  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.5k Views 40 Watching
    @gvorster 868 is the default so you don't need to do anything. If you want to change it, add
    #define MY_RFM69_FREQUENCY
    before including MySensors.h in your sketch. See https://github.com/mysensors/MySensors/blob/a31eff112e4895198bf6ec385fdeedb2910bb628/MyConfig.h#L588 for valid settings.
    G
    G
    gvorster
    Great, thanks!
    G 1 Reply Last reply
    • palande.vaibhavP
      palande.vaibhavP
      palande.vaibhav
      wrote on last edited by palande.vaibhav
      @DiverAlpha said:
      Hi all,
      I'm using the Arduino Micro with al NRF24L01 radio. With the micro it's not posible to use the pin config of the Nano.
      I got it working with the connections below.
      NRF24 > Micro
      Miso > Miso
      Mosi > Mosi
      SCK > SCK
      CSN > Pin D7
      CE > Pin D8
      Thereby I put the code below in my arduino code before de "#include <SPI.h>"
      // Pin Confuguration for Arduino Micro
      #define MY_RF24_CE_PIN 8
      #define MY_RF24_CS_PIN 7
      Maybe this is helpful for some other users.
      Grtz Diver
      @DiverAlpha
      Thanx a lot for commenting with that information. I was having problems with the Arduino Mega. I connected the NRF24L01+ to the appropriate SPI pins on the Mega and then just defined the CE and CS pins in the code an now it works. Thanks again
      • DiverAlphaD
        DiverAlphaD
        DiverAlpha
        Hi all,
        I tried a lot in the last coup[le of days but I can't get my network up and running...
        I've got a Micro DHT sensor ans a Uno Ethernet Gateway.
        The output of the Gateway:
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:RADIO:OK
        0;255;3;0;9;TSM:GW MODE
        0;255;3;0;9;TSM:READY
        IP: 192.168.5.8
        So I think this is nice but I'm not complete sure.
        The output of the DHT sensor:
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=105)
        TSM:FPAR
        TSP:MSG:SEND 105-105-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSM:FPAR
        TSM:FPAR
        TSM:FPAR
        !TSM:FPAR:FAIL
        !TSM:FAILURE
        TSM:PDT
        To me it seems that the sensor cannot get a good connection to the gateway by the RF connection. The physical distance between de two RF modules is about 15 cm and I'm using a 10uF condensator on both of the RF modules.
        Can someone tell me what I'm doing wrong?
        Tnx in advance!
        • DiverAlphaD DiverAlpha
          Hi all,
          IP: 192.168.5.8
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          TSM:FPAR
          !TSM:FPAR:FAIL
          !TSM:FAILURE
          TSM:PDT
          Tnx in advance!
          @DiverAlpha try moving the nodes further apart. It might be counter-intuitive, but many have had problems when nodes are too close.
          Do you get nothing at all in the log of the gateway when the sensor tries to find parent?
          • DiverAlphaD
            DiverAlphaD
            DiverAlpha
            @mfalkvidd, They are now 2 meters apart from each other but still the same problem. I was thinking in this direction also but because I build those two on the same breadboard, it was a bit difficult to separate them. I now build the sensor on another breadboard and moved is 2 meters away. It can't be any longer because of the length of my USB cables.
            All the logging I got from the gateway is posted in my previous post. So there is nothing about any child in there.
            mfalkviddM palande.vaibhavP 2 Replies Last reply
              @DiverAlpha strange. You could try hard-coding the parent on the node, see MY_PARENT_NODE_IS_STATIC and MY_PARENT_NODE_ID on https://www.mysensors.org/download/sensor_api_20
                palande.vaibhavP
                palande.vaibhavP
                palande.vaibhav
                #22
                @DiverAlpha
                I am no expert in this. But when I started using MySensors few months ago, I also had some problems. Not because there is a problem with MySensors but because I was doing the simplest of the mistakes and I needed to think simple and do simple things first.
                What I would suggest is just try the simplest of the code first. This post is considering that you are using MySensors library 2.0.
                This is what I did when I was trying out MySensors and I think you can try this too.
                Firstly connect Arduino you are using properly to the radio with the proper connections using the instructions here. If you are using Arduino Mega, the SPI pins are different. Here is the link for Arduino Mega: https://forum.mysensors.org/topic/4940/arduino-mega-nrf-wiring/3. Make sure you have decoupling capacitors attached between the VCC and GND pins of both the radios.
                After you make the connections upload the code for the gateway to one of the Arduinos. You can find the code in Arduino IDE, File > Examples > MySensors > GatewaySerial. Don't make any changes just upload the code.
                Then what I did the first time is just run the following motion sensor code to the other Arduino. I have made a few changes to make things simpler for the node to find the gateway.
                // Enable debug prints
                #define MY_NODE_ID 1
                #define MY_PARENT_NODE_ID 0
                //unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                #define CHILD_ID 0   // Id of the sensor child
                // Initialize motion message
                void presentation()  {
                  present(CHILD_ID, S_MOTION);
                  // Read digital motion value
                  Serial.println(tripped);
                  //sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
                Here, I have defined a NODE ID and defined the PARENT NODE ID for the node. Defining parent ID makes sure that the gateway that you have is the one, the node is supposed to connect to. I didn't even have motion sensor connected to the node here. This is just to make sure that first time you get everything working.
                If this is done correctly the node and gateway should talk to each other and gateway should have the motion sensor registered.
                Hope this helps.
                • DiverAlphaD
                  DiverAlphaD
                  DiverAlpha
                  Hy all,
                  Thanks for your help. Unfortunately it didn't solved the problem :-(.
                  I tried it with putting the NODE_ID's om static but that didn't help. MY_PARENT_NODE_IS_STATIC is totally not recognized in the Arduino IDE...
                  I tried just what @palande.vaibhav mentioned with the code he posted. The only adjustment is that I had to change the CE and CS pin on the sensot because I'm using a Adruino Micro. Further the code was just copy-paste but the same result in the serial communication as I posted earlier. (Except now the ID was 1 in stead of 105...)
                  palande.vaibhavP 1 Reply Last reply
                    Hy all,
                    palande.vaibhavP
                    palande.vaibhavP
                    palande.vaibhav
                    @DiverAlpha
                    I tried it on my setup. The node shows the output with BC (st=bc) when I only have the node connected in that is powered ON. But when I power ON my gateway in they start communicating and I get st=ok.
                    Here is the node without gateway connected:
                    TSM:INIT
                    TSM:RADIO:OK
                    TSP:ASSIGNID:OK (ID=1)
                    TSM:FPAR
                    TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    After I power ON the gateway I get following output:
                    TSM:PDT
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    TSP:MSG:PAR OK (ID=0, dist=1)
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=1)
                    TSM:UPL
                    TSP:PING:SEND (dest=0)
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    TSP:MSG:PONG RECV (hops=1)
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    SHT31 test
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                    TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=22,sg=0,ft=0,st=ok:Temperature and switch
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                    TSP:MSG:SEND 1-1-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                    TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                    TSP:MSG:SEND 1-1-0-0 s=2,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                    Request registration...
                    TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                    TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    Node registration=1
                    Init complete, id=1, parent=0, distance=1, registration=1
                    TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:22.0
                    Temp *C = 21.32
                    TSP:MSG:SEND 1-1-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.32
                    Hum. % = 75.48
                    TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=1,pt=7,l=5,sg=0,ft=0,st=ok:75.48
                    Basically you need to have at least one node and a gateway working for MySensors to run properly.
                    Here is the thread I started when I had the same problem: https://forum.mysensors.org/topic/4941/problem-getting-the-code-to-run-with-mysensors-library-2-0/35
                    Read last few comments, you will get the idea of what I am saying. You can also try the fix for this suggested by ayo in the comment #35.
                    • G gvorster
                      Great, thanks!
                      G
                      G
                      gvorster
                      Great, thanks!
                      I have a RFM69HCW and was getting a terrible connection from 5 meters through two thin walls.
                      After using:
                      #define IS_RFM69HW
                      The connection and range is incredible!
                      I live in an appartment 3rd floor, put a node in my mailbox which is 15 meters below and still got sensor data.
                      This did not work for me before using NRF24L01+
                      • pepsonP
                        pepsonP
                        pepson
                        Hi
                        how long is real range on radio RFM69HW ? It is better than NRF24L01 ?
                          Yes, generally, lower frequency -> longer range (but also lower transmission speed).
                          • pepsonP
                            pepsonP
                            pepson
                            But speed RFM69HW is too slow ? For use it to relay switch and some sensors... ? What is better to home automation ? RFM69HW or NRF24L01 ?
                            • pepsonP pepson
                              Hi
                              G
                              G
                              gvorster
                              wrote on last edited by gvorster
                              #29
                              @pepson said:
                              Hi
                              This post has some more info on this: Which is better: RFM69 or NRF24L01+
                              I want to use these radio's indoors and need to have a good connection through a couple of thin walls. My impression is that the RFM69 has at least better wall penetration. I'm using the RFM69HCW 868Mhz with only a 82mm wire connected to the ANT pin.
                              I tested the Mock sketch and enabled a few mock sensors. Throughout my appartment I have no problem having a good connection.
                              But, there are fake NRF24L01+ chips out there which might be the cause of my penetration connections errors.
                              I'm buying my RFM69 radio's from a reliable distributor in the Netherlands http://webshop.ideetron.nl/HopeRF
                              • pepsonP
                                pepsonP
                                pepson
                                When uusing RFM69HW i must also use Capacitor as for NRF24L01 ?
                                korttomaK 1 Reply Last reply
                                • pepsonP pepson
                                  korttomaK
                                  korttomaK
                                  korttoma
                                  @pepson
                                  I do not think that the RFM69HW is as sensitive as the NRF24L01 but adding a Capacitor will not hurt.
                                  It also depends on how clean your power source is. If the power is clean you do not need to filter it using Capacitor.
                                  • Tomas
                                    A Former User
                                    Hi guys!
                                    I'd like to ask you about a problem. When I use RFM69 radios on my nodes, they are working fine, but when I try to use the NRFs everything is falling apart and that's driving me crazy. I can't find the solution to use NRFs (I've got 20 of them). I tried everything, read the forum a hundred times, but can't find the solution. Poer sources are perfect, every NRF has it's own 3.3v source and after a few hours or a few days perfect working, the nodes disappear (not all and not in the same time). I'm using Domoticz as controller on a RPI 2. I saw the node's L13 led's blinking is much lighter after the node disappears. When it's working okay, the led is blinking on full.
                                    Thank you for the suggestions, and have a nice day
                                    • ? A Former User
                                      Hi guys!
                                      @ZsoltZombori what does the serial debug output of the nodes say?
                                      ? 1 Reply Last reply
                                      • ? A Former User
                                        Hi guys!
                                        palande.vaibhavP
                                        palande.vaibhavP
                                        palande.vaibhav
                                        @ZsoltZombori
                                        I had a problem of the LED on pin 13 glowing dim after some time of system running fine when I had 2 sensors connected to the Arduino and sensors had their own separate 5V power supply. So, I had a 5V power supply separate from the Arduino's 5V and that was supplying current to those sensors.
                                        I had the sensor's data pins connected to Arduino but I didn't have GND of power supply and Arduino connected. I solved the problem by connecting the GND of power supply to the GND of the Arduino.
                                        See if that is the case with you.
                                        Hope this helps.
                                          A Former User
                                          @mfalkvidd I put the node on serial for the night and everything works fine now. No errors occured, I'm still waiting.
                                          @palande-vaibhav The GNDs are always connected in my circuits to prevent GND problems. Thanks for the tip.
