  3. nRf24L01+ connection quality meter
43 Posts 18 Posters 26.7k Views 33 Watching
  • karl261K karl261
    @AWI Strange, with the latest sketch I get
    nrf-quality-meter.ino:88:34: error: invalid conversion from 'int' to 't_backlighPol' [-fpermissive]
    In file included from nrf-quality-meter.ino:45:0:
    C:\Dokumente und Einstellungen\Philipp\Eigene Dateien\Arduino\libraries\LiquidCrystal/LiquidCrystal_I2C.h:53:4: error: initializing argument 3 of 'LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, t_backlighPol)' [-fpermissive]
    LiquidCrystal_I2C (uint8_t lcd_Addr, uint8_t backlighPin, t_backlighPol pol);
    compiling...
    It works using the other line...
    // ***** LCD
    //LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
    LiquidCrystal_I2C lcd(0x27, 16, 2);  // Set the LCD I2C address
    AWIA
    AWIA
    AWI
    @karl261 probably I am using another library for the display. I got it from the Arduino library manager.
    • N
      N
      Nicklas Starkel
      @AWI what is the board between the nano and the radio?
      Something available via aliexpress?
      I really do not need this as I live in a small flat.. but I NEED THIS! :laughing:
      AWIA 1 Reply Last reply
      • N Nicklas Starkel
        AWIA
        AWIA
        AWI
        wrote on last edited by AWI
        #27
        @Nicklas-Starkel you can find it in the MySensors shop It is a nrf24l01+ socket adapter board. It guarantees a stable supply and includes the famous "radio capacitor"
        • siodS
          siodS
          siod
          wrote on last edited by siod
          #28
          Hi @AWI,
          thanks for the code and the project! ~~Unfortunately my biggest problem is to get my LCD working. It does not do anything with your code, other testcode to test the display is working fine. I am using this line and it should work fine:
          Any idea what else I could check? I am using arduino IDE 1.6.10
          edit: getting this in the serial monitor of the device:
          TSM:INIT
          TSM:RADIO:OK
          TSP:ASSIGNID:OK (ID=250)
          TSM:FPAR
          TSP:MSG:SEND 250-250-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
          TSP:MSG:BC
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          then it starts over again...
          edit2:
          Think I got it now, seems like my gateway wasn´t responding or whatever, now it seems to work...
          Edit3:
          I got 1 fail and 5000 miss 60%...
          Now what does this mean??
          Edit4:
          I think I need some help: Most of the time I get this on my gw´s Serial Monitor:
          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
          0;255;3;0;9;TSP:MSG:READ 250-250-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
          0;255;3;0;9;TSP:MSG:BC
          0;255;3;0;9;TSP:MSG:FPAR REQ (sender=250)
          0;255;3;0;9;TSP:MSG:GWL OK
          After some reboots of the quality meter and I guess with a lot of luck it starts working occasionally
          This is from the serial monitor of the quality meter:
          TSP:MSG:READ 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
          !TSP:MSG:PVER mismatch
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          I already added a 47u Cap and added those lines to the code:
          #define MY_PARENT_NODE_ID 0                         // fixed parent to controller when 0 (else comment out = AUTO)
          no luck at all...
          edit5:
          Now I opened the serial output of my GW again, which seems to started the communication:
          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
          0;255;3;0;9;TSP:MSG:PINGED (ID=250, hops=1)
          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          0;255;3;0;9;!TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
          0;255;3;0;9;Sending message on topic: mygateway1-out/250/255/0/0/17
          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
          0;255;3;0;9;Sending message on topic: mygateway1-out/250/255/3/0/6
          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=0,t=4,pt=0,l=21,sg=0:Quality counter Q 250
          0;255;3;0;9;Sending message on topic: mygateway1-out/250/0/0/0/4
          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:0
          0;255;3;0;9;TSP:MSG:ACK msg
          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=ok:0
          0;255;3;0;9;Sending message on topic: mygateway1-out/250/0/1/0/3
          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1
          0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=ok:1
          0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:2
          I don´t get it what is going on here. Restarted quality meter: blank LCD... :(
          still learning...
          • NickBuilderN
            NickBuilderN
            NickBuilder
            wrote on last edited by NickBuilder
            #29
            Great tool for a mysensors builder @AWI! I also want to sort out the good radios from the bad, I have enough trouble as it is trying to troubleshoot my questionable sensors.
            I got around to building a quality meter for myself, although without the adapter board and with some additional differences. But I really don't understand the output, the fail and miss percentage is almost always 100 % for most of my radios. Am I missing something? Perhaps I should change some addresses to static ones? I thought that perhaps I had to define a corresponding item in Openhab in order for the packages to be acknowledged but this doesn't change the outcome.
            Here's the serial output from the "quality meter":
            TSM:INIT
            TSM:RADIO:OK
            TSM:FPAR
            TSP:MSG:READ 0-0-250 s=255,c=3,t=8,pt=1,l=1,sg=0:0
            TSP:MSG:PAR OK (ID=0, dist=1)
            TSM:FPAR:OK
            TSM:ID
            TSM:CHKID:OK (ID=250)
            TSM:UPL
            TSP:PING:SEND (dest=0)
            !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
            TSP:MSG:READ 0-0-250 s=255,c=3,t=25,pt=1,l=1,sg=0:1
            TSP:MSG:PONG RECV (hops=1)
            TSP:CHKUPL:OK
            TSM:UPL:OK
            TSM:READY
            !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=1,st=fail:0100
            !TSP:MSG:SEND 250-250-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=2,st=fail:2.0.0
            !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=3,st=fail:0
            TSP:MSG:READ 0-0-250 s=255,c=3,t=6,pt=0,l=1,sg=0:M
            !TSP:MSG:SEND 250-250-0-0 s=0,c=0,t=4,pt=0,l=21,sg=0,ft=4,st=fail:Quality counter Q 250
            Request registration...
            !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            !TSP:SEND:TNR
            TSM:FPAR
            !TSP:SEND:TNR
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:CHKUPL:OK
            TSM:UPL:OK
            TSM:READY
            !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=fail:2
            TSP:MSG:READ 0-0-250 s=255,c=3,t=27,pt=1,l=1,sg=0:1
            Node registration=1
            Init complete, id=250, parent=0, distance=1, registration=1
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:0
            Fail on message: 0 # 1
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:0
            Missed messages: 0
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:1
            Fail on message: 1 # 2
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:2
            Fail on message: 2 # 3
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:3
            Fail on message: 3 # 4
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:3
            Missed messages: 2
            !TSP:SEND:TNR
            Fail on message: 4 # 5
            !TSP:SEND:TNR
            Fail on message: 5 # 6
            !TSP:SEND:TNR
            Fail on message: 6 # 7
            !TSP:SEND:TNR
            Fail on message: 7 # 8
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 8 # 9
            !TSP:SEND:TNR
            Fail on message: 9 # 10
            !TSP:SEND:TNR
            Fail on message: 10 # 11
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:CHKUPL:OK
            TSM:UPL:OK
            TSM:READY
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:11
            Fail on message: 11 # 12
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:11
            Missed messages: 7
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:12
            Fail on message: 12 # 13
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:13
            Fail on message: 13 # 14
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:14
            Fail on message: 14 # 15
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:15
            Fail on message: 15 # 16
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 16 # 17
            !TSP:SEND:TNR
            Fail on message: 17 # 18
            !TSP:SEND:TNR
            Fail on message: 18 # 19
            !TSP:SEND:TNR
            Fail on message: 19 # 20
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:CHKUPL:FAIL (hops=255)
            !TSM:UPL:FAIL
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 20 # 21
            !TSP:SEND:TNR
            Fail on message: 21 # 22
            !TSP:SEND:TNR
            Fail on message: 22 # 23
            !TSP:SEND:TNR
            Fail on message: 23 # 24
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 24 # 25
            !TSP:SEND:TNR
            Fail on message: 25 # 26
            !TSP:SEND:TNR
            Fail on message: 26 # 27
            !TSP:SEND:TNR
            Fail on message: 27 # 28
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            !TSM:UPL:FAIL
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 28 # 29
            !TSP:SEND:TNR
            Fail on message: 29 # 30
            !TSP:SEND:TNR
            Fail on message: 30 # 31
            !TSP:SEND:TNR
            Fail on message: 31 # 32
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 32 # 33
            !TSP:SEND:TNR
            Fail on message: 33 # 34
            !TSP:SEND:TNR
            Fail on message: 34 # 35
            !TSP:SEND:TNR
            Fail on message: 35 # 36
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:CHKUPL:OK
            TSM:UPL:OK
            TSM:READY
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:36
            Fail on message: 36 # 37
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:37
            Fail on message: 37 # 38
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:37
            Missed messages: 25
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:38
            Fail on message: 38 # 39
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:38
            Missed messages: 0
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:39
            Fail on message: 39 # 40
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:39
            Missed messages: 0
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:40
            Fail on message: 40 # 41
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:40
            Missed messages: 0
            !TSP:SEND:TNR
            Fail on message: 41 # 42
            !TSP:SEND:TNR
            Fail on message: 42 # 43
            !TSP:SEND:TNR
            Fail on message: 43 # 44
            TSM:FPAR:OK
            TSM:ID
            !TSP:SEND:TNR
            Fail on message: 44 # 45
            TSM:UPL
            TSP:CHKUPL:OK
            TSM:UPL:OK
            TSM:READY
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:45
            Fail on message: 45 # 46
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:45
            Missed messages: 4
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:46
            Fail on message: 46 # 47
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:47
            Fail on message: 47 # 48
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:47
            Missed messages: 1
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:48
            Fail on message: 48 # 49
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:48
            Missed messages: 0
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:49
            Fail on message: 49 # 50
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 50 # 51
            !TSP:SEND:TNR
            Fail on message: 51 # 52
            !TSP:SEND:TNR
            Fail on message: 52 # 53
            !TSP:SEND:TNR
            Fail on message: 53 # 54
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 54 # 55
            !TSP:SEND:TNR
            Fail on message: 55 # 56
            !TSP:SEND:TNR
            Fail on message: 56 # 57
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            !TSM:UPL:FAIL
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 57 # 58
            !TSP:SEND:TNR
            Fail on message: 58 # 59
            !TSP:SEND:TNR
            Fail on message: 59 # 60
            !TSP:SEND:TNR
            Fail on message: 60 # 61
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 61 # 62
            !TSP:SEND:TNR
            Fail on message: 62 # 63
            !TSP:SEND:TNR
            Fail on message: 63 # 64
            !TSP:SEND:TNR
            Fail on message: 64 # 65
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            !TSM:UPL:FAIL
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 65 # 66
            !TSP:SEND:TNR
            Fail on message: 66 # 67
            !TSP:SEND:TNR
            Fail on message: 67 # 68
            !TSP:SEND:TNR
            Fail on message: 68 # 69
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 69 # 70
            !TSP:SEND:TNR
            Fail on message: 70 # 71
            !TSP:SEND:TNR
            Fail on message: 71 # 72
            !TSP:SEND:TNR
            Fail on message: 72 # 73
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            !TSM:UPL:FAIL
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 73 # 74
            !TSP:SEND:TNR
            Fail on message: 74 # 75
            !TSP:SEND:TNR
            Fail on message: 75 # 76
            !TSP:SEND:TNR
            Fail on message: 76 # 77
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 77 # 78
            !TSP:SEND:TNR
            Fail on message: 78 # 79
            !TSP:SEND:TNR
            Fail on message: 79 # 80
            !TSP:SEND:TNR
            Fail on message: 80 # 81
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            !TSM:UPL:FAIL
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 81 # 82
            !TSP:SEND:TNR
            Fail on message: 82 # 83
            !TSP:SEND:TNR
            Fail on message: 83 # 84
            !TSP:SEND:TNR
            Fail on message: 84 # 85
            TSM:FPAR
            !TSP:SEND:TNR
            Fail on message: 85 # 86
            !TSP:SEND:TNR
            Fail on message: 86 # 87
            !TSP:SEND:TNR
            Fail on message: 87 # 88
            !TSP:SEND:TNR
            Fail on message: 88 # 89
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
            TSP:MSG:READ 99-99-0 s=0,c=1,t=1,pt=7,l=5,sg=0:62.2
            !TSM:MSG:REL MSG, but not a repeater
            TSP:CHKUPL:OK
            TSM:UPL:OK
            TSM:READY
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=fail:89
            Fail on message: 89 # 90
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:90
            Fail on message: 90 # 91
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:91
            Fail on message: 91 # 92
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:92
            Fail on message: 92 # 93
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:92
            Missed messages: 43
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:93
            Fail on message: 93 # 94
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:93
            Missed messages: 0
            !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:94
            Fail on message: 94 # 95
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:94
            Missed messages: 0
            !TSP:SEND:TNR
            Fail on message: 95 # 96
            !TSP:SEND:TNR
            Fail on message: 96 # 97
            !TSP:SEND:TNR
            Fail on message: 97 # 98
            !TSP:SEND:TNR
            Fail on message: 98 # 99
            TSM:FPAR:OK
            TSM:ID
            TSM:UPL
            Also, the meter in action generating the output above can be seen here: LINK
            After some time, >10 min, the fail percentage is 100 % and the miss percentage around 85 %. Not impressive if interpreted correctly. Could someone give me some pointers to what the problem is? I don't talk "mysensors protocol".
            Sorry @siod, I don't think I can help you. You seem to get a lot more messages through though.
            • NickBuilderN NickBuilder
              TSM:INIT
              TSM:RADIO:OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              !TSM:UPL FAIL, SNP
              TSM:FPAR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              Node registration=1
              Missed messages: 0
              !TSM:UPL FAIL, SNP
              TSM:FPAR
              Missed messages: 2
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              Missed messages: 7
              !TSM:UPL FAIL, SNP
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              Missed messages: 25
              Missed messages: 0
              Missed messages: 0
              !TSM:UPL FAIL, SNP
              TSM:FPAR
              Missed messages: 0
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              !TSP:SEND:TNR
              TSM:UPL
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              Missed messages: 4
              Missed messages: 1
              Missed messages: 0
              !TSM:UPL FAIL, SNP
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              !TSM:UPL:FAIL
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              TSP:CHKUPL:OK
              TSM:UPL:OK
              TSM:READY
              Missed messages: 43
              Missed messages: 0
              !TSM:UPL FAIL, SNP
              TSM:FPAR
              Missed messages: 0
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              TSM:FPAR:OK
              TSM:ID
              TSM:UPL
              AWIA
              AWIA
              AWI
              #30
              @NickBuilder you seem to have a pretty bad connection (hardware related) . The meter has to be built with a reliable power source and connections. I can't see from the movie how your radio is powered. The reason for using the adapter plate is that it includes a separate ldo and capacitors.
              NickBuilderN 1 Reply Last reply
              • siodS siod
                Hi @AWI,
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                TSP:MSG:BC
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                edit2:
                Edit3:
                Edit4:
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                no luck at all...
                edit5:
                AWIA
                AWIA
                AWI
                #31
                @siod the meter works like a normal sketch. If it does not get past making a connection the rest of the code won't start (ie the LCD). To be honest I can't make up a reason from the serial logs except that your node has problems finding it's parent.
                • AWIA AWI
                  NickBuilderN
                  NickBuilderN
                  NickBuilder
                  @AWI, it's hardly visible but I'm actually using a 3V3 buck and a 10 uF cap to power the radio. But I took your advice and tried tos power the radio seperately with two AA batterys, and a cap just in case. This should be a really clean source of power but the outcome is still the same.
                  I guess I'll order som new radios, hopefully from a different supplier. I'll get some adapter boards with (switchless) LDO's while I'm at it.
                  Why is the parent changing from 255 to 0 back and forth? I have a serial gateway connected to a Pi and aside from some temp sensors I also have an RC switch for my outlets which also acts as a gateway but the adress is neither 255 nor 0.
                    AWIA
                    AWIA
                    AWI
                    @NickBuilder I hope you solve your issues with new radio's. I have very little which don't function at all.
                    The id "0" belongs to your gateway "255" is a kind of broadcast id which is a.o. used when a node number is not known. Both id's are not available for you to assign to a node.
                    • karl261K
                      karl261K
                      karl261
                      For those who need and don't have a display like me, here is my sketch version for output to the serial console. So what I do is, I run around with a laptop connected to the node and watch the serial console, or, I just move around with a tablet and the node. The tablet is connected to my raspi and I watch the output of my gw on the pi using picocom. Picocom handles very well the missing line feeds in the output. The gw output is also very informative, there are no statistics, but still I see when stuff fails...
                      Thanks for the cool sketch @AWI!
                       PROJECT: MySensors / Quality of radio transmission
                       PROGRAMMER: AWI (MySensors libraries)
                       DATE: 20160529/ last update: 20160530
                       FILE: AWI_Send.ino
                       LICENSE: Public domain
                       Hardware: ATMega328p board w/ NRF24l01
                          and MySensors 2.0
                      Special:
                      Summary:
                          Sends a radio message with counter each  x time to determine fault ratio with receiver
                      Remarks:
                          Fixed node-id & communication channel to other fixed node
                      Change log:
                      20160530 - added moving average on fail/ miss count, update to 2.0
                      //****  MySensors *****
                      #define MY_RADIO_NRF24                                  // Enable and select radio type attached
                      //#define MY_RF24_CHANNEL 80                                // radio channel, default = 76
                      // MIN, LOW, HIGH, MAX
                      #define MY_NODE_ID 250
                      #define NODE_TXT "Q 250"                                // Text to add to sensor name
                      #define MY_PARENT_NODE_ID 99                          // fixed parent to controller when 0 (else comment out = AUTO)
                      #define MY_BAUD_RATE 9600
                      // #define MY_RF24_CE_PIN 7                             // Ceech board, 3.3v (7,8)  (pin default 9,10)
                      // #define MY_RF24_CS_PIN 8
                      #define DESTINATION_NODE 0                              // receiving fixed node id (default 0 = gateway)
                      // helpers
                      #define LOCAL_DEBUG
                      #ifdef LOCAL_DEBUG
                      #define Sprint(a) (Serial.print(a))                     // macro as substitute for print, enable if no print wanted
                      #define Sprintln(a) (Serial.println(a))                 // macro as substitute for println
                      #define Sprint(a)                                       // enable if no print wanted -or-
                      #define Sprintln(a)                                     // enable if no print wanted
                      // MySensors sensor
                      #define counterChild 0
                      // send constants and variables
                      int messageCounter = 0 ;
                      const int messageCounterMax = 100 ;                     // maximum message counter value
                      const unsigned counterUpdateDelay = 500 ;               // send every x ms and sleep in between
                      // receive constants and variables
                      boolean failStore[messageCounterMax] ;                  // moving average stores & pointers
                      int failStorePointer = 0 ;
                      boolean missedStore[messageCounterMax] ;
                      int missedStorePointer = 0 ;
                      int newMessage = 0 ;
                      int lastMessage = -1 ;
                      int missedMessageCounter = 0 ;                          // total number of messages in range (messageCounterMax)
                      int failMessageCounter = 0 ;                            // total number of messages in range (messageCounterMax)
                      uint8_t parent = 0 ;                                    // parent node-id
                      // standard messages
                      MyMessage counterMsg(counterChild, V_PERCENTAGE);       // Send value
                          for(int i= 0 ; i <  messageCounterMax ; i++){       // init stores for moving averages
                              failStore[i] = true ;
                              missedStore[i] = true ;
                          missedStorePointer = failStorePointer = 0 ;
                          delay(1000);
                      void presentation(){
                      // MySensors
                          present(counterChild, S_DIMMER, "Quality counter " NODE_TXT) ;  // counter uses percentage from dimmer value
                          // Sprint("count:") ; Sprintln(messageCounter) ;
                          Sprint("Parent: "); Sprint(parent); Sprint("       Fail "); Sprint(failMessageCounter); Sprint("   "); Sprint(getCount(failStore, messageCounterMax)); Sprintln("%");
                          Sprint("Destination: "); Sprint(DESTINATION_NODE); Sprint("  Miss "); Sprint(missedMessageCounter); Sprint("   "); Sprint(getCount(missedStore, messageCounterMax)); Sprintln("%");
                          missedStore[failStorePointer] = false  ;            // set slot to false (ack message needs to set) ;
                          boolean succes = failStore[failStorePointer] = send(counterMsg.setDestination(DESTINATION_NODE).set(failStorePointer), true);  // send to destination with ack
                          if (!succes){
                              failMessageCounter++ ;
                              Sprint("Fail on message: ") ; Sprint(failStorePointer) ;
                              Sprint(" # ") ; Sprintln(failMessageCounter);
                          failStorePointer++ ;
                          if(failStorePointer >= messageCounterMax){
                              failStorePointer =  0   ;                       // wrap counter
                          parent = getParentNodeId();                         // get the parent node (0 = gateway)
                          wait(counterUpdateDelay) ;                          // wait for things to settle and ack's to arrive
                      void receive(const MyMessage &message) {                // Expect few types of messages from controller
                          newMessage = message.getInt();                      // get received value
                          switch (message.type){
                              case V_PERCENTAGE:
                                  missedStore[newMessage] = true ;            // set corresponding flag to received.
                                  if (newMessage > lastMessage){              // number of messages missed from lastMessage (kind of, faulty at wrap)
                                      Sprint("Missed messages: ") ; Sprintln( newMessage - lastMessage - 1) ;
                                      missedMessageCounter += newMessage - lastMessage - 1 ;
                                  lastMessage = newMessage ;
                                  break ;
                              default: break ;
                      // calculate number of false values in array
                      // takes a lot of time, but who cares...
                      int getCount(boolean countArray[], int size){
                          int falseCount = 0 ;
                          for (int i = 0 ; i < size ; i++){
                              falseCount += countArray[i]?0:1 ;
                          return falseCount ;
                      • Mark SwiftM
                        Mark SwiftM
                        Mark Swift
                        @karl261 I tried your code and it pretty much just gives me failures? I don't have any issues with nodes and tried it out of curiosity, any ideas? It seems to send pretty fast, perhaps its spamming my gateway too much?
                        karl261K 1 Reply Last reply
                        • Mark SwiftM Mark Swift
                          karl261K
                          karl261K
                          karl261
                          @Mark-Swift Where do you see the failures? Do you have a log output?
                          The code is for mysensors 2.0.0. Did you adapt all the network specific #define in the beginning of the sketch to your network? In my example there is a static parent set and the static parent has the ID 99. If that does not exist, there will be failures.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            Hi @karl261 I'm using the latest 2.0 snapshot, and did change the network specific settings. I'll grab a debug output and post it up next time I get access to the gateway...
                            • AWIA AWI
                              NickBuilderN
                              NickBuilderN
                              NickBuilder
                              @AWI, thanks to your sketch and the concept of transmission quality measurement I did some adjustments to my setup.
                              I guess the most critical reason for the bad numbers shown on the meter for my network was due to a poor gateway. After applying the cheep and dirty EMI fix, a ground connected foil, and playing around with the transceiver power I finally got some good numbers on the meter.
                              So now I've placed a post-it on each module indicating a sort of long term fail average. A couple of them shows quite poor fail/miss values, 60-80 %. The best ones reaches around 5-15 % but this could be due to the gateway radio.
                              Actually I still don't know if the gateway transceiver is optimized. I should test some additional radio units.
                              Using large caps for the radio is recommended. There's no reason why not to use a bigger cap, > x00 uF. The ones rated for lower voltages are quite small in physical terms.
                              Thank you for this @AWI!
                              • D
                                dakipro
                                I just wanted to say thanks for this project, I think we need more tools like this that increase quality of our projects (and thus increase WAF as well).
                                Also wanted to ask would it be too complicated and/or practical to include measurement of the radio consumption while it is sending and sleeping?
                                Maybe a switch/jumper and a bit of code modification that would let radio sleep, and we could use a amper meter in serial with the radio? Even better if some simple "integrated" current measurement method could be used, some voltage drop on some other pins measured directly in the tester or what not (that would be above my knowledge, but I might just try it in a few months when I get some spare time)
                                • D dakipro
                                  AWIA
                                  AWIA
                                  AWI
                                  @dakipro It would take a resistor and analog power reading to include basic power measurement. Current would vary between ~3mA and 70mA (with amplified radio).
                                  H 1 Reply Last reply
                                  • AWIA AWI
                                    H
                                    H
                                    Heizelmann
                                    @AWI Thanks for this great tool. It helped me very much and I tried to implement some extended features.
                                    Here is my current result: It has now a menu interface with two buttons. You can change the pa level and the send repeat tries. Further you can measure the current of the radio module and reset the store. Configuration parameters are stored in EEPROM. See following code for more details.
                                      PROGRAMMER: AWI (MySensors libraries), modified by Heizelmann
                                      DATE: 20160529/ last update: 20171012
                                      FILE: AWI_Send.ino
                                      Hardware: ATMega328p board (e.g. Arduino pro nano) w/ NRF24l01
                                      and MySensors 2.1.1
                                      Special:
                                      Summary:
                                      Remarks:
                                      Change log:
                                      20171012 - extensions by @Heizelmann
                                               . added radio current measurement
                                               . added pa level switching
                                               . added send repeat option
                                               . added LCD Display with parallel interface
                                               . added two button to change pa level, send repeat count, reset store and display radio current
                                               . store config params in EEPROM
                                               . connect timeout with MY_TRANSPORT_WAIT_READY_MS
                                      @see https://forum.mysensors.org/topic/3984/nrf24l01-connection-quality-meter
                                    // Set LOW transmit power level  if you have an amplified NRF-module
                                    // if power your radio separately with a good regulator you can turn up PA level.
                                    #define MY_RF24_PA_LEVEL RF24_PA_MAX //default = MAX on nodes, LOW on gateway and repeater
                                    #define NODE_TXT "Quality counter Q 250"
                                    // Init timeout for gateway not reachable
                                    #define MY_TRANSPORT_WAIT_READY_MS 20000 //ms; supported since MySensors V2.1 beta
                                    //#define MY_PARENT_NODE_ID 32              // fixed parent to controller when 0 (else comment out = AUTO)
                                    #define MY_BAUD_RATE 115200
                                    //#include <LiquidCrystal_I2C.h>                // LCD display with I2C interface
                                    #include <LiquidCrystal.h>                      // LCD display with parallel interface
                                    #include <OneButton.h> //from https://github.com/mathertel/OneButton/blob/master/examples/TwoButtons/TwoButtons.ino
                                    // helpers
                                    #define LOCAL_DEBUG
                                    #ifdef LOCAL_DEBUG
                                    // MySensors sensor
                                    #define COUNTER_CHILD 0
                                    // Loop delays
                                    const unsigned long displayInterval = 1000UL ;      // display update in ms
                                    unsigned long lastDisplayUpdate = 0 ;         // last update for loop timers
                                    MyMessage counterMsg(COUNTER_CHILD, V_PERCENTAGE);   // Send value
                                    // ***** LCD
                                    #define LCD_COLS 16
                                    #define LCD_ROWS 2
                                    //LiquidCrystal_I2C lcd(0x27, 16, 2);  // Set the LCD I2C address
                                    LiquidCrystal lcd(8, 7, 6, 5, 4, 3); // LCD with paralell interface
                                    #define CURRENT_PIN A5
                                    #define BUTTON1_PIN A1
                                    #define BUTTON2_PIN A2
                                    OneButton button1(BUTTON1_PIN, true); //PullUp, Activelow
                                    OneButton button2(BUTTON2_PIN, true); //PullUp, Activelow
                                    // Options
                                    #define EEPROM_FLAG 0
                                    #define EEPROM_PA_LEVEL 1
                                    #define EEPROM_SEND_REPEATS 2
                                    #define LEVEL_ITEMS 4
                                    const char *paLevelNames[LEVEL_ITEMS] = { "MIN", "LOW", "HIGH", "MAX" };
                                    uint8_t rf24palevel = MY_RF24_PA_LEVEL;
                                    #define MIN_REPEAT_DELAY 50
                                    #define MAX_REPEAT_DELAY 200
                                    uint8_t sendRepeats = 3;
                                    // Current measurement
                                    #define CORRECTION 9.285
                                    int currentMa;
                                    // Menu
                                    #define MENU_TIMEOUT 10000
                                    enum mode { STATE_RUN, STATE_RUN2, STATE_PALEVEL, STATE_RESEND};
                                    mode opState = STATE_RUN;
                                    unsigned long lastClickedMillis;
                                    boolean dspRefresh = true;
                                    void before() {
                                      pinMode(CURRENT_PIN, INPUT);
                                      analogReference(INTERNAL);
                                      //  Wire.begin();  // I2C
                                      // ** LCD display **
                                      lcd.begin(LCD_COLS, LCD_ROWS);
                                      //lcd.setBacklight(HIGH);
                                      lcd.home();
                                      lcd.setCursor(0, 0);
                                      lcd.print("AWIQuality nRF24");
                                      lcd.setCursor(0, 1);
                                      lcd.print("Connect...");
                                      initStore();
                                      delay(1000);
                                      button1.attachClick(onButton1Pressed);
                                      button1.attachLongPressStart(onButton1LongPressed);
                                      button2.attachClick(onButton2Pressed);
                                      if (loadState(EEPROM_FLAG) == 0xFF) {
                                        rf24palevel = loadState(EEPROM_PA_LEVEL);
                                        sendRepeats = loadState(EEPROM_SEND_REPEATS);
                                        saveState(EEPROM_FLAG, 0xFF);
                                        saveState(EEPROM_PA_LEVEL, rf24palevel);
                                        saveState(EEPROM_SEND_REPEATS, sendRepeats);
                                      present(COUNTER_CHILD, S_DIMMER, NODE_TXT) ;  // counter uses percentage from dimmer value
                                      button1.tick();
                                      button2.tick();
                                      if (opState != STATE_RUN && opState != STATE_RUN2 && millis() - lastClickedMillis > MENU_TIMEOUT) {
                                        Sprintln("Timeout");
                                        setRFLevel(rf24palevel);
                                      if (dspRefresh) LCD_local_display();
                                      if ( opState == STATE_RUN ) {
                                        Sprint("count:") ; Sprintln(messageCounter++) ;
                                        boolean success = failStore[failStorePointer] = resend(counterMsg.setDestination(DESTINATION_NODE).set(failStorePointer), sendRepeats);  // send to destination with ack
                                        currentMa = analogRead(CURRENT_PIN) / CORRECTION;
                                        if (!success) {
                                        if (failStorePointer >= messageCounterMax) {
                                        dspRefresh = true;
                                      switch (message.type) {
                                        case V_PERCENTAGE:
                                          if (newMessage > lastMessage) {       // number of messages missed from lastMessage (kind of, faulty at wrap)
                                          break ;
                                        default: break ;
                                    int getCount(boolean countArray[], int size) {
                                      for (int i = 0 ; i < size ; i++) {
                                        falseCount += countArray[i] ? 0 : 1 ;
                                      return falseCount ;
                                    void initStore() {
                                      for (int i = 0 ; i <  messageCounterMax ; i++) { // init stores for moving averages
                                      missedMessageCounter = failMessageCounter = 0;
                                    void setRFLevel(uint8_t rfLevel) {
                                      Sprint("Set RF Level to "); Sprintln(rf24palevel);
                                      uint8_t rfsetup = (((MY_RF24_DATARATE) & 0b10 ) << 4) | (((MY_RF24_DATARATE) & 0b01 ) << 3) | (((rfLevel << 1))) + 1; // +1 for Si24R1;
                                      RF24_setRFSetup(rfsetup);
                                    boolean resend(MyMessage &msg, int repeats) {
                                      int repeat = 0;
                                      int repeatdelay = 0;
                                      boolean sendOK = false;
                                      while ((sendOK == false) and (repeat < repeats)) {
                                        if (send(msg, true)) { //send
                                          sendOK = true;
                                          sendOK = false;
                                          repeatdelay += random(MIN_REPEAT_DELAY, MAX_REPEAT_DELAY);
                                        repeat++;
                                        delay(repeatdelay);
                                      return sendOK;
                                    void onButton1Pressed() {
                                      dspRefresh = true;
                                      lcd.clear(); lcd.home();
                                      switch (opState) {
                                        case STATE_RUN:
                                          opState = STATE_PALEVEL;
                                        case STATE_RUN2:
                                        case STATE_PALEVEL:
                                          opState = STATE_RESEND;
                                        case STATE_RESEND:
                                      lastClickedMillis = millis();
                                    void onButton2Pressed() {
                                      dspRefresh = true;
                                      switch (opState) {
                                        case STATE_RUN:
                                          opState = STATE_RUN2;
                                        case STATE_RUN2:
                                        case STATE_PALEVEL:
                                          rf24palevel++; if (rf24palevel > 3) rf24palevel = 0;
                                        case STATE_RESEND:
                                          sendRepeats++; if (sendRepeats > 3) sendRepeats = 1;
                                    void onButton1LongPressed() {
                                      initStore();
                                    void LCD_local_display(void) {
                                      dspRefresh = false;
                                      char buf[LCD_COLS + 1];                     // buffer for max 16 char display
                                      switch (opState) {
                                        case STATE_RUN:
                                          snprintf(buf, sizeof buf, "P%-3dFail%4d%3d%%", parent, failMessageCounter, getCount(failStore, messageCounterMax));
                                          lcd.print(buf);
                                          snprintf(buf, sizeof buf, "D%-3dMiss%4d%3d%%", DESTINATION_NODE , missedMessageCounter, getCount(missedStore, messageCounterMax));
                                          lcd.print(buf);
                                        case STATE_RUN2:
                                          snprintf(buf, sizeof buf, "PA Level = %s", paLevelNames[rf24palevel]);
                                          lcd.print(buf);
                                          snprintf(buf, sizeof buf, "Current = %dmA", currentMa);
                                          lcd.print(buf);
                                        case STATE_PALEVEL:
                                          lcd.print(buf);
                                        case STATE_RESEND:
                                          snprintf(buf, sizeof buf, "Send repeats = %d", sendRepeats);
                                          lcd.print(buf);
                                    • H Heizelmann
                                        FILE: AWI_Send.ino
                                        and MySensors 2.1.1
                                        Special:
                                        Summary:
                                        Remarks:
                                        Change log:
                                      // helpers
                                      #define LOCAL_DEBUG
                                      #ifdef LOCAL_DEBUG
                                      // MySensors sensor
                                      // Loop delays
                                      // ***** LCD
                                      #define LCD_COLS 16
                                      #define LCD_ROWS 2
                                      // Options
                                      int currentMa;
                                      // Menu
                                      void before() {
                                        lcd.home();
                                        initStore();
                                        delay(1000);
                                        button1.tick();
                                        button2.tick();
                                          if (!success) {
                                          dspRefresh = true;
                                          case V_PERCENTAGE:
                                            break ;
                                          default: break ;
                                        return falseCount ;
                                      void initStore() {
                                        int repeat = 0;
                                            sendOK = true;
                                            sendOK = false;
                                          repeat++;
                                          delay(repeatdelay);
                                        return sendOK;
                                        dspRefresh = true;
                                        switch (opState) {
                                          case STATE_RUN:
                                          case STATE_RUN2:
                                          case STATE_PALEVEL:
                                          case STATE_RESEND:
                                        dspRefresh = true;
                                        switch (opState) {
                                          case STATE_RUN:
                                          case STATE_RUN2:
                                          case STATE_PALEVEL:
                                          case STATE_RESEND:
                                        initStore();
                                        dspRefresh = false;
                                        switch (opState) {
                                          case STATE_RUN:
                                            lcd.print(buf);
                                            lcd.print(buf);
                                          case STATE_RUN2:
                                            lcd.print(buf);
                                            lcd.print(buf);
                                          case STATE_PALEVEL:
                                            lcd.print(buf);
                                          case STATE_RESEND:
                                            lcd.print(buf);
                                      H
                                      H
                                      Heizelmann
                                      See further advanced project nRF24Doctor. Great thanks to @Technovation
                                      • H Heizelmann
                                        Technovation
                                        @heizelmann I'm happy to see that you can appreciate my work as a continuation of the nice job you already did on this thread.
