  3. Soundsensor
Soundsensor
9 Posts 3 Posters 2.6k Views 4 Watching
  • D Offline
    davedeluxe
    I have a Soundsensor (http://www.satistronics.com/images/l/1255/3807.jpg) to determine if a smoke detector has been activated.
    My Sketch is the following but I´m not the best in Coding so maybe someone can help me because it doesn´t work :/
    Output: TSP:MSG:SEND 10-10-0-0 s=12,c=1,t=35,pt=2,l=2,sg=0,ft=0,st=ok:97
    #define CHILD_ID 12   // Id of the sensor child
    #define SND_SENSOR_ANALOG_PIN 0
    unsigned long SLEEP_TIME = 5; // Sleep time between reads (in seconds)
    MyMessage msg(CHILD_ID, V_VOLUME);
    int lastSND = -1;
      sendSketchInfo("Rauchmeldermelder", "1.0");
      present(CHILD_ID, S_CUSTOM);
       pinMode(SND_SENSOR_ANALOG_PIN, INPUT);
      int SND = map(analogRead(SND_SENSOR_ANALOG_PIN), 0, 1024, 100, 0);
      if (SND != lastSND) {
        Serial.println(SND);
        send(msg.set(SND));
        lastSND = SND;
    sleep(3000);
    • D davedeluxe
      int lastSND = -1;
          send(msg.set(SND));
          lastSND = SND;
      sleep(3000);
      @davedeluxe looks like it is working to me. Why do you think it does not work?
      • D Offline
        davedeluxe
        The output is everytime the same:
        and when I play with the potentiometer this comes out:
        TSP:MSG:SEND 10-10-0-0 s=12,c=1,t=35,pt=2,l=2,sg=0,ft=0,st=ok:1
        In FHEM I got the following values:
        mapReading_value112 12 value1
        mapReading_value212 12 value2
        mapReading_value312 12 value3
        mapReading_value412 12 value4
        mapReading_value512 12 value5
        setReading_value112 1
        setReading_value212 1
        setReading_value312 1
        setReading_value412 1
        setReading_value512 1
        I don´t know what that means but it´s useless
        • H Offline
          H Offline
          Shouldn't this be A0 ?
          • D Offline
            davedeluxe
            Yes of course.
            I thouht that means A0
            • D Offline
              davedeluxe
              I´ve changed it to #define SND_SENSOR_ANALOG_PIN A0
              but the result is the same :(
              • mfalkviddM Offline
                what is the result of the Serial.println(SND); in your loop?
                • D Offline
                  davedeluxe
                  All I get is this:
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                  TSP:MSG:PAR OK (ID=0, dist=1)
                  TSM:FPAR:OK
                  TSM:ID
                  TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                  TSP:MSG:READ 0-0-255 s=255,c=3,t=4,pt=0,l=2,sg=0:10
                  TSP:ASSIGNID:OK (ID=10)
                  TSM:CHKID:OK (ID=10)
                  TSM:UPL
                  TSP:PING:SEND (dest=0)
                  TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                  TSP:MSG:READ 0-0-10 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                  TSP:MSG:PONG RECV (hops=1)
                  TSP:CHKUPL:OK
                  TSM:UPL:OK
                  TSM:READY
                  TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                  TSP:MSG:SEND 10-10-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                  TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                  TSP:MSG:READ 0-0-10 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                  TSP:MSG:READ 0-0-10 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                  TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=11,pt=0,l=17,sg=0,ft=0,st=ok:Rauchmeldermelder
                  TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                  TSP:MSG:SEND 10-10-0-0 s=12,c=0,t=23,pt=0,l=0,sg=0,ft=0,st=ok:
                  Request registration...
                  !TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=fail:2
                  TSP:MSG:SEND 10-10-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=ok:2
                  TSP:MSG:READ 0-0-10 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                  Node registration=1
                  Init complete, id=10, parent=0, distance=1, registration=1
                  97
                  97
                    So the sensor seems to only get readings of 1 and 97. These readings are then sent by MySensors. If you are expecting anything else than 97 and 1, you'll need to investigate the sensor.
                    Try printing the raw analog value (without map) and see if that gives a clue.
                    12.1k
