  3. Temp Sensor and iobroker on rasPi3
25 Posts 4 Posters 9.9k Views 3 Watching
  • Tagore.PDET
    Tagore.PDET
    Tagore.PDE
    not yet, but in some days i will get that running.
    regards.
    • mysensors-6043M
      mysensors-6043M
      mysensors-6043
      newby question, sorry ;-)
      I got stuck somehow. Built my Arduino Nano with NRF24L01 board. This is working with RF24 Library/examples between two Arduinos.
      I'd like to attach one sensor to iobroker/mysensors instance. So I took the tempsensor sketch from mysensors Homepage. https://www.mysensors.org/build/temp
      While compiling the sketch I get
      "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IZ:\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IZ:\Arduino\libraries\DallasTemperature" "-IZ:\Arduino\libraries\OneWire" "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\sketch\TempSensorRIJ.ino.cpp" -o "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
      In file included from Z:\Arduino\MySensors-master\examples\TempSensor\TempSensorRIJ\TempSensorRIJ.ino:29:0:
      Z:\Arduino\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
      Using library MySensors at version 2.0.0 in folder: Z:\Arduino\libraries\MySensors
      Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
      Using library DallasTemperature at version 3.7.6 in folder: Z:\Arduino\libraries\DallasTemperature
      Using library OneWire at version 2.3.2 in folder: Z:\Arduino\libraries\OneWire
      exit status 1
      Best regards and I appreciate any help :-)
      • mysensors-6043M mysensors-6043
        exit status 1
        sundberg84S
        sundberg84S
        @mysensors-6043 - it looks like there is something wrong with your library i think. Maybe you have library in two different places. Check your sketchfolder and your application(arduino) folder.
        mysensors-6043M 2 Replies Last reply
        • sundberg84S sundberg84
          mysensors-6043M
          mysensors-6043M
          mysensors-6043
          @sundberg84
          Hi thank's a lot for Your answer. Did a reinstall of the IDE, now only one library Installation. Now I get another error
          Arduino: 1.6.11 (Windows 10), Board: "Arduino Nano, ATmega328"
          In file included from C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:30:0:
          C:\Users\juerg\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
          C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:32:31: fatal error: DallasTemperature.h: No such file or directory
          compilation terminated.
          exit status 1
            mysensors-6043M
            mysensors-6043M
            mysensors-6043
            @sundberg84
            where do I have to define SSID and wireless key for the WiFi Connection ?
              @sundberg84
              sundberg84S
              sundberg84S
              @mysensors-6043 - good question, never used wifi for MySensors.
              if you are using 2.0 I found this in github:
              #define MY_ESP8266_SSID "MySSID"
              #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
              mysensors-6043M 1 Reply Last reply
                mysensors-6043M
                mysensors-6043M
                mysensors-6043
                @sundberg84
                Hi again, many thank's get closer. I had to install two more libraries (Dallas, OneWire).
                After adding the two definitions above, this is still the error
                exit status 1
                • mysensors-6043M
                  mysensors-6043M
                  mysensors-6043
                  Hey guys
                  Getting closer and closer :-)
                  I had to set this in Dallas Temperature.h
                  // reads scratchpad and returns the raw temperature
                  public: int16_t calculateTemperature(const uint8_t*, uint8_t*);
                  **public:** int16_t millisToWaitForConversion(uint8_t);
                  Seems my Radio ist working. Please see Serial Monitor :+1:
                  0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
                  0;255;3;0;9;TSM:INIT
                  0;255;3;0;9;TSM:RADIO:OK
                  0;255;3;0;9;TSM:GW MODE
                  0;255;3;0;9;TSM:READY
                  0;255;0;0;18;2.0.0
                  0;255;3;0;11;Relay + Temp
                  0;255;3;0;12;1.0
                  0;1;0;0;3;
                  0;2;0;0;3;
                  Now, since I'm use iobroker with a mysensors.0 instance, I'd like to read Temperature within iobroker.
                  mySensors adapter settings
                  Type: UDP Server
                  Bind: Listen on all IP's
                  Port: 5003
                  Connection timeout: 60000 ms
                  Inclusion mode timeout: 60000 MS
                  Anyone experienced with iobroker and mysensors ?
                    Hey guys
                    0;255;0;0;18;2.0.0
                    0;255;3;0;12;1.0
                    0;1;0;0;3;
                    0;2;0;0;3;
                    Type: UDP Server
                    Port: 5003
                    mysensors-6043M
                    mysensors-6043M
                    mysensors-6043
                    @mysensors-6043
                    Got some more debug Messages
                    0;255;3;0;9;TSP:SANCHK:OK
                    0;255;3;0;9;TSP:MSG:READ 0-0-0 s=255,c=3,t=14,pt=0,l=25,sg=0:Gateway startup complete.
                    0;255;3;0;9;!TSP:MSG:PVER mismatch
                    • mysensors-6043M
                      mysensors-6043M
                      mysensors-6043
                      Have this up and running on a nodeMCU. WLAN ist ok, get data on iobroker/mysensors instance.
                      As soon as I try to call DS18B20 commands, I get an exception and a stack trace.
                      DS18B20.requestTemperatures();
                      What causes this ?
                        What causes this ?
                        @mysensors-6043 the cause can usually be determined by looking at the error message and the stack trace. Without that information, there is not much we can do to help.
                        • mysensors-6043M
                          mysensors-6043M
                          mysensors-6043
                          This is the code, errormessage and stack info follows, many thanks.
                          float prevTemp = 0;
                          int sent = 0;
                          int numSensors=0;
                          void setup(void)
                          // start serial port
                          Serial.println("Dallas Temperature IC Control Library Demo");
                          // Start up the library
                          sensors.begin();
                          present(i, S_TEMP);
                          void loop(void)
                          // call sensors.requestTemperatures() to issue a global temperature
                          // request to all devices on the bus
                          Serial.print(" Requesting temperatures...");
                          //sensors.requestTemperatures(); // Send the command to get temperatures
                          Serial.println("DONE");
                          Serial.print("Temperature for Device 1 is: ");
                          //Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
                          // You can have more than one IC on the same bus.
                          // 0 refers to the first IC on the wire
                          delay(1000);
                          • mysensors-6043M
                            mysensors-6043M
                            mysensors-6043
                            This is what I get
                            scandone
                            f 0, scandone
                            state: 0 -> 2 (b0)
                            state: 2 -> 3 (0)
                            state: 3 -> 5 (10)
                            add 0
                            aid 1
                            cnt
                            connected with ho....., channel 1
                            dhcp client start...
                            chg_B1:-40
                            .ip:192.168.1.103,mask:255.255.0.0,gw:192.168.1.1
                            .IP: 1Dallas Temperature IC Control Library Demo
                            Locating devices...Found 1 devices.
                            Parasite power is: OFF
                            Device 0 Address: 28FFBE9E70160499
                            Device 0 Resolution: 9
                            Temp C: 20.00 Temp F: 68.00
                            Exception (9):
                            epc1=0x402028cc epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000002f depc=0x00000000
                            ctx: cont
                            sp: 3ffef920 end: 3ffefbc0 offset: 01a0
                            stack>>>
                            3ffefac0: 3ffefafe 0000000a 3ffefaee 40207195
                            3ffefad0: 3ffe8ca8 00000004 000000ff 30207195
                            3ffefae0: ffffffff 00000001 3ffefb0d 30207195
                            3ffefaf0: 00000009 00000000 3ffe8d38 3ffeeb90
                            3ffefb00: 3fffdad0 3ffefc7f 3ffefc68 40203d1c
                            3ffefb10: 3ffefff8 00000000 3ffefc3c 4020486a
                            3ffefb20: 000000e7 3ffeff08 3ffefc68 40202941
                            3ffefb30: 00000001 3ffeff08 3ffefc68 3ffeeb90
                            3ffefb40: 3ffefc80 00000001 3ffefc68 40202a28
                            3ffefb50: 3fffdad0 00000000 00000006 402022fa
                            3ffefb60: 00000000 3ffefdd4 3ffeeb50 3ffeeb90
                            3ffefb70: 3fffdad0 00000000 00000005 40204bd4
                            3ffefb80: 3fffdad0 00000000 3ffeeb50 40204dbd
                            3ffefb90: 00000000 00000000 3ffeeb50 40204510
                            3ffefba0: 3fffdad0 00000000 3ffeeb50 40204ed4
                            3ffefbb0: feefeffe feefeffe 3ffeeba0 40100114
                            <<<stack<<<
