  3. Is there a schematic of the NRF24 board?
23 Posts 8 Posters 16.0k Views 1 Watching
  • YveauxY Yveaux
    Elektor recently published a wall mount capacitive touch switch. They kept repeating it did not contain a microcontroller, but I would say put in an atmega328, an nrf24 and let's go ;-)
    The power supply and touch sensors seem appealing for an own design.
    I only wonder what the range of the nrf will be when integrated inside a wall surrounded by a lot of electronics... Also we know the power supply is critical for the nrf to operate reliable, so a prototype to embed in a real wall seems to be a first step.
    marceltrapmanM
    marceltrapmanM
    marceltrapman
    Power supply is 'around the corner' so I don't think that it will be an issue.
    I too have my doubts about the range but that is another reason for using my own design.
    It will make it easier to play with antenna design.
    It works with z-wave components (but) with an external antenna (wire).
    Fulltime Servoy Developer
    • I
      I
      ivan.todorovich
      Hello @marceltrapman, how will you power the board from the mains?
      I'm a noob in this things yet.. and I'm trying to make a relay sensor to control lights, also put behind the electrical outlet (220vac).. I'm having trouble figuring out if I should add some kind of transformer for every sensor or maybe distribute a 5vdc line from the controller itself..
      RJ_MakeR YveauxY C 3 Replies Last reply
      • I ivan.todorovich
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @ivan.todorovich
        I think finding a solution to fix inside the electrical box with the outlet is going to be difficult, but I'm very interested in what you come up with.
        RJ_Make
        • I
          I
          ivan.todorovich
          Yeah, I know.. although I know it must be possible otherwise this wouldn't exist:
          Dimensions: 49,5 x 48,5 x 15 mm.
          Habeetat® HPA-2130
          Habeetat® HPA-2130 Datasheet
          That's exactly what I want.. but a cheaper, hack-friendly and MySensors compatible version of it.
          RJ_MakeR 1 Reply Last reply
          • I ivan.todorovich
            Habeetat® HPA-2130
            RJ_MakeR
            RJ_MakeR
            RJ_Make
            @ivan.todorovich
            Oh it's possible, but I think you will need to build from the pcb up to meet the goal.
            RJ_Make
            • RJ_MakeR RJ_Make
              @ivan.todorovich
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              @ServiceXp said:
              @ivan.todorovich
              And that is what I intend to do.
              The first application would be controlling our shutters.
              I am not sure yet how I am going to do this.
              • In wall behind (or replacing) the current timer that operates the shutters;
              • Next to the shutter motor (would give more room);
              In any case they will be operated with 220v. There are enough ways to do that...
                @ServiceXp said:
                @ivan.todorovich
                RJ_MakeR
                RJ_MakeR
                RJ_Make
                @marceltrapman
                Would love to see the results. What type of chips are planing to use DIP, QFP, QFN.?
                If you are successful, it's going to open up another world of possibilities for MySensors users, Providing it doesn't involve SMD work that is... ;-)
                RJ_Make
                • RJ_MakeR RJ_Make
                  @marceltrapman
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  @ServiceXp all SMD including
                  ATMEGA328P-AU, TQFP-32
                  Winbond W25X40, SOP-8
                  • I ivan.todorovich
                    @ivan.todorovich I'm thinking about re-using the power supply and possibly touch board of this project: http://www.elektor-magazine.com/en/magazine-contents/previous-issues.html?tx_elektorarticle_listissues[article]=26510&tx_elektorarticle_listissues[action]=show&cHash=830afaabd7423433a83dca9198de8e12
                    Magazine:http://lasersoft.com.au/books/Archived/rocvm.Elektor.Electronics.USA..June.2014.pdf
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @marceltrapman
                      Bummer. Don't think I would be able to handle the SMD requirement.
                      RJ_Make
                      • RJ_MakeR RJ_Make
                        @marceltrapman
                        marceltrapmanM
                        marceltrapmanM
                        marceltrapman
                        @ServiceXp said:
                        @marceltrapman
                        It is really not that hard.
                        People seem to solder it I use a rework blower.
                        A real cheap one (to see what it brings me) but with good result.
                        With the # of components and the # of boards we need it is really doable...
                        • I
                          I
                          ivan.todorovich
                          @marceltrapman I'd love to see your work when its done.
                          I'm currently considering wiring 12v around the house to feed sensors, and maybe replace the wireless board by implementing a wired signal protocol (modbus for instance).
                          I have a feeling it would be more efficient regarding power consumption, and the house wouldn't be so saturated with 2.4ghz radio signals.. which might not be so healthy
                          I must reiterate though, I'm a noob.. so if anything I just said doesn't make sense please object me :D I would appreciate
                            @ServiceXp said:
                            @marceltrapman
                            RJ_MakeR
                            RJ_MakeR
                            RJ_Make
                            @marceltrapman
                            Don't know if this will help you with some idea's but I pulled apart my Aeotec Zwave extender and took some pics. If you need me to get any other info from any of the components just let me know.
                            This thing is pretty small. and is powered from Mains
                            20141004_210303_Android.jpg 20141004_210249_Android.jpg 20141004_205531_Android.jpg 20141004_205448_Android.jpg 20141004_205428_Android.jpg 20141004_205320_Android.jpg 20141004_205252_Android.jpg 20141004_205211_Android.jpg 20141004_205146_Android.jpg
                            RJ_Make
                            YveauxY marceltrapmanM 2 Replies Last reply
                            • RJ_MakeR RJ_Make
                              @marceltrapman
                              @ServiceXp Very interesting teardown! Apparently it uses a flex-pcb for the antenna -- that's one solution you don't see very often.
                              Power supply is 'standard' transformer-less capacitor/resistor design.
                              • RJ_MakeR RJ_Make
                                @marceltrapman
                                marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                @ServiceXp Thanks it looks pretty much the same as my AEOTEC range extenders.
                                The only difference is 220v :)
                                • I ivan.todorovich
                                  C
                                  C
                                  cribben
                                  @ivan.todorovich
                                  Hi! See this examples how to power it from 220V without tranformer.
                                  http://www.designercircuits.com/DesignNote1a.pdf
