  3. The basics of MySensors?
11 Posts 2 Posters 5.9k Views 1 Watching
    This thread contains comments for the article "MySensors Library - v2.x" posted on MySensors.org.
    marexM
    marexM
    marex
    I have a question regarding the API to access the sensor nRF24L01.
    What happened to the function RF24_openReadingPipe?
    It used to be part of the API.
    Has it removed because it is obsolete.
    What it is the right way to read data from a pipe?
    • marexM marex
      @marex I don't believe MySensors has had such a function. Sounds way too nrf24-specific, MySensors abstracts away the transport. Where did you find it?
      • marexM
        marexM
        marex
        https://github.com/mysensors/MySensors/blob/development/drivers/RF24/RF24.h
        • marexM
          marexM
          marex
          I connected my NodeMCU to a nRF24L01 as explained at
          https://www.mysensors.org/build/esp8266_gateway
          I don´t know how to listen to messages from a pipe.
          The corresponding NR24 API for Arduino supports the function openReadingPipe:
          • marexM marex
            @marex Sending and receiving messages with MySensors is described at https://www.mysensors.org/download/sensor_api_20#sending-data and https://www.mysensors.org/download/sensor_api_20#handling-incoming-radio-messages
            The low-level functions of the different transports are not part of MySensors. Why do you want to use them directly?
            marexM 1 Reply Last reply
              marexM
              marexM
              marex
              @mfalkvidd I´m just looking for an easy way of receiving temperature data transmitted by 3 Arduino Nano connected to a NRF24.
              I´d like to use a NodeMCU connected to a NRF24 to receive the temperature data from the 3 Arduino Nano and make them available over WifI to my cell phone. Can I use the mysensor library to receive data transmitted using a different library (https://github.com/TMRh20/RF24/blob/master/RF24.h)? Can it work in principle? Or should the transmitter use the mysensor library too?
              • marexM marex
                @marex you could probably build something that decodes MySensors if you want to, but that would essentially be re-implementing MySensors. It could be a fun challenge, if you are into that sort of thing.
                But if you just want to get things working, load the ESP8266 gateway sketch on your ESP8266/NodeMCU and use the temperature example on your Nanos.
                • marexM
                  marexM
                  marex
                  That would work for a local temperature sensor connected directly to the NodeMcu.
                  What I would like to achieve is different. I would like to use a NodeMcu as gateway.
                  It should be able to receive data from different sensors in my house.
                  For the radio communication I´d like to use an inexpensive NRF24 transceiver.
                  • marexM marex
                    @marex then what I linked to is exactly what you want.
                      marexM
                      marexM
                      marex
                      @mfalkvidd I actually use a different kind of temperature/humidity sensor. I will adjust the Arduino sketch and try. Thanks a lot.
                      • mfalkviddM
                        Discussion continued at https://forum.mysensors.org/topic/5080/the-basics-of-mysensors-continued/ (couldn't figure out how to fork such a long discussion into just one topic, the forum software doesn't seem to handle that. Sorry.)
