works i remembered that i had this problem before with binary switch sample
