Node with DS18B20 and DHT22
Hi!
First sorry for my bad english :)
I'm trying to make a node with 2 DS18B20 and 2 DHT22 but in domoticz the DS18B20 is show like "Temp + Humidity" sensors (with the humidity value of the 1st DHT22).
I've read on github that it's possible to set "groupID" to resolve this problem, but i don't understand how to set this.
I've try this, but not working:
present(0, S_TEMP, "SENSOR1"); present(1, S_TEMP, "SENSOR2"); present(CHILD_ID_TEMP1, S_TEMP, "SENSOR3"); present(CHILD_ID_HUM1, S_HUM, "SENSOR3"); present(CHILD_ID_TEMP2, S_TEMP, "SENSOR4"); present(CHILD_ID_HUM2, S_HUM, "SENSOR4");Does someone can explain me please ?
Thank you.
Hi!
Thank you.
Welcome to the MySensors community @dokho !
I think the discussion in https://forum.mysensors.org/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz/8 will give you what you need. See if that helps and report back the result. We'll try to help if you get stuck.
Hi !
Thank you for the greeting @mfalkvidd :)
I've already read the discussion you've quote but i'm not sure to understand: some say "modify domoticz code" other say "present sensor after each other" ...
Witch version of mysensors is needed to do what i try ? 2.0 or beta ?
I'm using, perhaps it's not the good version ... -
Hi!
I've try with developpement librairies and it's the same.
For information this is the sketch i'm using:
// Enable debug prints #define MY_DEBUG // Enable and select radio type attached #define MY_RADIO_NRF24 //#define MY_RADIO_RFM69 //#define MY_RS485 #include <SPI.h> #include <MySensors.h> #include <DHT.h> #include <DallasTemperature.h> #include <OneWire.h> #define MAX_ATTACHED_DS18B20 6 #define ONE_WIRE_BUS 4 #define DHT1_DATA_PIN 2 #define DHT2_DATA_PIN 3 #define CHILD_ID_DHT1HUM 6 #define CHILD_ID_DHT1TEMP 7 #define CHILD_ID_DHT2HUM 9 #define CHILD_ID_DHT2TEMP 8 #define SENSOR_TEMP_OFFSET 0 // Sleep time between sensor updates (in milliseconds) // Must be >1000ms for DHT22 and >2000ms for DHT11 static const uint64_t UPDATE_INTERVAL = 3000; unsigned long SLEEP_TIME = 30000; bool metric = true; bool receivedConfig = false; int numSensors=0; OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs) DallasTemperature sensors(&oneWire); // Pass the oneWire reference to Dallas Temperature. MyMessage msgDallas(0,V_TEMP); MyMessage msgDHT1Temp(CHILD_ID_DHT1TEMP,V_TEMP); MyMessage msgDHT1Hum(CHILD_ID_DHT1HUM,V_HUM); MyMessage msgDHT2Hum(CHILD_ID_DHT2HUM,V_HUM); MyMessage msgDHT2Temp(CHILD_ID_DHT2TEMP,V_TEMP); DHT dht; void before() { // Startup up the OneWire library sensors.begin(); } void setup() { // requestTemperatures() will not block current thread sensors.setWaitForConversion(false); } void presentation() { // Send the sketch version information to the gateway sendSketchInfo("DualDHTandDallas", "1.1"); // Fetch the number of attached temperature sensors numSensors = sensors.getDeviceCount(); // Present all sensors to controller for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { present(i, S_TEMP); } present(CHILD_ID_DHT1TEMP,S_TEMP); present(CHILD_ID_DHT1HUM,S_HUM); present(CHILD_ID_DHT2HUM,S_HUM); present(CHILD_ID_DHT2TEMP,S_TEMP); metric = getConfig().isMetric; } void loop() { // Fetch temperatures from Dallas sensors sensors.requestTemperatures(); // query conversion time and sleep until conversion completed int16_t conversionTime = sensors.millisToWaitForConversion(sensors.getResolution()); // sleep() call can be replaced by wait() call if node need to process incoming messages (or if node is repeater) sleep(conversionTime); // Read temperatures and send them to controller for (int i=0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) { // Fetch and round temperature to one decimal float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.; // Send in the new temperature send(msgDallas.setSensor(i).set(temperature,1)); #ifdef MY_DEBUG Serial.print("Dallas"); Serial.print(i); Serial.print(" :"); Serial.println(temperature); #endif // sleep(SLEEP_TIME); } dht.setup(DHT1_DATA_PIN); // set data pin of DHT1 sensor if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod()) { Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!"); } // Sleep for the time of the minimum sampling period to give the sensor time to power up // (otherwise, timeout errors might occure for the first reading) sleep(dht.getMinimumSamplingPeriod()); // Force reading sensor, so it works also after sleep() dht.readSensor(true); // Get temperature from DHT library float dht1temperature = dht.getTemperature(); if (isnan(dht1temperature)) { Serial.println("Failed reading temperature from DHT!"); } else if (!metric) { dht1temperature = dht.toFahrenheit(dht1temperature); } dht1temperature += SENSOR_TEMP_OFFSET; send(msgDHT1Temp.set(dht1temperature, 1)); #ifdef MY_DEBUG Serial.print("DHT1TEMP: "); Serial.println(dht1temperature); #endif sleep(UPDATE_INTERVAL); // Get humidity from DHT library float dht1humidity = dht.getHumidity(); if (isnan(dht1humidity)) { Serial.println("Failed reading humidity from DHT"); } else { send(msgDHT1Hum.set(dht1humidity, 1)); #ifdef MY_DEBUG Serial.print("DHT1HUM: "); Serial.println(dht1humidity); #endif } // Sleep for a while to save energy sleep(UPDATE_INTERVAL); dht.setup(DHT2_DATA_PIN); // set data pin of DHT2 sensor if (UPDATE_INTERVAL <= dht.getMinimumSamplingPeriod()) { Serial.println("Warning: UPDATE_INTERVAL is smaller than supported by the sensor!"); } // Sleep for the time of the minimum sampling period to give the sensor time to power up // (otherwise, timeout errors might occure for the first reading) sleep(dht.getMinimumSamplingPeriod()); // Force reading sensor, so it works also after sleep() dht.readSensor(true); // Get temperature from DHT library float dht2temperature = dht.getTemperature(); if (isnan(dht2temperature)) { Serial.println("Failed reading temperature from DHT!"); } else if (!metric) { dht2temperature = dht.toFahrenheit(dht2temperature); } dht2temperature += SENSOR_TEMP_OFFSET; send(msgDHT2Temp.set(dht2temperature, 1)); #ifdef MY_DEBUG Serial.print("DHT2TEMP: "); Serial.println(dht2temperature); #endif sleep(UPDATE_INTERVAL); // Get humidity from DHT library float dht2humidity = dht.getHumidity(); if (isnan(dht2humidity)) { Serial.println("Failed reading humidity from DHT"); } else { send(msgDHT2Hum.set(dht2humidity, 1)); #ifdef MY_DEBUG Serial.print("DHT2HUM: "); Serial.println(dht2humidity); #endif } sleep(UPDATE_INTERVAL); }And in domoticz all childs have the same ID (#1)
Noboby have an idea of the problem ?
[EDIT]
And i just discover an other "problem": the 2nd DHT22 humidity value is updated with the value of the 1st one... -
Ok so the number next to V_TEMP in the values column are groupID ?
The problem in my DS18B20+DHT22 node is that they have all the same groupID, so domoticz group TEMP and HUM in the same device and the HUM of the 1st DHT22 is updated with the HUM of the 2nd one ...
So I researched this a bit and here is the answer:
The grouping of devices origins from this commit:
https://github.com/domoticz/domoticz/pull/847and the logic is:
https://github.com/domoticz/domoticz/issues/276Unfortunately it doesn´t work very well with other sensor combinations that Temp/hum/pressure - like mine with voltage, impedance and so on..
I found a workaround by naming all sensors v_hum - then they are placed in different groups and are possible to work with in domoticz...
