  3. nRf24L01+ connection quality meter
43 Posts 18 Posters 26.6k Views 33 Watching
  • B
    B
    boozz
    @AWI
    And when you start explaining they look somewhat odd don't they?
    • mrc-coreM
      mrc-coreM
      mrc-core
      I'm having a problem in this part off the code:
      "present(counterChild, S_DIMMER, "Quality counter " NODE_TXT) ; // counter uses percentage from dimmer value"
      I'm getting this error:
      "exit status 1
      'present' was not declared in this scope"
      How can i fix this ?
      • mrc-coreM mrc-core
        "exit status 1
        @mrc-core sounds like you are using the stable (1.5.x) version of MySensors. This sketch requires the development version which is available on github
        • mrc-coreM
          mrc-coreM
          mrc-core
          Thanks for the quick reply.
          i'm going to change the versions :)
          • bjacobseB
            bjacobseB
            bjacobse
            Can this be extended to also measure NRF24l01 standby current? Maybe some "fake" modules have a high current consumption in stadnby mode, this could drain batteries quickly when used in battery operated devices
            • cjrpriestC
              cjrpriestC
              cjrpriest
              wrote on last edited by cjrpriest
              #21
              Hi @AWI, could you kindly post your updated version of the sketch that has the parent and destination node numbers on the display?
              AWIA 1 Reply Last reply
              • cjrpriestC cjrpriest
                AWIA
                AWIA
                AWI
                @cjrpriest Here you go..
                 PROJECT: MySensors / Quality of radio transmission
                 PROGRAMMER: AWI (MySensors libraries)
                 DATE: 20160529/ last update: 20160530
                 FILE: AWI_Send.ino
                 LICENSE: Public domain
                 Hardware: ATMega328p board w/ NRF24l01
                	and MySensors 2.0
                Special:
                Summary:
                	Sends a radio message with counter each  x time to determine fault ratio with receiver
                Remarks:
                	Fixed node-id & communication channel to other fixed node
                Change log:
                20160530 - added moving average on fail/ miss count, update to 2.0
                //****  MySensors *****
                #define MY_RADIO_NRF24									// Enable and select radio type attached
                //#define MY_RF24_CHANNEL 80								// radio channel, default = 76
                #define MY_NODE_ID 250
                #define NODE_TXT "Q 250"								// Text to add to sensor name
                //#define MY_PARENT_NODE_ID 42							// fixed parent to controller when 0 (else comment out = AUTO)
                // #define MY_RF24_CE_PIN 7								// Ceech board, 3.3v (7,8)  (pin default 9,10)
                // #define MY_RF24_CS_PIN 8
                #define DESTINATION_NODE 0								// receiving fixed node id (default 0 = gateway)
                // display
                #include <Wire.h>											// I2C
                #include <LiquidCrystal_I2C.h>								// LCD display with I2C interface
                // helpers
                #define LOCAL_DEBUG
                #ifdef LOCAL_DEBUG
                #define Sprint(a) (Serial.print(a))						// macro as substitute for print, enable if no print wanted
                #define Sprintln(a) (Serial.println(a))					// macro as substitute for println
                #define Sprint(a)										// enable if no print wanted -or-
                #define Sprintln(a)										// enable if no print wanted
                // MySensors sensor
                #define counterChild 0
                // send constants and variables
                int messageCounter = 0 ;
                const int messageCounterMax = 100 ; 					// maximum message counter value
                const unsigned counterUpdateDelay = 500 ;				// send every x ms and sleep in between
                // receive constants and variables
                boolean failStore[messageCounterMax] ;					// moving average stores & pointers
                int failStorePointer = 0 ;
                boolean missedStore[messageCounterMax] ;
                int missedStorePointer = 0 ;
                int newMessage = 0 ;
                int lastMessage = -1 ;
                int missedMessageCounter = 0 ; 							// total number of messages in range (messageCounterMax)
                int failMessageCounter = 0 ; 							// total number of messages in range (messageCounterMax)
                uint8_t parent = 0 ;									// parent node-id
                // Loop delays
                const unsigned long displayInterval = 1000UL ;			// display update in ms
                unsigned long lastDisplayUpdate = 0 ;					// last update for loop timers
                // standard messages
                MyMessage counterMsg(counterChild, V_PERCENTAGE);		// Send value
                // ***** LCD
                //LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
                LiquidCrystal_I2C lcd(0x27, 16, 2);  // Set the LCD I2C address
                	Wire.begin();  // I2C
                    // ** LCD display **
                    // LCD 2 lines * 16 char.
                    lcd.begin(16, 2);
                    lcd.setBacklight(HIGH);
                    lcd.setCursor(0, 0);
                	lcd.print("AWI Quality nRF24");
                	for(int i= 0 ; i <  messageCounterMax ; i++){		// init stores for moving averages
                		failStore[i] = true ;
                		missedStore[i] = true ;
                	missedStorePointer = failStorePointer = 0 ;
                	delay(1000);
                void presentation(){
                // MySensors
                	// Sprint("count:") ; Sprintln(messageCounter) ;
                	LCD_local_display();
                	missedStore[failStorePointer] = false  ; 			// set slot to false (ack message needs to set) ;
                	boolean succes = failStore[failStorePointer] = send(counterMsg.setDestination(DESTINATION_NODE).set(failStorePointer), true);  // send to destination with ack
                	if (!succes){
                		failMessageCounter++ ;
                		Sprint("Fail on message: ") ; Sprint(failStorePointer) ;
                		Sprint(" # ") ; Sprintln(failMessageCounter);
                	failStorePointer++ ;
                	if(failStorePointer >= messageCounterMax){
                		failStorePointer =  0	;						// wrap counter
                	parent = getParentNodeId();							// get the parent node (0 = gateway)
                	wait(counterUpdateDelay) ;							// wait for things to settle and ack's to arrive
                void receive(const MyMessage &message) {  				// Expect few types of messages from controller
                	newMessage = message.getInt();						// get received value
                	switch (message.type){
                		case V_PERCENTAGE:
                			missedStore[newMessage] = true ;			// set corresponding flag to received.
                			if (newMessage > lastMessage){				// number of messages missed from lastMessage (kind of, faulty at wrap)
                				Sprint("Missed messages: ") ; Sprintln( newMessage - lastMessage - 1) ;
                				missedMessageCounter += newMessage - lastMessage - 1 ;
                			lastMessage = newMessage ;
                			break ;
                		default: break ;
                // calculate number of false values in array
                // takes a lot of time, but who cares...
                int getCount(boolean countArray[], int size){
                	int falseCount = 0 ;
                	for (int i = 0 ; i < size ; i++){
                		falseCount += countArray[i]?0:1 ;
                	return falseCount ;
                void LCD_local_display(void){
                /* prints all available variables on LCD display with units
                    char buf[17]; 											// buffer for max 16 char display
                    snprintf(buf, sizeof buf, "p%-3dFail%4d%3d%%", parent, failMessageCounter, getCount(failStore, messageCounterMax));
                    lcd.print(buf);
                    lcd.setCursor(0, 1);
                    snprintf(buf, sizeof buf, "d%-3dMiss%4d%3d%%", DESTINATION_NODE , missedMessageCounter, getCount(missedStore, messageCounterMax));
                	lcd.print(buf);
                cjrpriestC karl261K 2 Replies Last reply
                • AWIA AWI
                   FILE: AWI_Send.ino
                  	and MySensors 2.0
                  Special:
                  Summary:
                  Remarks:
                  Change log:
                  // display
                  // helpers
                  #define LOCAL_DEBUG
                  #ifdef LOCAL_DEBUG
                  // MySensors sensor
                  // Loop delays
                  // ***** LCD
                      lcd.begin(16, 2);
                  	delay(1000);
                  // MySensors
                  	if (!succes){
                  		case V_PERCENTAGE:
                  			break ;
                  		default: break ;
                  	return falseCount ;
                      lcd.print(buf);
                  	lcd.print(buf);
                  cjrpriestC
                  cjrpriestC
                  cjrpriest
                  Thanks very much @AWI 👍
                  • AWIA AWI
                     FILE: AWI_Send.ino
                    	and MySensors 2.0
                    Special:
                    Summary:
                    Remarks:
                    Change log:
                    // display
                    // helpers
                    #define LOCAL_DEBUG
                    #ifdef LOCAL_DEBUG
                    // MySensors sensor
                    // Loop delays
                    // ***** LCD
                        lcd.begin(16, 2);
                    	delay(1000);
                    // MySensors
                    	if (!succes){
                    		case V_PERCENTAGE:
                    			break ;
                    		default: break ;
                    	return falseCount ;
                        lcd.print(buf);
                    	lcd.print(buf);
                    karl261K
                    karl261K
                    karl261
                    wrote on last edited by karl261
                    #24
                    @AWI Strange, with the latest sketch I get
                    nrf-quality-meter.ino:88:34: error: invalid conversion from 'int' to 't_backlighPol' [-fpermissive]
                    In file included from nrf-quality-meter.ino:45:0:
                    C:\Dokumente und Einstellungen\Philipp\Eigene Dateien\Arduino\libraries\LiquidCrystal/LiquidCrystal_I2C.h:53:4: error: initializing argument 3 of 'LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, t_backlighPol)' [-fpermissive]
                    LiquidCrystal_I2C (uint8_t lcd_Addr, uint8_t backlighPin, t_backlighPol pol);
                    compiling...
                    It works using the other line...
                    // ***** LCD
                    • karl261K karl261
                      compiling...
                      // ***** LCD
                      AWIA
                      AWIA
                      AWI
                      @karl261 probably I am using another library for the display. I got it from the Arduino library manager.
                      • N
                        N
                        Nicklas Starkel
                        @AWI what is the board between the nano and the radio?
                        Something available via aliexpress?
                        I really do not need this as I live in a small flat.. but I NEED THIS! :laughing:
                        • N Nicklas Starkel
                          AWIA
                          AWIA
                          AWI
                          wrote on last edited by AWI
                          #27
                          @Nicklas-Starkel you can find it in the MySensors shop It is a nrf24l01+ socket adapter board. It guarantees a stable supply and includes the famous "radio capacitor"
                          • siodS
                            siodS
                            siod
                            wrote on last edited by siod
                            #28
                            Hi @AWI,
                            thanks for the code and the project! ~~Unfortunately my biggest problem is to get my LCD working. It does not do anything with your code, other testcode to test the display is working fine. I am using this line and it should work fine:
                            Any idea what else I could check? I am using arduino IDE 1.6.10
                            edit: getting this in the serial monitor of the device:
                            TSM:INIT
                            TSM:RADIO:OK
                            TSP:ASSIGNID:OK (ID=250)
                            TSM:FPAR
                            TSP:MSG:SEND 250-250-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSP:MSG:READ 3-3-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                            TSP:MSG:BC
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            then it starts over again...
                            edit2:
                            Think I got it now, seems like my gateway wasn´t responding or whatever, now it seems to work...
                            Edit3:
                            I got 1 fail and 5000 miss 60%...
                            Now what does this mean??
                            Edit4:
                            I think I need some help: Most of the time I get this on my gw´s Serial Monitor:
                            0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                            0;255;3;0;9;TSP:MSG:READ 250-250-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                            0;255;3;0;9;TSP:MSG:BC
                            0;255;3;0;9;TSP:MSG:FPAR REQ (sender=250)
                            0;255;3;0;9;TSP:MSG:GWL OK
                            After some reboots of the quality meter and I guess with a lot of luck it starts working occasionally
                            This is from the serial monitor of the quality meter:
                            TSP:MSG:READ 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                            !TSP:MSG:PVER mismatch
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            I already added a 47u Cap and added those lines to the code:
                            #define MY_PARENT_NODE_ID 0                         // fixed parent to controller when 0 (else comment out = AUTO)
                            no luck at all...
                            edit5:
                            Now I opened the serial output of my GW again, which seems to started the communication:
                            0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                            0;255;3;0;9;TSP:MSG:PINGED (ID=250, hops=1)
                            0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                            0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                            0;255;3;0;9;!TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                            0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
                            0;255;3;0;9;Sending message on topic: mygateway1-out/250/255/0/0/17
                            0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                            0;255;3;0;9;Sending message on topic: mygateway1-out/250/255/3/0/6
                            0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=0,t=4,pt=0,l=21,sg=0:Quality counter Q 250
                            0;255;3;0;9;Sending message on topic: mygateway1-out/250/0/0/0/4
                            0;255;3;0;9;TSP:MSG:READ 250-250-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                            0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                            0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:0
                            0;255;3;0;9;TSP:MSG:ACK msg
                            0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=ok:0
                            0;255;3;0;9;Sending message on topic: mygateway1-out/250/0/1/0/3
                            0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:1
                            0;255;3;0;9;TSP:MSG:SEND 0-0-250-250 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=ok:1
                            0;255;3;0;9;TSP:MSG:READ 250-250-0 s=0,c=1,t=3,pt=2,l=2,sg=0:2
                            I don´t get it what is going on here. Restarted quality meter: blank LCD... :(
                            still learning...
                            • NickBuilderN
                              NickBuilderN
                              NickBuilder
                              wrote on last edited by NickBuilder
                              #29
                              Great tool for a mysensors builder @AWI! I also want to sort out the good radios from the bad, I have enough trouble as it is trying to troubleshoot my questionable sensors.
                              I got around to building a quality meter for myself, although without the adapter board and with some additional differences. But I really don't understand the output, the fail and miss percentage is almost always 100 % for most of my radios. Am I missing something? Perhaps I should change some addresses to static ones? I thought that perhaps I had to define a corresponding item in Openhab in order for the packages to be acknowledged but this doesn't change the outcome.
                              Here's the serial output from the "quality meter":
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSP:MSG:READ 0-0-250 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                              TSP:MSG:PAR OK (ID=0, dist=1)
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:CHKID:OK (ID=250)
                              TSM:UPL
                              TSP:PING:SEND (dest=0)
                              !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
                              TSP:MSG:READ 0-0-250 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                              TSP:MSG:PONG RECV (hops=1)
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=1,st=fail:0100
                              !TSP:MSG:SEND 250-250-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=2,st=fail:2.0.0
                              !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=3,st=fail:0
                              TSP:MSG:READ 0-0-250 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=0,t=4,pt=0,l=21,sg=0,ft=4,st=fail:Quality counter Q 250
                              Request registration...
                              !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=5,st=fail:2
                              !TSM:UPL FAIL, SNP
                              TSM:FPAR
                              !TSP:SEND:TNR
                              TSM:FPAR
                              !TSP:SEND:TNR
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              !TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=fail:2
                              TSP:MSG:READ 0-0-250 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                              Node registration=1
                              Init complete, id=250, parent=0, distance=1, registration=1
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:0
                              Fail on message: 0 # 1
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:0
                              Missed messages: 0
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:1
                              Fail on message: 1 # 2
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:2
                              Fail on message: 2 # 3
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:3
                              Fail on message: 3 # 4
                              !TSM:UPL FAIL, SNP
                              TSM:FPAR
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:3
                              Missed messages: 2
                              !TSP:SEND:TNR
                              Fail on message: 4 # 5
                              !TSP:SEND:TNR
                              Fail on message: 5 # 6
                              !TSP:SEND:TNR
                              Fail on message: 6 # 7
                              !TSP:SEND:TNR
                              Fail on message: 7 # 8
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 8 # 9
                              !TSP:SEND:TNR
                              Fail on message: 9 # 10
                              !TSP:SEND:TNR
                              Fail on message: 10 # 11
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:11
                              Fail on message: 11 # 12
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:11
                              Missed messages: 7
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:12
                              Fail on message: 12 # 13
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:13
                              Fail on message: 13 # 14
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:14
                              Fail on message: 14 # 15
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:15
                              Fail on message: 15 # 16
                              !TSM:UPL FAIL, SNP
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 16 # 17
                              !TSP:SEND:TNR
                              Fail on message: 17 # 18
                              !TSP:SEND:TNR
                              Fail on message: 18 # 19
                              !TSP:SEND:TNR
                              Fail on message: 19 # 20
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              TSP:CHKUPL:FAIL (hops=255)
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 20 # 21
                              !TSP:SEND:TNR
                              Fail on message: 21 # 22
                              !TSP:SEND:TNR
                              Fail on message: 22 # 23
                              !TSP:SEND:TNR
                              Fail on message: 23 # 24
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 24 # 25
                              !TSP:SEND:TNR
                              Fail on message: 25 # 26
                              !TSP:SEND:TNR
                              Fail on message: 26 # 27
                              !TSP:SEND:TNR
                              Fail on message: 27 # 28
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 28 # 29
                              !TSP:SEND:TNR
                              Fail on message: 29 # 30
                              !TSP:SEND:TNR
                              Fail on message: 30 # 31
                              !TSP:SEND:TNR
                              Fail on message: 31 # 32
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 32 # 33
                              !TSP:SEND:TNR
                              Fail on message: 33 # 34
                              !TSP:SEND:TNR
                              Fail on message: 34 # 35
                              !TSP:SEND:TNR
                              Fail on message: 35 # 36
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:36
                              Fail on message: 36 # 37
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:37
                              Fail on message: 37 # 38
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:37
                              Missed messages: 25
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:38
                              Fail on message: 38 # 39
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:38
                              Missed messages: 0
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:39
                              Fail on message: 39 # 40
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:39
                              Missed messages: 0
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:40
                              Fail on message: 40 # 41
                              !TSM:UPL FAIL, SNP
                              TSM:FPAR
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:40
                              Missed messages: 0
                              !TSP:SEND:TNR
                              Fail on message: 41 # 42
                              !TSP:SEND:TNR
                              Fail on message: 42 # 43
                              !TSP:SEND:TNR
                              Fail on message: 43 # 44
                              TSM:FPAR:OK
                              TSM:ID
                              !TSP:SEND:TNR
                              Fail on message: 44 # 45
                              TSM:UPL
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:45
                              Fail on message: 45 # 46
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:45
                              Missed messages: 4
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:46
                              Fail on message: 46 # 47
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:47
                              Fail on message: 47 # 48
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:47
                              Missed messages: 1
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:48
                              Fail on message: 48 # 49
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:48
                              Missed messages: 0
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:49
                              Fail on message: 49 # 50
                              !TSM:UPL FAIL, SNP
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 50 # 51
                              !TSP:SEND:TNR
                              Fail on message: 51 # 52
                              !TSP:SEND:TNR
                              Fail on message: 52 # 53
                              !TSP:SEND:TNR
                              Fail on message: 53 # 54
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 54 # 55
                              !TSP:SEND:TNR
                              Fail on message: 55 # 56
                              !TSP:SEND:TNR
                              Fail on message: 56 # 57
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 57 # 58
                              !TSP:SEND:TNR
                              Fail on message: 58 # 59
                              !TSP:SEND:TNR
                              Fail on message: 59 # 60
                              !TSP:SEND:TNR
                              Fail on message: 60 # 61
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 61 # 62
                              !TSP:SEND:TNR
                              Fail on message: 62 # 63
                              !TSP:SEND:TNR
                              Fail on message: 63 # 64
                              !TSP:SEND:TNR
                              Fail on message: 64 # 65
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 65 # 66
                              !TSP:SEND:TNR
                              Fail on message: 66 # 67
                              !TSP:SEND:TNR
                              Fail on message: 67 # 68
                              !TSP:SEND:TNR
                              Fail on message: 68 # 69
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 69 # 70
                              !TSP:SEND:TNR
                              Fail on message: 70 # 71
                              !TSP:SEND:TNR
                              Fail on message: 71 # 72
                              !TSP:SEND:TNR
                              Fail on message: 72 # 73
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 73 # 74
                              !TSP:SEND:TNR
                              Fail on message: 74 # 75
                              !TSP:SEND:TNR
                              Fail on message: 75 # 76
                              !TSP:SEND:TNR
                              Fail on message: 76 # 77
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 77 # 78
                              !TSP:SEND:TNR
                              Fail on message: 78 # 79
                              !TSP:SEND:TNR
                              Fail on message: 79 # 80
                              !TSP:SEND:TNR
                              Fail on message: 80 # 81
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              !TSM:UPL:FAIL
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 81 # 82
                              !TSP:SEND:TNR
                              Fail on message: 82 # 83
                              !TSP:SEND:TNR
                              Fail on message: 83 # 84
                              !TSP:SEND:TNR
                              Fail on message: 84 # 85
                              TSM:FPAR
                              !TSP:SEND:TNR
                              Fail on message: 85 # 86
                              !TSP:SEND:TNR
                              Fail on message: 86 # 87
                              !TSP:SEND:TNR
                              Fail on message: 87 # 88
                              !TSP:SEND:TNR
                              Fail on message: 88 # 89
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              TSP:MSG:SEND 250-250-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                              TSP:MSG:READ 99-99-0 s=0,c=1,t=1,pt=7,l=5,sg=0:62.2
                              !TSM:MSG:REL MSG, but not a repeater
                              TSP:CHKUPL:OK
                              TSM:UPL:OK
                              TSM:READY
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=0,st=fail:89
                              Fail on message: 89 # 90
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=1,st=fail:90
                              Fail on message: 90 # 91
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=2,st=fail:91
                              Fail on message: 91 # 92
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=3,st=fail:92
                              Fail on message: 92 # 93
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:92
                              Missed messages: 43
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=4,st=fail:93
                              Fail on message: 93 # 94
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:93
                              Missed messages: 0
                              !TSP:MSG:SEND 250-250-0-0 s=0,c=1,t=3,pt=2,l=2,sg=0,ft=5,st=fail:94
                              Fail on message: 94 # 95
                              !TSM:UPL FAIL, SNP
                              TSM:FPAR
                              TSP:MSG:READ 0-0-250 s=0,c=1,t=3,pt=2,l=2,sg=0:94
                              Missed messages: 0
                              !TSP:SEND:TNR
                              Fail on message: 95 # 96
                              !TSP:SEND:TNR
                              Fail on message: 96 # 97
                              !TSP:SEND:TNR
                              Fail on message: 97 # 98
                              !TSP:SEND:TNR
                              Fail on message: 98 # 99
                              TSM:FPAR:OK
                              TSM:ID
                              TSM:UPL
                              Also, the meter in action generating the output above can be seen here: LINK
                              After some time, >10 min, the fail percentage is 100 % and the miss percentage around 85 %. Not impressive if interpreted correctly. Could someone give me some pointers to what the problem is? I don't talk "mysensors protocol".
                              Sorry @siod, I don't think I can help you. You seem to get a lot more messages through though.
                              • NickBuilderN NickBuilder
                                TSM:INIT
                                TSM:RADIO:OK
                                TSM:FPAR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                !TSM:UPL FAIL, SNP
                                TSM:FPAR
                                !TSP:SEND:TNR
                                TSM:FPAR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                Node registration=1
                                Missed messages: 0
                                !TSM:UPL FAIL, SNP
                                TSM:FPAR
                                Missed messages: 2
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                Missed messages: 7
                                !TSM:UPL FAIL, SNP
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                Missed messages: 25
                                Missed messages: 0
                                Missed messages: 0
                                !TSM:UPL FAIL, SNP
                                TSM:FPAR
                                Missed messages: 0
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                !TSP:SEND:TNR
                                TSM:UPL
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                Missed messages: 4
                                Missed messages: 1
                                Missed messages: 0
                                !TSM:UPL FAIL, SNP
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                !TSM:UPL:FAIL
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                TSP:CHKUPL:OK
                                TSM:UPL:OK
                                TSM:READY
                                Missed messages: 43
                                Missed messages: 0
                                !TSM:UPL FAIL, SNP
                                TSM:FPAR
                                Missed messages: 0
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                !TSP:SEND:TNR
                                TSM:FPAR:OK
                                TSM:ID
                                TSM:UPL
                                AWIA
                                AWIA
                                AWI
                                #30
                                @NickBuilder you seem to have a pretty bad connection (hardware related) . The meter has to be built with a reliable power source and connections. I can't see from the movie how your radio is powered. The reason for using the adapter plate is that it includes a separate ldo and capacitors.
                                NickBuilderN 1 Reply Last reply
                                • siodS siod
                                  Hi @AWI,
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSP:MSG:BC
                                  !TSM:FPAR:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  edit2:
                                  Edit3:
                                  Edit4:
                                  !TSM:FPAR:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  no luck at all...
                                  edit5:
                                  AWIA
                                  AWIA
                                  AWI
                                  #31
                                  @siod the meter works like a normal sketch. If it does not get past making a connection the rest of the code won't start (ie the LCD). To be honest I can't make up a reason from the serial logs except that your node has problems finding it's parent.
                                  • AWIA AWI
                                    NickBuilderN
                                    NickBuilderN
                                    NickBuilder
                                    @AWI, it's hardly visible but I'm actually using a 3V3 buck and a 10 uF cap to power the radio. But I took your advice and tried tos power the radio seperately with two AA batterys, and a cap just in case. This should be a really clean source of power but the outcome is still the same.
                                    I guess I'll order som new radios, hopefully from a different supplier. I'll get some adapter boards with (switchless) LDO's while I'm at it.
                                    Why is the parent changing from 255 to 0 back and forth? I have a serial gateway connected to a Pi and aside from some temp sensors I also have an RC switch for my outlets which also acts as a gateway but the adress is neither 255 nor 0.
                                      AWIA
                                      AWIA
                                      AWI
                                      @NickBuilder I hope you solve your issues with new radio's. I have very little which don't function at all.
                                      The id "0" belongs to your gateway "255" is a kind of broadcast id which is a.o. used when a node number is not known. Both id's are not available for you to assign to a node.
                                      • karl261K
                                        karl261K
                                        karl261
                                        For those who need and don't have a display like me, here is my sketch version for output to the serial console. So what I do is, I run around with a laptop connected to the node and watch the serial console, or, I just move around with a tablet and the node. The tablet is connected to my raspi and I watch the output of my gw on the pi using picocom. Picocom handles very well the missing line feeds in the output. The gw output is also very informative, there are no statistics, but still I see when stuff fails...
                                        Thanks for the cool sketch @AWI!
                                         FILE: AWI_Send.ino
                                            and MySensors 2.0
                                        Special:
                                        Summary:
                                        Remarks:
                                        Change log:
                                        // MIN, LOW, HIGH, MAX
                                        #define MY_PARENT_NODE_ID 99                          // fixed parent to controller when 0 (else comment out = AUTO)
                                        #define MY_BAUD_RATE 9600
                                        // helpers
                                        #define LOCAL_DEBUG
                                        #ifdef LOCAL_DEBUG
                                        // MySensors sensor
                                            delay(1000);
                                        // MySensors
                                            Sprint("Parent: "); Sprint(parent); Sprint("       Fail "); Sprint(failMessageCounter); Sprint("   "); Sprint(getCount(failStore, messageCounterMax)); Sprintln("%");
                                            Sprint("Destination: "); Sprint(DESTINATION_NODE); Sprint("  Miss "); Sprint(missedMessageCounter); Sprint("   "); Sprint(getCount(missedStore, messageCounterMax)); Sprintln("%");
                                            if (!succes){
                                                case V_PERCENTAGE:
                                                    break ;
                                                default: break ;
                                            return falseCount ;
                                        • Mark SwiftM
                                          Mark SwiftM
                                          Mark Swift
                                          @karl261 I tried your code and it pretty much just gives me failures? I don't have any issues with nodes and tried it out of curiosity, any ideas? It seems to send pretty fast, perhaps its spamming my gateway too much?
                                          karl261K 1 Reply Last reply
