  3. Advice about RF nRF24L01+ to send/receive sensory information
29 Posts 3 Posters 11.9k Views 2 Watching
  • Walyson Albuquerque MachadoW Walyson Albuquerque Machado
    Hey!
    Thanks @mfalkvidd !
    I'm trying to make the module nRF24l01+ work with the micro SD card in parallell and I'm having some trouble.
    The micro SD card is working, but the nRF24l01+ not.
    The nRF24l01+ works fine when there's no micro SD card.
    Can anyone give me a help, please!?
    TX:
    #include <RF24.h>
    #define REFRESH_TIME 1000
    RF24 radio (9, 10);
    byte enderecos[][6] = {"1node"};
    float dadosenviados[2];
    // Bateria
    int sensorTensaoDC = A0;
    float valorTensaoDC;
    int amostragem = 1000;
    float mediaTotalTensaoDC = 0;
    float R1 = 28000.0;
    float R2 = 7600.0;
    int sensorValue_aux = 0;
    float voltsporUnidade = 0.004887586;// 5%1023
    //Velocidade
    unsigned long lastRefresh = millis();
    float circMetric = 0.17;
    volatile long loopCount = 0;
    void setup ()
      analogReference(DEFAULT);
      pinMode(A0, INPUT);
      attachInterrupt(0, speedCalc, RISING);
      radio.begin();
      radio.openWritingPipe(enderecos[0]);
      radio.stopListening();
    void bateria ()
      for(int i=0; i < amostragem ; i++)
        valorTensaoDC = analogRead(sensorTensaoDC);
        valorTensaoDC =(valorTensaoDC*voltsporUnidade);
        mediaTotalTensaoDC = mediaTotalTensaoDC+ (valorTensaoDC / (R2/(R1+R2)));
        delay(1);
      dadosenviados[0] = mediaTotalTensaoDC / amostragem;
    void velocidade ()
      if (millis() - lastRefresh >= REFRESH_TIME)
        detachInterrupt(0);
        dadosenviados[1] = (3600*circMetric*loopCount)/(millis() - lastRefresh);
        loopCount = 0;
    void speedCalc()
      loopCount++;
    void envio ()
      radio.write(&dadosenviados, sizeof(dadosenviados));
      delay(10);
      dadosenviados[0] = 0;
      dadosenviados[1] = 0;
      bateria();
      velocidade();
      envio();
    RX:
    #include <SD.h>
    #include <RF24.h>
    #include <LiquidCrystal.h>
    #define CE_PIN   9 // RF
    #define CSN_PIN 10 //RF
    #define SS_P 8// SD
    RF24 radio (9, 10);
    File dataFile;
    LiquidCrystal lcd(3, 2, 7, 6, 5, 4);
    String dadosrecebidos[2];
    void setup ()
    pinMode(CSN_PIN, OUTPUT); // RF
    pinMode(CE_PIN, OUTPUT); // RF
    pinMode(SS_P, OUTPUT); // SD
      digitalWrite(SS_P, HIGH);
      digitalWrite(CSN_PIN, HIGH);
      digitalWrite(CE_PIN, HIGH);
      SPI.begin();
      delay(50);
      digitalWrite(CSN_PIN, LOW);
      digitalWrite(CE_PIN, LOW);
        radio.begin();
        radio.openReadingPipe(1, enderecos[0]);
        radio.startListening();
      lcd.begin(20, 4);
      lcd.clear();
      lcd.setCursor(5, 0);
      lcd.print("Teste 1.6");
      delay(5000);
      lcd.setCursor(3, 2);
      lcd.print("Carregando...");
      delay(5000);
      lcd.clear();
      digitalWrite(SS_P, LOW);
        if (SD.begin(SS_P))
        lcd.setCursor(0, 0);
        lcd.print("Cartao presente!");
        lcd.setCursor(0, 1);
        lcd.print("Pronto para gravar.");
        delay(5000);
        lcd.setCursor(3, 3);
        lcd.print("Iniciando...");
        delay(5000);
        lcd.print("Insira o cartao!");
        lcd.print("Se ja inseriu,");
        lcd.setCursor(0, 2);
        lcd.print("verifique o");
        lcd.setCursor(0, 3);
        lcd.print("cartao");
        delay(5000);
        dataFile = SD.open("datalog.txt", FILE_WRITE);
        if (dataFile)
        dataFile.println("Tensão e velocidade");
        dataFile.close();
        dataFile.println("Erro");
    void recebido ()
       if (radio.available())
        while (radio.available())
          radio.read(&dadosrecebidos, sizeof(dadosrecebidos));
        lcd.clear();
        lcd.print("TENSAO");
        lcd.setCursor(7, 0);
        lcd.print(dadosrecebidos[0]);
        lcd.print("VOLTS");
        lcd.print("VELOCIDADE");
        lcd.setCursor(11, 1);
        lcd.print(dadosrecebidos[1]);
        lcd.print("KM/H");
    void gravar()
      // make a string for assembling the data to log:
      String dataString = ""; //this line simply erases the string
      dataString += "Tensao ";
      dataString += (dadosrecebidos[0]);
      dataString += " VOLTS";
      dataString += " / ";     //puts a comma between the two bits of data
      dataString += "Velocidade ";
      dataString += (dadosrecebidos[1]);
      dataString += " KM/H";
      delay (1000);
      // if the file is available, write to it:
      if (dataFile)
        dataFile.println(dataString);
        dataFile.close();
      // if the file isn't open, pop up an error:
    void loop ()
      recebido();
      gravar();
    AWIA
    AWIA
    AWI
    @Walyson-Albuquerque-Machado from your sketch I conclude that you are not using MySensors as framework for creating you sensor and logger.
    @mfalkvidd gave you some good suggestions for using a SPI bus interface.
    The purpose of this forum is to work with/ discuss the MySensors framework.
    Give MySensors a try and discover that it solves a lot of your low level interface issues.
    Walyson Albuquerque MachadoW 1 Reply Last reply
    • AWIA AWI
      @AWI Hi.
      Sure, I'm going to try and then I come back here.
        Hey. I'm trying to use Mysensors, but I got these errors. Are there a specific command that I should use? I didn't find any example.
        error: 'RF24' does not name a type RF24 radio(MY_RF24_CE_PIN, MY_RF24_CS_PIN);
        error: 'radio' was not declared in this scope radio.begin();
        AWIA 1 Reply Last reply
          AWIA
          AWIA
          AWI
          @Walyson-Albuquerque-Machado The MySensors site is full of examples. You probably have an incomplete instalation or conflicting (RF24) libararies. Try getting started
            I'm getting started and I'm researching about Mysensors. I would like some tips, please.
            I know that I must set this first:
            #define RF24_CE_PIN       9
            #define RF24_CS_PIN      10
            #define RF24_PA_LEVEL      RF24_PA_MAX
            #define RF24_CHANNEL     76
            #define RF24_DATARATE      RF24_250KBPS
            #define SOFTSPI
            #ifdef SOFTSPI
            #include <MyConfig.h>
            And I know that in 2.0.x I don't need to set this:
             .begin();
            But I don't know how to define in Mysensors when it's Writing / stopListening and Reading / startListening
            startListening();
            Also how to Write the sensor information and Read:
            Is this how I send the sensor information? If so, how do I read?
              sendSketchInfo("Distance Sensor", "1.0");
              present(CHILD_ID, S_DISTANCE);
              #define SOFTSPI
              #ifdef SOFTSPI
               .begin();
              startListening();
              AWIA
              AWIA
              AWI
              @Walyson-Albuquerque-Machado You are getting on track. You should not bother about the radio, it is hidden (abstracted) in MySensors. You send with the "send" function and receive with the "receive" function. Everything as described in the API.
              I would suggest you build a simple sensor/sketch (i.e. relay actuator) before diving deeper.
              I am still taking some tough lessons combining devices on the SPI bus. Like @mfalkvidd mentioned in his post
              Let us know your progress.
                I'm trying to do the battery level example and I'm getting this:
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=10)
                TSM:FPAR
                TSP:MSG:SEND 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSP:MSG:READ 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                TSP:MSG:BC
                TSM:FPAR
                TSP:MSG:BC
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                What does it mean? Why can't I read the serial messages?
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSP:MSG:BC
                  TSM:FPAR
                  TSP:MSG:BC
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  AWIA
                  AWIA
                  AWI
                  Your node does not find a parent (gateway) so no response from another node. For documentation: a little indirect but this post by @mfalkvidd should help.
                    Ok, I'm getting there. I appreciate your advices, thanks. :smile:
                    Now I can see the battery level in the serial. But I didn't understand how to receive the battery level in the gateway to show on my LCD display.
                    Gateway ok:
                    0;255;3;0;9;TSM:INIT
                    0;255;3;0;9;TSM:RADIO:OK
                    0;255;3;0;9;TSM:GW MODE
                    0;255;3;0;9;TSM:READY
                    0;255;0;0;18;2.0.0
                    0;255;3;0;9;TSP:MSG:READ 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    0;255;3;0;9;TSP:MSG:BC
                    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=10)
                    0;255;3;0;9;TSP:MSG:GWL OK
                    0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                    0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                    0;255;3;0;9;TSP:MSG:PINGED (ID=10, hops=1)
                    0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                    0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                    0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                    10;255;0;0;17;2.0.0
                    0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    10;255;3;0;6;0
                    0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Battery Meter
                    0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                    0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                    0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                    Node ok:
                    TSM:INIT
                    RF24:write register, reg=0, value=14
                    RF24:read register, reg=6, value=35
                    RF24:flushRX
                    TSM:RADIO:OK
                    RF24:start listening
                    RF24:write register, reg=10, value=10
                    TSM:FPAR
                    RF24:stop listening
                    RF24:open writing pipe, recipient=255
                    RF24:write register, reg=10, value=255
                    RF24:send message to 255, len=7
                    RF24:flushTX
                    RF24:MAX_RT
                    TSP:MSG:READ 0-0-10 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    TSP:MSG:FPAR (PPAR FOUND)
                    TSP:MSG:PAR OK (ID=0, dist=1)
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=10)
                    TSM:UPL
                    TSP:PING:SEND (dest=0)
                    TSP:MSG:PONG RECV (hops=1)
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    Init complete, id=10, parent=0, distance=1, registration=1
                    Battery Voltage: 0.00 V
                    Battery Voltage: 5.91 V
                      Gateway ok:
                      0;255;0;0;18;2.0.0
                      10;255;0;0;17;2.0.0
                      10;255;3;0;6;0
                      Node ok:
                      TSM:INIT
                      RF24:flushRX
                      TSM:RADIO:OK
                      TSM:FPAR
                      RF24:stop listening
                      RF24:flushTX
                      RF24:MAX_RT
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:UPL
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      AWIA
                      AWIA
                      AWI
                      @Walyson-Albuquerque-Machado Back to one of your previous posts. What kind of LCD display are you using. Do you have one with I2C interface?
                        Hey. I don't have I2C interface. Do I need it?
                        I have one like this, 20x4:
                          AWIA
                          AWIA
                          AWI
                          @Walyson-Albuquerque-Machado It is much easier to connect an I2C display (only 2 wires and power).But if you have pins left on your arduino and the patience to solder you're ok.
                          an adapter plate:
                            I have pins and I have already done this. :stuck_out_tongue_closed_eyes:
                              Is that how I send ? Can I use BINARY to my hall effect sensor? I'm using the digital pin to count every time it passes through a magnet.
                              MyMessage msg(NODE_ID, V_STATUS);
                              float value = 0;
                                  present(NODE_ID, S_BINARY);
                                  send(msg.set(value));
                              Is that how I receive?
                                  // Handle incoming message
                                Please, someone tell me how to get the voltage that i'm receiving. I've tried many things, I don't know why this doesn't work.
                                msgvolt.getFloat();
                                I can see the battery in the gateway through serial, but I don't know how to get it to show on the LCD.
                                Node:
                                #define MY_DEBUG_VERBOSE_RF24
                                #define DESTINATION_NODE 0
                                #define MY_NODE_ID 10
                                #define MY_PARENT_NODE_ID  0
                                #define MY_RF24_CE_PIN 9
                                #define MY_RF24_CS_PIN 10
                                #define MY_RF24_PA_LEVEL_GW RF24_PA_LOW
                                #define MY_RF24_CHANNEL 76
                                float R1 = 28000.0;
                                float R2 = 7600.0;
                                float voltsporUnidade = 0.005278592; // 5%1023
                                float dadosenviados;
                                MyMessage msgvolt(4, V_VOLTAGE);
                                  pinMode(A0, INPUT);
                                   sendSketchInfo("Battery Meter", "1.0");
                                   present(4, S_MULTIMETER, "Voltage", true);
                                  dadosenviados = mediaTotalTensaoDC / amostragem;
                                   Serial.print(dadosenviados);
                                   Serial.println(" V");
                                 send(msgvolt.setDestination(DESTINATION_NODE).set(dadosenviados, 2), 1);
                                  wait(2000);
                                Gateway:
                                #define MY_GATEWAY_SERIAL
                                #define MY_NODE_ID 0
                                #define DESTINATION_NODE 10
                                float dadosenviados = 0;
                                  lcd.begin(20, 4);
                                  lcd.clear();
                                  delay(5000);
                                  delay(5000);
                                  lcd.clear();
                                      sendSketchInfo("Battery Meter", "2.0");
                                      present(4, S_MULTIMETER);
                                void receive(const MyMessage &msgvolt) {
                                  saveState(msgvolt.sensor, msgvolt.getFloat());
                                 dadosenviados = msgvolt.getFloat();
                                request(4, V_VOLTAGE, 10);
                                void incomingMessage(const MyMessage &msgvolt) {
                                    lcd.clear();
                                    lcd.print(dadosenviados);
                                    lcd.print("VOLTS");
                                    lcd.print(msgvolt.getFloat());
                                    wait(1000);
                                      Serial.print("Battery Voltage: ")`;
                                  msgvolt.getFloat();
                                  Node:
                                  float R1 = 28000.0;
                                  float R2 = 7600.0;
                                    pinMode(A0, INPUT);
                                    wait(2000);
                                  Gateway:
                                    lcd.begin(20, 4);
                                    lcd.clear();
                                    delay(5000);
                                    delay(5000);
                                    lcd.clear();
                                      lcd.clear();
                                      lcd.print("VOLTS");
                                      wait(1000);
                                  AWIA
                                  AWIA
                                  AWI
                                  wrote on last edited by AWI
                                  #21
                                  @Walyson-Albuquerque-Machado a few things :
                                  • the receive routine should be the only place where you receive and read the incoming messages. So skip the incomingmessage routine and add its functionality to receive.
                                  • you don't need to 'request' anything as the node already sends messages all the time.
                                  • savestate writes only byte (8 bit) values, so you need to decompose a float to bytes in order to save it. (best to use an 'union' for that)
                                  Be aware that the gateway (node 0) receives the messages from all nodes connected. You need to make sure that that the incoming message is the one to display.
                                  In summary, to receive messages : the receive routine is called automatically when a message is received. You read the message content (store in a global variable) , and display it.
                                    wrote on last edited by Walyson Albuquerque Machado
                                    #22
                                    Ok, I'm going to erase the void incomingMessage(const MyMessage &msgvolt) and the request(4, V_VOLTAGE, 10).
                                    Also no savestate.
                                    I tried to store in a global variable and display, but I didn't understand It, how do I read!?
                                      if (msgvolt.type==V_VOLTAGE) {
                                        digitalWrite(msgvolt.sensor, msgvolt.getFloat());
                                    Serial.println(msgvolt.getFloat());
                                    Serial.println(dadosenviados);
                                    Serial.println(msgvolt.data);
                                    This is what I'm getting in the serial:
                                    Node:
                                    Battery Voltage: 8.68 V
                                    RF24:stop listening
                                    RF24:open writing pipe, recipient=0
                                    RF24:write register, reg=10, value=0
                                    RF24:write register, reg=16, value=0
                                    RF24:send message to 0, len=12
                                    RF24:flushTX
                                    RF24:write register, reg=7, value=48
                                    RF24:write register, reg=0, value=15
                                    TSP:MSG:SEND 10-10-0-0 s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:8.68
                                    RF24:read message, len=12
                                    RF24:write register, reg=7, value=64
                                    TSP:MSG:READ 0-0-10 s=4,c=1,t=38,pt=7,l=5,sg=0:8.68
                                    Battery Voltage: 8.69 V
                                    Gateway:
                                    10;4;1;0;38;8.68
                                    0;255;3;0;9;TSP:MSG:READ 10-10-0 s=4,c=1,t=38,pt=7,l=5,sg=0:8.68
                                    0;255;3;0;9;TSP:MSG:ACK msg
                                    0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:8.68
                                    10;4;1;0;38;8.68
                                      Also no savestate.
                                      Node:
                                      RF24:stop listening
                                      RF24:flushTX
                                      Gateway:
                                      10;4;1;0;38;8.68
                                      10;4;1;0;38;8.68
                                      AWIA
                                      AWIA
                                      AWI
                                      @Walyson-Albuquerque-Machado Apart from the line digitalWrite(msgvolt.sensor, msgvolt.getFloat()); (what do you want to accomplish here? wrtie a float value to a digital output?) it should be fine. The gateway is receiving the volt message so communication is working.
                                      this dadosenviados = msgvolt.getFloat(); variable should hold the value, but does not seem to be executed. Try with a println if the "receive" routine is called at all. As you are receiving values with a gateway (node = 0) this is a special case. I need to emulate this. As we seem to be living in a different timezones it can take a while...
                                      So if anybody else has a direct answer...
                                        Hello! Hm, I removed the digitalWrite and I don't undestand why it doesn't get the data. I tried to print something in the receive routine and I got nothing. What do you mean about special case?
                                        Thanks for the time spent with me.
                                          AWIA
                                          AWIA
                                          AWI
                                          @Walyson-Albuquerque-Machado I mirrored your setup and tried to read the messages coming into the gateway, No succes :-(
                                          The "special" situation is that it's only recent that a Gateway can have locally attached sensors (and actuators..) As mentioned before the gateway receives messages from all the sensors in a (standard) MySensors netword (node 0) to forward them to a controller.
                                          I'm sure I did this before so need to investigate a little further.
                                          Basic question is: Does the receive() function in a gateway react to incoming sensor messages?
                                          12.5k
