  3. Domoticz
  4. Domotiocz + Rain gauge
61 Posts 12 Posters 45.6k Views 12 Watching
  • sinczeS sincze
    @sundberg84 , very nice. I would say.. I want that as well ;-)
    any suggestions for a shopping and modification list?
    As I don't have a 3D printer to print the thing myself.
    TheoLT
    TheoLT
    TheoL
    @sincze Hello my friend, just curious how many sensors you've got hooked up at the moment?
    • TheoLT TheoL
      @sundberg84 Thanx for your fast reply. So what happens when the float resets to 0?
      sundberg84S
      sundberg84S
      @TheoL - Just to add what we discussed in chat for future questions - If float would hit the maximum value (which is hugh so lets hope its not a problem) im not sure what will happen...
      TheoLT 1 Reply Last reply
      • sundberg84S sundberg84
        TheoLT
        TheoLT
        TheoL
        @sundberg84 It's also not a concern of the MySensors node. This should be handled by Domoticz. I really like your sketch, it works like a charm. I modified it to my needs so that I can run the node without the sleep. Still need to think of an hourly heart beat. But almost there.
        • TheoLT TheoL
          sundberg84S
          sundberg84S
          @TheoL - If you modify the sketch with a heartbeat() please post it :) Im interested as well!
          • TheoLT
            TheoLT
            TheoL
            @AWI do you happen to know if the pulse counter in Domoticz is a 1mm pulse counter? Or is it a real tip pulse counter? Right know where checking whenever the rain fall exceeds 1mm and send a pulse ++ in that case. Meaning we miss some pulse counts when we reset the node.
            AWIA 1 Reply Last reply
            • TheoLT TheoL
              AWIA
              AWIA
              AWI
              @TheoL My rain meter counts in 1 mm resolution but I am sending actual total (in mm) from the start of sensor and keep totals in EEPROM.
              • AWIA AWI
                TheoLT
                TheoLT
                TheoL
                @AWI (Glad that your back, hope you're doing allright) So, if I understand your setup correctly you don't send the pulse count to Domoticz? I kind of like it, because that way I can reset the rain sensor many times and still keep the rain fall log in sync, without using the EPROM.
                And my rain sensor did reset a couple of times. I had to put a diode (Dutch name is blus diode) between the two wires coming out from the rain gauge to prevent this.
                • TheoLT TheoL
                  AWIA
                  AWIA
                  AWI
                  @TheoL (i'm fine, thank you) That is what i'm doing. The only thing what I need to do after a reset is delete the miscalculation in Domoticz (easy). My sensor (oregon) uses a 'reed' switch (no induction). I MySensoriz'ed it without losing the original circuitry and function. (so in parallel).
                  0_1475422212074_upload-82d166bf-a999-4d76-b3e3-8c010fa5f427
                  • AWIA AWI
                    TheoLT
                    TheoLT
                    TheoL
                    wrote on last edited by TheoL
                    #21
                    @AWI A lesson learned a couple of month ago. When using an induction reed switch (some of them have a coil around the glass) always add a reversed diode. Otherwise the polarity of the reed switch is being turned for just a millisecond which is enough to cause the arduino to reset ;-). I'm still learning a lot about electronics.
                    At the moment the diode seems to work. No Arduino resetting for the last couple of hours.
                    Regarding to the pulse counter is seems to work perfectly. That way I don't need to store any values on the EPROM, which is something I prefer not to do. I just query the current pulse count from Domoticz when the sensors boots. Sending the total amount of rain is as easy as pulse count * bucket size. Not real rocket science.
                      TheoLT
                      TheoLT
                      TheoL
                      #22
                      @sundberg84 Here's the first version of the sketch. Note that I don't use the sleep. My main goal for creating my own outside weather station is to get rid of the batteries. Because they always same to stop working whenever I'm not at home.
                       Arduino Tipping Bucket Rain Gauge, SI7021 Temperature + Humidity sensor
                       Created October 2nd 2016
                       Author by Theo
                       This node uses a tipping bucket rain gauge for measuring rain fall. And a si7021 Temperature and Humidity sensor. The logic in
                       this sketch might be specific for Domoticz, because of the Pulse counter.
                       Based upon sketches created by @BulldogLowell / @PeteWill, @sundber84
                       for free public use
                       Hardware used:
                       Arduino Pro Mini 3.3V
                       buck converter
                       nrf24L01+ radio
                       100 uf capacitor
                       2 10K resistors (for i2c)
                       1N007 diode
                       MI-SOL Rain Guage
                       SI7021 sensor
                       Version history:
                       02-10-2016 Initial version
                         Configure MySensors
                      // Enable debug prints
                      // #define MY_DEBUG
                        Include libraries used by the sketch
                      #include "ThresholdUtil.h"
                      #include <math.h>
                      #include <Time.h>
                      #include <SI7021.h>
                         Define constants used by sketch
                      #define BUCKET_PIN 3                  // The Arduino pin to which the bucket is attached. We need an interrupt pin (2 or 3 on the Uno and the Pro Mini)
                      #define SKETCH_INFO "Outside weather" // The name of the sketch as presented to the gateway
                      #define SKETCH_VERSION "1.0"          // The version of the sketch as presented to the gateway
                      #define CHILD_ID_HUM  2               // The child id of the humidity sensor
                      #define CHILD_ID_TEMP 1               // The child id of the temperature sensor
                      #define CHILD_ID_RAIN_LOG 4           // The child id of the rain gauge
                      #define MS_WAIT 100                   // short delay used to give the NRF24L01+ antenna some time to recover from the last data sending
                      #define bucketSize 0.3                // I've used a MI-SOL Rain Guage which has a bucket size of 0.3 mm
                         Declare MySensors messages used by the node
                      MyMessage msgHum( CHILD_ID_HUM, V_HUM );
                      MyMessage msgTemp( CHILD_ID_TEMP, V_TEMP );
                      MyMessage msgRain( CHILD_ID_RAIN_LOG, V_RAIN );
                      MyMessage lastCounterMsg( CHILD_ID_RAIN_LOG, V_VAR1 );
                         Declare variables used by the Sketch
                      SI7021 humiditySensor; // Declare a SI7021 Temp humidity sensor object
                      float hwRainVolume = 0;           // Current rainvolume calculated in hardware.
                      unsigned long hwPulseCounter = 0; // Pulsecount recieved from GW
                      boolean pcReceived = false;       // If we have recieved the pulscount from GW or not
                      unsigned long lastTipTime = millis(); // TS of when the bucket tip has been detected for the last time
                      volatile unsigned long wasTippedCounter; // Queue for storing the tipped counter as been set by the interrupt handler.
                      byte lastHour;                    // Stores the hour used for checking if time needs to be synchronized
                        Present all child's to the gateway and query for the pulse count known by the HA controller.
                        sendSketchInfo( SKETCH_INFO, SKETCH_VERSION );
                        wait( MS_WAIT );
                        present( CHILD_ID_HUM, S_HUM, "Outside temperature" );
                        wait( MS_WAIT );
                        present( CHILD_ID_TEMP, S_TEMP, "Outside humidity" );
                        wait( MS_WAIT );
                        present( CHILD_ID_RAIN_LOG, S_RAIN, "Rain fall" );
                        wait( MS_WAIT );
                        unsigned long functionTimeout = millis();
                        while ( pcReceived == false && millis() - functionTimeout < 30000UL ) {
                          request( CHILD_ID_RAIN_LOG, V_VAR1);
                          Serial.println(F("Getting pulse count"));
                          Serial.println(F("."));
                          wait( 1000 );
                        attachInterrupt( digitalPinToInterrupt( BUCKET_PIN ), sensorTipped, LOW ); //FALLING );  // depending on location of the hall effect sensor may need CHANGE
                         Setup of the sketch. It initializes all sensors and queries the gateway for the current time.
                        Serial.begin( 115200 );
                        pinMode( BUCKET_PIN, INPUT_PULLUP );
                        humiditySensor.begin();
                        registerThresholdedSensor( CHILD_ID_TEMP, 1, TEMPERATURE_SENSOR, 0.5, 30, 20 );
                        registerThresholdedSensor( CHILD_ID_HUM, 2, HUMIDTY_SENSOR, 2.0, 30, 20 );
                        while ( timeStatus() == timeNotSet && millis() - functionTimeout < 30000UL ) {
                          requestTime();
                          Serial.println(F("Getting Time"));
                          wait( 1000 );
                        lastHour = hour();
                        Sends the value of the rain gauge to the Gateway.
                      void sendRainVolumeData() {
                        float hwRainVolume = hwPulseCounter * bucketSize;
                        Serial.print( "Tipped " );
                        Serial.print( hwPulseCounter );
                        Serial.println( " times." );
                        Serial.print( "Rain fall is " );
                        Serial.print( hwRainVolume, 1 );
                        Serial.println( " mm." );
                        send( msgRain.set( (float)hwRainVolume, 1 ) );
                        wait( MS_WAIT );
                        send( lastCounterMsg.set( hwPulseCounter ) );
                        wait( MS_WAIT );
                        Main loop of the node. It checks:
                        - whether the rain gauge bucket has been tipped.
                        - whether the hourly heartbeat needs to be send.
                        - checks all thresholded sensors
                        if ( wasTippedCounter != hwPulseCounter ) {
                          hwPulseCounter = wasTippedCounter;
                          sendRainVolumeData();
                        byte currentHour = hour();
                        if (currentHour != lastHour) {
                          Serial.println( "Resyncing hour" );
                          requestTime(); // sync the time every hour
                          wait( MS_WAIT );
                          lastHour = currentHour;
                          sendRainVolumeData(); // Send heart beat
                        checkThresholdedSensors( readTHSensor, updatedTHSensorValue );
                        Interrupt handler for handling bucket tips.
                      void sensorTipped() {
                        unsigned long thisTipTime = millis();
                        if (thisTipTime - lastTipTime > 100UL) {
                          wasTippedCounter++;
                        lastTipTime = thisTipTime;
                        Threshold util wants to know the current value of a specific sensor.
                      void readTHSensor( uint8_t aSensorId, ThreshHoldedSensorType aType, float *value ) {
                        switch ( aSensorId ) {
                          case CHILD_ID_TEMP:
                            *value = data.celsiusHundredths / 100.0;
                          case CHILD_ID_HUM:
                            *value = data.humidityPercent;
                        Threshhold util detects that the value of a specific sensor needs to be send to the gateway.
                      void updatedTHSensorValue( uint8_t child_id, uint8_t sensor_id, ThreshHoldedSensorType sensor_type, float value ) {
                        switch ( child_id ) {
                          case CHILD_ID_TEMP:
                            Serial.print( "Sending temp " );
                            Serial.println( value, 1 );
                            send( msgTemp.set( value, 1 ) );
                            wait( MS_WAIT );
                          case CHILD_ID_HUM:
                            Serial.print( "Sending Humidity " );
                            send( msgHum.set( value, 1 ) );
                            wait( MS_WAIT );
                        Call back handler for handling time send by the gateway.
                      void receiveTime(unsigned long time) {
                        Serial.println( F("Time received..."));
                        setTime(time);
                        char theTime[6];
                        sprintf(theTime, "%d:%2d", hour(), minute());
                        Serial.println(theTime);
                        Callback handler for handling incomming MySensors message.
                        if ( message.sensor == CHILD_ID_RAIN_LOG && message.type == V_VAR1) { // We only expect pulse count values from the gateway
                          hwPulseCounter = message.getULong();
                          wasTippedCounter = hwPulseCounter;
                          pcReceived = true;
                          Serial.print("Received last pulse count from gw: ");
                          Serial.println(hwPulseCounter);
                      ps. Because the old MySensors API's where removed from the main page, I had to move over to MySensors 2.0. I just uploaded the MySensors 2.0 to my serial gateway and everything seems to work fine. With this I mean all MySensors 1.5 node's are still doing their work. Love it!
                      EDITED: Added rain rate. But still testing.
                      • TheoLT
                        TheoLT
                        TheoL
                        @AWI last question for today. Do you send the rain rate to domoticz as well? Still figuring out how to do this.
                        sundberg84S F 2 Replies Last reply
                        • TheoLT TheoL
                          sundberg84S
                          sundberg84S
                          @TheoL - No I dont, and if i remember right its because i sleep the node I cant do the calculations.
                            TheoLT
                            TheoLT
                            TheoL
                            @sundberg84 I've added it. But so far Domoticz doesn't return a value whenever I query a JSON for the sensor. Maybe it does when the clock switches to the next hour.
                            • TheoLT TheoL
                              F
                              F
                              flopp
                              Domoticz have some sort of rain rate, not like mm/12h, mm/6h but it will give mm/h depending how you send data to Domoticz it will be more or less correct.
                              • F flopp
                                TheoLT
                                TheoLT
                                TheoL
                                @flopp Thank you. What do you mean by sending data correctly? Do you have an example sketch?
                                F 1 Reply Last reply
                                • TheoLT TheoL
                                  F
                                  F
                                  flopp
                                  wrote on last edited by flopp
                                  #28
                                  Not correctly, I wrote depending.
                                  If you send data every 2 hours and ot every time the buck has tiped the rate will not be correct. Lets say you send/report every 2 hour, you report 10 mm, that means you have "collect" 10 mm for 2 hours. Maybe the hour was not raining, then the rate will show you 10mm/h, sorry if I confusing you.
                                  What I mean is that you should send/report directly when the buck has tiped then the rate in DZ will be correct rate/h.
                                  my sketch
                                  // Running this in Domoticz stable version 2.5 will not work - upgrade to beta.
                                  #define DIGITAL_INPUT_SENSOR 3 // The reed switch you attached. (Only 2 and 3 generates interrupt!)
                                  #define CHILD_ID 1 // Id of the sensor child
                                  #define BATT_CHILD 2
                                  #define NODE_ID AUTO // or AUTO to let controller assign
                                  #define SKETCH_NAME "Rain Gauge" // Change to a fancy name you like
                                  #define SKETCH_VERSION "1.8" // Your version
                                  unsigned long SLEEP_TIME = 180*60000; // Sleep time (in milliseconds).
                                  //unsigned long SLEEP_TIME = 20000; // use this instead for debug
                                  int hwPulseCounter = 0; // Pulsecount recieved from GW
                                  float fullCounter = 0; // Counts when to send counter
                                  float bucketSize = 0.5; // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
                                  boolean reedState; // Current state the reedswitch is in
                                  boolean oldReedState; // Old state (last state) of the reedswitch
                                  unsigned long lastSend =0; // Time we last tried to fetch counter.
                                  MyMessage volumeMsg(CHILD_ID,V_RAIN);
                                  MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                                  MyMessage battMsg(BATT_CHILD, V_VOLTAGE);
                                  #define VMIN 1.9 // Vmin (radio Min Volt)=1.9V (564v)
                                  #define VMAX 3.0 // Vmax = (2xAA bat)=3.0V (892v)
                                  int batteryPcnt = 0; // Calc value for battery %
                                  int batLoop = 0; // Loop to help calc average
                                  int batArray[3]; // Array to store value for average calc.
                                  int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
                                  long result;
                                  float batteryPcnt;
                                  float batteryVolt;
                                  pinMode(6,OUTPUT);
                                  digitalWrite(6,HIGH);
                                  //analogReference(INTERNAL); // For battery sensing
                                  pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP); // sets the reed sensor digital pin as input
                                  reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
                                  oldReedState = reedState; // Set startup position for reedswitch
                                  //Begin (Change if you dont want static node_id! (NODE_ID to AUTO)
                                  gw.begin(incomingMessage, NODE_ID, false);
                                  // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
                                  gw.present(CHILD_ID, S_RAIN);
                                  gw.present(BATT_CHILD, S_MULTIMETER);
                                  Serial.println("Startup completed");
                                  delay(100);
                                  //gw.begin(incomingMessage, NODE_ID, false);
                                  unsigned long currentTime = millis();
                                  //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
                                  if (!pcReceived && (currentTime - lastSend > 5000)) {
                                  gw.request(CHILD_ID, V_VAR1);
                                  Serial.println("Request pulsecount");
                                  lastSend=currentTime;
                                  return;
                                  if (!pcReceived) {
                                  return;
                                  //Read if the bucket tipped over
                                  boolean tipped = oldReedState != reedState;
                                  //BUCKET TIPS!
                                  if (tipped==true) {
                                  Serial.println("The bucket has tipped over...");
                                  hwRainVolume = hwRainVolume + bucketSize;
                                  gw.send(volumeMsg.set((float)hwRainVolume,1));
                                  gw.wait(1000);
                                  fullCounter = fullCounter + bucketSize;
                                  //Count so we send the counter for every 1mm
                                  if(fullCounter >= 1){
                                  hwPulseCounter++;
                                  gw.send(lastCounterMsg.set(hwPulseCounter));
                                  gw.wait(1000);
                                  fullCounter = 0;
                                  readVcc();
                                  if (tipped==false) {
                                  //No bucket tipped over last sleep-period, check battery then...
                                  readVcc();
                                  Serial.println("sleep");
                                  digitalWrite(6,LOW);
                                  delay(1000);
                                  gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
                                  //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
                                  //Read if we have a incoming message.
                                  if (message.type==V_VAR1) {
                                  hwRainVolume = hwPulseCounter;
                                  pcReceived = true;
                                  delay(500);
                                  // Battery monitoring reading
                                  delay(500);
                                  // Calculate the battery in %
                                  float Vbat = sensorValue * VBAT_PER_BITS;
                                  if (batLoop > 1) {
                                  batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
                                  if (batteryPcnt > 100) {
                                  batteryPcnt=100;
                                  batLoop = 0;
                                  //Sends 1 per hour as a heartbeat.
                                  batLoop++;
                                  long readVcc() {
                                  Serial.println("readVcc");
                                  ADCSRA |= _BV(ADSC); // Convert
                                  result = ADCL;
                                  result |= ADCH<<8;
                                  result = 1126400L / result; // Back-calculate AVcc in mV
                                  //return result;
                                  batteryPcnt = (result - 3300) * 0.111111;
                                  batteryVolt = result/1000.000;
                                  gw.send(battMsg.set(batteryVolt, 3));
                                  /*Serial.print("battery volt:");
                                  Serial.println(batteryVolt, 3);
                                  Serial.print("battery percent:");
                                  Serial.println(batteryPcnt);
                                  • F flopp
                                    my sketch
                                    long result;
                                    float batteryPcnt;
                                    float batteryVolt;
                                    pinMode(6,OUTPUT);
                                    delay(100);
                                    return;
                                    if (!pcReceived) {
                                    return;
                                    //BUCKET TIPS!
                                    if (tipped==true) {
                                    gw.wait(1000);
                                    hwPulseCounter++;
                                    gw.wait(1000);
                                    fullCounter = 0;
                                    readVcc();
                                    readVcc();
                                    delay(1000);
                                    pcReceived = true;
                                    delay(500);
                                    delay(500);
                                    if (batLoop > 1) {
                                    batteryPcnt=100;
                                    batLoop = 0;
                                    batLoop++;
                                    long readVcc() {
                                    result = ADCL;
                                    result |= ADCH<<8;
                                    //return result;
                                    TheoLT
                                    TheoLT
                                    TheoL
                                    @flopp Thank you for the explanation. I think I've got it.
                                    I've added a RAINRATE msg like this
                                    MyMessage rainRateMsg( CHILD_ID_RAIN_LOG, V_RAINRATE );
                                    But I don't think domoticz uses it.
                                    • TheoLT
                                      TheoLT
                                      TheoL
                                      @sundberg84 Using a real pulse counter instead of a 1mm pulse counter seems to work perfectly. Luckily it makes the sketch a bunch easier to implement and read. And there will also be no loss of 0.2 or 0.5 mm rain fall whenever you reset the node while it didn't have a .0 value.
                                      • TheoLT TheoL
                                        F
                                        F
                                        flopp
                                        @TheoL RAINRATE is implemented according to this page https://github.com/domoticz/domoticz/blob/master/hardware/MySensorsBase.cpp but I don't know how to use it. I know that DZ doesn't work with this example https://www.mysensors.org/build/rain
                                        • F
                                          F
                                          flopp
                                          #32
                                          I have adjust my bucked to tip every ~0.25mm and calibrated it ofcourse
