  2. Announcements
  3. 💬 Dimmable LED Actuator
59 Posts 27 Posters 29.8k Views 27 Watching
  • H Offline
    H Offline
    wrote on last edited by hek
    This thread contains comments for the article "Dimmable LED Actuator" posted on MySensors.org.
    • J Offline
      J Offline
      jeti
      i am still kind of a beginner in programming...:disappointed:
      how does the:
       * This sketch is extensible to support more than one MOSFET/PWM dimmer per circuit.
       * http://www.mysensors.org/build/dimmer
      work?
      i have tried starting with adding a "_1" LED_PIN and other stuff:
      #define LED_PIN 3      // Arduino pin attached to MOSFET Gate pin
      #define LED_PIN_1 6      // Arduino pin attached to MOSFET Gate pin
      #define FADE_DELAY 35  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
      static int currentLevel = 0;  // Current dim level...
      static int currentLevel_1 = 0;  // Current dim level...
      MyMessage dimmerMsg(0, V_DIMMER);
      MyMessage dimmerMsg1(1, V_DIMMER);
      MyMessage lightMsg(0, V_LIGHT);
      MyMessage lightMsg1(1, V_LIGHT);
       * Dimmable LED initialization method
        // Pull the gateway's current dim level - restore light level upon sendor node power-up
        request( 0, V_DIMMER );
        request( 1, V_DIMMER );
        // Register the LED Dimmable Light with the gateway
        present( 0, S_DIMMER );
        present( 1, S_DIMMER );
        sendSketchInfo(SN, SV);
      , but this does not seem right, as i can not differentiat between for the input :confused:
      thanks in advance
      • thazlett144T Offline
        thazlett144
        It looks like you are trying to add another LED/Mosfet? I have done it this way, I have 3 on mine:
        To do this I may or may not have used some examples I found on this forum. I basically add the pins I am using (PWM capable) into an array. I have 4 pins defined (3 is in there twice) to get around the array references starting from 0. Probably a better way to do that but this was my quick way round it.
        I have basically adapted the code from the example LED Dimmer sketch to work with the array / multiple child devices.
        Hopefully thats helpful and what you were after?
        #define SN "MultiDimmableLED"
        #define SV "1.1"
        #define noLEDs 3
        const int LED_Pin[] = {3, 3, 5, 6}; //put 3 in twice as a start from 0 workaround
        #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
        MyMessage dimmerMsg(noLEDs, V_DIMMER);
        MyMessage lightMsg(noLEDs, V_LIGHT);
          // not sure this works
        for (int sensor=1; sensor<=noLEDs; sensor++){
          request( sensor, V_DIMMER );
         present(sensor, S_DIMMER);
         delay(2);
         *  Dimmable LED main processing loop
          if (message.type == V_LIGHT || message.type == V_DIMMER) {
            Serial.print( "Changing LED " );
            Serial.print(", PIN " );
            Serial.print( LED_Pin[message.sensor] );
            Serial.print(" level to " );
            Serial.print( ", from " );
            Serial.println( currentLevel );
            fadeToLevel( requestedLevel, message.sensor );
            send(lightMsg.set(currentLevel > 0 ? 1 : 0));
            // hek comment: Is this really nessesary?
            send( dimmerMsg.set(currentLevel) );
         *  This method provides a graceful fade up/down effect
        void fadeToLevel( int toLevel, int ledid ) {
          int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
          while ( currentLevel != toLevel ) {
            currentLevel += delta;
            analogWrite( LED_Pin[ledid], (int)(currentLevel / 100. * 255) );
            delay( FADE_DELAY );
        B 1 Reply Last reply
        • thazlett144T thazlett144
          #define SV "1.1"
          #define noLEDs 3
           delay(2);
          B Offline
          B Offline
          BartE
          wrote on last edited by BartE
          @thazlett144 can't help to make a few comments on your sketch (sorry)
          The led the array start from 0 and prevent the double pin declaration simply subtract one on usage so
          this LED_Pin[ledid] becomes this LED_Pin[ledid-1]
          please do use wait() instead of delay(), delay is blocking MySensors communication
          Answer: Yes, controllers like Vera want feedback about the new dimlevel
          thazlett144T 1 Reply Last reply
          • J Offline
            J Offline
            jeti
            thank you both, i will be testing soon!
            thanks again!
            • J Offline
              J Offline
              jeti
              so this works now like a charm:
              #define MY_NODE_ID 153
              #define SV "1.1"
              #define noLEDs 3
              const int LED_Pin[] = {3, 5, 6};
              #define FADE_DELAY 25  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
               wait(2);
                  analogWrite(LED_Pin[ledid-1], (int)(currentLevel / 100. * 255) );
                  wait( FADE_DELAY );
              thank you :thumbsup:
              PlantexP 1 Reply Last reply
              • K Offline
                K Offline
                korttoma
                I just tried the DimmableLightWithRotaryEncoderButton and I found that when rotating the rotary encoder clockwise the dim level decrease and turning it counter clockwise will increase the dim level. I would like it the other way around.
                Any ideas how to modify the sketch? Or is this a feature of my rotary encoder? Did I wire something wrong (I did check my wires and it is according to the instructions).
                • Tomas
                • H Offline
                  H Offline
                  Did you try just switching the pins for KNOB_ENC_PIN_x?
                  K 1 Reply Last reply
                  • H hek
                    K Offline
                    K Offline
                    korttoma
                    That did the trick. Thanks!
                    • Tomas
                    • B BartE
                      thazlett144
                      @BartE Thats great thank you. I am still learning anyway so there are gaps in my knowledge :-) I knew I could do something like that -1.
                      delay was part of the original example I think?
                      • pjblinkP Offline
                        pjblinkP Offline
                        pjblink
                        Hi guys,
                        Struggling with this a little and think it may be hardware related. I'm using a 3.3v pro mini and it won't let the 12v LEDs go to full brightness, at max dim level they're still quite dim. I've tried this on both regular flexi LED strip and the copper-wire type LEDs (final project is based on these).
                        I've tried with a different FET, an IRLB8721 and that goes to full brightness however won't switch the LEDS off completely so guessing there's a leak from that FET! I'm not sure if that's normal or not. Frustrating.
                        Ideally i want the circuitry to be 3.3v as i'm already converting the 12v LED power supply down to 3.3v for the nRF. I'd rather not have a 5v and 3.3v regulator.
                        Patrick
                        mfalkviddM ? 2 Replies Last reply
                        • pjblinkP pjblink
                          Hi guys,
                          Patrick
                          @pjblink I had the same problem in https://forum.mysensors.org/topic/2335/controlling-leds-with-the-irlz44n/ and another community member had something similar: https://forum.mysensors.org/topic/2335/controlling-leds-with-the-irlz44n/
                          The solution seems to be to buy new mosfets and hope that they work properly.
                          pjblinkP 1 Reply Last reply
                            pjblinkP Offline
                            pjblinkP Offline
                            pjblink
                            @mfalkvidd So keep trying IRLZ44N FETs?
                            • pjblinkP pjblink
                              @pjblink probably. Several people have reported their IRLZ44N opening fully at 3.3V.
                              • K Offline
                                K Offline
                                korttoma
                                Inspirational pictures from my Dimmable LED Actuator with rotary encoder device I made for my sons bedside lamp.
                                Running this at 12VDC. His lamp had a G9 socket so I just broke apart the G9 LED bulb and soldered some G4 12VDC LED lights like these to it and replaces the "Dumb" switch with a 5mm DC plug. It turned out so nice that I think I will MySensor my own bedside lamp also.
                                Edit: btw, I found the nice big knobs from here -> eBay
                                • Tomas
                                • K Offline
                                  K Offline
                                  korttoma
                                  Bahh.. I had the 12VDC connected directly to the RAW pin on the Arduino Pro mini and yesterday it failed.
                                  I should have known better. Now added a 5V regulator to the device and a new 5V Pro Mini.
                                  • Tomas
                                  • MalmQM Offline
                                    MalmQM Offline
                                    MalmQ
                                    Hi all
                                    I love the mysensors project. I have made a lot of sensors by now. Now I would like to control these LED-lights with a dimmer node:
                                    http://www.siriushome.dk/product/50200/ (in danish)
                                    The specs. for the LEDs are 6W@80V.
                                    I have two questions that I hope you can help me with.
                                    A) What is the easiest way to drive an arduinonode from 80v. Is a DC/DC converter the only way?
                                    B) What mosfet would you suggest using for controling the LEDs?
                                    I hope you can help. Many thanks.
                                    // MalmQ
                                    • pjblinkP pjblink
                                      Hi guys,
                                      Patrick
                                      ? Offline
                                      ? Offline
                                      A Former User
                                      wrote on last edited by A Former User
                                      @pjblink the irlzn44n is very sensitive to over heat during solder, I have lost some of them during soldering :) please be careful
                                      • C Offline
                                        C Offline
                                        Creaky
                                        Hi!
                                        I'd like to use this sketch with a 5V Arduino Nano, do I need to use another type of MOSFET for this?
                                        From the OP I gather that the IRLZ44N is used because of the lower gate threshold in combination with the 3.3v operating voltage, but won't the IRLZ44N gate be saturated very quickly when using 5v?
                                        Creaky
                                        • C Creaky
                                          Hi!
                                          Creaky
                                          @Creaky the dimmer uses PWM to control the light level, so the mosfet is always either in cutoff or fully saturated. So using IRLz44N with 5V will work just as well as 3.3V.
                                          C 2 Replies Last reply
                                          12.1k
