  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.4k Views 20 Watching
  • m26872M m26872
    @clempat Please post your sketch and maybe some hardware photo or diagram too.
    clempatC
    clempatC
    clempat
    @m26872 Sure I can do that. So I simplified the code to only focus on the si7021.
    Here it is: https://github.com/clempat/example-si7021
    And there the photo:
    m26872M 1 Reply Last reply
    • clempatC clempat
      m26872M
      m26872M
      m26872
      @clempat Don't think I can help you. Maybe clock related. What voltages do you use on Nano and Slim respectively? Do you have multiple parts to try with and get the same result? Why do you include and start wire.h, isn't already in Si7021.h ? My guess on "device Id 50" is that it's just a chinese clone reply.
      Photos look nice btw. :thumbsup:
      clempatC 1 Reply Last reply
      • m26872M m26872
        clempatC
        clempatC
        clempat
        @m26872 Thank you. Yes I wanted to try with a pro mini 8Mhz but I need to prepare the pin 4 and 5. I will keep inform when I do it this week end.
        Thanks for the picture but with this nice setup it is difficult to make it bad :)...
        I includes wire.h like in the exemple in https://github.com/LowPowerLab/SI7021 but of course after I tried without. The nano was directly connected to usb and the slim through 3,3V USB to serial.
        • clempatC
          clempatC
          clempat
          Ok with the arduino micro 8Mhz all works good too.
          Reading...
          T: 20.29
          H: 54
          device ID: 50
          • clempatC
            clempatC
            clempat
            So sad I still not getting it working with the slim node :( !!! Always same result either with internal 1mhz or 8mhz...
            • clempatC clempat
              m26872M
              m26872M
              m26872
              @clempat Make it with external 8MHz then ? Then it should be like a Pro Mini 3.3V.
              • m26872M m26872
                clempatC
                clempatC
                clempat
                @m26872 I will give a try and let you know... Thanks.
                • miljumeM
                  miljumeM
                  miljume
                  Hello
                  I also have big problems with getting the node to send temp and hum values
                  It starts up and presents itself to the GW but then nothing happens
                  I have tested the SI721 module with a simple arduino code and then it reads and prints both values just fine
                  My code is below, in practice its a version of Sensebender Micro code. I have changed the force transmit value to 1
                  Exactly as @clempat I have tried both 1MHz optiboot and 8MHz internal oscillator without any success
                  * Version 1.0 - Thomas Bowman MC8rch
                  * Version 1.3 - Thomas Bowman MC8rch
                  * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
                  * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
                  * Version 1.4 - Thomas Bowman MC8rch
                  * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
                  * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
                  * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
                  // Define a static node address, remove if you want auto address assignment
                  //#deine MY_NODE_ID 3
                  #include <SI7021-master\SI7021.h>
                  #include <RunningAverage.h>
                  // Uncomment the line below, to transmit battery voltage as a normal sensor value
                  #define BATT_SENSOR    199
                  #define RELEASE "1.4"
                  #define AVERAGES 2
                  // Child sensor ID's
                  #define CHILD_ID_TEMP  1
                  #define CHILD_ID_HUM   2
                  #define FORCE_TRANSMIT_INTERVAL 1
                  SI7021 humiditySensor;
                  // Sensor messages
                  #ifdef BATT_SENSOR
                  MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
                  // Global settings
                  int measureCount = 0;
                  int sendBattery = 0;
                  boolean isMetric = true;
                  boolean highfreq = true;
                  boolean transmission_occured = false;
                  float lastTemperature = -100;
                  int lastHumidity = -100;
                  long lastBattery = -100;
                  * Setup code
                  	Serial.begin(9600);
                  	Serial.print(RELEASE);
                  	Serial.flush();
                  	humiditySensor.begin();
                  	Serial.flush();
                  	isMetric = getConfig().isMetric;
                  	Serial.print(F("isMetric: ")); Serial.println(isMetric);
                  	raHum.clear();
                  	sendTempHumidityMeasurements(false);
                  	sendBattLevel(false);
                  	sendSketchInfo("TempHum", RELEASE);
                  	present(CHILD_ID_HUM, S_HUM);
                  #ifdef BATT_SENSOR
                  	present(BATT_SENSOR, S_POWER);
                  *  Main loop function
                  	measureCount++;
                  	sendBattery++;
                  	bool forceTransmit = false;
                  	if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
                  		forceTransmit = true;
                  		measureCount = 0;
                  	/*  if (sendBattery > 60)
                  	sendBattLevel(forceTransmit); // Not needed to send battery info that often
                  	sendBattery = 0;
                  	sleep(MEASURE_INTERVAL);
                  * Sends temperature and humidity from Si7021 sensor
                  * Parameters
                  void sendTempHumidityMeasurements(bool force)
                  	bool tx = force;
                  	raHum.addValue(data.humidityPercent);
                  	Serial.print(F("TempDiff :"));Serial.println(diffTemp);
                  	Serial.print(F("HumDiff  :"));Serial.println(diffHum);
                  	if (isnan(diffHum)) tx = true;
                  	if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
                  	if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
                  	if (tx) {
                  		measureCount = 0;
                  		float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                  		Serial.print("T: ");Serial.println(temperature);
                  		Serial.print("H: ");Serial.println(humidity);
                  		send(msgHum.set(humidity));
                  		lastHumidity = humidity;
                  		transmission_occured = true;
                  		if (sendBattery > 60) {
                  			sendBattLevel(true); // Not needed to send battery info that often
                  			sendBattery = 0;
                  * Parameters
                  	if (force) lastBattery = -1;
                  	long vcc = readVcc();
                  	if (vcc != lastBattery) {
                  		lastBattery = vcc;
                  #ifdef BATT_SENSOR
                  		float send_voltage = float(vcc) / 1000.0f;
                  		send(msgBatt.set(send_voltage, 3));
                  		// Calculate percentage
                  		long percent = vcc / 14.0;
                  		sendBatteryLevel(percent);
                  long readVcc() {
                  	uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
                  • m26872M
                    m26872M
                    m26872
                    It would be interesting if someone with issues also tried older versions of libs for Si7021 and/or MySensors.
                    • W
                      W
                      wergeld
                      So, after a few months of 2 nodes up and running using the HTU21D sensor I have come the conclusion that the HTU21D is no good for where I live. Lately it has been getting cooler outside (down to mid 50s F) but humidity is still high. As the evening progresses the humidity gets to 100% and the node no longer sends data. This happens around 6pm every day (about half and hour after sunset). It then comes back online at about 10 am the next day. The node that I have inside does not have this issue (same shipment of arduino, pcb, and HTU21D sensors and the same arduino code). Both running off of fresh AAs. May need to upgrade to the SI7021 for outside node.
                      Here is the graph showing last 7 days. As you can see it flatlines (literally!) at 100% humidity!
                      All good times with the learning!
                      • W wergeld
                        m26872M
                        m26872M
                        m26872
                        @wergeld Relative humidity at 100% during night sounds very realistic to me. Are you confusing it with the "absolute humidity"? Or is your concern that the "force transmit" isn't working?
                        • bjacobseB
                          bjacobseB
                          bjacobse
                          Mine does the same, but it's also very humid at night - I think this is normal behavoir
                          • W
                            W
                            wergeld
                            @m26872 & @bjacobse - Yes, 100% humidity is normal here. Good old Florida! My concern is that the node stops reporting. Possibly due to condensation shorting out something. During the summer here we also hit 100% humidity but it is also a lot hotter (high 90s). Now, I think that the cooler temps are forcing a dew point that is allowing water to condense on the node. Then during the morning it drys out and resumes transmitting. I would like to find a way to stop this.
                            • W wergeld
                              m26872M
                              m26872M
                              m26872
                              @wergeld
                              https://forum.mysensors.org/topic/1560/how-to-protect-your-outdoor-sensor
                              W 1 Reply Last reply
                              • m26872M m26872
                                @wergeld
                                W
                                W
                                wergeld
                                @m26872 I have looked at a lot of those links. I am leaning towards covering my node in non-reactive glue. This will seal all contacts. The only part that would be difficult would be the actual teeny tiny sensor chip on the HTU21D. Hopefully any condensation there can be minimal. The next step would be to make sure the battery case is sealed as well (although I do not think this will be much of an issue).
                                • bjacobseB
                                  bjacobseB
                                  bjacobse
                                  Do you have some battery saving stuff in your code, so you maybe wakeup check temp + humidity, and if they are same value as previous, then go back to sleep - no need to use battery usage to send same values again, this can cause your sensor to not report values
                                  • bjacobseB bjacobse
                                    W
                                    W
                                    wergeld
                                    @bjacobse Yes, I am checking the values and if the same as last transmission I abort and go back to sleep. If, however, it has been 3 hours since last transmission I force it to send.
                                    • E
                                      E
                                      Eawo
                                      wrote on last edited by Eawo
                                      #133
                                      I've done 6 nodes off this sensor. Do I have to change something else then node id? Also I'm using the 1mhz bootloader with bud rate 9200 should I change that in the sketch?
                                      Seems like I only get the temprature and humidity once on first start up...
                                      Edit:
                                      I think my problem is that I haven't changed the bud rate in mysensors.h file. I've just reinstalled everything now and I don't know how to get si7021 installed the right way. I installed the package inside arduino but it doesn't work.
                                      I such a noob sorry guys
                                      • E
                                        E
                                        Eawo
                                        I have problem to get my sensors to work. Thay start up and shows a not so accurate value sometimes and thay report once or twice but then never again. I thought it was because buad rate was wrong in the MyConfig.H file. Now i changed that and i tried a few different codes and librarys. Nothing seems to work.
                                        So my question is which code and library should i use?
                                        I got the slim node and sensor as in the first post.
                                        Im running 1mhz optiboot bootloader from the slim node thread
                                        And i updated mysensors to 2.1.
                                        • E Eawo
                                          m26872M
                                          m26872M
                                          m26872
                                          @Eawo Sorry for a late reply. Please post your sketch to begin with.
                                          Do you have v2.1 for both gateway and sensors?
                                          "#define MY_BAUD_RATE 9600" should be before the "include MySensors.h" and that should be all regarding baud rate setting. No need to mess with MyConfig.h in v2.x.
                                          A lot of the SlimNode example codes are still in v1.x unfortunately. So please look at more recent post above in this thread instead for v2.x.
                                          To verify the Si7021 you should use a clean Arduino+Si7021 setup with the only hw/sw needed for that, i.e. no radio or MySensors-library. Si7021-example sketches generally comes with the lib.
