  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.5k Views 40 Watching
  • drradkinD
    drradkinD
    drradkin
    Can I use an arduino nano for this? If so, What pins do I use? Also, will I need to change the code?
      Yes you can. Use the same pins for Nano.
      • G
        G
        gvorster
        I used RFM69 with Arduino before and a library where I have to initialize the radio with the frequency (868MHZ in my case) Does the mysensors library work for all frequencies of RFM69 without telling it which frequency to use?
        • G gvorster
          @gvorster 868 is the default so you don't need to do anything. If you want to change it, add
          #define MY_RFM69_FREQUENCY
          before including MySensors.h in your sketch. See https://github.com/mysensors/MySensors/blob/a31eff112e4895198bf6ec385fdeedb2910bb628/MyConfig.h#L588 for valid settings.
          G 1 Reply Last reply
            G
            G
            gvorster
            Great, thanks!
            • palande.vaibhavP
              palande.vaibhavP
              palande.vaibhav
              wrote on last edited by palande.vaibhav
              @DiverAlpha said:
              Hi all,
              I'm using the Arduino Micro with al NRF24L01 radio. With the micro it's not posible to use the pin config of the Nano.
              I got it working with the connections below.
              NRF24 > Micro
              Miso > Miso
              Mosi > Mosi
              SCK > SCK
              CSN > Pin D7
              CE > Pin D8
              Thereby I put the code below in my arduino code before de "#include <SPI.h>"
              // Pin Confuguration for Arduino Micro
              #define MY_RF24_CE_PIN 8
              #define MY_RF24_CS_PIN 7
              Maybe this is helpful for some other users.
              Grtz Diver
              @DiverAlpha
              Thanx a lot for commenting with that information. I was having problems with the Arduino Mega. I connected the NRF24L01+ to the appropriate SPI pins on the Mega and then just defined the CE and CS pins in the code an now it works. Thanks again
              • DiverAlphaD
                DiverAlphaD
                DiverAlpha
                Hi all,
                I tried a lot in the last coup[le of days but I can't get my network up and running...
                I've got a Micro DHT sensor ans a Uno Ethernet Gateway.
                The output of the Gateway:
                0;255;3;0;9;TSM:INIT
                0;255;3;0;9;TSM:RADIO:OK
                0;255;3;0;9;TSM:GW MODE
                0;255;3;0;9;TSM:READY
                IP: 192.168.5.8
                So I think this is nice but I'm not complete sure.
                The output of the DHT sensor:
                TSM:INIT
                TSM:RADIO:OK
                TSP:ASSIGNID:OK (ID=105)
                TSM:FPAR
                TSP:MSG:SEND 105-105-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                TSM:FPAR
                TSM:FPAR
                TSM:FPAR
                !TSM:FPAR:FAIL
                !TSM:FAILURE
                TSM:PDT
                To me it seems that the sensor cannot get a good connection to the gateway by the RF connection. The physical distance between de two RF modules is about 15 cm and I'm using a 10uF condensator on both of the RF modules.
                Can someone tell me what I'm doing wrong?
                Tnx in advance!
                • DiverAlphaD DiverAlpha
                  Hi all,
                  IP: 192.168.5.8
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  Tnx in advance!
                  @DiverAlpha try moving the nodes further apart. It might be counter-intuitive, but many have had problems when nodes are too close.
                  Do you get nothing at all in the log of the gateway when the sensor tries to find parent?
                  • DiverAlphaD
                    DiverAlphaD
                    DiverAlpha
                    @mfalkvidd, They are now 2 meters apart from each other but still the same problem. I was thinking in this direction also but because I build those two on the same breadboard, it was a bit difficult to separate them. I now build the sensor on another breadboard and moved is 2 meters away. It can't be any longer because of the length of my USB cables.
                    All the logging I got from the gateway is posted in my previous post. So there is nothing about any child in there.
                    mfalkviddM palande.vaibhavP 2 Replies Last reply
                      @DiverAlpha strange. You could try hard-coding the parent on the node, see MY_PARENT_NODE_IS_STATIC and MY_PARENT_NODE_ID on https://www.mysensors.org/download/sensor_api_20
                        palande.vaibhavP
                        palande.vaibhavP
                        palande.vaibhav
                        #22
                        @DiverAlpha
                        I am no expert in this. But when I started using MySensors few months ago, I also had some problems. Not because there is a problem with MySensors but because I was doing the simplest of the mistakes and I needed to think simple and do simple things first.
                        What I would suggest is just try the simplest of the code first. This post is considering that you are using MySensors library 2.0.
                        This is what I did when I was trying out MySensors and I think you can try this too.
                        Firstly connect Arduino you are using properly to the radio with the proper connections using the instructions here. If you are using Arduino Mega, the SPI pins are different. Here is the link for Arduino Mega: https://forum.mysensors.org/topic/4940/arduino-mega-nrf-wiring/3. Make sure you have decoupling capacitors attached between the VCC and GND pins of both the radios.
                        After you make the connections upload the code for the gateway to one of the Arduinos. You can find the code in Arduino IDE, File > Examples > MySensors > GatewaySerial. Don't make any changes just upload the code.
                        Then what I did the first time is just run the following motion sensor code to the other Arduino. I have made a few changes to make things simpler for the node to find the gateway.
                        // Enable debug prints
                        #define MY_NODE_ID 1
                        #define MY_PARENT_NODE_ID 0
                        //unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                        #define CHILD_ID 0   // Id of the sensor child
                        // Initialize motion message
                        void presentation()  {
                          present(CHILD_ID, S_MOTION);
                          // Read digital motion value
                          Serial.println(tripped);
                          //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                        Here, I have defined a NODE ID and defined the PARENT NODE ID for the node. Defining parent ID makes sure that the gateway that you have is the one, the node is supposed to connect to. I didn't even have motion sensor connected to the node here. This is just to make sure that first time you get everything working.
                        If this is done correctly the node and gateway should talk to each other and gateway should have the motion sensor registered.
                        Hope this helps.
                        • DiverAlphaD
                          DiverAlphaD
                          DiverAlpha
                          Hy all,
                          Thanks for your help. Unfortunately it didn't solved the problem :-(.
                          I tried it with putting the NODE_ID's om static but that didn't help. MY_PARENT_NODE_IS_STATIC is totally not recognized in the Arduino IDE...
                          I tried just what @palande.vaibhav mentioned with the code he posted. The only adjustment is that I had to change the CE and CS pin on the sensot because I'm using a Adruino Micro. Further the code was just copy-paste but the same result in the serial communication as I posted earlier. (Except now the ID was 1 in stead of 105...)
                          palande.vaibhavP 1 Reply Last reply
                            Hy all,
                            palande.vaibhavP
                            palande.vaibhavP
                            palande.vaibhav
                            @DiverAlpha
                            I tried it on my setup. The node shows the output with BC (st=bc) when I only have the node connected in that is powered ON. But when I power ON my gateway in they start communicating and I get st=ok.
                            Here is the node without gateway connected:
                            TSM:INIT
                            TSM:RADIO:OK
                            TSP:ASSIGNID:OK (ID=1)
                            TSM:FPAR
                            TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            After I power ON the gateway I get following output:
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            TSP:MSG:PAR OK (ID=0, dist=1)
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:CHKID:OK (ID=1)
                            TSM:UPL
                            TSP:PING:SEND (dest=0)
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                            TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            TSP:MSG:PONG RECV (hops=1)
                            TSP:CHKUPL:OK
                            TSM:UPL:OK
                            TSM:READY
                            SHT31 test
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                            TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:Temperature and switch
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                            TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                            TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                            TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                            Request registration...
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                            TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                            Node registration=1
                            Init complete, id=1, parent=0, distance=1, registration=1
                            TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.0
                            Temp *C = 21.32
                            TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.32
                            Hum. % = 75.48
                            TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:75.48
                            Basically you need to have at least one node and a gateway working for MySensors to run properly.
                            Here is the thread I started when I had the same problem: https://forum.mysensors.org/topic/4941/problem-getting-the-code-to-run-with-mysensors-library-2-0/35
                            Read last few comments, you will get the idea of what I am saying. You can also try the fix for this suggested by ayo in the comment #35.
                            • G gvorster
                              Great, thanks!
                              G
                              G
                              gvorster
                              Great, thanks!
                              I have a RFM69HCW and was getting a terrible connection from 5 meters through two thin walls.
                              After using:
                              #define IS_RFM69HW
                              The connection and range is incredible!
                              I live in an appartment 3rd floor, put a node in my mailbox which is 15 meters below and still got sensor data.
                              This did not work for me before using NRF24L01+
                              • pepsonP
                                pepsonP
                                pepson
                                Hi
                                how long is real range on radio RFM69HW ? It is better than NRF24L01 ?
                                  Yes, generally, lower frequency -> longer range (but also lower transmission speed).
                                  • pepsonP
                                    pepsonP
                                    pepson
                                    But speed RFM69HW is too slow ? For use it to relay switch and some sensors... ? What is better to home automation ? RFM69HW or NRF24L01 ?
                                    • pepsonP pepson
                                      Hi
                                      G
                                      G
                                      gvorster
                                      wrote on last edited by gvorster
                                      #29
                                      @pepson said:
                                      Hi
                                      This post has some more info on this: Which is better: RFM69 or NRF24L01+
                                      I want to use these radio's indoors and need to have a good connection through a couple of thin walls. My impression is that the RFM69 has at least better wall penetration. I'm using the RFM69HCW 868Mhz with only a 82mm wire connected to the ANT pin.
                                      I tested the Mock sketch and enabled a few mock sensors. Throughout my appartment I have no problem having a good connection.
                                      But, there are fake NRF24L01+ chips out there which might be the cause of my penetration connections errors.
                                      I'm buying my RFM69 radio's from a reliable distributor in the Netherlands http://webshop.ideetron.nl/HopeRF
                                      • pepsonP
                                        pepsonP
                                        pepson
                                        When uusing RFM69HW i must also use Capacitor as for NRF24L01 ?
                                        korttomaK 1 Reply Last reply
                                        • pepsonP pepson
                                          korttomaK
                                          korttomaK
                                          korttoma
                                          @pepson
                                          I do not think that the RFM69HW is as sensitive as the NRF24L01 but adding a Capacitor will not hurt.
                                          It also depends on how clean your power source is. If the power is clean you do not need to filter it using Capacitor.
                                          • Tomas
