  3. Temp Sensor and iobroker on rasPi3
25 Posts 4 Posters 9.9k Views 3 Watching
  • mysensors-6043M mysensors-6043
    Arduino: 1.6.11 (Windows 10), Board: "Arduino Nano, ATmega328"
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\juerg\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\juerg\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries Z:\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10611 -build-path C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose Z:\Arduino\MySensors-master\examples\GatewayESP8266\GatewayESP8266.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\juerg\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\juerg\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries Z:\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10611 -build-path C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose Z:\Arduino\MySensors-master\examples\GatewayESP8266\GatewayESP8266.ino
    Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
    Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
    Detecting libraries used...
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\sketch\GatewayESP8266.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\sketch\GatewayESP8266.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\sketch\GatewayESP8266.ino.cpp" -o "nul"
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM\src" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\sketch\GatewayESP8266.ino.cpp" -o "C:\Users\juerg\AppData\Local\Temp\build6a79aaaf9edceffc501302251a9673e9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    Z:\Arduino\MySensors-master\examples\GatewayESP8266\GatewayESP8266.ino:136:27: fatal error: ESP8266WiFi.h: No such file or directory
    #include <ESP8266WiFi.h>
    compilation terminated.
    Using library EEPROM at version 2.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\EEPROM
    Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
    exit status 1
    @mysensors-6043
    this means that the Arduino IDE is trying to compile the code for an Arduino Nano. Since the gateway sketch is for ESP8266, it will fail to compile for Arduino nano.
    Select the ESP8266 in the Tools->Board menu. Follow the instructions on https://github.com/esp8266/Arduino#installing-with-boards-manager if you haven't installed the ESP8266 board.
    • mysensors-6043M
      mysensors-6043M
      mysensors-6043
      Hi Thank's
      I changed Board Type to ESP8266, but now I get
      Sketch uses 243,757 bytes (56%) of program storage space. Maximum is 434,160 bytes.
      Global variables use 34,440 bytes (42%) of dynamic memory, leaving 47,480 bytes for local variables. Maximum is 81,920 bytes.
      warning: espcomm_sync failed
      error: espcomm_open failed
      error: espcomm_upload_mem failed
      and the serial monitor say's wifi shield not present -> yes this is true not connected yet
      • mysensors-6043M
        mysensors-6043M
        mysensors-6043
        https://www.google.ch/search?q=arduino+nano+wifi&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjXsMHIxPvOAhUENxQKHcIwAUoQ_AUICCgB&biw=1680&bih=933#imgrc=yNkJrmEzEp2z2M%3A
        That's my WiFi shield
        • mysensors-6043M
          mysensors-6043M
          mysensors-6043
          is this the correct cabling ?
          https://www.google.ch/search?q=arduino+nano+wifi&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjXsMHIxPvOAhUENxQKHcIwAUoQ_AUICCgB&biw=1680&bih=933#imgrc=Rk6oZ2LAUQDc6M%3A
            @mysensors-6043 sorry, I didn't realize you were using the esp as wifi shield. The esp gateway sketch is meant to run directly on an esp board such as nodemcu, adafruit huzza, wemos d1 mini, esp-12 and similar.
            You could see if @Tagore-PDE got something working in this thread: https://forum.mysensors.org/topic/4374/arduino-uno-esp8266/
            • Tagore.PDET
              Tagore.PDET
              Tagore.PDE
              not yet, but in some days i will get that running.
              regards.
              • mysensors-6043M
                mysensors-6043M
                mysensors-6043
                newby question, sorry ;-)
                I got stuck somehow. Built my Arduino Nano with NRF24L01 board. This is working with RF24 Library/examples between two Arduinos.
                I'd like to attach one sensor to iobroker/mysensors instance. So I took the tempsensor sketch from mysensors Homepage. https://www.mysensors.org/build/temp
                While compiling the sketch I get
                "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IZ:\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IZ:\Arduino\libraries\DallasTemperature" "-IZ:\Arduino\libraries\OneWire" "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\sketch\TempSensorRIJ.ino.cpp" -o "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                In file included from Z:\Arduino\MySensors-master\examples\TempSensor\TempSensorRIJ\TempSensorRIJ.ino:29:0:
                Z:\Arduino\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                Using library MySensors at version 2.0.0 in folder: Z:\Arduino\libraries\MySensors
                Using library DallasTemperature at version 3.7.6 in folder: Z:\Arduino\libraries\DallasTemperature
                Using library OneWire at version 2.3.2 in folder: Z:\Arduino\libraries\OneWire
                exit status 1
                Best regards and I appreciate any help :-)
                  exit status 1
                  sundberg84S
                  sundberg84S
                  @mysensors-6043 - it looks like there is something wrong with your library i think. Maybe you have library in two different places. Check your sketchfolder and your application(arduino) folder.
                  mysensors-6043M 2 Replies Last reply
                  • sundberg84S sundberg84
                    mysensors-6043M
                    mysensors-6043M
                    mysensors-6043
                    @sundberg84
                    Hi thank's a lot for Your answer. Did a reinstall of the IDE, now only one library Installation. Now I get another error
                    In file included from C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:30:0:
                    C:\Users\juerg\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
                    C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:32:31: fatal error: DallasTemperature.h: No such file or directory
                    exit status 1
                      mysensors-6043M
                      mysensors-6043M
                      mysensors-6043
                      @sundberg84
                      where do I have to define SSID and wireless key for the WiFi Connection ?
                        @sundberg84
                        sundberg84S
                        sundberg84S
                        @mysensors-6043 - good question, never used wifi for MySensors.
                        if you are using 2.0 I found this in github:
                        #define MY_ESP8266_SSID "MySSID"
                        #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
                        mysensors-6043M 1 Reply Last reply
                          mysensors-6043M
                          mysensors-6043M
                          mysensors-6043
                          @sundberg84
                          Hi again, many thank's get closer. I had to install two more libraries (Dallas, OneWire).
                          After adding the two definitions above, this is still the error
                          exit status 1
                          • mysensors-6043M
                            mysensors-6043M
                            mysensors-6043
                            Hey guys
                            Getting closer and closer :-)
                            I had to set this in Dallas Temperature.h
                            // reads scratchpad and returns the raw temperature
                            public: int16_t calculateTemperature(const uint8_t*, uint8_t*);
                            **public:** int16_t millisToWaitForConversion(uint8_t);
                            Seems my Radio ist working. Please see Serial Monitor :+1:
                            0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
                            0;255;3;0;9;TSM:INIT
                            0;255;3;0;9;TSM:RADIO:OK
                            0;255;3;0;9;TSM:GW MODE
                            0;255;3;0;9;TSM:READY
                            0;255;0;0;18;2.0.0
                            0;255;3;0;11;Relay + Temp
                            0;255;3;0;12;1.0
                            0;1;0;0;3;
                            0;2;0;0;3;
                            Now, since I'm use iobroker with a mysensors.0 instance, I'd like to read Temperature within iobroker.
                            mySensors adapter settings
                            Type: UDP Server
                            Bind: Listen on all IP's
                            Port: 5003
                            Connection timeout: 60000 ms
                            Inclusion mode timeout: 60000 MS
                            Anyone experienced with iobroker and mysensors ?
                              Hey guys
                              0;255;0;0;18;2.0.0
                              0;255;3;0;12;1.0
                              0;1;0;0;3;
                              0;2;0;0;3;
                              Type: UDP Server
                              Port: 5003
                              mysensors-6043M
                              mysensors-6043M
                              mysensors-6043
                              @mysensors-6043
                              Got some more debug Messages
                              0;255;3;0;9;TSP:SANCHK:OK
                              0;255;3;0;9;TSP:MSG:READ 0-0-0 s=255,c=3,t=14,pt=0,l=25,sg=0:Gateway startup complete.
                              0;255;3;0;9;!TSP:MSG:PVER mismatch
                              • mysensors-6043M
                                mysensors-6043M
                                mysensors-6043
                                Have this up and running on a nodeMCU. WLAN ist ok, get data on iobroker/mysensors instance.
                                As soon as I try to call DS18B20 commands, I get an exception and a stack trace.
                                DS18B20.requestTemperatures();
                                What causes this ?
                                  What causes this ?
                                  @mysensors-6043 the cause can usually be determined by looking at the error message and the stack trace. Without that information, there is not much we can do to help.
                                  • mysensors-6043M
                                    mysensors-6043M
                                    mysensors-6043
                                    This is the code, errormessage and stack info follows, many thanks.
                                    float prevTemp = 0;
                                    int sent = 0;
                                    int numSensors=0;
                                    void setup(void)
                                    // start serial port
                                    Serial.println("Dallas Temperature IC Control Library Demo");
                                    // Start up the library
                                    sensors.begin();
                                    present(i, S_TEMP);
                                    void loop(void)
                                    // call sensors.requestTemperatures() to issue a global temperature
                                    // request to all devices on the bus
                                    Serial.print(" Requesting temperatures...");
                                    //sensors.requestTemperatures(); // Send the command to get temperatures
                                    Serial.println("DONE");
                                    Serial.print("Temperature for Device 1 is: ");
                                    //Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
                                    // You can have more than one IC on the same bus.
                                    // 0 refers to the first IC on the wire
                                    delay(1000);
                                    • mysensors-6043M
                                      mysensors-6043M
                                      mysensors-6043
                                      This is what I get
                                      scandone
                                      f 0, scandone
                                      state: 0 -> 2 (b0)
                                      state: 2 -> 3 (0)
                                      state: 3 -> 5 (10)
                                      add 0
                                      aid 1
                                      cnt
                                      connected with ho....., channel 1
                                      dhcp client start...
                                      chg_B1:-40
                                      .ip:192.168.1.103,mask:255.255.0.0,gw:192.168.1.1
                                      .IP: 1Dallas Temperature IC Control Library Demo
                                      Locating devices...Found 1 devices.
                                      Parasite power is: OFF
                                      Device 0 Address: 28FFBE9E70160499
                                      Device 0 Resolution: 9
                                      Temp C: 20.00 Temp F: 68.00
                                      Exception (9):
                                      epc1=0x402028cc epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000002f depc=0x00000000
                                      ctx: cont
                                      sp: 3ffef920 end: 3ffefbc0 offset: 01a0
                                      stack>>>
                                      3ffefac0: 3ffefafe 0000000a 3ffefaee 40207195
                                      3ffefad0: 3ffe8ca8 00000004 000000ff 30207195
                                      3ffefae0: ffffffff 00000001 3ffefb0d 30207195
                                      3ffefaf0: 00000009 00000000 3ffe8d38 3ffeeb90
                                      3ffefb00: 3fffdad0 3ffefc7f 3ffefc68 40203d1c
                                      3ffefb10: 3ffefff8 00000000 3ffefc3c 4020486a
                                      3ffefb20: 000000e7 3ffeff08 3ffefc68 40202941
                                      3ffefb30: 00000001 3ffeff08 3ffefc68 3ffeeb90
                                      3ffefb40: 3ffefc80 00000001 3ffefc68 40202a28
                                      3ffefb50: 3fffdad0 00000000 00000006 402022fa
                                      3ffefb60: 00000000 3ffefdd4 3ffeeb50 3ffeeb90
                                      3ffefb70: 3fffdad0 00000000 00000005 40204bd4
                                      3ffefb80: 3fffdad0 00000000 3ffeeb50 40204dbd
                                      3ffefb90: 00000000 00000000 3ffeeb50 40204510
                                      3ffefba0: 3fffdad0 00000000 3ffeeb50 40204ed4
                                      3ffefbb0: feefeffe feefeffe 3ffeeba0 40100114
                                      <<<stack<<<
