  3. Temp Sensor and iobroker on rasPi3
25 Posts 4 Posters 9.9k Views 3 Watching
  • mysensors-6043M
    mysensors-6043M
    mysensors-6043
    newby question, sorry ;-)
    I got stuck somehow. Built my Arduino Nano with NRF24L01 board. This is working with RF24 Library/examples between two Arduinos.
    I'd like to attach one sensor to iobroker/mysensors instance. So I took the tempsensor sketch from mysensors Homepage. https://www.mysensors.org/build/temp
    While compiling the sketch I get
    "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IZ:\Arduino\libraries\MySensors" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IZ:\Arduino\libraries\DallasTemperature" "-IZ:\Arduino\libraries\OneWire" "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\sketch\TempSensorRIJ.ino.cpp" -o "C:\Users\juerg\AppData\Local\Temp\build14b4b70b0a2cd12641001758a79163f9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    In file included from Z:\Arduino\MySensors-master\examples\TempSensor\TempSensorRIJ\TempSensorRIJ.ino:29:0:
    Z:\Arduino\libraries\MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    Using library MySensors at version 2.0.0 in folder: Z:\Arduino\libraries\MySensors
    Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
    Using library DallasTemperature at version 3.7.6 in folder: Z:\Arduino\libraries\DallasTemperature
    Using library OneWire at version 2.3.2 in folder: Z:\Arduino\libraries\OneWire
    exit status 1
    Best regards and I appreciate any help :-)
    • mysensors-6043M mysensors-6043
      exit status 1
      sundberg84S
      sundberg84S
      @mysensors-6043 - it looks like there is something wrong with your library i think. Maybe you have library in two different places. Check your sketchfolder and your application(arduino) folder.
      mysensors-6043M 2 Replies Last reply
      • sundberg84S sundberg84
        mysensors-6043M
        mysensors-6043M
        mysensors-6043
        @sundberg84
        Hi thank's a lot for Your answer. Did a reinstall of the IDE, now only one library Installation. Now I get another error
        Arduino: 1.6.11 (Windows 10), Board: "Arduino Nano, ATmega328"
        In file included from C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:30:0:
        C:\Users\juerg\Documents\Arduino\libraries\MySensors-master/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
        C:\Users\juerg\Documents\Arduino\tempSensorRIJ\tempSensorRIJ.ino:32:31: fatal error: DallasTemperature.h: No such file or directory
        compilation terminated.
        exit status 1
          mysensors-6043M
          mysensors-6043M
          mysensors-6043
          @sundberg84
          where do I have to define SSID and wireless key for the WiFi Connection ?
            @sundberg84
            sundberg84S
            sundberg84S
            @mysensors-6043 - good question, never used wifi for MySensors.
            if you are using 2.0 I found this in github:
            #define MY_ESP8266_SSID "MySSID"
            #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
            mysensors-6043M 1 Reply Last reply
              mysensors-6043M
              mysensors-6043M
              mysensors-6043
              @sundberg84
              Hi again, many thank's get closer. I had to install two more libraries (Dallas, OneWire).
              After adding the two definitions above, this is still the error
              exit status 1
              • mysensors-6043M
                mysensors-6043M
                mysensors-6043
                Hey guys
                Getting closer and closer :-)
                I had to set this in Dallas Temperature.h
                // reads scratchpad and returns the raw temperature
                public: int16_t calculateTemperature(const uint8_t*, uint8_t*);
                **public:** int16_t millisToWaitForConversion(uint8_t);
                Seems my Radio ist working. Please see Serial Monitor :+1:
                0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:RADIO:OK
                0;255;3;0;9;TSM:GW MODE
                0;255;3;0;9;TSM:READY
                0;255;0;0;18;2.0.0
                0;255;3;0;11;Relay + Temp
                0;255;3;0;12;1.0
                0;1;0;0;3;
                0;2;0;0;3;
                Now, since I'm use iobroker with a mysensors.0 instance, I'd like to read Temperature within iobroker.
                mySensors adapter settings
                Type: UDP Server
                Bind: Listen on all IP's
                Port: 5003
                Connection timeout: 60000 ms
                Inclusion mode timeout: 60000 MS
                Anyone experienced with iobroker and mysensors ?
                  Hey guys
                  0;255;0;0;18;2.0.0
                  0;255;3;0;12;1.0
                  0;1;0;0;3;
                  0;2;0;0;3;
                  Type: UDP Server
                  Port: 5003
                  mysensors-6043M
                  mysensors-6043M
                  mysensors-6043
                  @mysensors-6043
                  Got some more debug Messages
                  0;255;3;0;9;TSP:SANCHK:OK
                  0;255;3;0;9;TSP:MSG:READ 0-0-0 s=255,c=3,t=14,pt=0,l=25,sg=0:Gateway startup complete.
                  0;255;3;0;9;!TSP:MSG:PVER mismatch
                  • mysensors-6043M
                    mysensors-6043M
                    mysensors-6043
                    Have this up and running on a nodeMCU. WLAN ist ok, get data on iobroker/mysensors instance.
                    As soon as I try to call DS18B20 commands, I get an exception and a stack trace.
                    DS18B20.requestTemperatures();
                    What causes this ?
                      What causes this ?
                      @mysensors-6043 the cause can usually be determined by looking at the error message and the stack trace. Without that information, there is not much we can do to help.
                      • mysensors-6043M
                        mysensors-6043M
                        mysensors-6043
                        This is the code, errormessage and stack info follows, many thanks.
                        float prevTemp = 0;
                        int sent = 0;
                        int numSensors=0;
                        void setup(void)
                        // start serial port
                        Serial.println("Dallas Temperature IC Control Library Demo");
                        // Start up the library
                        sensors.begin();
                        present(i, S_TEMP);
                        void loop(void)
                        // call sensors.requestTemperatures() to issue a global temperature
                        // request to all devices on the bus
                        Serial.print(" Requesting temperatures...");
                        //sensors.requestTemperatures(); // Send the command to get temperatures
                        Serial.println("DONE");
                        Serial.print("Temperature for Device 1 is: ");
                        //Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
                        // You can have more than one IC on the same bus.
                        // 0 refers to the first IC on the wire
                        delay(1000);
                        • mysensors-6043M
                          mysensors-6043M
                          mysensors-6043
                          This is what I get
                          scandone
                          f 0, scandone
                          state: 0 -> 2 (b0)
                          state: 2 -> 3 (0)
                          state: 3 -> 5 (10)
                          add 0
                          aid 1
                          cnt
                          connected with ho....., channel 1
                          dhcp client start...
                          chg_B1:-40
                          .ip:192.168.1.103,mask:255.255.0.0,gw:192.168.1.1
                          .IP: 1Dallas Temperature IC Control Library Demo
                          Locating devices...Found 1 devices.
                          Parasite power is: OFF
                          Device 0 Address: 28FFBE9E70160499
                          Device 0 Resolution: 9
                          Temp C: 20.00 Temp F: 68.00
                          Exception (9):
                          epc1=0x402028cc epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000002f depc=0x00000000
                          ctx: cont
                          sp: 3ffef920 end: 3ffefbc0 offset: 01a0
                          stack>>>
                          3ffefac0: 3ffefafe 0000000a 3ffefaee 40207195
                          3ffefad0: 3ffe8ca8 00000004 000000ff 30207195
                          3ffefae0: ffffffff 00000001 3ffefb0d 30207195
                          3ffefaf0: 00000009 00000000 3ffe8d38 3ffeeb90
                          3ffefb00: 3fffdad0 3ffefc7f 3ffefc68 40203d1c
                          3ffefb10: 3ffefff8 00000000 3ffefc3c 4020486a
                          3ffefb20: 000000e7 3ffeff08 3ffefc68 40202941
                          3ffefb30: 00000001 3ffeff08 3ffefc68 3ffeeb90
                          3ffefb40: 3ffefc80 00000001 3ffefc68 40202a28
                          3ffefb50: 3fffdad0 00000000 00000006 402022fa
                          3ffefb60: 00000000 3ffefdd4 3ffeeb50 3ffeeb90
                          3ffefb70: 3fffdad0 00000000 00000005 40204bd4
                          3ffefb80: 3fffdad0 00000000 3ffeeb50 40204dbd
                          3ffefb90: 00000000 00000000 3ffeeb50 40204510
                          3ffefba0: 3fffdad0 00000000 3ffeeb50 40204ed4
                          3ffefbb0: feefeffe feefeffe 3ffeeba0 40100114
                          <<<stack<<<
