  3. Looking for detailed description for hacking a sonoff
45 Posts 12 Posters 53.2k Views 15 Watching
  • will hW
    will hW
    will h
    This article shows you how to connect an FTDI to the sonoff
    http://tech.scargill.net/itead-slampher-and-sonoff/
    From there, I think this tutorial will get you going
    https://learn.adafruit.com/adafruit-huzzah-esp8266-breakout/using-nodemcu-lua
    leading well into this project on Github, which, I think, is what you were referring to for MQTT on the Sonoff (all of this, of course, removes the original cloud functionality)
    https://github.com/elric91/nodemcu_sonoff
    • will hW
      will hW
      will h
      wrote on last edited by will h
      And then there is this:
      https://community.smartthings.com/t/release-sonoff-5-wifi-switch-device-handler/45957
      Would get you going pretty quickly (the FTDI explanation is a little more clear that the earlier link with the picture)
      I haven't yet made a MySensors node with an ESP, but it's doable
      http://forum.mysensors.org/topic/3583/mysensors-on-esp8266-esp01/4
      • will hW
        will hW
        will h
        Last one
        http://benlo.com/esp8266/esp8266QuickStart.html
        • alexsh1A
          alexsh1A
          alexsh1
          @TheoL I have just uploaded ESPEasy R78 stable firmware. It works really well on existing WiFi with Domoticz. The biggest advantage of it as a remote relay is that it reports its status to the virtual sensor in Domoticz. This is something z-wave devices do and something I've been missing with MySensors.
          @hek I think the memory is only 1Mb (Wemos D1 mini - 4Mb) and I am not sure it would be enough for the GW (with signing and other stuff).
          Price wise though this cannot beaten ($7 for the RF + ESP8266 version)
          • Mark SwiftM
            Mark SwiftM
            Mark Swift
            How could we make this a MySensors node?
            alexsh1A 1 Reply Last reply
            • Mark SwiftM Mark Swift
              alexsh1A
              alexsh1A
              alexsh1
              @Mark-Swift I do not think you can.
              IMHO one needs to (a) upgrade EEPROM. This is doable but very tricky the flash chip is in a place not easily accessible by a soldering iron
              (b) given that it is based on ESP, connect nrf24l01+ to it. Please see below how FTDI is connected - I think the same way you can connect Arduino Pro mini. I do not think you can connect nrf24l01+ directly as the GPIO number is limited (c) come up with a sketch for ESP8266 as a node.
              In my view this is just not worth the effort.
                @alexsh1
                Couldn't you just run the MySensors ESP gateway on it (presenting it as a binary switch)?
                  @alexsh1
                  alexsh1A
                  alexsh1A
                  alexsh1
                  @hek two issues with your proposal:
                  1. ESP-12 which is used for MySensors ESP GW has got more GPIOs and 4Mb memory. Sonoff has a limited number of GPIOs and 1Mb memory marginally better than ESP-01. This can be upgraded, but not easy. I can do SMT, but here is a challenge. See below
                  1. connect nrf24l01+ - I did not figure out how to do that given that GPIOs are limited. Sure Arduino can be connected, but it is not the same
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    A better photo for your understanding.
                    I know some people upgraded the chip, but the board got really messy. I do not think I can stick my fan into it - too many plastic components which will start melting.
                      I mean skip the NRF2401.. just run it as a standalone gw/node.
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @hek in this case it is doable. Not sure if 1mb Is enough though
                        peterscargillP 1 Reply Last reply
                        • FotoFieberF
                          FotoFieberF
                          FotoFieber
                          I hacked a sonoff dual:
                          https://itead.freshdesk.com/support/discussions/topics/11000006870
                          It should be easy to upload a wifi gateway sketch. I made an MQTT integration.
                          • Mark SwiftM
                            Mark SwiftM
                            Mark Swift
                            wrote on last edited by Mark Swift
                            Thanks for the great replies.
                            I'm not currently using MQTT, I'm running the Ethernet gateway via a W5100. Can I use the ESP boards, i.e this or the nodemcu without the need for an NRF24?
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @Mark-Swift how would you intend to use Sonoff with MySensors? Do you have the ESP GW?
                              I am using several Sonoffs with Domoticz via a JSON script. https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's
                              • peterscargillP
                                peterscargillP
                                peterscargill
                                So - I agree re: Sonoffs - we've written our own software at the tech blog and though not quite step by step it is easy enough to use and ROMS are available to save you having to get into compiling code. We use Node-Red and MQTT as the base of everything - so you have a number of ESP sensors and relay controllers etc all talking to a Raspberry Pi - or something much cheaper like an Orange Pi Zero running Armbian for example - and basically you're sending simple MQTT messages around the house - nothing has to go outside unless of course you want remote control at a distance. Modifying Sonoffs is easy - I'm sitting in front of some now updating them with our software - just in the process of figuring our which port is used for the second relay in the DUAL product.
                                • alexsh1A alexsh1
                                  peterscargillP
                                  peterscargillP
                                  peterscargill
                                  @alexsh1 Replace the FLASH in the Sonoff - easier in the latest models as they've put the FLASH chip on the back (Sonoff TH16 etc) - on the originals it was jammed in next to the programming button and a pain to replace.
                                  • peterscargillP peterscargill
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @peterscargill Peter, I am stuck with the previous model (WiFi + 433) and changing FLASH is literally impossible even with a small tip. Using a hot fan is not an option as it would melt down all plastic including the button.
                                    • EfflonE
                                      EfflonE
                                      Efflon
                                      Here is a working example of using Sonoff with MySensors and the mqtt gateway.
                                      No need to replace any flash etc...
                                      • EfflonE Efflon
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @Efflon we were talking about a different software whereby more flash was required
                                        Besides 1mb flash is not much in the esp8566 world
                                        • dbemowskD
                                          dbemowskD
                                          So I have been debating on getting some of these sonoffs. I am assuming the WiFi gateway in the build section of the site is what I would need to build? Is there a better option for using these with my Vera Plus?
