  2. Enclosures / 3D Printing
  3. Clean looking sensor node
90 Posts 13 Posters 51.1k Views 22 Watching
  • sglueS sglue
    Newbie here.
    I have used battery casing for sensebender & DC DC step up converter (2.5v to 5v).
    Have to do a bit of filing & swapping of battery contacts and drill hole for sensebender.
    Attach photos.
    1_1476969117224_SenseBender_2.JPG 0_1476969117224_SenseBender_1.JPG 0_1476969177222_DC DC Step up.JPG
    Yup, your photo captures the notion of what I'm planning to do:
    My original inspiration for it came from this:
    http://johan.kanflo.com/the-aaduino/
    which I might have done, except that I prefer the RFM69HW, which I don't think would fit in just one battery slot very easily.
      Here I just received the black "pucK' sensor case that was shown in the OP. Pretty fast considering it was free delivery using China Post. So far I like it the best because it has the air vents already a part of it. :smiley:
      Cliff KarlssonC 1 Reply Last reply
      • Nca78N
        That's why I selected it, best suited for temp sensor.
        Just received the first version of the PCB but it will need some improvements.
        But looks like it will work, not too bad for my first PCB ever :)
          Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          I really like the pcb´s you are using @NeverDie, is it possible to buy them anywhere?
            #36
            I'm just doing this for fun. If you want to buy something pre-made, I'd suggest buying a Moteino.
              Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              Ok, but is the PCB availible at OSHpark or is the files availble for sharing?
              • Nca78N Nca78
                @Nca78
                Are you sure there's space for the coincell holder? The case is pretty thin. I ordered some tabbed coincells, but am still waiting for them to arrive.
                  @Cliff-Karlsson
                  Maybe later. I'm still improving the design.
                  • Nca78N Nca78
                    #40
                    Here's a newer evolution of my small TH node that includes a co-planar antenna. So, no long monopole antenna sticking out of the case. :smile:
                    I haven't attached the TH sensor yet because I've run out of them, but I'm pretty sure it will fit. :wink:
                      @nca78
                      What's the best way to remove the cover on this thing? Do I just go for it with a pry tool, or is there a special trick to it?
                      I'm hopeful it will fit a CR2477 tabbed battery, but it would likely be a very close fit if it does. In case it doesn't, have you come across any options that are a bit thicker?
                      Nca78N 1 Reply Last reply
                        So, here's an example of such a $1 solar garden light:
                        Don't buy them for outdoor use, although that's what they're sold for. They'll rapidly corrode in wet weather and then cease to function. However, that shouldn't be a problem indoors.
                        Demounting the solar puck, it looks like this:
                        Here's the flip side with the guts removed:
                        Inside I put one of my RFM69HW temp-RH nodes. As you can hopefully see, there is room to spare.
                        These close-up photos probably make the puck look larger than it is. It is just 2-1/4" in diameter and 1-1/8" tall.
                        What do you think? Would it have good WAF? This one is a bit crufty because it was outside for about a year, and then I plucked it for these photos. When brand new they look more clean and polished, and so perhaps if kept indoors they would stay that way.
                        One possible concern with this particular example is that it has a metal band around it. That's not so ideal for an RF node, but it may not matter, as I tested the PCB node (just by itself, without the solar puck) within a closed refrigerator and still got adequate signal from it.
                        I tried running one of my nodes inside the solar puck that has the metal band (above). It's maybe a few dB worse, but the link budget is large enough that it just doesn't really matter. So, I think it remains a viable option as an enclosure for thicker nodes that don't easily fit inside the OP's thinner recharger puck.
                          @nca78
                          @NeverDie said:
                          @nca78
                          Sorry no magic solution to open :)
                          For the cell it should fit a 2477 but you need a thin PCB + thin holder.
                          Box is 10.6mm high minus 1.2mm thickness for the cover and 0.8mm PCB it leaves you with 8.6mm. 2477 is 7.7mm so you have 1mm left, not much but I think just enough if you use basic holder that's just made of a folded metal sheet.
                          But for such a basic sensor you would not need such a huge cell, CR2032 should last a very long time already, and 2450 could match your need of extra long lifetime and at the same time easily fit in the box. If your sketch is programmed correctly by the time a 2450 is dead the sensor will probably have become completely off because of aging ;)
                            I received the Q8 wireless charging pad (above):
                            http://www.ebay.com/itm/Q8-QI-Wireless-Charging-Pad-2-USB-Port-Splitter-HUB-Charger-Pad-For-Phone-F5/301913729117?_trksid=p2047675.c100623.m-1&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D39345%26meid%3Decb1959e8f164eb5ad0a17aeaa297f59%26pid%3D100623%26rk%3D3%26rkt%3D6%26sd%3D252485416371
                            However, it is even thinner than the OP's vented puck, and it's about double the square inches of foot print. So I don't see any real advantage to them.
                              For a thicker case, Amazon Dot looks like it might be very nice:
                              A bit pricey though!
                                I have ordered one also (In fact two as aliexpress payment messed up and asked me to process payment again, but few days after I realized the "failed" payment was in fact processed and sellers were sending everything twice...).
                                I'm planning to use one as gateway box with wemos d1 mini and smd pa/lna NRF24 side by side. Any chance it will fit this type of ESP board inside or it's too thin and I should go for ESP12 module instead ?
                                • Nca78N Nca78
                                  I just now measured the D1Mini, and it's about 6.7mm thick. If you removed the USB connector, it would be thinner.
                                  I haven't opened the QB wireless pad, so I don't know how much depth is available. However, the case itself is 8.5mm thick. In comparison, I measure the case thickness of your OP puck as 11.7mm.
                                    Thank you. Sounds like it won't fit :(
                                    For Amazon Dot yes it looks great, but 50$ is a bit too expensive for a case :D
                                      #49
                                      I notice that Kalia made his own uniquely shaped enclosure that he 3D printed himself:
                                      (for more detail see his posts under: https://forum.mysensors.org/topic/1566/mysensors-sensebender-micro-3dp-case/18)
                                      I'm not yet savvy about 3D printers, but from what I've been reading lately the line artifacts in the plastic may vary in how prominent they are depending on the quality of the software slicer that's used to produce the g-code that's sent to the 3D printer. Still, I'm not sure to what extent it's avoidable or just a reality of 3D prints. Would such line artifacts always be visible, regardless of which printer or software produced it?
                                      In any event, I like the way Kali molded the battery holder into the case itself. Very clever!
                                        #50
                                        @NeverDie the lines will be more or less visible depending on layer height (which varies by 3d printer model) but can easily be made totally smooth. See this video
                                        https://youtu.be/h2lm6FuaAWI
                                          #51
                                          Funny that in the video the demonstrator uses a polypropylene chamber, as I'm pretty sure acetone will strongly react with it. Aside from that, though, it was a good video. Thanks for posting it!
                                          He seems to imply this acetone vapor chamber approach only works on ABS printed models. Is that correct?
                                          Also, what must the 3D printer's layer height be for the lines to no longer be visible (without resorting to acetone vapors)?
