  3. Domoticz
  4. lost serial gateway after un plug power Rpi
45 Posts 8 Posters 20.0k Views 7 Watching
  • sinczeS sincze
    Hi.
    I had the same issue with (original) FTDI chipset ARDUINO.
    I use FTDI chipset because that enables me to FIX the USB to stick at for example USB20 and not to a different port. Comes in handy after a reboot. Domoticz will continue to work.
    However ... I had the same issue you described.
    I replaced ARDUINO with new one for testing with CH340.
    Gateway was recognized again.
    The failing FTDI Arduino that was nog recognized works perfectly well with my Windows 10 PC however not with Raspi.
    Keep in mind the CH340 has no serial number. I was unable to fix at a certain USB position.
    From your logs I can confirm I had the same issue.
    try: dmesg | grep "ÜSB"
    It will not show you a USB1 or USBx device.
    I bought a new FTDI arduino and said bye bye to the problem. All is working again.
    R
    R
    Reza
    @sincze
    sorry for weak in english , so you have use which one ? FT232 or CH340 ???
    now you have not same problem ???
    • sinczeS
      sinczeS
      sincze
      MySensors Evangelist
      No problem.
      I had problems with original FTDI arduino.
      For testing i changed to 340 arduino that worked.
      Than ordered new FTDI arduino.. And it worked again.
      Do you have a spare ARDUINO that you can flash with your gateway software??
      If your gateway is not assigned a /dev/ttyUSBx address It will not work.
      R 2 Replies Last reply
      • sinczeS sincze
        No problem.
        R
        R
        Reza
        @sincze
        sorry again , i am beginner :)
        first i do this Instructions (https://www.domoticz.com/wiki/PersistentUSBDevices) and dont work , after this , @tbowmo told me :
        lsusb
        -> provide the output
        unplug / plug the usb device
        once more in your terminal
        lsusb
        -> provide output
        also i do :
        dmesg
        so now after unplug/plug , my gateway dont detect and dont work
        • R
          R
          Reza
          i change usb port for my gateway and this working now , but after reset my problem again,,,,
          • sinczeS sincze
            No problem.
            R
            R
            Reza
            @sincze
            i use a spare ARDUINO but there is my problem yet...
            • tbowmoT tbowmo
              after you have powered on your raspberry, you log in
              then at the command prompt you type:
              lsusb
              lsusb
              -> provide output
              the same for dmesg. In a terminal type "dmesg" hit return, and provide the output, both before you unplug a device that is not working, and after you have done it, and it is working.
              R
              R
              Reza
              wrote on last edited by Reza
              #34
              @tbowmo
              now i run this
              lsusb
              lsusb
              -> provide output
              but after unplug power . there is my problem yet
              • sinczeS
                sinczeS
                sincze
                @Reza just to be sure: unplug power you mean:
                Unplug the power cord from raspberry right?
                Not unplug and replug FTDI device?
                R 1 Reply Last reply
                • sinczeS sincze
                  R
                  R
                  Reza
                  my serial gateway is always plug and connect. i mean unplug power of raspberry.
                  Suppose i use solar panel and battery for home and in cloudy day . power's home is off... so raspberry will be turn off...(or other reason for power off...)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @Reza
                    from the initial logs, after powerup, there is no FT232 listed in your lsusb listing, then you unplug and plug it again, and THEN the FT232 is present..
                    This IS not a bug in mysensors, as it's an HW chip (FT232) that your linux doesn't see before it's unplugged / plugged, it smells of a hardware issue with your nano. Now @sincze mentioned to you that he have had the same issues, and he cured it by exchanging the arduino, maybe it's worth a shot?
                    @awi also linked to a document, that describes how to make USB devices persistent in the naming (this can happen once in a while, that a USB device enumerates as a different device number.. That is, /dev/ttyUSB1 instead of /dev/ttyUSB0).
                    • tbowmoT tbowmo
                      @Reza
                      @Reza said:
                      R
                      R
                      Reza
                      #38
                      @tbowmo
                      thank you my friend . so this is related to my arduino totally . very very thank you
                      so i think , when complete gateway with a Rpi , this problem will be solved !!!
                      • tbowmoT tbowmo
                        @Reza
                        @Reza said:
                        R
                        R
                        Reza
                        @tbowmo
                        i test some arduino but all have this problem .
                        i have a question . is there a code in linux(Rpi) that after turn off/ on or reset Rpi (after some minutes) , usb port Be reset once !?
                        is there a ready code for this ?
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @Reza
                          Not that I know of..
                          • tbowmoT tbowmo
                            @Reza
                            R
                            R
                            Reza
                            @tbowmo
                            I'm looking for a solution for this issue :)
                            thank you
                            • peerkersezuukerP
                              peerkersezuukerP
                              peerkersezuuker
                              I have the same problem, i posted a question at the Domoticz Forum :
                              Not reconnecting serial portt
                              Greetz Peer
                              Domoticz / My Sensors / Z-Wave
                              https://www.kermisbuks.nl
                              • bjacobseB
                                bjacobseB
                                bjacobse
                                Somehow I think it's more related to the linux kernel than it's a mysensors or Domticz related issue
                                I would start to check which linux kernel you are using with uname -a and then start to search from this
                                Maybe it could also be USB power related? Try to use a better USB power supply to your RPI
                                https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=53832
                                • dbemowskD
                                  dbemowskD
                                  Why not connect the gateway to one of the onboard serial ports through the GPIO header? I have an Orange Pi which has a GPIO header that is pin compatible with the Raspberry Pi and I ran my gateway from there with no problems. I used pins 6, 8 and 10 which for me was /dev/ttyS3:
                                  The trick in doing this with Domoticz is to create a synlink. The reason for this is that Domoticz looks for a ttyUSBxxx device, so with the symlink you are basically tricking Domoticz into thinking that the onboard serial port is USB. In my case I created a symlink for ttyS3 to ttyUSB30 like this:
                                  sudo ln -s /dev/ttyS3 /dev/ttyUSB30
                                  This way you avoid having the problem of USB devices not being detected on boot.
                                  • peerkersezuukerP
                                    peerkersezuukerP
                                    peerkersezuuker
                                    Thank's for the answers to this problem.
                                    They didn't work for me, but i think i solved mine.
                                    Stop monitoring the serial port for data from a terminal session.
                                    See my post at Domoticz forum.
