  3. Temp Sensor and iobroker on rasPi3
25 Posts 4 Posters 9.9k Views 3 Watching
  • mysensors-6043M
    mysensors-6043M
    mysensors-6043
    is this the correct cabling ?
    https://www.google.ch/search?q=arduino+nano+wifi&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjXsMHIxPvOAhUENxQKHcIwAUoQ_AUICCgB&biw=1680&bih=933#imgrc=Rk6oZ2LAUQDc6M%3A
    • mysensors-6043M mysensors-6043
      @mysensors-6043 sorry, I didn't realize you were using the esp as wifi shield. The esp gateway sketch is meant to run directly on an esp board such as nodemcu, adafruit huzza, wemos d1 mini, esp-12 and similar.
      You could see if @Tagore-PDE got something working in this thread: https://forum.mysensors.org/topic/4374/arduino-uno-esp8266/
      • Tagore.PDET
        Tagore.PDET
        Tagore.PDE
        not yet, but in some days i will get that running.
        regards.
        • mysensors-6043M
          mysensors-6043M
          mysensors-6043
          newby question, sorry ;-)
          I got stuck somehow. Built my Arduino Nano with NRF24L01 board. This is working with RF24 Library/examples between two Arduinos.
          I'd like to attach one sensor to iobroker/mysensors instance. So I took the tempsensor sketch from mysensors Homepage. https://www.mysensors.org/build/temp
          While compiling the sketch I get
          "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IZ:\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IZ:\Arduino\libraries\DallasTemperature" "-IZ:\Arduino\libraries\OneWire" "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\sketch\TempSensorRIJ.ino.cpp" -o "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
          In file included from Z:\Arduino\MySensors-master\examples\TempSensor\TempSensorRIJ\TempSensorRIJ.ino:29:0:
          Z:\Arduino\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
          Using library MySensors at version 2.0.0 in folder: Z:\Arduino\libraries\MySensors
          Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
          Using library DallasTemperature at version 3.7.6 in folder: Z:\Arduino\libraries\DallasTemperature
          Using library OneWire at version 2.3.2 in folder: Z:\Arduino\libraries\OneWire
          exit status 1
          Best regards and I appreciate any help :-)
            exit status 1
            sundberg84S
            sundberg84S
            @mysensors-6043 - it looks like there is something wrong with your library i think. Maybe you have library in two different places. Check your sketchfolder and your application(arduino) folder.
            mysensors-6043M 2 Replies Last reply
            • sundberg84S sundberg84
              mysensors-6043M
              mysensors-6043M
              mysensors-6043
              @sundberg84
              Hi thank's a lot for Your answer. Did a reinstall of the IDE, now only one library Installation. Now I get another error
              Arduino: 1.6.11 (Windows 10), Board: "Arduino Nano, ATmega328"
              In file included from C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:30:0:
              C:\Users\juerg\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
              C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:32:31: fatal error: DallasTemperature.h: No such file or directory
              compilation terminated.
              exit status 1
                mysensors-6043M
                mysensors-6043M
                mysensors-6043
                @sundberg84
                where do I have to define SSID and wireless key for the WiFi Connection ?
                  @sundberg84
                  sundberg84S
                  sundberg84S
                  @mysensors-6043 - good question, never used wifi for MySensors.
                  if you are using 2.0 I found this in github:
                  #define MY_ESP8266_SSID "MySSID"
                  #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
                  mysensors-6043M 1 Reply Last reply
                    mysensors-6043M
                    mysensors-6043M
                    mysensors-6043
                    @sundberg84
                    Hi again, many thank's get closer. I had to install two more libraries (Dallas, OneWire).
                    After adding the two definitions above, this is still the error
                    exit status 1
                    • mysensors-6043M
                      mysensors-6043M
                      mysensors-6043
                      Hey guys
                      Getting closer and closer :-)
                      I had to set this in Dallas Temperature.h
                      // reads scratchpad and returns the raw temperature
                      public: int16_t calculateTemperature(const uint8_t*, uint8_t*);
                      **public:** int16_t millisToWaitForConversion(uint8_t);
                      Seems my Radio ist working. Please see Serial Monitor :+1:
                      0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
                      0;255;3;0;9;TSM:INIT
                      0;255;3;0;9;TSM:RADIO:OK
                      0;255;3;0;9;TSM:GW MODE
                      0;255;3;0;9;TSM:READY
                      0;255;0;0;18;2.0.0
                      0;255;3;0;11;Relay + Temp
                      0;255;3;0;12;1.0
                      0;1;0;0;3;
                      0;2;0;0;3;
                      Now, since I'm use iobroker with a mysensors.0 instance, I'd like to read Temperature within iobroker.
                      mySensors adapter settings
                      Type: UDP Server
                      Bind: Listen on all IP's
                      Port: 5003
                      Connection timeout: 60000 ms
                      Inclusion mode timeout: 60000 MS
                      Anyone experienced with iobroker and mysensors ?
                        Hey guys
                        0;255;0;0;18;2.0.0
                        0;255;3;0;12;1.0
                        0;1;0;0;3;
                        0;2;0;0;3;
                        Type: UDP Server
                        Port: 5003
                        mysensors-6043M
                        mysensors-6043M
                        mysensors-6043
                        @mysensors-6043
                        Got some more debug Messages
                        0;255;3;0;9;TSP:SANCHK:OK
                        0;255;3;0;9;TSP:MSG:READ 0-0-0 s=255,c=3,t=14,pt=0,l=25,sg=0:Gateway startup complete.
                        0;255;3;0;9;!TSP:MSG:PVER mismatch
                        • mysensors-6043M
                          mysensors-6043M
                          mysensors-6043
                          Have this up and running on a nodeMCU. WLAN ist ok, get data on iobroker/mysensors instance.
                          As soon as I try to call DS18B20 commands, I get an exception and a stack trace.
                          DS18B20.requestTemperatures();
                          What causes this ?
                            What causes this ?
                            @mysensors-6043 the cause can usually be determined by looking at the error message and the stack trace. Without that information, there is not much we can do to help.
                            • mysensors-6043M
                              mysensors-6043M
                              mysensors-6043
                              This is the code, errormessage and stack info follows, many thanks.
                              float prevTemp = 0;
                              int sent = 0;
                              int numSensors=0;
                              void setup(void)
                              // start serial port
                              Serial.println("Dallas Temperature IC Control Library Demo");
                              // Start up the library
                              sensors.begin();
                              present(i, S_TEMP);
                              void loop(void)
                              // call sensors.requestTemperatures() to issue a global temperature
                              // request to all devices on the bus
                              Serial.print(" Requesting temperatures...");
                              //sensors.requestTemperatures(); // Send the command to get temperatures
                              Serial.println("DONE");
                              Serial.print("Temperature for Device 1 is: ");
                              //Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
                              // You can have more than one IC on the same bus.
                              // 0 refers to the first IC on the wire
                              delay(1000);
                              • mysensors-6043M
                                mysensors-6043M
                                mysensors-6043
                                This is what I get
                                scandone
                                f 0, scandone
                                state: 0 -> 2 (b0)
                                state: 2 -> 3 (0)
                                state: 3 -> 5 (10)
                                add 0
                                aid 1
                                cnt
                                connected with ho....., channel 1
                                dhcp client start...
                                chg_B1:-40
                                .ip:192.168.1.103,mask:255.255.0.0,gw:192.168.1.1
                                .IP: 1Dallas Temperature IC Control Library Demo
                                Locating devices...Found 1 devices.
                                Parasite power is: OFF
                                Device 0 Address: 28FFBE9E70160499
                                Device 0 Resolution: 9
                                Temp C: 20.00 Temp F: 68.00
                                Exception (9):
                                epc1=0x402028cc epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000002f depc=0x00000000
                                ctx: cont
                                sp: 3ffef920 end: 3ffefbc0 offset: 01a0
                                stack>>>
                                3ffefac0: 3ffefafe 0000000a 3ffefaee 40207195
                                3ffefad0: 3ffe8ca8 00000004 000000ff 30207195
                                3ffefae0: ffffffff 00000001 3ffefb0d 30207195
                                3ffefaf0: 00000009 00000000 3ffe8d38 3ffeeb90
                                3ffefb00: 3fffdad0 3ffefc7f 3ffefc68 40203d1c
                                3ffefb10: 3ffefff8 00000000 3ffefc3c 4020486a
                                3ffefb20: 000000e7 3ffeff08 3ffefc68 40202941
                                3ffefb30: 00000001 3ffeff08 3ffefc68 3ffeeb90
                                3ffefb40: 3ffefc80 00000001 3ffefc68 40202a28
                                3ffefb50: 3fffdad0 00000000 00000006 402022fa
                                3ffefb60: 00000000 3ffefdd4 3ffeeb50 3ffeeb90
                                3ffefb70: 3fffdad0 00000000 00000005 40204bd4
                                3ffefb80: 3fffdad0 00000000 3ffeeb50 40204dbd
                                3ffefb90: 00000000 00000000 3ffeeb50 40204510
                                3ffefba0: 3fffdad0 00000000 3ffeeb50 40204ed4
                                3ffefbb0: feefeffe feefeffe 3ffeeba0 40100114
                                <<<stack<<<
