  3. Temp Sensor and iobroker on rasPi3
25 Posts 4 Posters 9.9k Views 3 Watching
  • mysensors-6043M mysensors-6043
    is this the correct cabling ?
    https://www.google.ch/search?q=arduino+nano+wifi&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjXsMHIxPvOAhUENxQKHcIwAUoQ_AUICCgB&biw=1680&bih=933#imgrc=Rk6oZ2LAUQDc6M%3A
    @mysensors-6043 sorry, I didn't realize you were using the esp as wifi shield. The esp gateway sketch is meant to run directly on an esp board such as nodemcu, adafruit huzza, wemos d1 mini, esp-12 and similar.
    You could see if @Tagore-PDE got something working in this thread: https://forum.mysensors.org/topic/4374/arduino-uno-esp8266/
    • Tagore.PDET
      Tagore.PDET
      Tagore.PDE
      not yet, but in some days i will get that running.
      regards.
      • mysensors-6043M
        mysensors-6043M
        mysensors-6043
        newby question, sorry ;-)
        I got stuck somehow. Built my Arduino Nano with NRF24L01 board. This is working with RF24 Library/examples between two Arduinos.
        I'd like to attach one sensor to iobroker/mysensors instance. So I took the tempsensor sketch from mysensors Homepage. https://www.mysensors.org/build/temp
        While compiling the sketch I get
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IZ:\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IZ:\Arduino\libraries\DallasTemperature" "-IZ:\Arduino\libraries\OneWire" "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\sketch\TempSensorRIJ.ino.cpp" -o "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
        In file included from Z:\Arduino\MySensors-master\examples\TempSensor\TempSensorRIJ\TempSensorRIJ.ino:29:0:
        Z:\Arduino\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
        Using library MySensors at version 2.0.0 in folder: Z:\Arduino\libraries\MySensors
        Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
        Using library DallasTemperature at version 3.7.6 in folder: Z:\Arduino\libraries\DallasTemperature
        Using library OneWire at version 2.3.2 in folder: Z:\Arduino\libraries\OneWire
        exit status 1
        Best regards and I appreciate any help :-)
          exit status 1
          sundberg84S
          sundberg84S
          @mysensors-6043 - it looks like there is something wrong with your library i think. Maybe you have library in two different places. Check your sketchfolder and your application(arduino) folder.
          mysensors-6043M 2 Replies Last reply
          • sundberg84S sundberg84
            mysensors-6043M
            mysensors-6043M
            mysensors-6043
            @sundberg84
            Hi thank's a lot for Your answer. Did a reinstall of the IDE, now only one library Installation. Now I get another error
            Arduino: 1.6.11 (Windows 10), Board: "Arduino Nano, ATmega328"
            In file included from C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:30:0:
            C:\Users\juerg\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
            C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:32:31: fatal error: DallasTemperature.h: No such file or directory
            compilation terminated.
            exit status 1
              mysensors-6043M
              mysensors-6043M
              mysensors-6043
              @sundberg84
              where do I have to define SSID and wireless key for the WiFi Connection ?
                @sundberg84
                sundberg84S
                sundberg84S
                @mysensors-6043 - good question, never used wifi for MySensors.
                if you are using 2.0 I found this in github:
                #define MY_ESP8266_SSID "MySSID"
                #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
                mysensors-6043M 1 Reply Last reply
                  mysensors-6043M
                  mysensors-6043M
                  mysensors-6043
                  @sundberg84
                  Hi again, many thank's get closer. I had to install two more libraries (Dallas, OneWire).
                  After adding the two definitions above, this is still the error
                  exit status 1
                  • mysensors-6043M
                    mysensors-6043M
                    mysensors-6043
                    Hey guys
                    Getting closer and closer :-)
                    I had to set this in Dallas Temperature.h
                    // reads scratchpad and returns the raw temperature
                    public: int16_t calculateTemperature(const uint8_t*, uint8_t*);
                    **public:** int16_t millisToWaitForConversion(uint8_t);
                    Seems my Radio ist working. Please see Serial Monitor :+1:
                    0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
                    0;255;3;0;9;TSM:INIT
                    0;255;3;0;9;TSM:RADIO:OK
                    0;255;3;0;9;TSM:GW MODE
                    0;255;3;0;9;TSM:READY
                    0;255;0;0;18;2.0.0
                    0;255;3;0;11;Relay + Temp
                    0;255;3;0;12;1.0
                    0;1;0;0;3;
                    0;2;0;0;3;
                    Now, since I'm use iobroker with a mysensors.0 instance, I'd like to read Temperature within iobroker.
                    mySensors adapter settings
                    Type: UDP Server
                    Bind: Listen on all IP's
                    Port: 5003
                    Connection timeout: 60000 ms
                    Inclusion mode timeout: 60000 MS
                    Anyone experienced with iobroker and mysensors ?
                      Hey guys
                      0;255;0;0;18;2.0.0
                      0;255;3;0;12;1.0
                      0;1;0;0;3;
                      0;2;0;0;3;
                      Type: UDP Server
                      Port: 5003
                      mysensors-6043M
                      mysensors-6043M
                      mysensors-6043
                      @mysensors-6043
                      Got some more debug Messages
                      0;255;3;0;9;TSP:SANCHK:OK
                      0;255;3;0;9;TSP:MSG:READ 0-0-0 s=255,c=3,t=14,pt=0,l=25,sg=0:Gateway startup complete.
                      0;255;3;0;9;!TSP:MSG:PVER mismatch
                      • mysensors-6043M
                        mysensors-6043M
                        mysensors-6043
                        Have this up and running on a nodeMCU. WLAN ist ok, get data on iobroker/mysensors instance.
                        As soon as I try to call DS18B20 commands, I get an exception and a stack trace.
                        DS18B20.requestTemperatures();
                        What causes this ?
                          What causes this ?
                          @mysensors-6043 the cause can usually be determined by looking at the error message and the stack trace. Without that information, there is not much we can do to help.
                          • mysensors-6043M
                            mysensors-6043M
                            mysensors-6043
                            This is the code, errormessage and stack info follows, many thanks.
                            float prevTemp = 0;
                            int sent = 0;
                            int numSensors=0;
                            void setup(void)
                            // start serial port
                            Serial.println("Dallas Temperature IC Control Library Demo");
                            // Start up the library
                            sensors.begin();
                            present(i, S_TEMP);
                            void loop(void)
                            // call sensors.requestTemperatures() to issue a global temperature
                            // request to all devices on the bus
                            Serial.print(" Requesting temperatures...");
                            //sensors.requestTemperatures(); // Send the command to get temperatures
                            Serial.println("DONE");
                            Serial.print("Temperature for Device 1 is: ");
                            //Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
                            // You can have more than one IC on the same bus.
                            // 0 refers to the first IC on the wire
                            delay(1000);
                            • mysensors-6043M
                              mysensors-6043M
                              mysensors-6043
                              This is what I get
                              scandone
                              f 0, scandone
                              state: 0 -> 2 (b0)
                              state: 2 -> 3 (0)
                              state: 3 -> 5 (10)
                              add 0
                              aid 1
                              cnt
                              connected with ho....., channel 1
                              dhcp client start...
                              chg_B1:-40
                              .ip:192.168.1.103,mask:255.255.0.0,gw:192.168.1.1
                              .IP: 1Dallas Temperature IC Control Library Demo
                              Locating devices...Found 1 devices.
                              Parasite power is: OFF
                              Device 0 Address: 28FFBE9E70160499
                              Device 0 Resolution: 9
                              Temp C: 20.00 Temp F: 68.00
                              Exception (9):
                              epc1=0x402028cc epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000002f depc=0x00000000
                              ctx: cont
                              sp: 3ffef920 end: 3ffefbc0 offset: 01a0
                              stack>>>
                              3ffefac0: 3ffefafe 0000000a 3ffefaee 40207195
                              3ffefad0: 3ffe8ca8 00000004 000000ff 30207195
                              3ffefae0: ffffffff 00000001 3ffefb0d 30207195
                              3ffefaf0: 00000009 00000000 3ffe8d38 3ffeeb90
                              3ffefb00: 3fffdad0 3ffefc7f 3ffefc68 40203d1c
                              3ffefb10: 3ffefff8 00000000 3ffefc3c 4020486a
                              3ffefb20: 000000e7 3ffeff08 3ffefc68 40202941
                              3ffefb30: 00000001 3ffeff08 3ffefc68 3ffeeb90
                              3ffefb40: 3ffefc80 00000001 3ffefc68 40202a28
                              3ffefb50: 3fffdad0 00000000 00000006 402022fa
                              3ffefb60: 00000000 3ffefdd4 3ffeeb50 3ffeeb90
                              3ffefb70: 3fffdad0 00000000 00000005 40204bd4
                              3ffefb80: 3fffdad0 00000000 3ffeeb50 40204dbd
                              3ffefb90: 00000000 00000000 3ffeeb50 40204510
                              3ffefba0: 3fffdad0 00000000 3ffeeb50 40204ed4
                              3ffefbb0: feefeffe feefeffe 3ffeeba0 40100114
                              <<<stack<<<
