  3. Advice about RF nRF24L01+ to send/receive sensory information
29 Posts 3 Posters 11.9k Views 2 Watching
  • Walyson Albuquerque MachadoW Walyson Albuquerque Machado
    @mfalkvidd Thank you! I really appreciated your advices.
    I'm using two Arduinos UNO and at the moment I can see battery level using a lcd and a voltage sensor module.
    Now I'm going to build the nRF module, but I have a doubt about the Arduino UNO pin using SPI interface MOSI, MISO and SCK.
    One UNO with nRF > pin 11, 12 and 13 / SD card > pin 11, 12 and 13
    Another UNO with nRF > pin 11, 12 and 13 / lcd > pin 11, 12, 2, 3, 4 and 5
    They use the same pins, what am I gonna do? Put them in parallel?
    @Walyson-Albuquerque-Machado it depends on which libraries and which lcd and sd card reader you are using. Some can be put in parallell, with addition of a slave select pin. An alternative is to use softspi as described in https://www.mysensors.org/build/ethernet_gateway and https://github.com/mysensors/MySensors/blob/development/examples/GatewayW5100/GatewayW5100.ino#L57
    With softspi, an extra spi bus is created and one of the components (the w5100 ethernet module in the above example) is connected to the extra bus so it does not interfere with the nrf.
    https://learn.sparkfun.com/tutorials/serial-peripheral-interface-spi is a good start if you want to learn more about spi.
      wrote on last edited by Walyson Albuquerque Machado
      Hey!
      Thanks @mfalkvidd !
      I'm trying to make the module nRF24l01+ work with the micro SD card in parallell and I'm having some trouble.
      The micro SD card is working, but the nRF24l01+ not.
      The nRF24l01+ works fine when there's no micro SD card.
      Can anyone give me a help, please!?
      TX:
      #include <RF24.h>
      #define REFRESH_TIME 1000
      RF24 radio (9, 10);
      byte enderecos[][6] = {"1node"};
      float dadosenviados[2];
      // Bateria
      int sensorTensaoDC = A0;
      float valorTensaoDC;
      int amostragem = 1000;
      float mediaTotalTensaoDC = 0;
      float R1 = 28000.0;
      float R2 = 7600.0;
      int sensorValue_aux = 0;
      float voltsporUnidade = 0.004887586;// 5%1023
      //Velocidade
      unsigned long lastRefresh = millis();
      float circMetric = 0.17;
      volatile long loopCount = 0;
      void setup ()
        analogReference(DEFAULT);
        pinMode(A0, INPUT);
        attachInterrupt(0, speedCalc, RISING);
        radio.begin();
        radio.openWritingPipe(enderecos[0]);
        radio.stopListening();
      void bateria ()
        for(int i=0; i < amostragem ; i++)
          valorTensaoDC = analogRead(sensorTensaoDC);
          valorTensaoDC =(valorTensaoDC*voltsporUnidade);
          mediaTotalTensaoDC = mediaTotalTensaoDC+ (valorTensaoDC / (R2/(R1+R2)));
          delay(1);
        dadosenviados[0] = mediaTotalTensaoDC / amostragem;
      void velocidade ()
        if (millis() - lastRefresh >= REFRESH_TIME)
          detachInterrupt(0);
          dadosenviados[1] = (3600*circMetric*loopCount)/(millis() - lastRefresh);
          loopCount = 0;
      void speedCalc()
        loopCount++;
      void envio ()
        radio.write(&dadosenviados, sizeof(dadosenviados));
        delay(10);
        dadosenviados[0] = 0;
        dadosenviados[1] = 0;
        bateria();
        velocidade();
        envio();
      RX:
      #include <SD.h>
      #include <RF24.h>
      #include <LiquidCrystal.h>
      #define CE_PIN   9 // RF
      #define CSN_PIN 10 //RF
      #define SS_P 8// SD
      RF24 radio (9, 10);
      File dataFile;
      LiquidCrystal lcd(3, 2, 7, 6, 5, 4);
      String dadosrecebidos[2];
      void setup ()
      pinMode(CSN_PIN, OUTPUT); // RF
      pinMode(CE_PIN, OUTPUT); // RF
      pinMode(SS_P, OUTPUT); // SD
        digitalWrite(SS_P, HIGH);
        digitalWrite(CSN_PIN, HIGH);
        digitalWrite(CE_PIN, HIGH);
        SPI.begin();
        delay(50);
        digitalWrite(CSN_PIN, LOW);
        digitalWrite(CE_PIN, LOW);
          radio.begin();
          radio.openReadingPipe(1, enderecos[0]);
          radio.startListening();
        lcd.begin(20, 4);
        lcd.clear();
        lcd.setCursor(5, 0);
        lcd.print("Teste 1.6");
        delay(5000);
        lcd.setCursor(3, 2);
        lcd.print("Carregando...");
        delay(5000);
        lcd.clear();
        digitalWrite(SS_P, LOW);
          if (SD.begin(SS_P))
          lcd.setCursor(0, 0);
          lcd.print("Cartao presente!");
          lcd.setCursor(0, 1);
          lcd.print("Pronto para gravar.");
          delay(5000);
          lcd.setCursor(3, 3);
          lcd.print("Iniciando...");
          delay(5000);
          lcd.print("Insira o cartao!");
          lcd.print("Se ja inseriu,");
          lcd.setCursor(0, 2);
          lcd.print("verifique o");
          lcd.setCursor(0, 3);
          lcd.print("cartao");
          delay(5000);
          dataFile = SD.open("datalog.txt", FILE_WRITE);
          if (dataFile)
          dataFile.println("Tensão e velocidade");
          dataFile.close();
          dataFile.println("Erro");
      void recebido ()
         if (radio.available())
          while (radio.available())
            radio.read(&dadosrecebidos, sizeof(dadosrecebidos));
          lcd.clear();
          lcd.print("TENSAO");
          lcd.setCursor(7, 0);
          lcd.print(dadosrecebidos[0]);
          lcd.print("VOLTS");
          lcd.print("VELOCIDADE");
          lcd.setCursor(11, 1);
          lcd.print(dadosrecebidos[1]);
          lcd.print("KM/H");
      void gravar()
        // make a string for assembling the data to log:
        String dataString = ""; //this line simply erases the string
        dataString += "Tensao ";
        dataString += (dadosrecebidos[0]);
        dataString += " VOLTS";
        dataString += " / ";     //puts a comma between the two bits of data
        dataString += "Velocidade ";
        dataString += (dadosrecebidos[1]);
        dataString += " KM/H";
        delay (1000);
        // if the file is available, write to it:
        if (dataFile)
          dataFile.println(dataString);
          dataFile.close();
        // if the file isn't open, pop up an error:
      void loop ()
        recebido();
        gravar();
      AWIA 1 Reply Last reply
        Hey!
        Thanks @mfalkvidd !
        TX:
        #include <RF24.h>
        RF24 radio (9, 10);
        // Bateria
        float R1 = 28000.0;
        float R2 = 7600.0;
        //Velocidade
        void setup ()
          pinMode(A0, INPUT);
          radio.begin();
        void bateria ()
            delay(1);
        void velocidade ()
            detachInterrupt(0);
            loopCount = 0;
        void speedCalc()
          loopCount++;
        void envio ()
          delay(10);
          bateria();
          velocidade();
          envio();
        RX:
        #include <SD.h>
        #include <RF24.h>
        #define SS_P 8// SD
        RF24 radio (9, 10);
        File dataFile;
        void setup ()
          SPI.begin();
          delay(50);
            radio.begin();
          lcd.begin(20, 4);
          lcd.clear();
          delay(5000);
          delay(5000);
          lcd.clear();
            if (SD.begin(SS_P))
            delay(5000);
            delay(5000);
            delay(5000);
            if (dataFile)
            dataFile.close();
        void recebido ()
            lcd.clear();
            lcd.print("VOLTS");
            lcd.print("KM/H");
        void gravar()
          delay (1000);
          if (dataFile)
            dataFile.close();
        void loop ()
          recebido();
          gravar();
        AWIA
        AWIA
        AWI
        @Walyson-Albuquerque-Machado from your sketch I conclude that you are not using MySensors as framework for creating you sensor and logger.
        @mfalkvidd gave you some good suggestions for using a SPI bus interface.
        The purpose of this forum is to work with/ discuss the MySensors framework.
        Give MySensors a try and discover that it solves a lot of your low level interface issues.
        Walyson Albuquerque MachadoW 1 Reply Last reply
        • AWIA AWI
          @AWI Hi.
          Sure, I'm going to try and then I come back here.
            Hey. I'm trying to use Mysensors, but I got these errors. Are there a specific command that I should use? I didn't find any example.
            error: 'RF24' does not name a type RF24 radio(MY_RF24_CE_PIN, MY_RF24_CS_PIN);
            error: 'radio' was not declared in this scope radio.begin();
              AWIA
              AWIA
              AWI
              @Walyson-Albuquerque-Machado The MySensors site is full of examples. You probably have an incomplete instalation or conflicting (RF24) libararies. Try getting started
                I'm getting started and I'm researching about Mysensors. I would like some tips, please.
                I know that I must set this first:
                #define RF24_CE_PIN       9
                #define RF24_CS_PIN      10
                #define RF24_PA_LEVEL      RF24_PA_MAX
                #define RF24_CHANNEL     76
                #define RF24_DATARATE      RF24_250KBPS
                #define SOFTSPI
                #ifdef SOFTSPI
                #include <MyConfig.h>
                And I know that in 2.0.x I don't need to set this:
                 .begin();
                But I don't know how to define in Mysensors when it's Writing / stopListening and Reading / startListening
                startListening();
                Also how to Write the sensor information and Read:
                Is this how I send the sensor information? If so, how do I read?
                  sendSketchInfo("Distance Sensor", "1.0");
                  present(CHILD_ID, S_DISTANCE);
                  #define SOFTSPI
                  #ifdef SOFTSPI
                   .begin();
                  startListening();
                  AWIA
                  AWIA
                  AWI
                  @Walyson-Albuquerque-Machado You are getting on track. You should not bother about the radio, it is hidden (abstracted) in MySensors. You send with the "send" function and receive with the "receive" function. Everything as described in the API.
                  I would suggest you build a simple sensor/sketch (i.e. relay actuator) before diving deeper.
                  I am still taking some tough lessons combining devices on the SPI bus. Like @mfalkvidd mentioned in his post
                  Let us know your progress.
                    I'm trying to do the battery level example and I'm getting this:
                    TSM:INIT
                    TSM:RADIO:OK
                    TSP:ASSIGNID:OK (ID=10)
                    TSM:FPAR
                    TSP:MSG:SEND 10-10-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                    TSP:MSG:READ 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                    TSP:MSG:BC
                    TSM:FPAR
                    TSP:MSG:BC
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    What does it mean? Why can't I read the serial messages?
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSP:MSG:BC
                      TSM:FPAR
                      TSP:MSG:BC
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      AWIA
                      AWIA
                      AWI
                      Your node does not find a parent (gateway) so no response from another node. For documentation: a little indirect but this post by @mfalkvidd should help.
                        Ok, I'm getting there. I appreciate your advices, thanks. :smile:
                        Now I can see the battery level in the serial. But I didn't understand how to receive the battery level in the gateway to show on my LCD display.
                        Gateway ok:
                        0;255;3;0;9;TSM:INIT
                        0;255;3;0;9;TSM:RADIO:OK
                        0;255;3;0;9;TSM:GW MODE
                        0;255;3;0;9;TSM:READY
                        0;255;0;0;18;2.0.0
                        0;255;3;0;9;TSP:MSG:READ 10-10-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                        0;255;3;0;9;TSP:MSG:BC
                        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=10)
                        0;255;3;0;9;TSP:MSG:GWL OK
                        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                        0;255;3;0;9;TSP:MSG:PINGED (ID=10, hops=1)
                        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                        10;255;0;0;17;2.0.0
                        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                        10;255;3;0;6;0
                        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Battery Meter
                        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                        Node ok:
                        TSM:INIT
                        RF24:write register, reg=0, value=14
                        RF24:read register, reg=6, value=35
                        RF24:flushRX
                        TSM:RADIO:OK
                        RF24:start listening
                        RF24:write register, reg=10, value=10
                        TSM:FPAR
                        RF24:stop listening
                        RF24:open writing pipe, recipient=255
                        RF24:write register, reg=10, value=255
                        RF24:send message to 255, len=7
                        RF24:flushTX
                        RF24:MAX_RT
                        TSP:MSG:READ 0-0-10 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        TSP:MSG:FPAR (PPAR FOUND)
                        TSP:MSG:PAR OK (ID=0, dist=1)
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:CHKID:OK (ID=10)
                        TSM:UPL
                        TSP:PING:SEND (dest=0)
                        TSP:MSG:PONG RECV (hops=1)
                        TSP:CHKUPL:OK
                        TSM:UPL:OK
                        TSM:READY
                        Init complete, id=10, parent=0, distance=1, registration=1
                        Battery Voltage: 0.00 V
                        Battery Voltage: 5.91 V
                          Gateway ok:
                          0;255;0;0;18;2.0.0
                          10;255;0;0;17;2.0.0
                          10;255;3;0;6;0
                          Node ok:
                          TSM:INIT
                          RF24:flushRX
                          TSM:RADIO:OK
                          TSM:FPAR
                          RF24:stop listening
                          RF24:flushTX
                          RF24:MAX_RT
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:UPL
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          AWIA
                          AWIA
                          AWI
                          @Walyson-Albuquerque-Machado Back to one of your previous posts. What kind of LCD display are you using. Do you have one with I2C interface?
                            Hey. I don't have I2C interface. Do I need it?
                            I have one like this, 20x4:
                              AWIA
                              AWIA
                              AWI
                              @Walyson-Albuquerque-Machado It is much easier to connect an I2C display (only 2 wires and power).But if you have pins left on your arduino and the patience to solder you're ok.
                              an adapter plate:
                                I have pins and I have already done this. :stuck_out_tongue_closed_eyes:
                                  Is that how I send ? Can I use BINARY to my hall effect sensor? I'm using the digital pin to count every time it passes through a magnet.
                                  MyMessage msg(NODE_ID, V_STATUS);
                                  float value = 0;
                                      present(NODE_ID, S_BINARY);
                                      send(msg.set(value));
                                  Is that how I receive?
                                      // Handle incoming message
                                    Please, someone tell me how to get the voltage that i'm receiving. I've tried many things, I don't know why this doesn't work.
                                    msgvolt.getFloat();
                                    I can see the battery in the gateway through serial, but I don't know how to get it to show on the LCD.
                                    Node:
                                    #define MY_DEBUG_VERBOSE_RF24
                                    #define DESTINATION_NODE 0
                                    #define MY_NODE_ID 10
                                    #define MY_PARENT_NODE_ID  0
                                    #define MY_RF24_CE_PIN 9
                                    #define MY_RF24_CS_PIN 10
                                    #define MY_RF24_PA_LEVEL_GW RF24_PA_LOW
                                    #define MY_RF24_CHANNEL 76
                                    float R1 = 28000.0;
                                    float R2 = 7600.0;
                                    float voltsporUnidade = 0.005278592; // 5%1023
                                    float dadosenviados;
                                    MyMessage msgvolt(4, V_VOLTAGE);
                                      pinMode(A0, INPUT);
                                       sendSketchInfo("Battery Meter", "1.0");
                                       present(4, S_MULTIMETER, "Voltage", true);
                                      dadosenviados = mediaTotalTensaoDC / amostragem;
                                       Serial.print(dadosenviados);
                                       Serial.println(" V");
                                     send(msgvolt.setDestination(DESTINATION_NODE).set(dadosenviados, 2), 1);
                                      wait(2000);
                                    Gateway:
                                    #define MY_GATEWAY_SERIAL
                                    #define MY_NODE_ID 0
                                    #define DESTINATION_NODE 10
                                    float dadosenviados = 0;
                                      lcd.begin(20, 4);
                                      lcd.clear();
                                      delay(5000);
                                      delay(5000);
                                      lcd.clear();
                                          sendSketchInfo("Battery Meter", "2.0");
                                          present(4, S_MULTIMETER);
                                    void receive(const MyMessage &msgvolt) {
                                      saveState(msgvolt.sensor, msgvolt.getFloat());
                                     dadosenviados = msgvolt.getFloat();
                                    request(4, V_VOLTAGE, 10);
                                    void incomingMessage(const MyMessage &msgvolt) {
                                        lcd.clear();
                                        lcd.print(dadosenviados);
                                        lcd.print("VOLTS");
                                        lcd.print(msgvolt.getFloat());
                                        wait(1000);
                                          Serial.print("Battery Voltage: ")`;
                                      msgvolt.getFloat();
                                      Node:
                                      float R1 = 28000.0;
                                      float R2 = 7600.0;
                                        pinMode(A0, INPUT);
                                        wait(2000);
                                      Gateway:
                                        lcd.begin(20, 4);
                                        lcd.clear();
                                        delay(5000);
                                        delay(5000);
                                        lcd.clear();
                                          lcd.clear();
                                          lcd.print("VOLTS");
                                          wait(1000);
                                      AWIA
                                      AWIA
                                      AWI
                                      wrote on last edited by AWI
                                      #21
                                      @Walyson-Albuquerque-Machado a few things :
                                      • the receive routine should be the only place where you receive and read the incoming messages. So skip the incomingmessage routine and add its functionality to receive.
                                      • you don't need to 'request' anything as the node already sends messages all the time.
                                      • savestate writes only byte (8 bit) values, so you need to decompose a float to bytes in order to save it. (best to use an 'union' for that)
                                      Be aware that the gateway (node 0) receives the messages from all nodes connected. You need to make sure that that the incoming message is the one to display.
                                      In summary, to receive messages : the receive routine is called automatically when a message is received. You read the message content (store in a global variable) , and display it.
                                        #22
                                        Ok, I'm going to erase the void incomingMessage(const MyMessage &msgvolt) and the request(4, V_VOLTAGE, 10).
                                        Also no savestate.
                                        I tried to store in a global variable and display, but I didn't understand It, how do I read!?
                                          if (msgvolt.type==V_VOLTAGE) {
                                            digitalWrite(msgvolt.sensor, msgvolt.getFloat());
                                        Serial.println(msgvolt.getFloat());
                                        Serial.println(dadosenviados);
                                        Serial.println(msgvolt.data);
                                        This is what I'm getting in the serial:
                                        Node:
                                        Battery Voltage: 8.68 V
                                        RF24:stop listening
                                        RF24:open writing pipe, recipient=0
                                        RF24:write register, reg=10, value=0
                                        RF24:write register, reg=16, value=0
                                        RF24:send message to 0, len=12
                                        RF24:flushTX
                                        RF24:write register, reg=7, value=48
                                        RF24:write register, reg=0, value=15
                                        TSP:MSG:SEND 10-10-0-0 s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:8.68
                                        RF24:read message, len=12
                                        RF24:write register, reg=7, value=64
                                        TSP:MSG:READ 0-0-10 s=4,c=1,t=38,pt=7,l=5,sg=0:8.68
                                        Battery Voltage: 8.69 V
                                        Gateway:
                                        10;4;1;0;38;8.68
                                        0;255;3;0;9;TSP:MSG:READ 10-10-0 s=4,c=1,t=38,pt=7,l=5,sg=0:8.68
                                        0;255;3;0;9;TSP:MSG:ACK msg
                                        0;255;3;0;9;TSP:MSG:SEND 0-0-10-10 s=4,c=1,t=38,pt=7,l=5,sg=0,ft=0,st=ok:8.68
                                        10;4;1;0;38;8.68
                                          Also no savestate.
                                          Node:
                                          RF24:stop listening
                                          RF24:flushTX
                                          Gateway:
                                          10;4;1;0;38;8.68
                                          10;4;1;0;38;8.68
                                          AWIA
                                          AWIA
                                          AWI
                                          @Walyson-Albuquerque-Machado Apart from the line digitalWrite(msgvolt.sensor, msgvolt.getFloat()); (what do you want to accomplish here? wrtie a float value to a digital output?) it should be fine. The gateway is receiving the volt message so communication is working.
                                          this dadosenviados = msgvolt.getFloat(); variable should hold the value, but does not seem to be executed. Try with a println if the "receive" routine is called at all. As you are receiving values with a gateway (node = 0) this is a special case. I need to emulate this. As we seem to be living in a different timezones it can take a while...
                                          So if anybody else has a direct answer...
                                          12.5k
