  3. [ESP8266] use soft signing
5 Posts 2 Posters 2.2k Views 2 Watching
  • AndurilA Offline
    AndurilA Offline
    Anduril
    Hey there,
    I tried to use soft signing with my ESP8266 gateway and a nano node.
    I have both setup with the SecurityPersonalizer to the same Soft-HMAC. But what pin to use as soft signing seed?
    • S Offline
      Hello @Anduril
      From the doc ;) here https://www.mysensors.org/about/signing
      "For the software backed signingbackend, an unconnected analog pin is required to set a random seed for the pseudo-random generator. It is important that the pin is floating, or the output of the pseudo-random generator will be predictable, and thus compromise the signatures. "
      So for instance, adcs like A6, A7 etc. let it floating (not connected).
      • AndurilA Offline
        AndurilA Offline
        Anduril
        yeah I know the reason for having an unconnected analog pin, my question was more about which to use on an ESP. Does it have an A7? I don't find one in the pinout. I only see A0 (which is not used in my case), can this be the floating pin for soft signing?
        • S Offline
          ah oki, lol how i didn't see that :)
          yep on esp8266 you have only one adc, so it's A0
          • AndurilA Offline
            AndurilA Offline
            Anduril
            ok so
            // Select soft/hardware signing method
            #define MY_SIGNING_SOFT //!< Software signing
            //#define MY_SIGNING_ATSHA204 //!< Hardware signing using ATSHA204A
            #define MY_SIGNING_SOFT_RANDOMSEED_PIN A0 //!< Unconnected analog pin for random seed
            should give a good random signing.
