  3. [SOLVED] latest git-snapshot causes freezes
46 Posts 6 Posters 13.2k Views 5 Watching
  • cimba007C cimba007
    @scalz Thanks for the hint with the while-loop. I changed the i2c-read the following way:
    void FaBo3Axis::readI2c(uint8_t register_addr, uint8_t num, uint8_t buffer[])
      Wire.beginTransmission(_i2caddr);
      Wire.write(register_addr);
      Wire.endTransmission();
      Wire.requestFrom(_i2caddr, num);
      int i = 0;
      uint8_t limit = num;
      while(Wire.available() && limit--)
    	Serial.print("r");
        buffer[i] = Wire.read();
        i++;
    Now it should under no circumstanced read more then the number given. Sadly this had no impact:
     | 34291
    34291 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
    34357 TSF:MSG:ACK
    134390 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    r34471 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
    34537 MCO:SLP:TPD
    34553 MCO:SLP:WUP=1
     | 34553
    34553 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
    34553 TSF:MSG:ACK
    134553 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    Just before the sleep ..
    I then added a Serial.flush() to the "r"-output ..
    	Serial.print("readI2c");
    	Serial.flush();
      int i = 0;
    	Serial.print("r");
    	Serial.flush();
        i++;
    54706 MCO:SLP:WUP=1
     | 54706
    54706 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
    54706 TSF:MSG:ACK
    154706 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    Now the freeze is clearly before entering the sleep function ..
    but then .. on another round ..
     | 56623
    56623 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
    56623 TSF:MSG:ACK
    156623 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    readI2c
    readI2cgot # from slave: 1
    r78987 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
    79052 MCO:SLP:TPD
    79069 MCO:SLP:WUP=1
     | 79069
    79069 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
    79069 TSF:MSG:ACK
    179069 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    readI2c
    So .. your tip was very good .. it seems to be related to the
    -call .. only one questions remains .. why was it working perfectly on the stable library?
    Just to be sure I will run exactly the same code in a non-stop loop with the stable library ..
    tekkaT
    tekkaT
    tekka
    @cimba007 What AVR board defs are you on?
    • cimba007C
      cimba007C
      cimba007
      @tekka said:
      AVR board def
      What do you mean with AVR board def?
      https://forum.mysensors.org/topic/4999/latest-git-snapshot-causes-freezes/17
      I am using an arduino pro-mini china clone (328p) with 8mhz internal oscillator and DIV_8 fuse.
      The bootloader is an "APM Optiboot 1Mhz" .. cant find the link right now.
      tekkaT 1 Reply Last reply
        @tekka said:
        AVR board def
        tekkaT
        tekkaT
        tekka
        wrote on last edited by tekka
        #21
        @cimba007 You'll find the information in your Boards Manager (under Tools | Board | Boards Manager)
        • cimba007C
          cimba007C
          cimba007
          yeah .. sorry
          0_1475435692355_upload-68958f1f-2d52-4640-bdf0-b33688831f9f
            yeah .. sorry
            tekkaT
            tekkaT
            tekka
            @cimba007 ok, do you see it hapepening if you downgrade the AVR board defs to 1.6.12 or 13?
            • cimba007C
              cimba007C
              cimba007
              btw .. the "old" library is running happy for 6 minutes now ... still continuing
              TSP:MSG:READ 0-0-14 s=0,c=1,t=16,pt=2,l=2,sg=0:0
              1TSP:MSG:SEND 14-14-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=ok:0
              r | 373997
              r | 374177
              @tekka: I will try the "new snapshot" with the board defs you mentioned .. standby
              • cimba007C
                cimba007C
                cimba007
                @1.6.12 board defs
                r68550 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
                68599 MCO:SLP:TPD
                68632 MCO:SLP:WUP=1
                 | 68632
                68632 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                68632 TSF:MSG:ACK
                168632 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                readI2c
                @1.6.13 board defs
                r62914 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255
                62980 MCO:SLP:TPD
                62996 MCO:SLP:WUP=1
                 | 62996
                62996 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0
                62996 TSF:MSG:ACK
                162996 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
                readI2c
                  #26
                  hmm..too bad that didn't do the trick..but there was something (and that's an issue which can appear easily when using other libs, "hidden" while) and difficult to reproduce exactly the same case on my side as i'm not using the same radio.
                  i've dl the latest snpashot. so i will check on my side if one of my sketch is still running fine (with 4ints) and if i get the problem i'll try to debug it too. but i hope to not get it lol :)
                  • cimba007C
                    cimba007C
                    cimba007
                    That would be nice .. my latest findings point out that the i2c-function is getting stuck. I investigated the i2c-source of arduino a bit and found out it is quite depending on interrupts.
                    This is now
                    wild speculation
                    For some reason interrupts got disabled while the i2c library is trying to write some data on the i2c-bus ..
                    wild-speculation-end
                    • cimba007C
                      cimba007C
                      cimba007
                      wrote on last edited by cimba007
                      #28
                      Code working: (4minutes+)
                        sei();
                        fabo3axis.readIntStatus();
                      Code not working:
                        //sei();
                      I noticed that interrupts in the sleep function are only detached if the intrrupt occurs ..
                      whereas in the stable
                      	detachInterrupt(interrupt1);
                      	if (interrupt2!=0xFF) detachInterrupt(interrupt2);
                      They get detached after the wakeup in the sleep ..
                      What if .. for some strange reason the interrupt is interfearing with .. whatever?!
                      EDIT: with the added sei(); the node is running for 10 minutes now ...
                      EDIT2: Running for 20 minutes now ..
                        @ikkeT Are you using the latest stable or snapshot version?
                        ikkeTI
                        ikkeTI
                        ikkeT
                        @cimba007 I cloned the master branch from git about week ago. Or which ever is the default. I'll come back tomorrow, already in bed now.
                        • tekkaT tekka
                          @cimba007 Thanks, I'll try to reproduce it. What Arduino IDE & AVR Board defs are you using?
                          @ikkeT Same here, can you upload your (minimal) sketch to reproduce and also indicate MySensors, Arduino IDE and AVR board def versions?
                          ikkeTI
                          ikkeTI
                          ikkeT
                          @tekka the scetch is here along with the libraries, just use it as Arduino folder to reproduce:
                          https://github.com/ikke-t/sensebender
                          I'll check the versions tomorrow (UTC+3). The arduino ide is 1.6.xx whatever is the very latest in Fedora 24.
                          • ikkeTI
                            ikkeTI
                            ikkeT
                            wrote on last edited by ikkeT
                            #31
                            @tekka, the versions are:
                            Mysensors is development branch, I didn't pay attention while cloning, it's set to default to development:
                            commit 8cacb4825b256f63aa2fc51468fd11a90bb19678
                            Merge: 75a100f 8ccb1ca
                            Author: Patrick Fallberg <patrick@fallberg.net>
                            Date:   Thu Sep 22 19:02:11 2016 +0200
                            Arduino IDE is 1.6.4
                            $ rpm -qa arduino*
                            arduino-core-1.6.4-8.fc24.noarch
                            arduino-doc-1.6.4-8.fc24.noarch
                            arduino-1.6.4-8.fc24.noarch
                            My IDE board manager shows Arduino AVR boards version 1.6.7, and it seems there is newer one available, 1.6.14. I will update that.
                            Mysensors AVR board definition for Micro version is 1.0.1
                              so far, on my side, using custom sleep() and other mix, my ints are still working..i'm using latest snap' now, and still in 1.6.8..
                              but that's not the same usecase as i'm not using mys sleep for this node..
                              I will try your case; at least mine is working well :) . it could be sort of race..always a dilemma somewhere..
                              • cimba007C
                                cimba007C
                                cimba007
                                #33
                                I got suspecious about the code working with the manual adding of sei() before calling the i2cread-function.
                                So I changed the end of hwPowerDown to include a serial output with a flush.
                                	// restore saved WDT settings
                                	WDTCSR = WDTsave;
                                	Serial.println("sei()");
                                	Serial.flush();
                                	sei();
                                	// enable ADC
                                	ADCSRA |= (1 << ADEN);
                                Now have a close look at how sei()-output is missing just before the freeze:
                                57114 MCO:SLP:TPD<\n>
                                sei()<\r><\n>
                                57147 MCO:SLP:WUP=-1<\n>
                                 | 57180<\r><\n>
                                57180 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n>
                                57245 TSF:MSG:ACK<\n>
                                157262 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0<\n>
                                readI2cgot # from slave: 1<\r><\n>
                                r57376 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255<\n>
                                57442 MCO:SLP:TPD<\n>
                                sei()<\r><\n>
                                57475 MCO:SLP:WUP=-1<\n>
                                 | 57491<\r><\n>
                                57507 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n>
                                57573 TSF:MSG:ACK<\n>
                                157589 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0<\n>
                                r57704 MCO:SLP:MS=16,SMS=0,I1=1,M1=3,I2=255,M2=255<\n>
                                57769 MCO:SLP:TPD<\n>
                                57786 MCO:SLP:WUP=1<\n>
                                 | 57786<\r><\n>
                                57786 TSF:MSG:READ,0-0-14,s=0,c=1,t=16,pt=2,l=2,sg=0:0<\n>
                                57786 TSF:MSG:ACK<\n>
                                157786 TSF:MSG:SEND,14-14-0-0,s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0<\n>
                                readI2c
                                Just after "57769 MCO:SLP:TPD<\n>" the sei()-output is missing. Thus I suspect that interrupts are not enabled when the readI2c-function is called .. and as i2c is depending on interrupts the code gets stuck there.
                                Still no idea why the sei() is "sometimes" not called ...
                                Notice how the "millis" interrupt is not called after the missing sei .. thus all timestamps are the same:
                                 | 57786<\r><\n>
                                readI2c
                                • cimba007C
                                  cimba007C
                                  cimba007
                                  #34
                                  Comparing the code to the atmel documentation here:
                                  http://www.atmel.com/webdoc/AVRLibcReferenceManual/group__avr__sleep.html
                                  mysensors explicit disables interrupts after wake from sleep:
                                  	sei();
                                      // Directly sleep CPU, to prevent race conditions! (see chapter 7.7 of ATMega328P datasheet)
                                  	sleep_cpu();
                                      sleep_disable();
                                  	// restore previous WDT settings
                                  	cli();
                                  whereas the atmel documentation enables interrupts
                                  #include <avr/interrupt.h>
                                      #include <avr/sleep.h>
                                    set_sleep_mode(<mode>);
                                    cli();
                                    if (some_condition)
                                      sleep_enable();
                                      sleep_bod_disable();
                                      sei();
                                      sleep_cpu();
                                      sleep_disable();
                                    sei();
                                  Might not be totally related as the code did not change from last stable .. except one line:
                                  	WDTCSR |= (1 << WDIE); // set the WDIE flag to enable interrupt callback function.
                                  is now missing in the snapshot ..
                                  Adding an extra sei() after the sleep_disable() is not the solution .. still thought it might be noteworthy
                                    	sei();
                                    	sleep_cpu();
                                        sleep_disable();
                                    	cli();
                                      cli();
                                      if (some_condition)
                                        sleep_enable();
                                        sei();
                                        sleep_cpu();
                                        sleep_disable();
                                      sei();
                                    #35
                                    Can you indicate where this change is located?
                                    I compared 2.0.0 (master) to 2.0.1beta (development) and WDTCSR is only touched in MyHwATMega328.cpp
                                    The watchdog related parts seem identical between both versions...
                                    Futhermore, is it the library located at https://github.com/FaBoPlatform/FaBo3Axis-ADXL345-Library/blob/master/src/FaBo3Axis_ADXL345.cpp that you are using?
                                    • cimba007C
                                      cimba007C
                                      cimba007
                                      #36
                                      Jep, this is the library.
                                      https://github.com/mysensors/MySensors/blob/development/core/MyHwATMega328.cpp#L86
                                      https://github.com/mysensors/MySensors/blob/master/core/MyHwATMega328.cpp#L75
                                      well .. I have no idea but on my code it is there:
                                      0_1475516793275_upload-115e8437-9933-4d71-ba85-0f3f11ea7036
                                      Seems to be neither in the stable nor the developement branch .. but I most gotten it somewhere .. lets check
                                      I think I added it for some reason on latest stable. Otherwise pinchage-interrupt was not working with mysensors-library .. I will try to remove it on stable to see if I get stuck there too and add in snapshot to see if it helps in some way.
                                      EDIT1: Adding in the latest snapshot doesn't change a thing
                                      EDIT2: Removing it in the latest stable doesn't change a thing
                                      I might have added it from another testsketch .. but it would be better located in that sketch right after the sleep function .. so just ignore it for now - my bad ;_(
                                        @cimba007 Well, I filed (https://github.com/mysensors/MySensors/issues/598) and fixed (https://github.com/mysensors/MySensors/pull/599) and issue with interrupts not being detached correctly in all cases when using hwSleep().
                                        This might be causing your issue, but is hard to say without actually debugging the code.
                                        Once the PR is merged, could you try getting the latest development branch and see if it fixes the issue? (please use the development branch, without any local modifications)
                                        • cimba007C
                                          cimba007C
                                          cimba007
                                          #38
                                          Just copy'pasted your fix and .. voila
                                          Problems seems to be solved - although I do not unterstand why?!
                                          • _wakeUp2Interrupt should be totally unrelated as it is never set
                                          • detach should happen in the ISR
                                          .. even if the interrupt is not detached correctly .. how should it lead to the total skip of these code:
                                          	cli();
                                          	wdt_reset();
                                          	// enable WDT changes
                                          	WDTCSR |= (1 << WDCE) | (1 << WDE);
                                          	WDTCSR = WDTsave;
                                          	Serial.flush();
                                          	sei();
                                          	// enable ADC
                                          	//WDTCSR |= (1 << WDIE); // set the WDIE flag to enable interrupt callback function.
                                          As this code-snipped is skipped sei() gets never called in my case .. and the subsequent call to i2c freezes the node ... as i2c depends on interrupts ..
                                          Anyway thanks Yveaux .. althour your fix is simple .. i don't know why it is working ...
                                          EDIT: Furthermore .. even if the interrupt is not detached in the isr .. there should be no further interrupt if the interrupt register is not read via i2c .. and that in fact doesn't happen >:>
